View Full Version : Parts Classifieds
- Z-28 Mint Original 16" wheels and tires (restored)
- New .675 lift Comp 926 Springs & Ti Retainers
- 99-02 F-body Engine Harness
- FS: Complete 408, solid roller
- Hoosier slicks 26x9.5-14lt quick time pro drag radials
- Procharger D1 Kit
- firehawk wheels and tires $500
- FS: Innovate LM-2 Wideband #3806
- Fs gm 323 & 342 gear set and lq9 lifters
- Nitrous Express Nitrous bottles (2)
- LS1 Intake
- FS: Built Short Block, 418" iron block solid roller
- LS1 T-56 Built Texas Drivetrain Performance
- 1le springs whole set SOLDDDDDDD
- 5.3 LM7 60k Shortblock
- SOLD ls7 crank $250 (needs work)
- Blank off panels for battery and fuse box relocation 4th gen F-body
- SOLD!! Kent Moore Flywheel Holding Tool J-42386
- Custom bogart bolted r/t
- T-tops
- the giveaway thread
- 98-02 TA Taillights
- SOLD delphi 96# injectors $275
- 5.3 part out
- 7" Lilliput Screen and RCA Cables
- spec 2+ clutch, 2800 miles
- 2000 firehawk part out
- 97-03 Grand Prix GTP full set of gray leather seats
- FS: ECM from 2009 LS3 vette (part # 1262-5455)
- FS: ProCharger 6-rib 4.25" pulley
- 6LE 2.5" stainless CME tips w/lip and 6LE CME rear valance NEW!
- FS: new katech LS9R clutch kit
- Assembled 243 Heads
- Weld ProStars
- 370 ci short block fresh
- Texas Speed 224/228 cam 114 lsa only 1k miles
- 215/231 .630/.617 114 cam F/S or Trade
- FS: stock ls1 flywheel, valve springs and cam
- FS: Mil Spec stainless steel V-band clamps & flanges, 2.5 in.
- BNIB UMI torque arm/ Lower control arms
- LS1 style 60lb injectors.
- LS2 stock exhaust manifolds
- slp lid & filter, 98 heads , 98 racetronix fuel pump, 10lb bottle blanket
- 2009 6.2 Engine and Trans
- Stock LS1 Fbody Radiator
- 90/92 mm hsw brute force nitrous plate
- NOS nitrous bottle
- JGS 40mm wastegate
- F Body Weld Prostars New Mickey Drag Radials NC
- 2 c6 z06 19" chrome wheels TRADE
- 370 Built for boost! $3000 Longblock $4000 Turn key sold
- Eibach Drag Launch Front Springs New
- 4.8 fs
- For Sale FAST LSXR 102 Intake W/Rails L92/LS3
- NX kit, LC-1, 6.0l longblocks, ls3 intake,5.3 aluminum blocks
- Clutch, Nitrous, Suspension and Shift Light
- GA New Ls6 clutch kit with new flywheel 300obo
- 2x Bazooka DVC 6.5" Sail Panel subs. ( SOLD )
- lq4 parts
- LS6 Intake
- Wiring Harnesses and PCM
- Ls3 cam setup (vvt delete)
- Summit Warriors, Nitrous Kit, Stock Cam stuff, 243s. Blah
- LS Front Distributer Drive Conversion Kit
- 1995 Camaro Bose Cd Player + rear sub
- FS: LS1 Shortblock
- 3g turbo setup
- 42lb Bosch fuel inj.
- Blitz SBC-I-D boost controller
- Three Walbro 341s for sale
- Aeromotive Eliminator Fuel Pump
- Bosch 96 lb/hr Injectors Low Impedence
- Fast 102,102TB,LS2rails...
- Precision 86lb/hr Injectors Low Impedence
- TCI 399754 Flexplate. SOLD SOLD SOLD
- FS: LS9 cam, LS3 rockers and stands, LS3 springs
- (2) Bosch 13111 02 sensors
- Parts clean out stock and performance
- Cheap stock parts
- 93-02 F-body AirLift 1000 Drag Bags
- Front Baer Big Brake Kit For 93-02 F-body
- knock sensors and harness, cam sensor, crank sensor
- 2 Wilwood 4 Piston Calipers w/ Pads
- LSX TH350 Swap Minus Trans- All High End Parts
- F/S SVO green top 42LBS injectors.
