View Full Version : Parts Classifieds
- 90mm Aluminum Billet LS3/LS7 Maf Housing
- LQ9 Long Block Bent Rod
- 2 Stock Rear C5 Rims
- 1 Kumho ECSTA tire: 315 30 18
- FS: NEW CTS-V Heat Exchanger
- pro yank 3400 converter new
- Nitrous, headers, ect..
- Control Arm Relocation Brackets, Bolt-on-CAB002
- 3 inch Stainless Steel Cutout
- Neal Chance TH-350 5200 N/A converter
- Built 5.3 built for boost long or short block
- Borla Rear Section Touring Exhaust W/Quad Round Tips & X Pipe #140129 C6 Corvette
- FTI 3200 Stall Converter 4l60e
- Built 4L65E plus converter etc
- 94-97 LT1 carbon fiber fuel rail covers
- Holley Dominator and much more...
- BTE Top Sportsman Powerglide
- New Wiseco K451x3903
- Hotside w/waste gate
- FS: LS6 Intake
- 5.3l iron shortblock, with custom cam FS
- M6 Crossmember
- 243 Heads Complete & Stock
- ls1 intake, tb and rails/ lowering springs
- cbr performance products 8-rib 8.65" dia crank pulley
- Chrome Firehawk Wheels/Tires Michigan
- Aem driver box
- 799 Heads Complete F/S -SOLD-
- Zex NITROUS BOTTLE HEATER-82045
- 82009 Zex Remote Bottle Valve Opener
- Edelbrock Weld-On Subframe Connectors 5290
- 98-02 camaro firebird trans am drl light control module 10407669
- FS/FT: ST 25mm solid rear sway bar. trade for 21/22/23mm bar or $150 shipped
- Few turbo misc parts for sale.
- 22" Chevy Trailblazer SS replica rims w/ tires and lug kit
- LS6 Intake
- NOS 2 Stage TPS/RPM Window Switch
- LS solid motor mounts
- Ls6 oil pump, ssra
- Granatelli LS1/LS6 MAF Sensor
- Valley pan & valve covers
- 134-6006 ARP rod bolts
- Nitrous & Fuel soleniods
- Ls1 fast fuel rails with crossover kit and gauge
- OEM LS2 injectors
- Pro Systems Pro Series 4150 Carburetor 830CFM
- 2000-2007 Monte Carlo Trailer Hitch
- 2006-2007 Monte Carlo 2006-2009 Impala Aluminum Cold Air Induction Kit
- 6spd lower shifter boot
- f/s ls7 clutch with ls2 flywheel
- Mast LS3 4500 efi intake
- New Billet S480 ETR H.O ---Racecover
- T-56 rebuild parts
- stock phb and lca's '00 Z
- Twin Turbo Kit for Gen 5 Camaro
- For sale: Fuel Injectors and Low Z versafueler boxes
- AFM/DOD components. New take off items
- 421ci sbc AFR235
- 421ci sbc AFR235
- 421ci sbc AFR235
- Koul Tools complete AN assembly kit
- Holly ls7 high ram intake/Dual 4500 TB/Dual Stage Nitrous
- 48lb RaceTronix fuel injectors
- Complete 6 speed change over parts
- Pacesetter Y-Pipe
- Tbss nx express plate kit
- NIB comp push rods. 7.400 $125.00 shipped
- 02 ~50k mile ls1 shortblock
- Direct port super victor 4 solenoid along with 4150 accufab must go quick
- Callies Dragon Slayer crank, Racepak UDX dash, Cam
- LS2 Block
- Holley efi touch screen
- EPS custom Cam
- 02 Trans Am clean up
- Lingenfelter GT2-3 Cam
- Ls7 single plane (((($200))))
- K & n cold air intake 2005-2006 pontiac gto
- Procharger F1-A KIT 2004-2006 Pontiac GTO
- Comp cams dual valve springs .675" lift 26926ts-kit
- HARLAND SHARP ROLLER ROCKERS 1.7 ratio
