View Full Version : Parts Classifieds
- FTP 98mm lid
- lt1 t56
- 98-02 Camaro tail lights for sale.
- Yella Terra 6638 1.7:1 roller rockers BNIB $350 Shipped PRICE DROPPED
- FS: Linelock AC comp, Tick master cylinder line, Stock master, Spare, Valvetrain etc
- BMR Strut tower brace, red
- LS 5.3L Sleeved 427ci Forged Motor Complete or Short Block
- LSX Beck Intake Sheetmetal
- LS1 Trickflow 235cc Heads CNC
- Edelbrock Victor Jr. LS Carb intke
- 1984 S10 drag Race Part out
- AI 243 CNC heads, dual springs, comp trunion
- Lug Nuts and Caps, GTO FRC, PS Bracket, Much more!! NO REASONABLE OFFER REFUSED!!
- NIB 4th Gen Wilwood Brake Kits
- ls6 intake
- ls1 cam and clutch
- Turbo Kit (PTK knock-off)
- covercraft car cover, stock tb
- Aftermarket 3.5" 1350 Aluminum Drive Shaft
- PP Typhoon Intake Manifold
- Techna-Fit Stainless Brake Lines Without ASR/TCS
- 00-06 gm truck hypertec programmer 4.8 5.3 6.0 8.1
- High Impedance Bosch 160# SOLD
- LT1 T56 Bellhousing and Clutch Fork
- LS1, LQ6/9 front drive set up
- HSW 92MM plate
- F/S ARP Rod Bolts, Like New
- LS 5.3 6.0 PARTS misc engine parts
- F/S 1997-2004 ARP Head Studs
- comp 918 springs/ 7.400 hi-temp push rods
- vic jr efi w/ sheet metal elbow
- hsw 78mm plate nitrous
- umi body mount torque arm
- CIRCLE D 278MM 3200 Stall HP LS Converter FOR SALE
- LT1 CC306 Cam with 114 LSA $180 shipped
- GTO Gauge cluster & BCM
- Holley 750 double pumper, holley 750 vacuum secondaries, holley 600 cfm
- Truck intake and throttle body fuel rails and injectors, also oil pan!
- PRICE DROP!!!! Yukon 4.56 gears for 9 inch rear end 160 SHIPPED
- Stand alone fuel system, low pressure
- Race ported Vic Jr and 90mm Fab elbow.
- Stock ls1 lid
- 1 ls6 piston/rod combo
- TSP ms3 cam
- Yellow zo6 valve springs
- Stock 241 Ls1 heads
- stock LS1 heads
- T-Top shades
- SLP Camaro SS floor mats
- Nitrous parts, gauges,dirty dingo swap plates, 3rd/4th gen misc.
- FS: Yella Terra Ultralite 1.7 rockers
- Pro_Matic shifter ++
- 99-04 corvettes fuel rail covers(blk/red)
- LS6 Intake, satin silver, all new gaskets
- T56 F-Body Transmission Cross Member
- stock A/C parts FS - make an offer
- Rear quarters for C5 Corvette (FRC/Z only)
- Sold Aeromotive A1000 Sold
- Turbo set-up parts
- Corbeau Seat for sale like new, see pics
- 1978-1981 G-Body LS engine swap mount kit 107-0018-60
- MOOG Ball joints, Tie rods, brand new alternator, 02 sensors, scanner, etc
- FS: 12 bolt 4.56 gears & Strange spool
- Fresh 468 big block chevrolet ! ! ! !
- LS1 Motor/Trans with GOODIES
- Diret port kit with stand alone and controller
- need any gm big block 8100 8.1L parts
- Trailblazer ss intake
- tremec t56 transmission 13-86-020
- wipers parts, wipers, arms, trans, mount everything
- valvetrain parts, turn signals, short stick
- FS/FT: Interior part out and other random items
- Fel-Pro MS 98016 T
- WS6 Lower airbox 4 Sale
- l92 accesories 6l80
- Megasquirt, EFI stuff, turbo stuff for sale..LOOK!!
- 2ea 0411 PCMs
- (((STS Meth Race Pump)))
- *SOLD*Fresh .010/.010 ground & polished 4.8L crank.
- FS - Trick flow pushrods 7.45" 0.080 wall
- Kooks 1-7/8" x 3" Race Headers | Kooks Catted 3" Y-Pipe With Flowmaster Merge - SOLD!
