View Full Version : Parts Classifieds
- Fuel rail
- Smoke/Clear Air Lid
- Sold
- 5.3 flat top pistons and rods
- FBody LS1 Manifolds $40
- Built 6.0 L76, LS2, LSX
- NX 10LB Bottle *Pic Added*
- FIC 1100CC High-Z Injectors LS1/LS6 - 1000 miles
- Full set Titanium Del West Valves for LS1/6/2 Heads (8) Intake, (8) Exhaust
- LQ4 6.0L V8 Engine w/ Harness, ECM and LS1 Intake
- ZEX Nitrous box for wet kit
- Stock 6.0 317 casting heads with comp springs
- 99-02 camaro / firebird steering wheel w/ radio controls w/ airbag
- FC 8.8 Ronin Kit Axles (REAL T2 Outers)
- Holey HP EFI ECU
- Custom Comp Cam
- Balancer Pinning Kit
- sending unit relocation kit
- msd8733 , 4l60e tailshaft, alum drive shaft, shifter
- Gen3 engine harness, maf sensor, pcm
- SOLD......LS6 intake with new 42lb injectors and POTZ ported throttle body
- SOLD..Advanced Induction heads 226 cc ....super low miles...new BTR springs
- 315/35/17 tires for sale
- Aei alt mount with 140amp alt blower cam
- KYB AGX 8 way adjustable shocks/struts
- LT-1 Cylinder Heads
- LT-1/LE-1 air intake parts
- 93-02 Firebird driver side door switch
- proton nitrous kit brand new
- Pushrods, 5/16" x 7.350"-7.400" & 3/8" x 7.400"
- FS: Stock V1 LS6 exhaust manifolds - $free.99 + shipping
- Dark star 17x4 17x10 rests with new tires
- TrickFlow differential cover
- ls6 aluminum engine block
- Push rods & wheel studs
- Fast LSXR 102mm LS7 Intake
- Garage clean out MSD 6010 Ported 241s Victor jr carb yank 4400
- NIB SPEC Stage 2 Kit SC092
- LT1 Parts Explosion! Get them while there hot
- Dynamat Truck Kit 20 Sq Ft
- 18x4 Skinny (CTS Spare)
- 222/230 .601/.585 115.5+5 Camshaft
- LS2/7 silverblade TBs and LS3 gold TB
- 2 new toyo proxes 295 45 18
- 4th gen ss wheels and tires for sale
- GZ Super Pro vacuum pump for LSX
- F1X procharger head unit and GTO brackets
- Hoosier Racing Tube
- 01 tahoe 5.3 engine harness
- 5.3 Truck Intake, fuel rails, injectors
- Fast ez efi 2.0 fuel injection self tuning system
- Trans Am Lower airbox.
- LQ4 pistons, e-fans, truck oil pan
- Fast Fuel Rails for LS1
- Looking for Fast 78mm to, buy or trade for LS6
- parting out 04 gto
- Mint condition ls1 intake only 2000 miles
- Fast 102 lsx R rectangular port manifold
- madman motor plate, mid plate and strange master cylinder
- Truck Engine Parts Exhaust Manifolds, Pan, AC Compressor, VVT
- SLP cold air intake
- Timing Tuner & Ashtray Switchplate (Brand New)
- FS: LS1 intake manifold
- Ford 9 inch pro gear big pinion 3:89
- Weisco 402 flat top pistons 4.005 4inch crank
- Lunati 383 3.905 pistons and new Ap rings
- Weisco 402 pistons +5cc 4 inch crank
- FS:Misc parts(autometer,emblems,key fobs, afco, Eibach)
- GM musclecar LS swap oil pan
- Weld RTS
- Complete LS1 and GTO T56 Drop in. (Kooks, Monster, etc)
- C5 Corvette brake calipers with brackets and pads
- Sold
- --FS Misc Fbody C5 C6 C7 CORVETTE 5th GEN CAMARO AND CADILLAC PARTS--
- EFILive Flashscan V2 Parts
- 1999 - 2002 Trans Am WS6 Gauge Cluster (with only 1868 miles) Very Low Mileage!!