- FoxBody LS swap exhaust system
- 15x4 jegs sport stars, 2 brand new kirkey race seats SOLD
- sold sold
- 6.0 iron 408
- SS Partout/T56 swap parts - Performance and Stock
- Stock ls1 fans
- B&M trans cooler
- Griffin turbo radiator
- LT1 Firebird HID Conversion
- LS3 Stock Cam, Plug Wires, LS3 Corvette CAI, WS6 Springs
- New race star 15x3.75 wheels
- FS next to new 17x9 zr1 wheels
- Dominant Motorsports GTO Dual Cone Intake
- Lontubes ory pipe cats part out (SOLD)
- Foxbody Mustang LS Conversion Fuel System
- Fs/t 4l80e
- Foxbody Conversion headers
- B&M 700R4 / 4L60E Deep Pan
- nitrous parts, 411 ecm, timing twister, etc
- HP Tuner Pro
- TNT nitrous kit with accessories
- LS6 injectors (28lb) with rails
- New GTO OIl Pan
- Fast Fuel Rails, Fuel lines
- Fast Fuel Rails
- PRC 5.3 stage 2.5 Heads
- Magic Stick 3 Cam
- ARP Head Bolts 134-3610
- LS6 Engine - Rebuilt, completely fresh - LS1
- Nick Williams 102mm Cable Throttle Body
- Fast 102mm Intake ls1,ls2,ls6
- Ebony interior trim & carpet
- built t56 f-body
- NIB PAC 1211x .625 springs
- Pro Comp LS1 1.8 roller rockers NIB
- 93-02 fbody Baer GT+ brake kit fs
- 3.73 gears and install kit and perfect launch diff cover
- Truck,Car manifolds, Shifter, T56 crossmember
- 01 Firebird Trans Am Shifter (stock)
- Truck coil packs
- 102 godspeed tb
- Fidanza 12.75lb Flywheel
- WTT racestar darkstars 15x3.75 w/ new 165/80 tires for a 17x7 darkstar w/tires.
- LS7 Cylinder Heads 40k miles, NW 102 DBW TB
- Stock Fuel Rail and Injectors
- Fbody alternator, starter, throttle body,water pump
- Ls1 coils
- Zex Nitrous perimeter plate for sale
- UPR LS1 to 4.6 Adapters and solid motor mounts
- Gloss black 6.0 Badge
- PAC 1221X NEW Duel Valve Spring and Ti R416 retainers NEW
- tial 44mm wastegate
- Mufflex 3.5" Dual Outlet w/Spintech and QTP 3.5" elec cutout
- Sold
- Cam and springs fs or trade
- C5 Corvette Reprodution Deep Dish Wheels For Sale!!
- FS: fresh forged LS6 (disassembled) boost ready
- Looking for a A1000 fuel pump
- WTT/WTS HSW 90mm plate for NX plate
- Aluminum driveshaft
- 3 Channel 10 bolt w/4.11 gear
- Safety pistons hypertec 4.030
- camaro passenger air bag
- On3 76mm turbo - Brand new in box
- lt1 starter
- FS: texas speed 7.350
- FS: 2 OEM 18s, DiabloSport Predator Tuner U7191
- Weld RTS 15x10 Wheels & MT Drag Radials
- COMPLETE L92 HEADS with ROCKERS AND COMPLETE ly6 intake
- Fully Built TH400
- ARP head bolts 134-3610 NIB
- QA1 "R" shocks/springs (275)
- Comp Cams Trunion upgrade NIB
- Air to water intercooler heat exchanger Supercharger Pulley
- LS1/LS6 ARP Hex Head Stud kit for sale $150.00
- New Diamond Racing Part number D802TS Piston set for Sale***SOLD***
- Procharger F2 for sale. Polished, reverse rotaton
- 4l60 to 4l80e tuned by frost/pcm4less harness
- Mighty Demon 650 Carburetor + accessories SOLD!
- FS: 347 LS Built Boost Longblock
- Stock 2001 Camaro SS parts.
- l92 carb vic jr intake
- LSx Swap Harness, New!
