View Full Version : Parts Classifieds
- Manual door bezels
- LS-7 stuff
- full floating lq4 rods
- Trickflow GenX 255 ls3 6 bolt heads New
- 4 - 18 x 9.5 Corvette Spyders (replicas)
- stock 241 heads
- Vig Stall for C5 or LT1
- Magnacharger (partial)
- Circle D 3600 Stall, Tsunami Cam
- NIB LT4 Hot Cam Kit
- Vibrant turbo flange and flex couplers
- Gm tech2 tech 2
- 2002 Corvette C5 DBW throttle body
- AFR springs
- FTI 3000-3200 Converter LT/700R4/4L60 SRLT0082
- ls1 396 forged dish pistons
- Wheel Spacer/ Adapter 1 inch for camaro/transam
- 99-02 M6 PCM and harness
- Dbw parts
- 243 heads
- Comp Cam 222/224
- Weld pro stars 15x8 and 15x4 rims
- 35th Anniversary Edition Vinyl Stripes
- 6 speed pedals
- Diablosport predator 7198x
- used oem & aftermarket parts forsale
- A&A Stage 3 Blower Cam
- Corvette C6 Double Din DVD Radio
- Manley 7.4" .80 wall ls pushrods (new)
- Tan seat belts, stock exhaust, stock air box
- FS: Low-Mile LS6 Cam w/Springs
- Ws6 oem ram air hood
- 2000 ws6 wheels 17x9
- 2000 LS1, Built Auto, Turbo Kit, Injectors
- Differential Gears
- Ls1 timing tuner
- 8.8 locker NEW.
- Nitrous Kit *SOLD*
- RJS 5 point harness
- ID2000 injectors- only 1100 miles
- Spohn LCA's, Torsen LSD, axles, lots of stock parts
- complete 98 trans am partout ls1
- LS1 carb setup, TR224 cam
- Comp 7.4 pr's, #30 SVO injectors, LS6 intake and more
- AutoXray 3000 OBD1 and OBDII Engine scanner tool for parts or repair
- Dyno tune, ARP, WB LM2, Walbro, Valve Covers, Truck Maf
- Leftover LQ4 Parts - Cheap
- Ls1, ls2, ls6 and lsx parts
- [SOLD] 6LE Leather Seats
- LS7 Black Mamba cam & Lingenfelter gt 11 cam f/s or f/t
- red anadized fuel rails with -6 line no fitting
- 2 new nitto nt555 extreme performance tires 315/35zr/17
- Parting Out Excellent Condition 2001 Z28 1SC Complete Interior
- 2000 WS6 full beige/neutral interior + set of ebony seat belts
- FS: Strange narrowed 12 bolt 57" FBody
- FS:set of firehawk wheels with tires
- FS: precision industries stall
- F/S: 5.3 LM7 shortblock
- TCI Flexplate, MSD E-Curve Distributor, RobbMc Fuel Pump,
- stock driver side a-pillar
- Zex nitrous bottle
- OEM chrome C6 wheels with Eagle F1 tires
- ATI LSX Cog Balancer Supercharger - Double Keyed
- ARP Head bolts Fits 04 newer LS motors
- Ported ls3 intake
- Spohn tubular motor mounts
- WS6 Wheels, Narrowed Fronts, Black/Silver
- LT1 Hypertech Power Programmer III PN#365752
- 78 mm turbonitics ball bearing turbo with billet wheel
- 4l80 flexplate
- Aeromotive A1000 fuel pressure regulator w/ gauge & trans temp gauge
- SLP 85mm MAF,3.23 gears for sale
- RC Racing 71# injectors
- NGK AFX Wideband......$185 shipped
- 93-02 RS body trim with Xenon front bumper
- New Precision Industries stall for th350 th400 PG
- SOLD Complete 4L60E swap F/S
- 28-1545 Granatelli spark plug wires
- LSx Flexplate with TH350/400 Trans
- Holley LSX valve covers polished
- Pro 5.0 short shifter
- LS6 electronic throttle body
- slp catback and stock parts
- CSR straight 360 thermostat housing
- lsa zl1 supercharger brand new with accessories
- 2002 lq4 and 2005 lq4 Blocks
- Magnafuel 625 fuel pump
- 2001 as sway bars
- x2 Derale 16925
- LS1 Throttle Body, 26 & 28lb Injectors, 411 PCM
- Machine Silver OEM C6 Body Panels
- Ls1 f body ac lines and bracket w/ tensioner
- sold
- Forged LS 347 Iron Block Nitrous 5.7
- 4.8/5.3 wire harness
- UMI safety loop, UMI torque arm, backing plates, axles
- LS1 Fuel Rail *SOLD*
- ccw centercaps polished new set of 4
- ford 9" pro 4.29 gears
- 99 z28 pcm and harness auto trans
- holley covers brand new 241-90
- FAST intake gaskets
- 2 sets of 317's and a short block lq4
- LTX performance/turbo kit
- Sold!!!!