- Kooks 1 3/4 long tubes
- 799 heads
- Jakes 4l80e manual control box
- M6 Ebony Center Console (Full)
- VFN WSQ Hood. Unpainted. Maryland.Sold
- LS6 Fuel Rail w/Return
- SOLD - LS3 Injectors (2 sets)
- PSI max life valve sprngs
- GM Hot Cam and springs
- Mahle forged Pistons *FS/Trade*
- Hypertech power programmer 3
- Camaro trans am
- Nitrous Outlet Pass side head solenoid bracket
- ARP Pro Series Head Studs for 97-03 LS engines PN 234-4110 - BRAND NEW!
- powerglide crossmember
- Nitrous Outlet 4AN filter
- Nitrous Outlet F Body ash tray panel
- LS1,LS2,LS3 LS6 LSX Mock up block
- Nitrous Outlet Fuel Pressure Safety Switch
- Nitrous Outlet Fully Auto heated nitrous bracket
- Nitrous Express Bottle opener
- BNIB WELD Center caps
- BNIB ARP 3.25 Wheel studs
- 1" F Body spacers
- 317s/BTR Duals - FIC 1100cc - Turbo Cam - LS7 Lifters - LS1 Intake
- 4l80e hughes torque converter triple disc
- C5 ZO6 Chrome Wheels. Only 1 front and 1 rear in perfect chape
- NEW set of LS3 valves(hollow intake!)
- Stainless Works 67-69 Camaro / 68-72 Nova LS Swap headers
- 2" Amercian Racing Headers, primaries and Y pipe
- Blackout tail light covers
- Ported 241 heads and Trex cam
- 05-06 GTO LS2 Fuel Rail Covers
- LS1 heads and intakes
- Cam Motion cam for sale... 243/259
- GT55 TURBO BNIB***dont be scared of a big turbo
- 4L80 Circle-D Torque Converter
- Fuel System, QTP Headers and ls6 intake
- LS1 coil packs
- HP tuners suite MPVI pro used $350
- BMR K-member, Upper arms, rear qa1
- WTT: 4l80 for t56
- Headers- NEVER USED MAC Mid-Length w/ Cats
- '95 Z28 ... scrapping everything left ASAP!
- 440 rwhp package cheap plus yank and 6010 and 850 hp carb
- 1998 Camaro SS Parts LCA Panhard Rear End Driveshaft
- LS1 F-body complete accessory setup (a/c, alt., PS, Waterpump, etc)
- ARP Bolts / Studs , KA Tech Chain / Cloyes gears , BTR Pushrods
- Fast 92 mm tb 54092
- Brand new Comp Cams 3158kt Timing set
- Circle D 3200, AC Delco knock sensors + truck intake gasket set, Dorman harness, NIB
- C5/c6 1300hp ecs intercooler
- Camaro Gauge Cluster w/ Only 3K Miles
- bbk shorty headers and bypass pipes
- ***Bran new cam FS***
- 98-02 camaro body parts
- Comp Cam, Brand New in Box, 239 247, 620 632, 109+2
- LS Microsquirt
- Tick Performance Shims
- 237cc Prc cnc heads 6 bolt with upgrades
- 799 heads with yellow springs
- Viking coilovers front/rear f body
- (SOLD) Brand New F1A Procharger Reverse Rotation
- 317 heads w/inconel exh. valves, 5 angle valve job **SOLD**
- sold
- Fjo nitrous controller
- 243 Heads
- Firebird gray door panels $75.00 each (SOLD)
- Misc parts and LS books
- 853 Heads
- Firebird white mirror assemblies (SOLD)
- 93-97 firebird headlight mounting panel (SOLD)
- 93-97 drivers side firebird headlight assembly (SOLD)
- Firebird upper dash panel gray $80.00
- (Sold) Used moroso 21150 Fbody oil pan
- Diablo I-1000 FS
- HP Tuners (New)
- 99 trans am rear cross drilled and slotted rotors
- N/A nitrous part out
- 98 LS1 dropout NO TRANS
- 98 Ecm and m6 harness
- UMI Trans mount TQ Arm
- Aeromotive fuel pressure regulator (boost reference)
- ls1 block, ls1 rods pistons,eagle rods
- Fast fuel rails with crossover
- Wiseco pistons, set of 8
- FAST XFI Edash 301517
- Aerospace 3 vane vacuum pump
- SHURflo pump for turbo *New
- BMR F-Body Driveshaft Loop & Hotchkis F-Body LCA's
- MSD 2-Step 8733
- Ls7 intake and tb
- Two ON3 Ball Bearing 6766 turbos
- lsa pistons/rods
- 2006 Pontiac GTO Stock Exhaust + Stock Driveshaft (LOWERED PRICE)
- New 20 circuit wiring harness
- Fs stock ls1 intake
- C5 Brake Calipers and Caliper Brackets
- 2 Cams out of my 402 NEED GONE ASAP
- Ricks Custom Fox Tank with A1000 NEED GONE ASAP
- Florida 50 Autometer Gauge Cluster Fox 86 NEED GONE ASAP
- Billet Aluminum Nasty Performance Valve Covers
- 1998 ls1 parts
- GM Card MAF and aluminum mounting boxx
- Dart 205 Bare Head w/full set of 16 Valves
- PARTING OUT 2004 GTO - LS1 / M6 - Nice Car!