- CNC ported 243's with ls6 valves
- CNC ported LS3 heads New LS3 valves
- Camaro parts
- Spohn lsx k-member for 82-92 f-body
- 01 WS6 Wheels and new F1 tires
- Nick Williams 102mm TB for your LS2 TB
- LS1 Aluminum Drive shaft
- Bunch ls stuff
- Fs: Ls1 Fbody oil pan baffle.
- 2x 295 50 16 mickey thompson et street II's
- Camaro Z28 16 inch snowflake wheels
- FS: LS3 shortblock (13k miles)
- FS: 416ci rotating assembly (Callies 4" crank, h-beam rods, wiseco pistons)
- Forged LS6 short block
- Stock 2000 injectors full set of eight (8)- low miles
- AUDIO- Stock/aftermarket- Monsoon CD, stock cd changer, kenwood 6.5", etc!!!!
- Ls7 intake
- fs:weld wheels
- Fs: FJO progressive n20 controller
- Vintage Air Compressor Brackets 141803-MCA
- FS: 85mm maf, Fbody K+N, Fbody Lid, LS1 maf ends
- *SOLD* NIB BMR springs
- Katech Valve Covers
- 2005 silverado truck intake and TB
- Strange F-Body 12-bolt, NEW
- 05 GTO Calibers and Rotors F/S
- EFILive w/ extra licenses; laptop
- Autometer fuel pressure gauge
- BRAND NEW IN BOX MTX Amplified Thunderform
- Garage Clean Out - LS1, LT1, Suspension Parts
- TURBOSMART race port 50mm BOV
- Ls1 f body t56 parts
- 5th Gen Camaro paddle shifters
- Lloyd Ultra Mats for 5th Gen Camaro
- 42# Green Top Injectors 5k Miles
- FS/T chrome c6 zo6 rims with tires
- EPS Cam, 241 Heads, Trickflow Pushrods, Misc....
- Gregg Weld/ Racestar Dragstars 15x3.5 for sale
- F/s Ls7 lifters, l92 heads, Muscle car oil pan kit....LOOK!!!!
- Huron Speed "Newsed" Turbo Kit w/ Turbo+WG+BOV
- (2) m&h drag radials 275/50/17
- FS: Used 05-06 GTO MP112 Complete Kit
- Huron Speed Group Purchase Turbo Kit
- Stock 17" gto wheels, fit fbody
- LS2 Intake Manifold
- BMR Upper A-Arms
- 93-02 fbody QA1 front coilovers and springs 275lb
- Complete 03 LQ4 6.0 Long Block
- FS: Bare LS3 heads from vette w/ 13k miles (can include valves/springs loose)
- FS: 2009 Corvette LS7 clutch/pressure plate/flywheel - 13k miles
- RS body kit/ SS hood / subthump /
- 5.3 Engine Harness & Fuel Injectors
- ARP Studs-Patroit Gold Springs-Callies Rods
- Suspension & wheels
- built 4l60e & convertor
- 1998-2002 pontiac firebird parts
- Lots of stuff for sale
- 93-97 camaro a4 custom shift plate insert, camaro shift knob
- T56 front plate- Corvette & t56 service kit
- Camaro and Trans Am radio bezels
- Set of 243 Heads from vette with 16k miles---SOLD---
- sold!! 98 ls1 intakes, throttle body, fuel rail
- 05-06 GTO AEM CAI W/ External IAT Sensor
- FOR SALE---Bogart GT Wheels Only!!
- Fabricated Valve covers
- Nitrous Outlet fuel sysem and solinoids
- Ported LS6 intake and Throttle body
- Ported Ls2 intake by Land Speed
- 449CI LS2 short block
- Mahle Forged pistons NIB Power Pack.
