View Full Version : Parts Classifieds
- carb vic jr ls3/l92
- OEM Z06 Speedlines (4)18x10.5/(2)17x9.5
- 100mm callaway MAF housing, $75. (no sensor)
- FS: 10 bolt complete out of a 00 Fbody
- BNIB : competition sump kit, 79-04 Granatelli coilovers
- Random SS/TA parts
- LS3/L92 heads
- 232/240 XE-R Fresh Regrind G5X2 Comp Cam
- all kinds of parts F/S comp cam pushrods, pacesetter headers, ls7 lifters FTP ram air
- LS2 90MM Throttlebody, DBW, black, polished ID, 90mm Ring for FAST102
- 2009 C6 3.42 Rear diff
- LS H beam rods
- LS 4 inch stroker crank, new
- Katech LS7 rods
- 2000 Camaro part out
- Complete 243 heads
- BadlanzHPE Electric Exhaust Cutouts 3 in
- four new drilled and slotted rotors for 160$ shipped!
- harlan sharp 1:7 rockers, new, asking $300
- Huron Speed "Newsed" Turbo Kit w/ Turbo+WG+BOV
- F-body Oil Pan, Pickup, Windage tray
- Msd coils, 4th gen tail lights, wheel spacers.
- OEM and halo Headlights,, blackout side markers, Electric guages ETC
- RAM AIR for 4th Gen A/C equipped cars
- Fbody Magnaflow exhaust tips
- LS2 Timing Chain
- 6LE Tweeter Pods
- NEW LSA Heads w/ upgraded LS3 Valves & Springs (LS3 L92 L76 Head) ZL1 CTS-V
- LT1 Tuning ,PERFORMANCE & STOCK PARTS, ZR1 RIMS, SRP TURBO PISTON&RODS,B&M
- LS3 top end
- FS: Lid, LS3 intake, abs block, ps cooler, radiator, 706 heads, oil pump,timing chain
- Moroso 7qt Oil pan NEW!!
- 3" Electric Cutout & wiring/switch BNIB/ 3" manual cutout
- Bogart Classic Stars with Slicks and Skinnies (Trades needed!)
- TBSS engine cover
- Norris Motorsports Catch can
- SS Seats (ebony leather)
- .650 lift PRC gold valve springs..
- Another L99 LS3 complete 6.2 Camaro SS 6l80
- SOLD! Motorad Thermostat | Alternator Relocation Kit
- American Racing Torque Thrust M Wheels with Goodyear Eagle Tires
- Lots of Parts for Sale!!!!!
- LS1 TB 65 shipped ls1 headers 160 shipped 15x10 190 shipped
- LS6 Coolant Crossover Line & Rear Plugs
- LS7 head gaskets/ARP intake bolts
- F/s Strange 12bolt, Umi t/a+mount, umi drag bar
- T56 offset lever GTO F/S o Trade
- FS: LS3 heads with Patriot Gold springs
- LS2 and 2006 GTO parts BRAND NEW AND USED!!!
- 408 forged shortblock 1200+hp, Tilton 4 disc clutch
- 243 Ported Cylinder Heads
- 1.8 Yella Terra rockers LS1 LS2 LS6
- Free ORY and other stuff cheap
- Lunati LS1 Lifters Link-Bar
- 3200 ptc torque converter
- ls1 engine long block
- FS: Brand new PLX gauges
- FS: Brand new 2010 Camaro Shifters
- FS: LS3 and VVT cams
- FS: brand new turbo stuff
- Precision GT4276 Turbo, Kentucky turbo hotside
- C5 Suspension/ Drivetrain, Kenne Bell, Fuel Pumps, 4l80E...
