View Full Version : Parts Classifieds
- ARP Pro 2000 rod bolts 12pt with 3/8ths Socket and lube
- Ported Fast custom painted 90/90 Setup with 42LBS Injector's and Fuel Rail
- NEW LS Carbon Fiber Valve Covers HOT!
- gmpp l92 carbed intake
- SOLD! NEW 1 7/8 ARH Stainless Headers No Smog HOT!
- FS: 20" Camaro Center Wheel Caps *NEW*
- PRC .650 lift springs BRAND NEW
- Black Z06 Rims (Crome Lip)
- Aeromotive GM LT-1 Fuel Pressure Regulator For Sale
- Lsx parts, etc
- Compstar Rods and FTI Torque Converter - Cheap
- O2 Simulators
- Strange 3.5" chromoly driveshaft
- *SOLD* Burkhart front bumper support w/ Afco radiator, water pump....
- FAST DUAL Wideband Setup w/ RPM Module
- 2 new ac delco 10456222 knock sensors
- LS1 Stock exhaust and Cats
- Vig 3600 stall converter
- FS-Trex
- RX Catch Can
- FS: Assembled LS7 Heads. LS7x TSP PRC
- SLP 1.85 ratio roller rockers
- 42# Injectors, New In Box
- TEA Stage 2.5 LS1/LS6 Heads and YT rockers !!!!Sold!!!!
- Callies Compstar 4.100 Crank
- MTI- G1 for sale
- Accel Superram Plenum and Runners
- spare tires, owners manual, and a few other items
- NX Single nozzle wet kit w/ extras
- FS: New ARP main stud kit
- FAST 57's, AutoMeter Tach, Hoosier Slicks, ProTorque Converter, Wiseco 4.07" Pistons
- 98 trans am part out! ALL MUST GO!
- 317 heads 55k miles
- Black American Torque Thrust Wheels & Tires
- LS2 Valve Springs, Seats, Retainers
- Precision 78mm turbo
- 2010 Camaro LS3 Flywheel, Pressure plate & Clutch
- Stock crossmember w/LCA's & rack & pinion
- Comp Cam 230/230 .561/.561 115LSA
- loud mouth exhaust
- C6 LS2 Corvette alternator SOLD
- WTB: BMR/Strano/UMI Suspension
- oem hurst shifter n knob
- Textraila Twin Disk Clutch
- Hooker Tips, LS3 Valvesprings, Billet Fuel rails...NEED GONE!
- LT1 355 Shortblock - SRP Pistons, SCAT Rods etc
- Moroso LS Engine Swap Oil Pan 20140
- C6 corvette 5 spoke polished rims
- New Mahle 4.06" pistons, Forged H beam rods, L92 bare heads, comp lifters, bearings
- LS2 Ported intake Manifold
- Clutch brake gas pedal assembly (Price Reduced)
- ported 243, 2 408 short blocks
- 243 LS2 Heads with PRC .675 lift springs
- 1982-2002 Camaro Bolt In Tubular Steering Column Kit
- 98-02 FBody Parts FS
- WTB Good used front upper tubular control arms
- UMI Short Shifter Handle
- Subwoofer Box Two Punch P2 12" Subs
- *PICS* Vented Opti Conversion! Fresh Stock heads!
- FS Vig 3600 stall
- camaro parts super list!!!
- D1 Procharger damaged
- FS: Injectors, SFI Pulley and Alternator
- Spohn Mount crossmember for TQ arm
- Killer carb intake setup fogger nitrous 950cfm
- *SOLD*New In Box Racetronix 255 w/hotwire kit for CTS-V
- Brand New 3pc ACT SX 17x8.5!!
- WTS/WTT spoolin performance alternator relocation bracket
- OEM LS2 Intake Manifold
- Complete Tan interior
- brand new poly motor mounts/clam shell for lsx fbody
- C5 Z06 wheels/tires, SLP lid, & Loudmouth 1
- camaro parts bit of everything!
- C5 Fully Built Differential (RKT56) 3:73 gears.