- 01 Trans Am going back stock. TT2s,Monster triple clutch,P1SC,cam,crankshaft,CBR
- LS valley cover with knock sensor holes deleted
- Intake, fuel system. carb, f body manifolds
- LS3 Block, K1 Tech 4" crank, Weiand Air ram, and more LS parts
- Parts clean out
- Built 4L80E (1300hp capable unit using all Jake's parts)
- Custom 3" Magnaflow duals
- Stagg Shocks and Struts for 93-02 fbody Brand New
- LS7 single plane for trade
- 1" billet valve cover spacers
- Texas Speed Torqer V3
- Lloyd Elliott ported GM LT4 heads and GM LT4 intake
- Johnson Roller Lifters
- McLeod Steel Flywheel
- FS- LS6 Intake Manifold
- F-body camaro firebird parking brake cables
- ISO; 98 m6 computer and wiring harness
- PAC 1518 .650 lift springs
- ls2 intake w/rails & injectors, complete unmolested uncut 2000 ls1 f body harness
- LS1 241 Heads {bare} 100 Shipped!!
- New MWC sub frame connectors
- FS: (2) Chrome 17X9.5 ZR1 OEM Wheels
- FS/FT 26/11.50/17 et streets on stock gto wheels
- Pre-built megasquirt 2 setup ***SOLD***
- MWC 9in
- 98-02 Trans Am Fog lights
- 2001 Camaro Radio and amp moonsoon
- lq9 PRICE REDUCE Longblock Low miles bad headgasket
- Muscle Car Pan
- Two Rick's gas tanks with twin internal pumps.
- Moroso electric water pump new $300
- parting out 98 Formula shell cheap
- FS-GTO rear bumper valance/diffuser or trade for performance parts
- SLP Loudmouth 1 Bullet Muffler, Polished C6 wheels, and 806 heads
- MT ET Drag Radials
- Jake's D3 Trans-brake / Valve Body (4L80E)
- Fast 102 cathedral (vengeance painted)
- Complete LS1 Engine/Trans/Drive shaft/PSI Harness/Computer
- Harland Sharp Roller Rockers
- f/s 85mm maf
- wiseco forged 454lsx piston set with rings pins and coated skirts
- FS: Spohn LS1 solid motor mounts - black
- FS: 1998 Z28 complete dropout
- Built 4L60E, PST 9" DS, stock alum ds, LT headers
- Viper t-56 ***fresh***
- Oil pan and pickup
- Low mile LS1 front hubs and LT1 rear calipers PRICE DROP!
- L92 Intake, Injectors and fuel rails
- Mustang ls1 swap header
- LSX Parts
- LS1 w/ 105k
- SIEMENS DEKA Fuel Injector 107962 60lb EV1 Compact
- Nitrous kit, MS3, forged pistons, 241s, Racetronix pump kit
- 04 GTO LS1 & 4L65e pullout 453 RWHP cam stall 20k miles!
- LPE Launch Controller/2-Step
- 99+ Racetronix hotwire kit
- LS1 with 243s and Cam FS!!! Look inside for all details!!!
- FS - Aluminum 6.0 Longblock
- 85mm Typhoon intake, fuel rails, Throttle body, and injectors
- GM 2 bar map sensor
- TSP 7.450 Pushrods
- Ls1 engine components
- GMPP Trans Controller 19212657
- FAST 92mm big mouth "lt" tb
- 98 TransAm exterior and interior parts F/S
- Charcoal WS6 Seats
- 4th gen OEM SS Hood and Spoiler - black
- nitrous bottle heater
- ARP Head Studs for Warhawk LS7X-NEW
- 232 240 .595 .608 115 LSA Cam $240 shipped
- Clearance Sale
- LME 402 and Rossler RMVB TH400
- F/S Truck Harness, Pedal, Tac, TB, and ECM
- Custom LT1 Cam
- HRI Sale of the week!
- (4) C6 Grand Sport front wheels w/Hankook C91s
- 18" Forgestar Cf5's
- Aeromotive A1000 Fuel pump
- UMI suspension parts
- Standalone, Bottle Heater, Spray Bar
- aeromotive a1000 pump
- NIB Tick F-Body Master Cylinder
- FS/WTT: Huron Speed Alternator relocation kit
- Comp Cams lifters 850-16 NIB
- Nib del west ls3 titanium intakes/exh valves
- Wiseco Chromoly wrist pins S643
- LS1 Headers
