View Full Version : Parts Classifieds
- Carrillo Pro A rods and Kateh 4.070 forged pistons DLC pins SOLD
- BMR Powerglide/TH350 Transmission Crossmember with Torque Arm Relocation
- New GM LSA high volume oil pump Sold
- New Diamond Pro Select 4.0-4.005 ring set SOLD
- Diablo Predator Tuner
- ISimple Ipod Radio Integration with Bluetooth adapter
- 4th gen y pipes
- 1997 to 2002 ls1 factory crank shaft 40k
- 1998 to 2002 ls1 fbody oil pan
- Tsp magic stick cam
- Nitrous bottle Stainless steel tunnel mount and switch panels
- PRC 227cc CNC Ported Small Bore 3.9"-4" Cylinder Heads
- 317 Heads
- Accel 4500 TB with sensors
- LS3, 4l80E, converter and Holley Dominator.
- Sold!!!
- New Painless perf 67/68 Fbody kit
- APS C6 TT kit, brand new LG C6 spindles, C6 Z06 rear
- Valentine One Radar Detector
- Summit Racing 60" Spark Plug Wires - Part Number SUM-881012
- GM Electrical Connectors and PCM Pins
- LS1 Coil Packs & Brackets
- LS1 A/C Compressor Bracket
- OEM LS1 Spark Plug Wires
- Tea stage 2 243 heads
- c6 wheels from my SS
- Katech Valve Covers and Coil Mounts
- FS....black z06 wheels/ BB Route 66 catback/ borla catback
- 5.3 GEN III LM7 Bare Block
- 04-06 GTO D1SC Procharger kit
- Ls1 accessories
- Holley Crinkl cut ( blk) & RX oil seperator
- Ls6 intake w/throttle body SOLD!!!!!!
- 04 LS6 cam
- T4 hotside kit and 66mm gate
- 6.5 L CHEVY GMC TURBO DIESEL Engine Complete w/ 4L80E Transmission
- Like New: Bogart Bolted RTs with Beadlocks
- VMAX Ring For FAST 102 intake
- FIC Flow Max 57lb Bosch EV14 LS2/L92
- Left over parts (LS3 rocker set up)
- Holley hi Ram intake LS3 105mm
- lt1 intake,water pump, ls1 map sensor
- WS6 Ram Air Lower Air Cleaner box
- Factory Steel / metal F body fuel tank
- F-body Power seat bracket with motors and switches
- 2 - 315/35/75 Goodyear Eagle F1 GS-D3 tires
- Nick Williams 90mm Throttle Body - uses - needs rebuild
- Holley HP EFI ecu new.
- JGS 60mm BOV NEW
- Forced inductions S485 Billet turbo
- 2014+ Silverado oem intake
- LS3/7 42lb injectors CHEAPPPPP
- Pacesetter fbody longtube ls1
- Haltech Venom C5 Intake Cheap!!
- BRAND NEW Tick shim kit (3 Shims)
- Melling High Volume Oil Pump
- Brand new ls3 intake manifold
- Custom Cam from Martin @ Tick (before he left)
- Trailblazer SS Kooks 1 7/8 LT's with ORY, PCM of NC E-Fan setup/Trans cooler setup
- Holley dominator set up
- Viper T56 built trans
- C5 Corvette Stock Hood, Factory Yellow paint in Maryland
- 4" Magnaflow Muffler
- (4) Polished 17x11 Deep dish ZR1 Wheels NIB for square setup
- LS3/LS7 Throttle Body
- 92mm Nitrous Outlet kit
- FAST XIM #305008 For Sale
- FS: ls7 Lsx 4150 carb style gm performance intake
- AC Delco LS1 TPS BNIB
- Brand new LS3 heads and bare intake off of crate engine. ---SOLD---
- slightly used set of ls3/ls7 HPI bosch 105lb high impedance injectors
- LS7 Clutch
- 2.04" hollw stem Ls3 intake valves
- tall aluminum valve covers with AN fittings
- 245 45 20 goodyear tires fs
- New ls3 heads
- 2000 SS camaro partout and spare parts
- Ported and Polished LS2 Throttle Body
- 275/40R17 rear racestars
- 18 in American Racing Wheels & Tires
- intake and exhaust manifolds plus oil pan
- Engine Covers - Front, Rear, Valley, Valve
- Kooks LS Fox LT's, x-pipe/muffler setup, BTR pushrods, 4150 TB
- Fresh LS 402 shortblock
- PTE 7675 .96a/r Brand New
- Front and rear engine covers!