- 2003 5.3l stock
- LT1 stuff for sale
- 04 z06 cam, Pacesetter headers, ORY, Dynomax muffler
- 93-02 firebid parts random
- new GM lt1 clutch master,slave and lines
- FS/FT LS1 parts for lt1 parts
- Nano 3000 Kit FS
- coilovers
- FS: C5 Corvette and LSX parts
- Grant Steering Wheel w/Installation Kit
- driverside truck manifold
- Trick Flow 4130 Chromemoly Heat Treated 8.200" Push Rods $45 shipped !
- Comp Cam Lsr Series 215/223 Duration .604/.610 Lift On 112 LSA
- Magnaflow catback C6 Corvette
- 98-02 TA/Firebird parts
- 243 heads and 799 heads for sale!!!
- Oil pans!!!
- F/s 80mm bbk throttle body
- Sold
- New UMI A Arms
- Take off Rocker arms for sale
- Umi K Member (new)
- LS2 valve cover "covers" for sale
- Textralia Clutch ( updated)
- ST80 1.25a/r turbine housing
- Bogart wheels with tires. 325/50/15 rears
- 3.42 gears 4 chanel
- Mini spool
- NW 90mm throttle body
- 98-02 TransAm instrument cluster
- fs/ft Drag Radials, Sportsman Pro fronts, Summit Star
- C6 Corvette LS2 Fuel Rail Covers - Titanium
- 2010 Corvette LS7 OEM GM Throttle Body - BRAND NEW
- WTB LS6 intake
- LS2 Cam
- Bassani O/R Y-pipe
- Fresh rebuilt LS1 LONGBLOCK in SC
- 78mm Nitrous Outlet plate kit With 15lb Bottle
- Trans Am Cowl hood
- Ported FAST 102
- F/S: GMMG Tips, Tranny Mount, Sway Bar Bshngs, Center cap decals...Pics Inside!
- Katech belt tensioner
- FS Ported 5.3s!
- Sold
- FS: LS1 853, 243 heads, Patriot springs, exhaust manifold
- stock parts for sale
- Stealth Box Panel
- lt1 parts an d 93-02 interior parts
- Mike Norris PVC Billet Catchcan -$75 Shipped
- FS: A&A kit, DP Fuel and Meth kits and extras
- f/s tsp 7.350 pushrods
- New 93-02 Manual Fan Switch
- Cats and Manifolds from 2002 TA
- 93-97 32mm FRONT SWAY BAR
- 2 bar map sensor
- 80mm Polished Holley Throttle Body
- Meziere Water pump WP119s Race
- One day only sale!! TRW Forged Flat top $160 Shipped
- FS NEW Tial 44mm wastegate and ss dump pipe
- NEW LS1 GM oil level sensor switch
- LT1 Procharger D1 Custom Kit
- Mufflex Y-Pipe
- Hooker SuperComp Long tubes 1993-1997 FBody
- Borla CatBack with DMH Cut-Out
- 98-02 Firebird Black Headlight Cover, Driver's side DS
- LS1 Fuel rail and High Flow MAF sensor ends for sale
- 317 Heads Double Springs Milled
- Comp Cams Pushrods for LS1
- OFI Turbo kit and Wolfe 6 point Roll cage FS!
- Nitto street tires and drag radials
- LS2 PCM GTO/Vette
- WTT Bassani Catback
- FS: Hypertech #30025 *SOLD*
- 93-02 fbody slp stainless muffler
- 241 heads $100 obo
- ls6 intake, 317 heads w/dual springs, clutch, and more
- Ls1 Parts for Sale
- turbonetics tc76
- Spohn tubular adjustable trans mounted torque arm for 98-02 fbody
- Gloss Black painted interior trim for C5
- STS Air bridge, push rods, rockers, rotors, etc.
- Red Spohn Solid Motor / Engine Mounts
- LOTs of GOODIES for you 3rd Gen / SBC guys!!! FREE SHIP ON MOST PARTS!!!
