View Full Version : Parts Classifieds
- Goodridge brake lines---LS1/C5 2 lines only
- SLP Lid with stock MAF
- NEW Wiseco custom (boost) pistons, 376" LS3
- Procharger Pulleys
- C5/FBody Random Parts, turbo, swap etc...
- PT91.5 turbo
- Stock LS1 TB
- MSD LS 2-step***SOLD***
- 42lb LS1 Injectors
- FT Timing Tuner box
- Racetronix Hotwire Kit
- Injector dynamics ID1000
- 317 heads
- Camaro Sonar Projector Halo Headlights - SOLD
- Pre 04 ARP head bolts
- Built TH350 With QuarterStick
- XT80 Turbo
- A bunch of brand new parts: sensors, alternator, blower cam
- Master Cylinder and Actuator for lt1 t56
- qa1 front and rear adj shocks and coil over springs
- 37lb injectors
- trade 6l80e trans
- (2) LS6 Intakes FS
- PORTED LS6 Intake
- BMR adjustable Panhard bar
- hooker headers,ypipe,exhaust
- 24x Conversion Coil Brackets LT1
- Shop Clean Out! Nano, Nitrous, E85 LOOK! UPDATE 10/10/13
- Brand new bare LS6 799 heads $450.00
- Low Mile Yank SS4000
- GM 3.73 Gears SOLD
- F-Body Hatch Release
- Boost controller / boost cam/ msd 2step/ meth /holley intake
- UMI/BMR Drive Shaft Saft Loop
- After build parts sale boost cam, valve covers, Crank Damper and More
- Stock 317 Heads *No Valves*
- RPM Level 5 RPM 4L80 new price
- 60lb injectors, b&m, off road y pipe.......
- ARP Main Studs
- WTB/WTT for LS6 Intake
- NIB: GM LS3 3-pc Timing Chain Set
- Few engine and exterior parts
- L76 6.0L Shortblock
- C6 Z51 Sway Bars $150+
- C5 & fbody parts!
- FS: ZR1 Exhaust Manifolds/Cats/X-pipe
- TFS245 TEA ported, YT shaft rockers,pushrods,LS2/7 coils,LS7 vcovers, 3k shipped
- Kooks 1 3/4" 02 camaro(SOLD)
- Stock g8 19" wheels
- Tick Performance Cam 243/258, Nitrous Express Bottle Valve
- Roush TVS2300 Tuner Kit
- Isky "Turbo" Cam with Accessories.
- Master power turbo t76
- comp cam 224
- 97-99 CORVETTE EXHAUST MANIFOLDS (pair) F/S
- fast 78,tb,700r4, converter, driveshaft
- ls1 vigilante 3600 stall torque convereter
- lt1 CSI electric water pump with housing NEW never used $150 ILLINOIS
- PT 7675 Billet Wheel/CEA- Anti Surge .96 T4
- master power t70, full turbo kit
- 6 rib bracket assembly, pulleys, belt, crank pulley***PICS***
- Stock exhaust
- Adj Random Tech TQ arm, Relocation brackets, alum drive shaft
- FAST 90mm Intake & 60 lb injectors
- 1997 camaro 16" 5 spoke wheels with like new 235/55/r16 tires.
- FS: carpet, sound mat
- c6 2007 18/19" corvette wheels oem
- FS: line lock, stock LT1 intake, O2 sensor
- C5 wheels
- 241 heads, ls1 crank, tsp cam and lifters
- Aeroforce Interceptor
- ttop hatch sub box enclosure with subs
- Mcleod RXT Twin Disk Clutch With Billet Steel Flywheel, Brand New In The Box!!
- Main PCM Plugs C1/C2 and Random Harness plugs
- 98 ls1 coils
- KB Racing T6 Stainless Turbo Kit for Sale
- Garrett gt4082 turbo
- Turbosmart EBoost 2 solenoid
- LS2 / T56 Combo, complete, still running, 34K Miles
- Ls1 bare block with caps clean,Hsw nitrous kit microedge
- Trick Flow valve spring kit
- 2005 5.3 engine harness, pcm, intake
- Corvette Z06 Stock Air Intake
- LS9 cam, ls3 valley cover, ls6 springs, GTO shifter
- FS: Complete LS6 Engine
- GM Ls7 Corvette Z06 Cylinder heads.