- Maggie mp112
- The tuning school beginners
- New Stage 4 Rear Differential 3:90
- New Transmission
- Parting out 2002 camaro z28 - ls1 / auto
- LS1 pacesetter ceramic long tubes
- Shorty 80lb injectors
- ARP 434-1202 SBC/GENIII LS 3/8 Flange SS 12pt Header Bolt Kit
- New Turbonetics 7875, QTP Electric Cutouts
- Killer Tall Deck Race Engine
- Parting out 98 Z28
- Ported fast 90
- LS/LT parts
- stock 243 heads
- Griffin 25241 vertical radiator
- FS: NX Plate Kit / Standalone / Heated Bracket
- Nitrous outlet kit ls1 with extras , priced to sell fast!
- 231/237 617/610 111+3 lsa
- Parting out 2007 cts v
- Auto Gauge Tach
- lingenfelter lnc-2001
- Ls1 block
- LT1 bell,clutch,GMPP fastburn heads
- FS: Triple Bosch 044 Fuel Pump Setup
- New Tick Cam
- Nitrous Outlet 92mm Plate kit
- UMI Rear Lower Control Arms, Double Roto-Joint, 82-02
- LS3 Intake Manifold/Fuel Rails and LS3 Throttle Body
- Jgs 60mm bov
- 93-02 front QA1 12 way adjustable coil overs
- NOS Nitrous Kit
- grand prix gxp struts
- ls6 injectors
- 30lb red top injectors & stock ls1 injectors and intake
- Sparco Seats
- 04-06 GTO Vara ram intake and JBA exhaust
- FS: Chrome C6 Z06 Spyder Wheels w/ tires + TPMS
- Ls1/lq9 Crank
- Reduced: 90mm NOS Plate, NX Remote Opener & 10lb Bottle w/NOS Hi Flow Valve Nitrous
- Fast 102 LSXR for LS3 square port heads - SOLD
- Rear pulleys and belt for TVS 1900 or 2300
- FAST LSX R 102 LS3 FS or Trade LS1/3 High Ram
- Wheels: CETA ZR1 Helo
- 1993-2002 OEM Camaro spoiler
- Pro 5.0 shifter, Hurst leather knob
- Circle D 245mm 3e 4200-4400 stall converter
- 4L60 trans from 98 z28
- Prostock Pontiac 18 degree big chief heads
- Pro Systems SV1 E85
- Custom 96mm T4 Billet S476 Turbo
- 347 ls1
- Billet Specialties Street Lite Wheels
- SVO REDTOP 30LB Injectors,Innovative LM1, 6 Speed Cross member**LS Garage Clean out**
- Custom blue gauge needles & 2 billet shift knobs
- Max effort ported 853 heads
- FS: 6.0L block, pistons, and h-beam rods
- Trick Flow 235CC Heads, BRAND NEW!
- FS: Black 15x10 Weld RTS Wheels C5 Fitment
- lsx intake
- 102 mm throttle body 225 shipped
- 4th gen Camaro SS black leather seats
- Alky Control dual nozzle C5 corvette meth kit
- Cartek flip drive y-body pulley offset
- A&A C5 intercooler
- WTS turbonetics TC 76-68mm turbo!
- 93-02 F body Camaro Trans am Firebird Center Console 6 speed with lid
- Forged Mahle 4.070 stock stroke pistons SOLD
- Lingenfelter GT9 camshaft Price Drop
- LSA Rotating Assemly W/Katech bolts & clutch SOLD
- 12570790 LS2 Silver Blade Throttle Body
- New FAST LS3 intake gaskets
- Advanced Induction Ported 243 Heads
- TRADE: LS3 intake for LS6
- Nitrous, UMI, BBK, K-member, S60 and more
- FS: LS3 Rockers Trunion Micro polished
- 98-02 Maf and injectors
- Flt lvl4 4l60e
- *Updated* TNT F1 Ring Nitrous Kit, NX Fire & Ice Bottle Heater System, Remote Opener
- 98-02 F-body LS1-LS6 Water Pump w/Steam fitting
- Street & Perf AC Mount for LS1 98-02 F Body
- Rear Diff Gears for 9 in. Rear (4.10)
- ly6 6.0 complete intake,tb,inj etc e38+pedal,harness
- Ls3 /L92 edlerbrock Vitoria Jr carb intake , msd 6010 ignition box
- Pair of 18x11 Weld RTS s71
- Procharger D1SC GTO kit
- ls1 AC bracket,lt1 brakes, hawk pads +misc; garage cleanup.