- Black C4 ZR1 Replicas 17x11
- Energy Suspension 3.1108G trans mount
- 224/240 .629" .620" 112 LSA Cam
- HP Tuners MPVI Pro Interface - extra credits
- lq4 wiring harness's and pcm and misc
- **sold**
- 10 bolt alum rear end cover with girdle
- TSP Texas Giant Camshaft
- Texas Speed Magic Stick 4 239/242 .649"/.609"
- Stock LS3 short block
- Slp double roller timing set.
- Black trans am air bag
- Random parts 241's,lt1 t56 parts...etc.
- 2005-2007 LS2 LS7 Throttlebody Drive by Wire
- Lingenfelter 100mm MAF
- fbody accessories
- FS:Corvette Mcleod Clutch,Zr1 wheels, PRT exhaust etc
- LS6 coolant crossover/plugs SOLD
- trans am/ camaro sub enclosure, Massive audio subs
- UMI Drive Shaft Safety Loop
- 402ci or bigger stroker cam 251 dur
- RPM 2800 Stall
- Lt1 t56 build part out
- 799 heads
- LS1 goodies. nib oil pan, hooker lt, water pump, maf
- Varrstoen Wheels 5x120
- SLP Lt1 Intake
- Dynomax muffler
- C6 Z06 Front Brake setup
- C5 Procharger P1SC1 kit for sale
- C5 Z06 rims and tires
- Milled 241 heads
- ls1 powerbond pulley,new in box
- FS: ID850's
- LT1 T56 Bellhousing, Mid Plate, Input Shaft
- Aerospace brakes
- ls6 intake,t/b,injectors,rails
- 35 Spline Moser Axles & Spool for 12 bolts
- L92 823 Heads 26918 Spiings Titanium Retainers Seats Seals LS3 Intake 227/231 Cam
- Ported LS1 heads 853
- P1sc for sale or trade
- New 3.5" DMH cutout
- FS: OEM 19" G8 GT Wheels W/O Tires
- 1999 Z28 Part Out
- looking for chevelle ls swap headers
- brand new pat g cam
- Griffin Radiator (typical turbo radiator)
- 8.5" posi gm 10 bolt
- 410 stroker short block
- Precision 7675 Turbo .96 a/r BRAND NEW
- Forged Mahle Pistons
- Garage Sale: LS6 Clutch , vacuum canister.. Lots of STUFF! LOOK!!!!!
- Twin fuel pumps/bucket from CTS V
- F/S: 48 lb/hr injectors at 43.5 psi with EV1 connector and 8.5/8.6 3.73 gears
- Clarion NX501 7-Inch Multimedia Control Station
- Custom 12" Subwoofer Box for 93-02 Camaro/Firebird
- Kooks Catted 05/06 GTO Mid Pipes with DMH Electric Low Profile Cutouts
- Complete LS6 intake/TB SOLD
- '01 F-body LS1/A4 harness and PCM
- Mint red Z06 fuel rail covers
- stock throttle body
- New lower balljoint/inner tierod/upper balljoint
- Complete Aeromotive A1000 system Check it out!
- Spec Super twin disc
- slp headers
- Strano Upper Control Arm Offset Bushings
- C6 c5 Corvette chassis LS3 drivetrain
- 317s, Fresh from the machine shop
- fs or trade LT1 trans am TAILS
- FS: LS2portworks ported TBSS Intake manifold
- LS engine swap temperature sender for old GM cars/ U14 gauges
- LQ9 GM Gen III Truck Ported Throttle Body, Fuel Rails and injectors
- WTS Stock & Aftermarket Parts(Lugs, Spec Clutch, Flywheel, Springs, Rods etc)
- 2000 Trans AM Auto ECU
- 102 mm nick williams throttle body
- 440 LSx rotating assembly Wiseco forged & Scat H-beam
- 2004 LQ4 Engine
- 20" Eagle alloy rims/tires
- GM OEM 16" Z28 wheels 245/50/16 Goodyear Eagle F1's
- fti 4000 stall for 4l60e and 4l65e must go
- WS6 Lower Air box and Whisper Lid
- LS7 specific rocker arm bolts
- lots of c5 parts in NY. wheel, tires, K&N, etc
- Forrester Racing Billet Aluminum Tensioner
- Truck manifolds, non-EGR
- ls3 swapped c5 full part out back to stock
- LS1 power steering pump, lines, bracket and bolts
- Hsw 78mm plate kit brand new
- beginner tuning the right way
- Truck Coils
- T6 Flanges, bends etc
- Monsoon Radio, and 12 disc CD changer
- Sold please delete
- New PT-88 0-miles and never mounted.