- FTI Ed curtis custom ground camshaft
- Ls6 243 heads ported dual valve springs
- LS2 Intake Manifold
- F-body and Chevelle parts
- LS1 MSD 2 Step 8733
- Mint Ebony Dash Pad, M6 Console Top, Console Lid, Monsoon Radio
- trst9 1300hp intercooler
- 1997 Trans Am convertible part out
- FS: full set of OE LS7 90* spark plug wires
- BUILT 4l60e LS1
- LS3 heads (821) with rockers/stands, fresh PRC .675's, and TSP p-rods...$1000/shipped
- 243s with 12k miles like new!
- FS: ported LS6 oil pump
- FS: MSD Boost A Pump
- Garage Sale: 3.42 Gears, Bellows, Panhard Rod, Breather, Spring Isolators, OPS
- Zl1 fuel pump like new, KB BAP
- Sold
- circle D stall convertor 3200 ls1 parts
- 1.6 Ratio Rocker Arms
- AFR LSX 245 V2 Heads
- 4L60E, Stock Converter, Transfer Case
- Stainless Works CALS1 67-69 Camaro LS rack and pinion headers
- 6l80 flexplate, Roller rockers, fabbed valve covers, comp cam
- Edelbrock Shorty Headers model #6573 w/ Carb Stamp
- Prostars FS/Trade
- Ls1 longblock
- 418ci ls3 longblock for sale
- th400 built tranny with break
- 5.3 take out parts- complete front serpentine system, mounts, etc...
- t56 bellhousing and gto cai
- Heat sink style coil packs
- Ported LS6 Intake Manifold
- Low mileage 243's, custom Martin cam, Pushrods
- 93 - 97 Firebird Trans Am HEADLIGHT MOUNTING PANEL
- F/S - C5 vert windscreen, HURST shifter, NOS bottle opener
- EFI Live AutoCal tuner
- Warhawk LS1X 15º Cylinder Head
- Firehawk Rims
- Turbo 400, converter, and flexplate
- Comp CT4 Billet 3BB 6767 Turbo
- C6 Exhaust Manifold
- 93-02 Camaro Freedom Spoiler Brand New
- 98+ aftermarket air intake + misc parts
- LS6 Intake, 799 heads, C5 TB and nitrous plate updated
- gmpp ls7 intake
- F.S.-Drag Pack
- Lots of ls1 parts for sale
- 2010-2012 V8 Camaro cold air intake and cat delete pipes
- Parting out 2013 GMC sierra
- Nitrous express Proton kit with accessories!
