View Full Version : Parts Classifieds
- LS Swap for 3rd Gen Fbody
- "1997 ws6 trans am"
- FS: LT1 Magnaflow Catback
- TSP Texas Giant cam F/S
- QA1 98 - 02 FBody front coil over shocks
- sbc parts!!!! garage clean up....
- (2)Weld Pro Stars 15x8 w/ MT Drag Radials $250.00, T56 Hurst Shifter Handle-
- 1998 PCM LS1 automatic
- FS:Nitrous Outlet 78mm Plate kit
- AC compressor of 2008 5.3 Suburban with mount
- F/s: 9.5" TCS 3000
- Passenger airbag and fuel rail
- 95mm revxtrem tb dbw , ls1 ported tb dbc
- WTT: AFR 225 for 215
- 6.0L Truck Exhuast Manifolds Sold
- NOS 05168 LS1 LS6 Nitrous Plate Kit EFI Camaro Corvette Firebird
- lt1 t56, fresh rebuild 5 miles only
- wtb LS6 front cover and rear cover!
- Hurst Shifter/Mud Flaps-new prices
- Turbonetics GTK1000 76mm bb turbo
- want to trade
- ls6 money maker intake with rails and injectors
- fs/ft: ls1 fbody oil pan
- G.I advance induction cnc 243 heads LIKE NEW
- Garage clean out f-body and truck
- 3.905" -25cc dish 6.125 rod Wiseco Forged pistons
- bw s475
- ford 9inch housing, center section, axles
- Fast 65 lbs injectors LS2
- HPTuners VCM Suite Standard w/6 credits
- 408 testing waters
- Speed Inc alternator relocation kit
- t56/9" PST 3.5" aluminum driveshaft
- Ported 241's with ls6 springs
- ls1 intake, 853 heads, and 5.3/4l60e wiring harness/ecu
- LS parts; sensors, clutch, ps pump, a/m gauge, fuel tank, 255 fuel pump
- 4.88 ford 8.8 gears new.
- harlan rpm window switch
- harris speed works no2 controller interface
- Full set of Weld Racing Wheels for sale
- LS and LT1 Blow Out Sale!!!! Low Prices! Updated 5/28/2012
- Hooker, Magnaflow, ZR1's, Nitto, Autometer
- 28# injectors
- FS: Weld Skinnies 15 x 3.5 w/ M/T S/R Radials
- 2001 corvette LS1 complete
- Billet Injectors (MRE 500's)
- Billet Injectors (MRE 235's)
- ARP Main Bolts-SBC/LT1---Fbody D/S Safety Loop
- Walbro fuel pump
- FS: C5 OEM fenders/quarters BLACK new paint! FRC/Z/Vert
- LS1 Parts, Intake, ported/polished/powdered TB, with new sensors, wire Harness, etc
- ***Jesel J2K Mohawk Rocker Arms - 1.7 Ratio***SOLD
- T56 00 Camaro trans $975
- SOLD - LSX Spec 3+ Clutch, PP, Billet Flywheel, Slave, & Arp bolts, only 2k miles
- Truck Manifolds
- 04-06 tein lowering springs
- Kooks stainless steel Y pipe FS
- big cam for sale
- Trans Am fog light in EXCELLECT condition
- FS: ls1/lq9/engine harness standalone+ecu+tb
- LS2 OEM fuel rail
- Sold
- BRAND NEW Ls1 F-body Flowmaster Cat Back Exhaust
- LS6 / LS2 valve sets
- 04 GTO JBA off road mid-pipes
- Corvette Oil Pan
- WTB: 1 silver ss ten spoke wheel
- ewp electric water pump
- OEM Z28 Camaro hood Arctic White
- Stock LS1 cam and 853 heads
- Stock 3:42 from 10 bolt
- 90 mm throttle body ptm
- Kooks 2" headers (coated) Kooks Ypipe
- C5 z06 chrome
- 2002 Trans Am Cluster 70k Miles
- FS: 3.40, 4.25, & 4.38 8 rib procharger pulley
- 5'' tach for sale
- WTB LS2 Timing cover and sensor
- Powerbond 25% UD balancer (Corvette)
- SICKEST FUEL RAILS EVER! CPR Billet
- 98-02 LS1 Hurst Shifter - Stock - M6
- TCI super street fighter 3800 stall, 4l60e
- AC / Heater controls with knobs
- SOLD capers hot wire kit for 99-02 fbody SOLD
- VIG 3600 stall converter for 4l60e 300$
- SOLD!!!!! LS3 AC Delco Plug Wires
- C5 Vette Head Unit, factory "Sub" amps, 3.5" full range speakers
- stock ls2 lifter w/ trays plus more
- Ported Fast 90, SLP Lid etc