- FRESh LT1, LT4 heads/procharger/ls conversion computer/headers FOR SALE
- VALVETRAIN parts, ls7 lifters, trays, heads, rockers
- Lots of LS1 Parts
- Camaro Berger Panel for sale
- corvette bat wing oil pan
- New Ls9 cam
- Garage clean out lots of good parts
- Brand new INNOVATE MTX-L wideband
- LS Coil packs the Good ones
- driveshaft(th400 to 9)
- FAST LSX Intake (LS7) and 102MM Throttle Body
- Fast ez efi, duel plane, msd
- NGK AFX with NTK Sensor - $225 Shipped
- Fs: shift boot ring
- rear seats TA(black)
- 15x10 Pro Stars 7.5 Backspacing
- Trunion upgraded stock rockers & 2 Harmonic balancers
- WTT: New in box 1.8 roller rockers for LS1 stock cam
- Fast 92mm throttle body 350 Obo
- 3 sets of t top shades and firebird filler tail light panel
- C6 Corvette Rims and Tires
- Drag Wheel set-up rears
- black slp strut tower brace
- MAST cnc intake LS7 4500 and Fast Throttle body
- SLP Smooth Bellow and MAF
- Nick Williams 102mm DBW
- LT1 style T56 w/ spec stage I clutch and hurst short shifter
- looking for real 98-02 OEM SS spoiler
- (Lt1 parts) 3400 stall/B&M trans cooler/4L60E for sale
- ***Patriot Gold .650
- intake bellow
- 30k mile LS1 starter-$75
- C5 Procharger / FAST 90
- ZR1 Wheels and Tires
- LE Custom Solid Roller Cam for a 383/396 LT1****SOLD****
- GI: Trade my ZR1's
- Throttle Plate LS1 & Firebird Airbag (LS Style)
- 4th generation Dash pad. Perfect condition won't ship. Tri-State area
- 2002 Trans Am Ram Air Front End ** Complete Car Sold**
- LS1 3D CAD for SALE!
- Lingenfelter RPM Limiter Timing Retard Launch Controller LNC-2000
- c5 vette wheels with drag radials
- Edelbrock Elbow,Tsp Springs,and more FS!!
- Sold
- Dupont ChromaBase Paint 50$ per QT ANY CODE!
- !!sold!!
- Diamond 4.030 forged Pistons 11519 part number
- 2-275/40r17 bfg kdw 2
- EGR/AIR & o2 Sensors
- B&m 70268 transmission cooler
- Kooks long tubes
- SS Camaro Ebony Leather Seats
- 4th Gen Tonneau Cover w/ Bag for Convertible
- Built th350
- LS9 headgaskets
- lsa zl1 springs/ret/seal/locks/push rods oem 15 miles
- Magnaflow Catback for 1999-2012 Chevy/GM Truck
- Innovate lc-1 wideband
- wtb- junk set of mock up lsx heads
- 219/232 .625/.599 113+4, 212/218 .531/.531 112+4 LS Cam
- Kenwood 4-Channel Amp + Bazooka 6.5" Subs
- Bosch 044 w/-8 an fittings
- Stock ls1 flywheel
- Nitrous part out Lots of good parts!
- RPM c5 Drivetrain
- ls7 heads fully ported brand new
- Gto ls1 drag wheels
- 6LE Splitter and carnads for 98-02 F-body
- Pacesetter Headers long tube headers & Y for LT1, Trick Flow Elbow
- SJM ABS Delete + Line Lock New In Box
- fs:harness,computer and starter
- Single bolt Comp 220/581/112 and PSI 1511 springs
- Garage Clean up *Cheap*
- prc 650. valvesprings,7.4 pushrods ls2 chain,tsp ls6 ported oilpump,all new
- ls1 heads complete
- Huron Speed Special Edition Truck Manifold Turbo Kit
- Turbo kit t6 front of the car mount
- Heads/Rocker/Intake package
- LS1 Intake
- Vfn lightweight hatch SOLD*****SOLD****SOLD***
- Weld RTS wheels with tires for sale or trade
- 3" sonoco vfn hood SOLD ***SOLD****SOLD***SOLD
- Weld wheels 15x10 ( DRAGLITES ) 5.5 BS
- Ls7 forge steel crank 4" SOLD***SOLD****SOLD
- F body 93-02 new 10 point SOLD**SOLD***SOLD**SOLD
- 93-02 Front BMR Lowering Springs and LS1 calipers.
- Selling Moda MD5 18-8 wheels with tires
- Fbody moser 9 inch 35 spline pro race
- fuse relay kit for building stand alone harness pics added
- LS1 T56 for sale
- brand new PRC 227 heads
- For Sale: F-Body Power Steering Pump
- SLP Jounce Spacers...SOLD
- Brand New Fuel Injected Forged Roller 600hp Edelbrock 454 BBC w/ TCI TH400
- BNIB Fast 102 intake and holley rails
