View Full Version : Parts Classifieds
- psi beehives/tsp pushrods
- Lingenfelter GT9 Cam
- Holeshot Holestar's with Tires, Lugs, and Spacers
- FS: F body engine acces, aluminum shaft
- F-Body Part Out, Exterior and Interior
- MBA billet aluminum polished door sills Fbody
- 3 channel 10 bolt 3.42 80K miles $275 OBO.
- Vic Jr. ls3/l92 intake, Precision elbow, Accufab 90mm TB
- PW66 wastegate
- Pair (2) CCW Classics 18x10.5 $600!!
- Racetronix 42lb injectors
- FS: Thunder Racing Anodized MAF Ends
- 2 Custom Comp cams, 4.160 bore .40 cometic gaskets.
- Billet Atomizers 225lbs
- 2005 GTO engine wire harness and Fuse box
- aeromotive a1000 regulator with 6an fittings
- 2000 Camaro SS Engine Harness 4L60E Transmission
- Methanol controller, Oil catch can, IAT sensor
- LS Parts Cleanout Sale
- SOLD!!! Comp Cam .617/.624 113 LSA PRICE DROP*
- kn fipk with brand new mass air
- Ls1/t56 harness & computer and more
- Tick remote bleeder
- 6spd B&M shifter
- Brand New GM LSA Heads $600 pair
- Fast LSX RT 102 gen 3 intake cathedral port NEW
- Bunch of parts for sale
- Hp tuners standard with 8 credits
- BNIB Ls1 Bmr alternator bracket 93-02 fbody
- Wtb 1998 Camaro/ Trans am ls1 computer
- *ORIGINAL* Brian Tooley SLR lifters
- Siemens Deka 3145 72lb Low Impedence trade for High Imp.
- HPE 4" electric cutout
- PTC Th400 to LS 8" 5000 Stall Converter, TCI Flex Plate Never Run
- Swap harness, driver box, injectors
- 4th LS1 A4 Engine Harness
- RPM Level 5 4L65e
- 98-02 Camaro Hood
- 07 5.3 HO 325 hp 2300 miles and 4l65e trans
- 04 GTO stock parts
- 98-02 headlights
- nos proshot fogger kit
- WS6 Airlid, SOTL catback & other exhaust.
- Built 4l60e fbody swap
- LS2 58x Harness from TBSS standalone setup
- 42lb injectors for sale
- 243 heads w/ new btr springs
- fbody American racing lt headers and y-pipe high flow cats slp cold air kit
- btr .660 kit steel retainers
- Tick Polluter cam/ 40lb injectors
- Magnafuel 4303 Pump, 7008 Filter and Fittings
- Crane fireball hi-6r ignition
- comp cam 225 shipped
- Brand new Race solutions complete 4th gen wiring harness
- Black Weld V series
- Ebony trans am seats full set
- Turbo/Stroker 93 Trans Am FULL CAR PART OUT
- NIB Holley Billet 12-125 fuel pump
- CME valance with tips
- Modded LS1 Great Condition + Fueled Racing S13 Swap Kit
- Taylor Spark Plug Wires for GTO
- Speed Eng Headers
- Keyed LT1 Hub
- 35th ss wheels
- Vortech V1 S with 60lb siemen deka injectors
- Luk stock replacement clutch/Pressure plate $75.00 Shipped
- Stock LS1 Rockers & Pedestals
- NEW AEM 320LPH Fuel Pump
- Sold- Brand New Magnusson TVS2300 Install Kit - LS2
- New BMR LS1 Turbo K-Member/New Prothane Motor Mounts
- PT7675 turbo >2000 miles SOLD
- WCCH L92 (823) Heads
- WTS/WTT Dark Stars
- FS: LSA/LS9 Injectors 52.5lb/hr@58 PSI
- LS3 Crate Motor Take Off Parts
- Parting 98 firebird
- Demod sale
- FS: 2007 Sturn Sky redline complete engine and transmission SOCAL