- Tick Master Cylinder with Slave Cylinder, McLeod clutch with Lt4 Pressure plate
- Comp Chromoly 7.425 Pushrods
- RARE Catback!!! ATR T-304 PITBULL **PICS / Video**
- Camaro Tail Lights & SS Berger Panel
- American Racing Headers 1 7/8" Stanless Long Tubes with Catted Y - TRADES
- Low miled 01 z06 yellow springs
- Innovate LC-1 / OT-2 Wideband Data Logging Combo BRAND NEW
- 95 Camaro Z28 - Roller or Partout
- Big stuff 3 ls1 dai new in box
- FS: TDP Diamond Stage 3 Clutch kit & master cylinder
- Compstar crank, rods, truck coils, Bullet camshaft, firecore, Power sear bottom
- Smooth Bellow, Clear Corners
- Comp Cam 7.300 Push Rod
- LS1 Gen III 5.3 engine parts for sale
- Futral motorsport F15 cam with PAC racing valve springs .625 lift....
- 2000 Chrome WS6 wheels/Firestone Firehawk Wide Oval Tires
- BNIB PI vigilante sprag converter for PG
- Mickey Thompson ET Streets 26X11.50-16LT
- 17" c5 z06 wheels - A MUST HAVE for Drag Racing a c6 z06
- LS1 Truck Coils complete with Brackets Non Heat Sink
- Fs ls9 injectors and bap
- LT1 Borla Catback Exhaust
- stock shifter and hurst knob
- F15 CAM Futral MotorSport/springs .625
- 2000 z28 ls1/t56 roller
- Z28 hood (Sebring Silver)
- SLP Bump Stop Spacers
- 41 lb injectors
- LS6 Valley Cover, VHP Tuner
- (2) Melling Oil Pumps
- FS: SBC Holley Stealthram with extras
- S10 Traction Bars
- edelbrock 3847 elbow for vic jr
- FS (((Camaro SS Grille)))
- Borla Axleback Mufflers G8 GT
- Comp Rockers, 2 piece timing cover, pa kmember,9 in. Locker and more!
- *****T56 Crossmember and A4 stuff******
- FS: Procharger Pulleys
- hsw 90mm nitrous kit with lots of extras
- Granatelli 85mm MAF
- ls1 water pump, timing covers new 853 heads stock pistons
- Brass Adapter to get oil to turbo, Autometer temp sender, LS1 oil cap
- 4 inch stroke windage tray for ls
- Late LS6 PCM '05 CTSv
- l92 style head 821 casting
- camaro rs rear 3 peice spoiler and rear bumper gfx
- F Body Mac Mid Length Headers NEW Dallas, TX
- msd timing twister ls1/ls6
- ls1 coil brackets with wiring harness
- 2 gm ls1/ls6 head gasket and new gm timing cover gasket
- Pacesetter 1 3/4" Long Tube Headers for sale
- QTP electric cutout
- BBK intake and Throttle body
- DBW pedal, TAC module
- Custom Cam Motion grind
- 6.0 Wiring harness 2002 chevy 2500 0411
- 72lb fuel injectors
- fast intake, AFR heads ect for sale
- Want too trade fast 92 mm intake for 102
- BNIB 228r Cam Package (SOLD!!!)
- MS4 cam
- FS/FT torque thrust m
- Aeromotive A1000 Fuel Pump & 40 Micron filter
- Weiand LS6 Intake Manifold
- Stock injectors off 2000 formula
- SOLD: SLP LM Resonator
- M/T ET Drag Radials 275/40/17
- (2) 2002 Camaro SS rims with drag radials
- FAST LS2 90mm throttle body for sale
- lq9 109k mile 317 heads
- (sold)New 4th Gen Camaro CME complete
- 2002 Camaro Stock Rearend, Low Mile, 3chnl
- (2) 175x12x2.5" Hypercoil coilover springs
- ( sold) New LS1 GM head bolts
- (4)Afco coilover spring adjusters 2.5' ID spring
- TAKE A LOOK, Cleaning out Garage MAKE OFFER, EVERYTHING MUST GO
- sold
- 2002 Camaro Tail lights SOLD
- UMI Adjustable Lower Control Arms
- Complete LS1 & 4L60E Trans dropout
- Comp Ultra Gold 1.72 Rockers - Trade for LS1/LS6 intake
- NEW PICS Magnaflow Catback SS 10 spoke wheels w/ tires
- 1991 Mustang 5.0 part out
- Melling 324S Oip Pump Pickup Tube NIB $40 Shipped
- 02 LQ4 Coil Packs
- turbo kit trade for wheels
- FS-LS7 633rwhp complete longblock
- Sold!!!!!