- ZL1 Injectors, LS7 Lifters
- HPtuners VCM suite basic and laptop
- LS3 90mm TB - Brand new DBW throttle body taken off GM 525hp crate motor
- LS6 valley cover
- Fabricated aluminum valve covers, abs block, black/white door panels
- LS1 F body Oil pan w/ windage tray, & dipstick +tube
- LQ4/LQ9 3 piece engine covers 90 shipped !!!!!!
- ly6 pistons rods possibly crankshaft
- DynaTech LS swap headers
- HPTuners Pro, AEM wideband combo
- LS6 intake with fuel rail/injectors
- LS4 Engine Parts
- T56 Pro 5.0 shifter (less than 500 miles)
- F-Body Pedal Assembly and Plug Wires
- Accel Ceramic Boot Plug Wires F-Body/Corvette New Open Box #9052C
- Edlebrock elbow,102mm TB CAI $250
- Fuel Injector Clinic 2150cc injectors
- Founders On-Car adjustable Panhard bar-SOLD
- 2 step
- LS6 Intake #12573572
- F1C Procharger
- 246-254-646-629-112
- 370 CI Nitrous Motor LS
- Performance and boosted parts
- Ls6 intake,80lb injectors, 2 sets fuel rails aeromotive fpr
- LT1 taillight's, truck dbw, alternator, (6)PCM's
- 243s from(on) 50K mile LS2 $500 Shipped OBO
- T56 Fbody Mainshaft
- c5 Z06 vararam intake
- Yella Terra Platinum YT6640 & YT5123 spacers $300 Shipped!
- Set of 4, Nitto NT555 on SSR GT-10 2-Piece Rims
- Meg's M16 wax
- B&M T56 Shifter and SLP knob great shape $110 Shipped
- 00' camaro ss throttle body w/ iac and tps sensors bone stock
- Nitrous Express, FTP, 85mm MAF, Mallory 685,XS Power
- 2004 GTO LS1 Fuel Line Covers
- Camaro export tail lights.
- New 2007-10 Duramax 6.6 K&N Cold Air Intake Kit.
- Z28 hood
- Z28 rear spoiler
- 275/40/18 tires - SOLD
- *** SOLD *** LS1 Edelbrock Aluminum Coil Covers
- 315/35/17 nitto Nt05 275/45/17 nitto 555
- Pair of cat converters off a 02 ws6
- 1000chp Ls1, twin turbo set up for sale
- *** SOLD *** Ported Victor Jr. LS1 Cathedral Port Intake Manifold
- *** SOLD *** LS1 Super Victor Cathedral Port Intake
- MSD DYNAFORCE STARTER for all LS
- E85 Flex Fuel Sensor for 5th gen Camaro
- Ton of Race Parts & Stock OEM Parts For Sale
- LS2 Factory Camshaft
- LS2 GTO 24 tooth Crankshaft .010" Under
- 2004-2006 GTO Hurst Shifter 6 Speed
- Eagle 7/16 8740 rod bolts and corvette regulator with fittings
- Ls1 Pacesetter headers, hooker cat back. Y pipe w gutted cats No Shipping
- a bunch of parts
- k member and suspension *local pickup only*
- wrecked car part out/garage clear out
- BMW Supercharged 402 LS2/T56 Part out
- LOTS of LS parts, heads, harness, intakes, manifolds, etc.
- ARE dry sump pan (possible whole kit)
- nano nitrous 3000
- firebird trans am part out 1994
- San Diego Area FS: Stock Ebony Leather Seats Great Condition
- EPP Blower Cam
- 1998 z28 partout