- 82-02 Fbody KYB GR2 Twin-Tube Shocks (Rear)
- KUP Steam/vapor/vent Kit. Canton Expansion tank
- Misc parts
- Burkhart 4 Channel ABS DELETE block
- sold
- 4L80E swap harness
- Yella Terra Platinum YT6640 & YT5123 spacers SOLD
- Heat sink coils, Taylor plug wires
- LS6 Build Partout
- Mcleod RXT/ RAM flywheel
- Fully Built TH400/ Circle D converter/ TCI Flexplate
- HKE LS3 429 ci Stroker Shortblock
- F-Body CARBON FIBER Targa Top
- LS3 Rocker arms excellent condition Sold
- trans am camaro random stuff
- Siemens 60lb Fuel Injectors
- wheels for sale
- 98-02 Camaro Factory Ground Effects
- 24" o2 extensions
- ecm and harness
- ls7 titanium rods
- Bump stops, control arm bushings, 160* thermostat
- Tick Custom Cam for stroker
- LS1 Magnaflow 15684 Cat Back
- NEW (LS1) Hooker Long Tube Headers
- Comp cams cam phaser 5460
- NEW LS1 Hooker Headers Y Pipe
- Gm motor mounts
- Fs: Ls3 valley cover
- Delphi maf sensor p/n 25168491
- 2 sets head gaskets p/n- 12610046 gm gaskets
- FS: LS6 INTAKE MANIFOLD - complete
- AEM air fuel ratio gauge with sensor and plug
- Devils Own stage 2/MM Catch can/Map Sensor
- LSX-Ford-emblem-sticker-Mustang-Fox-LSX
- 85 mm MAF w/adapter
- New Aquamist HFS-3 complete kit for f-body
- T56 Super Magnum
- Precision 6266 Gen 2 with DKT/APS Exhaust Housings
- Front Cts V 4 piston brembo calipers
- Alum Strange 9", Accufab tb, billet bottle bracket, goodridge brake lines, and more!
- Lt1 Eibach Prokit
- LS1 Fbody Oil pan
- 30th anniversary white leather seats (Pittsburgh area)
- LS3 shortblock, 823 heads, GTO twin turbo kit, ls3 intake manifold, PI converter
- Fbody 4L60e
- NEW LSX LS1 LS2 LS6 parts - intake,wires,water pump,exhaust
- NIB EPS Cam
- Professional Products 85mm intake an tb
- Morose oil pan for LS Camaro
- Turn Signal Housings - PERFECT Condition
- C6 Crank Dampers - very low miles
- 821 Heads - Like new
- FS: Vengeance Racing VRX5 Cam
- 2 brand new custom cut comp cams
- HPP3 for sale
- Stock Chrome Rims
- LSA 09 CTS-V heads $750
- pistons, rings, and rods from 09 CTS-V (LSA)
- comp shaft rockers pn 1500 ls1
- Xr1
- LS2 injectors & fuel rail - F-body accessories
- ls1 lid, 1 gallon fuel cell (NEVER USED)
- WTT 15" RTS Skinnies for 17" Skinnies
- Ccw drag pack off c5
- 4.100 Manley Crank
- SLP Lid, 85mm MAF, SS Mandrel Bends, Ebony leather seats, Brakes, ABS, and more...
- Firebird/Trans Am Vent Gauge pod things
- Fast Toys 104mm air lid and Fast Toys JAAM Ram air kit
- Racetronix lucas 42lb injectors
- 10x1.25mm #6 Beadlock splice fitting
- Sold
- BNIB Comp Cam
- ATI Superdamper-Y bodies
- Fs 30# Ev1 Accel yellow top injectors for ls1/6
- Mast LS7 4500 EFI Intake with Siemens 60lb Injectors and Fuel Rails
- *Updated 07/10/15* Garage Cleanout
- Automotive A1000 fuel pump
- FS:Stock 00' z28 wheels with tires
- LS6 Intake, CBM truck coil relocators
- 160 thermostat
- Misc. Parts for sale, intake, Fbody AC parts, etc.