- eibach springs
- Ported and Painted LS3 Intake
- 4th gen fbody procharger fan shroud w/radiator support, 99-02 fbody gauge cluster
- Hallman boost controller
- Siemens Deja 80 lb injectors Like New. SOLD
- New monster stage 2 clutch
- New McLeod RST clutch and Steel Flywheel SOLD
- LS3 Intake with Rails and New LS9 injectors SOLD
- Prc heads
- RX catchcan with dual check valve and breather cap
- Nitrous Wet Kit, purge, warmer, opener, bottle
- NOS Mini Nitrous Controller
- Misc. AN fittings *SOLD*
- 317 Heads
- Like new Mickey Thompson 28 10.5 stiff sidewall slicks akron ohio
- Billet th400 freakshow turbo converter
- Keith Kraft Stroker Cam LS
- Tick SNS Torque Max 3 Mild cam - SOLD!!
- MGW shifter
- Kooks 2" race headers c5 or c6 corvette
- 90mm Nitrous Outlet Plate Kit
- edelbrock performer rpm msd 6010 advanced induction heads
- Brand New LS3 Nitrous Outlet Kit
- Ls1 EGR
- Truck intake, coils
- Fast 90 intake, Thunder racing 224/224 cam
- '01 Z28 part out
- LS2 Silver Blade Throttle body Ported
- Nitrous Cam,LS7 Lifters,TR Push Rods,Katech Pump,Double roller timing chain
- SLP Blackwing Lid with Filter and Base
- Bare LS3 intake
- Earth-X ETX-900 Lithium battery, charger, holder
- Holley Terminator Throttle Body
- Ford Racing 42 lbs injectors Green Top
- GI: AFR205 56.5cc
- Brand New Yank SS3600
- LS2 heads, intake, headers and more
- LSX sensors
- Comp cam 306cc
- Need it gone!! H/C/I - 450rwhp setup - Custom Cam, FAST 102, CNC Ported Heads
- 6.0 LQ4, 4L80E, wire harness, exhaust etc.
- 2010-Current Camaro SS 20" Wheels
- LS1 Centerforce Clutch and Pressure Plate
- V2 LSA complete pullout for sale!
- New, never used Precision 6766 CEA Turbo
- Parting out 95 Trans Am
- Nick Williams 102MM Throttle Body - Free Shipping!
- 7.4" .08" Texas Speed Pushrods
- Sold-Tick SNS Torque Max Stage 2 Cam-New
- LS3 Throttle Body, Pan, & Cooler
- LS3 Nitrous Kit-Parting Out
- lingenfelter Trg-002 harness NEW
- WCCH stage 2 LS7 heads!!!!! TX.
- Camaro Parts (steering wheel, c5 brake conversion brackets, Suspension Parts)
- 2002 Camaro Z28 T56 crossmember
- shp ls next block
- Manley Crankshaft, 4" stroke
- Garage sale
- Tick Stage 2 Turbo Cam
- 9" 3.50 gears, Spicer 30 spline slip yoke for t56 magnum
- Ls2 complete intake to oil pan SOLD!!!!
- Ricks EFI Stainless Tank for Chevelle
- 1996 camaro Z28 ss slp floor mats rare
- FS: Fast 102 LSXR LS7
- SOLD: Stock LS7 Injectors low miles
- SOLD: Fast 102 LS7
- Latest sts turbo kit
- **SOLD***CCW Classics 17x11 93-02 F Body or Corvette w/tires
- Nitrous, Subwoofers, Catch can, suspension, etc
- New Torsen POSI
- FS: Brand New Exedy Twin Plate Clutch - GT04XD
- Speartech 4L80 Harness, Stock PCM (01 Trans Am)
- SOLD 1993 - 2002 GM F-Body Tunnel Brace Mounted Torque Arm w/ DSL
- Milodon # 30916 LS Series Chevy V8 Low Profile Street/Strip Heavy Duty Oil Pan
- Seimans deka 60lb short style
- MagnaFuel ProTuner 625 Series In-Line Fuel Pumps MP-4301 NEW!
- ***SOLD*** HSW F-Body ashtray switch panel
- TSP 418 Stroker for sale - Lashway Motorsports