- Corvette FRC's, Fan control relays+ Various
- lethal night fury used cam- 231/242; .617/.615; 113
- Custom Billet Specialties Wheels: 20x8.5 and 20x12
- Alpine 1000 watt amp
- powerbond camaro/gto underdrive pulley with belt
- Ls6 243 heads
- ls1 valve spring compressors
- BNIB - Hallman Evolution RX MBC w/ Cockpit controller
- New JGS 50mm BOV
- LS1 lifter trays
- Huge Tuning Kit! HPtuners Pro, Tuning School Learn at Home, Banish books, and more...
- Parting out a red 98 ss m6
- NIB Cxracing T72 turbo
- NEW PAC 1518 .650 lift valve springs
- Eibach Sportline Lowering Springs (98-02) Camaro/Firebird
- FS: Brand New LS7 Water Pump
- FS: LS3 springs, Heat sink coils
- Hypertech for 2000 Camaro Make Offer
- g6x3 cam package
- Hoarder moving sale, ls2's and l92 engines and much more
- LS1 Short Block + extra set Pistons and Rods
- Pioneer AVH-P4400BH with trans am brackets
- 99-02 Racetronix Fuel Pump & Sending Unit W/Hotwire Kit
- 88/89k 02 trans am cluster
- B&M 70266 SuperCooler
- ARP Cylinder Head Bolts
- GM Lifters
- Comp Custom Grind Cam
- C5 a/c compressor only 11,000 miles!!
- Chrome 5 Star C6 Rims for sale
- Midwest Chassis LS Tubular K-member......
- OEM LS exhaust manifolds
- 6.0 stock parts
- BNIB Magnaflow exhaust tips
- LQ9 Truck Intake Manifold Complete
- GM Performance LS carb intake manifold
- F.A.S.T 90MM Throttle Body
- Treadstone single turbo intercooler
- NIB FAST/TB/K-Member
- Motive 3.70 ring & pinion out of my MWC 9" barely used, priced to move!
- BS3 with DAI option
- Bbk tb, autometer cobalt gauge
- Auto center console
- 98 LS1 Long Block With Harness & Truck Accessories NC
- Taillamps
- Madman Manual Rack
- 200 amp alternator for 98-02 F-body/97-05 vette (Model: CS130D) CHEAP!!!
- PA Racing Kmemeber
- 19'/ 8.5 - Ruff Racing Wheels/Tires (NT555)
- 5.3 engine,4l60e,wiring and computer
- all random interior parts for 4th gens mostly 94 parts ILLINOIS
- 93-94 distributor works opti spark ILLINOIS $30.00
- 94 z28 tires for sale ILLINOIS $80.00
- Camaro ss partout
- 94 lt1 intake polished rails ILLINOIS 35.00
- FS: Misc New & takeoff LS Parts, Good stuff inside with PICS!
- 93-97 lt1 cylinder heads ILLINOIS $100.00
- Delphi stock PCM
- Lsx Heads Lt1 Block & Accesories
- FS: Vigilante 3000 Blower Stall for 4L60 Trans - Price Reduced $450 OBO
- Camaro Ebony Sail Panels
- FS: Misc '06+ Impala SS parts: Diablo,Tinted Tails, Engine Cover, radio adapter, etc.