- 4l80 Circle D Multi Disc Converter
- 99 convertible camaro ls1/auto part out
- GZ vacuum pump kit
- ZR1 Wheels with Nitto Drag Radials, 17X11 & 315/35r17
- FS: FAST 46 lb injectors ls2
- FS just about new Katech LS1/LS6 Billet Belt tensioner
- 98-02 A4 swap parts
- MSD 2 step, Edelbrock Waterpump, 8 second blower cam
- procharger F1A intercooled univ kit
- stock 2001 6.0l truck parts
- 2007 LY6 iron block
- L76 6.0L long block takeout w/mods
- Holley LS1 fuel rails with fittings
- ls1/6 fuel rails and 2 bar map sensor
- Used Crane Cam for LS Motor Specs in Pic!!!
- LS6/317 top end- LS Parts
- 2004 lq4/4l80e Complete dropout
- Fuel Pump FPA-002
- Motive 4.10 Gear GM 7.5 & 7.625
- LS7 with WCCH Heads in KY
- 2004 gto oil dipstick and tube
- 2004 GTO Pedals
- BMR 4l80e t/a crossmember & adj torque arm
- Twin Turbo system
- Granatelli LS1/LS6/LT1 Spark Plug wires with heat shields
- 3" IC piping with BOV flange
- custom heat sink truck coil brackets
- FS: LS6 Intake, Fuel rails and Polished stock TB
- 4th gen glove box gauge pod
- Doug Thorley Truck Shorty headers 309C
- Cam ls1 block an parts
- Almost new ET Streets 315/35/17 with 17x11 Zr1 wheels
- lt1 complete ac system and crane ignition
- ---Comp Cam for sale--- SOLD
- 243s for sale
- Wiseco Wrist Pins .927 BNIB
- LS6 intake, fuel injectors, and fuel rail
- FS: Built T56 swap kit (Tick MC & Monster clutch)
- fs 241 heads with patriot gold dual springs
- LS6 Intake/Ported TB/Injectors/Rails
- Foxbody ls1 turbo kit
- LS1 swap garage cleanout
- 4l80e Billet Converter, Shifter,
- ARH 1 7/8 Race Headers, Meziere Race Electric Water Pump
- Gt45 80mm turbo, Huron dp, timing cover
- Prochager 6 rib pulleys and crank pulley, ls1 injectors
- Brand new GM crate LS engines...cheap!
- Brand new 7.425 chromoloy pushrods for sale
- Fast 90, ls2 tb, ls3 injectors, tick sns 3 cam, Ud pulley.etc
- Camshaft and springs
- Aluminum drive shaft
- SBC 350 aftermarket parts
- L92 crate engine take out Pistons pins rings
- 11" Centerforce dual friction clutch/ flywheel
- Ls3 SLP Shaft 1.85 ratio new never ran
- LQ9 6.0 bare block
- FS: fuel rail covers/ls6 intake manifold/ ls1 throttle body
- Hks gt2 60mm wastegate brand new
- Nasty Performance LS3 Valve Covers (New)
- New Brian Tooley Jam Cam
- 2011 Camaro LS3 Parts
- LQ4 Intake, Oil pan
- 6LE center mount & spohn solid tubular motor mounts
- Complete 4.8 - Injectors - Manifolds - Coil Packs
- EV6 Injectors
- Trans Am parts
- FS: LS3 bare head castings (0823), LS3 valves
- FS: LS1/LS2/LS6 Mahle PowerPak Pistons for 402ci (4.005" Bore, 4.000" Stroke)
- FAST 102 LSXr cathedral intake
- FS: LS2 knock sensors & bolts
- Factory Ls7 cam
- LS7 Factory Valve Springs
- Katech 116 cam
- LS7 Oil Pump
- Katech Valve Springs
- Lingenfelter TRG 002
- S475 turbo, trick turbo truck manifold kit
- New piston sets Wiseco/CP pistons
- Super Victor, 4150 Throttle Body, Yella Terra's, Injectors, Push Rods
- (box of 5) WIX 51042 oil filters for LS1/LS6
- Kent Moore J-43145 LS1 Tool Set.
- Trailblazer SS Intake Rail and Injectors
- Spindles
- ms3 camshaft
- wtb crank pin kit
- Hotchkis Trailing Arms
- 2001 Trans am Stock parts
- Brand New Jegs Fuel Filter***SOLD***
- Moser 12 bolt, LCA's, Aerospace Brakes, Short T/A and bracket
- Speedtech Nitrous $350 *Lowered Price*