- Magnaflow LS1 Exhaust Catback System, Dual Split
- For sale: UMI front and rear sway bars, Diablo tuner
- Mustang Parts: Intake, Exhaust, Tune
- ProTorque Revolution Series TH400 Converter
- FS: 2012 LS7 Engine
- magnaflow catback
- TR-6060 2010 camaro SS trans
- NEW GM LS3 Hollow Stem INTAKE VALVES $140/set Shipped (12569427)
- LS3 corvette fuel rail covers
- 17x9 Camaro SS/ZR1 wheels with newer Hankook RS3 tires
- Ported LS2 Intake manifold
- Ported 243 heads, BRAND NEW! Stage 2 porting
- Fs:dynatech 1 7/8 headers corvette
- 98-02 LS1 K&N Intake Kit
- Braswell 4150-style (4760) carb
- Weldon A2045 carb deadhead regulator
- GMPP LSX carb ignition controller
- GZ Motorsports vacuum pump kit
- THIRD GEN GTA Trans AM Tan Seats
- Walbro Dual In Tank Set-Up
- ls2 intake with injectors and fuel rails
- WCCH ported LSX carb intake manifold (19244032)
- weiand 144 blower complete carb and bird catcher sbc
- F/S 6.0 rebuilt with 317 heads, turbo cam
- BW T-6 s475 (75/83) LOW MILES
- wts slp shocks and springs
- seimen deka 80lb injectors
- JE Flat top 408 pistons
- Eagle Forged I Beam Rods
- 2005 LS2 Shortblock
- Ls1 Rockers W/ Comp Trunion Upgrade
- MP T76, Turbonetics WG, Magnavolt, Misc.
- 87 Mustang Coupe Part out (For you LSX swap guys)
- Coverking custom car cover for SS Camaro
- feeler:hke 408
- ***SOLD***Trailblazer SS kooks 1 7/8" headers and catted Y
- New Ford 9 Motive 3:89 gear
- FAST 102 TB & Fast Toys 104mm Lid
- Nitrous Express 102mm Plate System! Custom! Loaded!
- Tci Flexplate
- Anyone need a set of LS1 241 heads
- 95 4L60e A4 transmission with shift kit
- Two Moser 12 bolt F-body rears - 3.73 Posi & 4.30 spool
- coils, heads, intake, and oil pan
- Corsa Clones...SOLD
- SOLD lg world challenge wheels for c6 z06,gs,zr1
- Nitrous Express NX MAXIMIZER
- BMR Lower Control Arms
- Lq4 370
- AI 226cc 799's w/BT .660' springs (SOLD)
- Fs:huge air to water intercooler
- 95 LT1 F-body MAF sensor
- Magna fuel regulator with o ring fittings low psi
- 96 Camaro SS Level II Bilstein shocks trade for stock +$
- bullseye s472..
- ***sold***
- Turbo hot parts, stock radiator, ls1 fans
- FS: 2 LS6 Intake Manifolds
- 4 Ws6 Wheels with tire.
- 6.0 intake
- C5Z corvette seats
- HSW 90mm Nitrous Plate and HSW The Interface
- Ls1 fans $100 shipped
- LSX Parts
- Ls1 block, cranks, and pistons and rods
- Pacesetter Cermaic headers. F-body
- 1998 Camaro pcm and engine harness
- Turbonetics evolutions wastegate (Brand New)
- Turbonetics TC 76 mm turbo (Brand New)
- 05 Silverado 6.0 SS exhaust manifolds
- Circle D stage 3 4l80 258mm multi disc for boost
- Nick Williams 90mm billet LS throttle body
- spohn drive shaft safty loop 93-02 F body
- 2 rear o2's from 00 Z28 30k mi
- AFE dry air filter for 5th gen Camaro
- LS1 longblock 97k miles
- 243 heads
- f body parts and new et street
- WTB: CME Quad Exhaust Tips, CASH IN HAND
- LS1 aluminum driveshaft
- 04 GTO LS1 and T56 9X,XXX miles
- UMI LS billet valve cover spacers
- Oem Gto 18s with caps and tires
- SLP Dual/Dual, OEM Black 2000 SS Hood, 4.10's, McLeod, Misc. F-body Parts
- WTT WTS TSP TQR V2 cam
- OEM Iroc Spoiler
- FS - Strano Rear Sway Bar
- FS - Alpine 9885 Head Unit + additional
- 82-02 F-Body UMI rear LCA's***SOLD***
- Autometer Carbonfiber nitrous gauge 2 5/8 mechanical
- Stock ls2 injectors 80 shipped and >2k miles ls3 150shipped
- TA seats, AC system, T-Tops, PHB/TA
- Big LSx cam
- 8.8 Housing modified for 4th Gen
- Ported Stock TB
- FS: New LS1 rear timing cover gasket
- Stock 02 LS1 Cam
- HS roller rockers, katech timing chain, arp head studs, cartek line lock and more...