- 37 lb racetronix injectors
- LS1 Engine and 4L60e Trans - 98 Camaro Drop Out
- LS6 Short Block, intake, oil pump, etc......
- Cheap custom grind FTI Cam Need gone asap
- Looking for converter buying buddy!
- SOLD!!! Kent-Moore J-42386-A
- F/S 1.8 Crane gold roller rockers
- SPARCO Pro 2000 SEATS PAIR!!!!!!
- B&M Transmission Super Cooler
- tial 38mm wastegate
- LS3 LONG BLOCK COMPLETE Intake/TB/Injectors/Rails 14k miles
- Harris speed works bottle and brackets
- Twin Garrett Turbos For Sale CHEAP!!
- Fs: livernous L92 Cnc ported heads *price reduced*
- Old School Weld Prostars
- F/S MSD digital window switch
- 8 Siemens 60lb injectors (LS1 style) & EV6 adapters
- NOS 2001-2002 Chrome SS 10 Spoke Camaro Wheels Rims
- NEW GTO LS1 Oil Pan w/pickup tube
- ls1 block heads new oil pump
- NX Twin EFI Dual Nozzle Nitrous system
- Procharger D1SC Tuner Kit F/S
- TAX SALE, Cam, push rods, springs, nitrous kit, cut outs, and much more
- Spec Steel Billet FlyWheel & Stock Hurst Shifter
- 383 advanced induction/je/crower/Callie's/th400/racetronix/
- Stainless hex head header bolts
- Torque thrust m's with tires
- Textralia exo triple disc clutch
- 1998 10 bolt
- weldon pump/regulator, BRAND NEW!
- Weld RTS Skinnies & DR for sale!!!
- LS1 parts for sale
- Wideband, nitrous pressure, qtp 4 inch opener
- Stock LS1 Throttle Body w/ IAC valve-SOLD!
- Capricorn Nikasil Liners
- ls1 crossovertube
- FS: 2004 Pontiac GTO Part-out
- Full set of Prostars for Sale with Tires 750
- built 4l60e 650hp, yank sc3000 stall
- LT/LS parts, 2nd gen parts c5 rims...
- Motron #60
- Strange Chromoly DS and Yoke
- used 2000 camaro z28 headlights
- LS3/LS7 to LS2 MAF Harness
- Street slayer pro clutch kit
- Pictures Added! LNC-002 Lingenfelter Adjustable Launch Controller
- LT1 McLeod Street Twin *BILLET*
- WTS WS6 Grill Inserts, Ebony Interior Parts + stock WS6 parts.
- Comp Cam 7.350 hardened pushrods
- Pacesetter lts 98-02 Camaro or firebird
- calico rod bearings, dual a pillar
- Ls1 and lq4 parts
- Ls1 fead
- 9 inch Ford cut down to fit 93-02 T/A Firebird Camaro from Moser
- Looking for a fast 90
- stock L92 valves!!!
- FS: Vortech V3 Si-trim Blower
- LT1 1.6rr/Valve Springs
- Black Z06 Wheels and Tires
- Weiand/Lingenfelter LS aluminum intake
- 317 Heads with 102k on them
- LQ4 Machine Bare Blocks/Short Block
- Granatelli and GM Z06 85mm Maf sensors
- 2002 Camaro AC system partout
- 1999 camaro clutch pack
- 98 Z28 part out
- Ford Racing 47 lb/hr EV6 Fuel Injectors - Set of 8
- Red top svo injectors
- Ported ls1 throttle body
- *LIKE NEW* D1SC Polished Procharger kit for LS1 F-body
- 853 heads, hooker headers, ory, slp flowpack, psi valve spring ,ls1 coolant crossover
- Wiseco 4.070 Piston Set
- LS7 Lifters