- Bosch 0280155968 42LB Injectors
- 446WHP H/C/I LS1 for sale + supporting mods
- MTi C2 Camsaft. 7.400 Pushrods
- quad tip CME with valance
- FS: New Autometer Ultra Lite gauges
- ISO ls9 injectors and ls6 cam
- Long tubes, yank 3600, ls1 shortblock, 241 &more
- Precision 66mm Wastegate
- 95 z28 rolling chassis
- Stock LS1 stuff FS: cam/intake/241s etc
- Bogart D10's 15" Wheels with M/T Tires
- NOS bottle and misc nos parts, 4" spintech
- Comp ultra gold 1.72 rockers, Valve cover spacers
- F-Body twin turbo kit
- in desperate need of an obd2 LT1 timing cover
- SOLD!! LSX Swap Mounts Transdapt
- Corbeau Sport seats with Fbody bracket
- Huron Speed T6 Turbo Kit, Hotside + Coldside
- BMR battery tray, KATECH plug wires, OEM plug wires
- Fog Lights for Trans Am
- Manley Pushrods
- LS1 Throttle Body & Oil Pan
- SOLD: PowerBond harmonic balancer 25% underdriven
- dynatech ls swap headers
- Stock LS1 injectors, torque converter, and springs
- fresh set of 243 heads
- Textralia clutch & pp, ls7 clutch, pp & flywheel
- fast 102 for ls3/l92 w/ fogger
- Comp Cams LS1 Hyd. Roller, valve springs, and pushrods
- BMR K-member for LS1 F body
- 35mm Strano bar
- TF 225s, BW billet s480, fast 102 etc.
- F/s nx nitrous race kit like new complete kit
- aem tru boost, FIC injectors and more
- katech belt tensioner & ARP exhaust studs
- 93-02 Camaro upper control arm with Strano Offset bushings
- walbro 255 for f body
- 6.0 block/mahle pistons 370ci
- 17x9 BBS replica (looking) Wheels
- Bnib Diamond DOUBLE Coated pistons 402ci
- Ls2 intake and ls2 throttle body
- Sts turbo ls1 fbody
- Sold
- LS3/L92 Edlebrock intake/rails/fast 4150TB
- G5x3 cam
- Garage clean out! MAKE OFFERS!!!
- Ls2 cam $175
- AFR 225 72cc **Sold**
- l92s Fs/ft
- fs or trade built th400 with converter
- vic jr, accufab, wiring etc..
- pewtet fuel rail covers. LS1 SS
- 2000 z28 factory manifolds
- C6 A&A V2 SI supercharger kit
- F-body seats, Coils
- Misc Parts. LS and LT
- Aerospace billet bracket and bottles, ARP head studs, Weld Pro Stars, boost a pump
- kooks 1 7/8 headers
- meziere elec water pump
- busted ls6 intake, stock ls1 fuel rails, injectors, and throttle body
- forged LS7 Fbody ready
- FS: Nick Williams 90mm throttle body
- FS: FAST 90mm intake manifold
- Ls swap parts msd,kooks lt for fox
- TSP oil ported ls6 oil pump, misc parts
- AFR 205 bigbore heads
- 2011 5.3 LC9 shortblock 20K Miles -SOLD-
- Clutch Master Cylinder Like New
- FS: 2002 Z28 stock REAR coil springs and shocks
- A4 Upper Console
- 370 forged lsx engine ported ls3 heads iron block intake to pan
- prc stage 2.5 5.2 60cc heads
- lt1 t56 setup
- 102mm fast ls3 intake
- 99 camaro ls1 pcm and harness
- Few random LS parts
- ARP Head Bolts and Comp Pushrods
- FS:408 Manley rot assembly LS6 heads more
- 93-97 firebird, trans am big block hood, lt1
- GM Stock Replacement Main Bolts
- 90mm NX Nitrous Plate - Dual Stage
- Ls1 longblock locked up
- Spec super twin clutch w/ 1,500 miles
- ptm billet 92mm tb
- Diamond 11512 4.030 Forged Pistons NEW!!!
- Fast 92mm intake for LS1/LS6
- Heads off 2010 C6 821's
- LS6 Intake, 3200 vigilante stall, and 4.10 gears
- Kicker Amps and Motive Gears For Chevy 1500
- aeromotive a1000, filter, regulator
- Monster stag 3
- Fast 36 lb injectors
- 22" Boss 330 Wheels
- UMI Solid Aluminum Motor Mounts for 98-02 F bodies