- 241 Heads, 99+ PCM, 60lb inj, torque arm and more
- WTS/WTT: Brand New Huron Speed no AC Single Turbo Kit
- Turbowerx oil scavenge pump (turbo)
- Mufflex exhaust, Lakewood control arms and stock Camaro hood and spoiler
- TSP 7.375" pushrods - NEW
- Pontiac WS6 Wheels & Tires, Mint Condition, 10,300 Miles
- For sale: go fast goodies
- Ls1 flywheel f body
- Stock pushrods
- Caspers MAP extension harness
- LS1 f body exhaust manifolds EGR
- 806 heads perimeter bolt heads with valve covers and coil packs
- QTP 3" low profile cut outs
- Oem gto exhaust
- Transmission Cooler Plus Fan - Sold
- 2 New S366 turbos
- misc gto, fbody, 5.3, and 6.0 parts
- Looking to buy 102mm nos plate
- FS: 345 NT05R Drag Radials w/ wheels
- 799 heads
- Siemens Deka 55lb 570cc Injectors (Set of 8) EV1 $255 OBO FS/FT
- bunch of motor parts. comp, harland sharp, texas speed
- Ls6 intake and ported throttle body
- PRC stage 2.5 59cc 5.3 heads
- LS 105amp Alternator OEM Delco
- Umi tunnel mount torque arm w/ DSL. Fbody fans, tex 0Z700
- F/S Ragin Racin LS7 Lethal cam
- Complete G8 GXP Exhaust
- My new FAST 102 (LS7)
- Auto meter boost gauge and air fuel gauge. stock intake bolts
- SOLD! LME Forged 370 For Boost, 0 miles, L92s, PatG Boost Cam
- full nitrous kit (pictures added)
- ProCharger 4in Inlet Conical Air Filter
- Parting 98 Z28
- New TCI Converter th400 or TH350
- Trans am & Camaro signs 35$ shipped
- Thunder Racing 7.2 PR and Guideplates
- LT1 Heads with Valve Springs $150
- BRAND NEW Scorpion 1.7 RR
- BRAND NEW yank 3000 stall
- LS1 stock internal parts
- 44mm Tial Wastegate
- Mint Eboost2 for sale
- Qtp QTEC30 electric cutout**PIC ADDED**
- Eagle 4340 stroker crank,24x,Sold !!!
- 3-pillar pod for T-top f-body
- New cam 226/236
- 799 heads
- NX Nitrous kit with 10lb 20920-10
- Suspension parts
- Brand new complete 799 Heads
- Fic ls2 60# injectors $300 shipped
- f body ls1 k frame with motor mount stands
- 241 Heads (Complete)
- Magnacharger 2.75" keyed pulley, Heat exchanger
- New 226/236 .578/.601 110lsa 106icl
- 18k mile 799 heads
- For Sale: Raptor Shift Light - $60
- C5 Corvette Rims
- 7 ls1 rods w/arp bolts
- Hp tuners pro version w/ Panasonic black ops cf-19 toughbook
- Procharger F1X for sale
- Driver side ebony hatch panel
- 4" hatch speakers (pair)
- WS6 Lower Air Box
- 99 camaro/firebird zr1 gray wheels set of 4
- .675 PRC EHT double spring Kit NEW
- T-Rex Cam
- Innovators West 8 rib stock diameter harmonic balancer
- ls1 comp upgraded rockers
- Sold!!!!Garrett turbo and waste gate
- 18" iForged Aero's with good tires
- Stainless brake cables and battery wire
- TSP 224/230 Cam
- 4th gen stuff
- PRC 215 Heads for sale
- random ls parts
- 05-06 GTO Vararam
- OEM WS6 raised airbox platform/radiator shroud
- OEM speeline WS6 wheels
- 2004 Lq4 Engine
- FS: C5 wheels
- FS: Honeycomb taillights
- Gto parts 04-06
- 4.8/5.3 LS truck parts
- New 3.4" Pulley 10Rib for Procharger - might fit others centrifugal blowers
- MSD Optispark V2
- Procharger F1X new
- LS engine parts and f body parts
- MWC ARB - New
- F/S SLP Factory Dual/Dual Exhaust (Great Condition)
- FS: JSP 98-02 SS Aftermarket spoiler
- Msd timing twister for a ls1
- New forged 383ci LT1
- Comp chromoly pushrods, LQ4/LQ9 intake and oil pan, LS3 valve springs
- FAST 57 lb Injectors
- Nitrous, A/F gauge, ls1 intake
- TSP 228R 114LSA, oil pump, 853 heads, steam vent tube
- C5 corvette partout - 39k miles
- Ls3 /l99 6.2 camaro complete engine with tranny !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- wtb: 1 ls1 piston from an odd cylinder
- Full Exhaust Setup