- 67 Camaro Suspension parts
- Clutch Master Cylinder Low Miles
- stock shifter from 2005 gto
- GTO exhaust
- Chevy 5.3l Vortec Engine LM7 Edelbrock Victor Jr Ls1 intake MSD 6LS & th200
- WTT complete 5.3L
- Brand new LSA, ctsv,ZR1 valve covers
- FS: Kooks Long Tube Headers 06+ Z06/ZR1
- Chevy Truck Sub box---extended cab
- MSD 2 step
- Valve cover spacers
- ASP crank pulley
- Stock monsoon amp
- UMI Performance Tunnel Mount Adjustable Torque Arm Used LS1 Camaro / Firebird
- FS: Good Year GS-A 335/35/17
- Professionally Painted Pewter LS6 Intake with Crossover Tube
- 1000hp 347
- LS6 Intake Manifold
- Trailer Guard TG1.5 Security System - NIB!
- 6.0l iron block , scat rods, mahle pistons , arp studs, ms3 cam, 4k stall
- Trailer Tie Downs - NIB
- Glowshift Air/Fuel Ratio Gauge
- F/S F-body items
- 5th gen Camaro part out
- Truck Coils, Brackets, & Harness D585 GM Part #19005218
- Holley ultra avenger 770
- 82-92 Koni/Eibach Springs/Shocks/Struts
- rank snout adaptors. NEW AND CHEAP
- 4" Mufflex Catback, 1-7/8" Headers
- CCW 505A 19" w/ Tires, C6 Z06 Brakes
- SET - BLIZZAKS - On 16inch wheels.
- Th400 Transmission
- 427 Forged pistons new...
- LS1 Flowmaster Catback, Pacesetter Y-pipe with 3 inch cutout. CHEAP
- Fast 102 setup
- PP Typhoon Intake 96mm,Matching 96mm TB & 42/50LB Green Top Injectors...Polished
- Autometer Traditional Mech Oil Guage and Copper Line
- L92 Truck Intake
- Selling parts after Midwest 9 install
- Turbo Race Car Part Out
- WTB: racetronix pump and Hotwire kit
- Replica F-body GMMG Camaro Exhaust - $95 picked up
- Callie's 4"stroke crank
- 02 WS6 Exhaust Manifolds + stock PHR, and Rear LCA
- WTS/WTT meziere ls1 electric water pump
- lt1 motor/accesories, tubular kmember, flamming river
- (((1999-2002 54k Camaro Gauge Cluster )))
- Spohn rear Control Arms
- Strange 12 Bolt, Sphoon UMI Supsension Koni's Stranos 93 02
- Cam pushrods and tsp oil pump
- Gi...fast ez efi !!! MORE PARTS ADDED!!!
- Guaging interest. T56 swap, built t56, pro 5.0 diamond clutch, harness, ect
- aftermarket and stock parts for sale
- Ls2 intake off of 2005 corvette SOLD!!!!!
- Spintech mufflers
- Brand New Nos NBM Plate filler
- LS2 intake manifold 10k miles ALMOST BRAND NEW!
- Complete TURBO KIT
- *****SLP LID FOR SALE***** 55+shipping!!!
- LS1 fbody coil pack brackets LS6 99-02 centerbolt
- Circle d 5500 stall 4l60e price drop
- C5 Batwing one piece pan
- LS1 Super Victor EFI intake manifold #28095 with fuel rail #3638
- Ir ingersoll rand 1/2 dr titanium 2131p7 timax composite impact gun w/socket set
- GM LS2 85mm MAF
- Nitrous Solenoids and lines
- Slighty Used LS7 Lifters
- Edge Torque converter 4000 stall lsx turbo 350
- McLeod 2009+ CTS-V & Camaro LSA Twin Disc clutch & Flywheel Assy
- Ls1 plate nitrous system
- Shop clean up
- ecs meth kit, KB boost a pump, 60 lb injectors
- 241 heads and gto exhaust
- C5 CCW Drag pack Refurbished and Repainted
- precision 88mm turbo
- SLP parts F/S
- FS: Complete dropout from a 98 SS
- Th350 BMR Crossmember
- 2005 GTO - Parting Out
- Perfromance !!!
- Injector Dynamics ID1000 fuel injectors (with adapters for LS1 LS6)
- Cloth Seats (Grey)
- 4L60e Rebuild kit
- koni front struts N.I.B, an purple lowering springs on stock struts.
- ls2 intake
- (SOLD) Lowering Springs and WS6 Sway Bars
- Fast 65lbs Injectors Shortys
- Nick Williams 102mm DBW
- FS:Custom grind cam 247/263
- Total Engine Airflow 243's