- Trans Am / Camaro electric fans
- Alternator and Power Steering Brackets
- Sony Headunit FS
- 2010 camaro mufflers/tips
- 17x9 Zr1's for sale
- Motovative Billet Vented Valley Cover SCRATCH AND DENT SALE
- LS2 243 heads with upgraded springs and pushrods
- FOR SALE: 19" tire, CTS door panels, rear cover, o2 sensors
- Nitrous Kit
- Brand New Proform 750 Race Carb
- Patriot Dual .650 springs
- Diablo Sport Trinity
- 10 bolt T/A girdle FS
- LS6 heads, 243
- NX Bottle Heater + transducer $75 Shipped
- FOR SALE: Kooks 3" High Flow Cats
- Custom LS1-LS6 Sheet Metal Intake
- Front mount Turbo kit
- Polished WS6 Wheels
- Misc Go Fast Lsx parts/L92 P&P Heads
- LS/TH400 4000 stall converter
- FS 4 stock 16"s w/ BFG 255/50/16
- Sold
- sold
- sold
- Parts for sale: 19" tire, CTS door panels, rear cover, o2 sensros
- G8 GT KOOK Ver2 axle back with J-pipes
- Ls1 parts ////////////////////
- d585 Coils $130 Shipped, 317's W/Rockers $160 Shipped
- New PAC 1518 valve springs, Manley pushrods, and LS3/L92 rocker stands
- CNC ported 241 heads w/ LS6 valves/springs
- 07 corvette exhaust perfect condition
- Arp head stud kit used. Powersteering pump etc...
- Ls1 long block and parts
- SBC chevy parts. 73-87 truck headers. random stuff
- SOLD: 772-16 Titanium retainers for 918, 915 Comp
- *sold*
- 98-01 camaro 5 star 16's with tires
- Thunder racing in car valve spring tool
- LS2 timing chain
- Stock lt1 injectors
- 6.5L Turbo Diesel Parts
- 2000 TA WS6 Complete Part out (white)
- KONI SA Rears
- 3800 Torque Converter
- LS1 stock parts
- 241 heads for sale
- Nitrous Outlet 90mm 4bolt plate and Thunder RacingTiming Tuner/nitrous controller
- ***SOLD*** Diablosport Predator - U7198 (UNLOCKED)
- Eibach Sportline rear lowering springs
- NEW UMI 2210 93-97 Torque Arm Relocation - Automatic, stock crossmember
- *Brand new* SLP LM1 Stainless Resonator for sale
- Summit 15 Gallon fuel cell
- Draglites 15x8 15x3.5 with tires NC
- Brand new ac delco 10456222 knock sensors from gmpartsdirect
- T56 built with clutch
- SLP "dynomouth" catback $300 shipped
- Unknown brand 3 hole N2O plate
- BNIB Yella Terra Ultra Lite 1.7:1 rockers
- WORKED AFR 205's
- Brand new spohn solid mm's!!
- LS3 Cam with Katech Timing Chain
- FS: rear SS brake lines for a ABS f body
- LS1/LS6 Head Studs
- brand new A4 "SHITER" and parts
- Accel DFI fuel injection controller for LT1
- 93-02 Camaro To Corvette Brake Conversion Brackets
- Slp LM1 trade for tsp duals or magnaflow
- 550+ Hp 383 Ls1 Fully Built
- Meziere Water Pump wp119
- 5.3 03 silverado accessories
- 4L60E Stock Automatic Transmission 60k miles, works PERFECTLY
- Rockford Fosgate Sub with FBODY Stealth Box
- 00' Camaro z28 parts!
- Holley stealthram Intake w/AFPR and 58mm TB
- Brand New Moser 12 Bolt/3.73/4 Channel/Powdercoated Black
- FS: Two used LS1 Fbody oil pans & one oil pan gasket
- Used C6 Ls2 exhaust manifolds
- BBK 58mm Throttle body
- ford 9'inch 4.56 gears, 241 heads
- T56 Bellhousing
- Fikse Profil 13 w/ BFGoodrich KDW 2
- LQ9 Cam....Low Miles
- 3 LQ4 Cranks, LQ4 & LS2 Rotating Assembly, 317 Heads,..Misc LS stuff
- LS1 stock heads/intake
- LT1 stuff updated
- lq4 pistons and rods
- Gauging interest in Callies crank & Pistions.
- LS2 camshaft and valve train parts for sale
- Cold Fusion 90mm N2O Plate kit
- Edelbrock Bottle Heater
- 60 lb Injectors