- Camaro SS Grill
- flowmatched Bosch SVO Green Top 42lb injectors
- Max flow ss mufflers, OEM Black Wrinkle Valve Covers, 12200411, 25168491 MAF, 100mm
- Brand new LS3 heads complete and used ls3 intake
- S60 Detroit locker Carrier with ABS ring
- 99-04 Hypertech (vette/fbody) + 2.5" Magnaflow rectangle tips
- Madman Wheelie Bars
- F/S 2003 C5 Corvette Getrag 3.15 rear diff 3 rib case
- 80lb. Deka/Siemens Injectors, Solid Tensioner, & Billet Fuel Rails For Sale!!
- 99 trans am part out in ohio NO MOTOR/TRANS
- Kooks headers and mid pipe w/cutouts GTO
- CNC Brake Clutch Levers for CBR1000rr & CB1000r
- Nitrous outlet plate
- 17 x 4.5 Weld Racing RTS
- rocker arms with trunion kit installed
- 98-02 brand new pacesetter y pipe
- LS1 Short block
- LS parts for sale
- FS: 05-06 Borla Catback w/5in tips
- ls1 ls2 parts
- lsx G-Body turbo hotside T4
- T76 Turbo(Chinese)
- Micro squirt 8ft harness
- RPM Level 4 T56
- ls2 parts and gto and gto spare
- Autometer Gauges
- Manley Stock size Ls1 intake Valves 2.08
- Lt1/ls1 parts power steering pump, accessory bracket, washer tank
- Custom 3" Stainless Turbo exhaust Made off Huron Kit
- Pontiac GTO parts for sale!!!
- Racetronix LT1 Fuel Pump Power Harness
- LS6 intake and ported throttle body
- Bosch 80lb injectors
- LS1 & 5.3 injectors
- LS6 Manifold Painted Gloss Black
- Warhawk ls, ETP LS7 Warhawk heads, Callies Magnum 4" crank
- FS: Comp Cam
- Comp Cams LS XER281HR 232/234 .595/.598 112LSA
- jba catless mids for 05-06 gto SOLD
- Bunch of misc. SBC/BBC parts,carb, springs, distributor
- 4.065" JE pistons and pins on LS3 rods with ARP bolts
- Nitrous Outlet 78mm plate kit NEW SAVE $$$
- FAST 102 for Cathedral port
- ls1 modded engine for sale/or maybe part out
- FTI 9" Nitrous/Nasty N/A converter!!!
- Trans am part out
- ARP Studs main & head, Pushrods, Cometic, Corvette FRC's, Connecting Rods
- 2003-08 350z Stereo CD player
- Full tan leather f body interior for sale or trade for ebony leather
- FS TSP 100mm maf, zo6 maf and ft 98mm lid
- bbk LT1 shortie headers
- Street/ strip TH350 transmission
- LS6 Intake SOLD
- slp springs
- New Derale 13261 transmission cooler
- Parting out complete 04 CTS-V
- Lots of parts for sale!!! **Price Drop**
- 275/40/17 Eagle F1 GS Tires FS
- BMR Suspension parts,Stall converter
- f/s stock coil packs,stock cats,stock fuel rails,procharger idler
- Brian toodlley double springs and fast 46 lbs injectors
- COMP .675 Dual Spring Kit
- Parting out 2006 gto ........ will ship
- LS7 Heads / Cam / exhaust
- Some Stock & Performance Parts
- LS2 GTO Alternator (Need to replace clip)
- LS1 auto belt tension adjuster, Perimiter bolt valve covers
- 1500 series silverado clutch pedal conversion parts - 200$ obo shipped to main 48
- brand new autometer cobalt boost gauge
- hotchkis stb for ls1 f body brand new!
- Compstar H-beams brand new
- 2001-2002 Exhuast Manifold
- Lt1 Cast Iron 290
- Edelbrock 7139 Cathedral Port High Rise Manifold Ported/Polished & 3629 Fuel Rails
