View Full Version : Parts Classifieds
- Camaro SS HOOD FOR SALE!!!!!!!!!!
- GTO engine covers
- Livernois 2C cam new
- *SOLD* Spec 3+ Clutch & Flywheel *SOLD*
- BMR Double Adjustable LCAs - Fbody
- BW S475 / MAF / MAP sensor
- 2010 camaro brembo brakes
- Trans Am / Firebird Front License Plate Covers
- Ported LS1 TB
- FS Edelbrock Vic Jr (LS3/L92) and Pro Systems Blow Thru
- Vacuum canister with hoses
- Monster SS 4L60E/4L65E transmission and stall
- Tick lvl3extreme viper t56
- Vortech V2 supercharger, brackets, water/air
- 03 lq4 6.0 complete pullout minus ecu.
- -8 earl's pre pump filter (and fittings and lines)
- 1998-02 Camaro and trans am interior pieces
- Ceramic Fbody headers $215+ shipping
- 85mm Delphi maf
- TSP ls6 oil pump ***SOLD***
- LG Motorsports G5X2 Cam
- WTB or Trade M6 Console for A4 Console
- NIB Comp Cam Lifters
- Engine Parts
- jasper rebuilt T56 98-02 with 5K miles a/m shifter no hydros
- Fast 92/92 HSW Plate, bottles, heaters w/therm hsw swtch all lines etc
- 5.3 Pre 2004 Long Block, PSI Harness and ECU, Fox Body Hot and Cold Side
- 6.0 truck oil pan, pick up
- FS: 6.2L short block
- BNIB Turbonetics T76 turbo
- LCA double adj spherical rod ends ((SOLD))
- Forged 408 Shortblock/Longblock
- 85mm MAF sensor
- SVO Red Top 30Lb (36Lb) Injectors
- REDUCED! NEW CHROME Torque Thrust II's w tires
- New American Racing Chrome Torque Thrust II's
- LS1/LS6 & LS2 & LS3 crankshafts FS
- LS2 & LS3 intake manifolds!
- **new bmr subframe connector 93-02 f-body
- Aeromotive A1000 Fuel Pump W/ Fittings
- Morel Link Bar lifters
- Bosch fuel pump
- Full Set of Weld Racing Wheels w/ MT tires!
- Intercooler piping stuff FS:
- Comp Cam, NEW
- PAIR of USED Flowmaster 70 Series Big Block II Mufflers 52570
- ls1 intake with stock t/h
- GM Performance L76/L92 EFI Intake
- Spec stage 2+ clutch
- Texas-Speed Chromoly 7.425 (LS1) Pushrods
- 245/45 17 michelin pilot sports
- New BMR Alternator bracket
- AR torque thrust 17x9.5 17x10.5 wtt/wts
- Autometer Pro-Comp Ultra-Lite Oil Pressure Gauge
- Cleaning out the shop Sale!
- LS1 Front & Rear Brakes
- trutrac diff for 9 inch,cheap.
- Ls1 turbo kit camaro trans am turbocharger t70 single front mount z28 ss 5.7 6.0
- fs pa racing th 350 cross member 98- 02 fbody
- $50 off Complete Cam Kits!
- Ceramic F-Body headers $275 shipped
- FIC Bosch 127# Injectors. Brand new.
- FS: Camaro bezel, monsoon stereo and monsoon cd changer.
- B&M superduty shifter cable- bran new
- B&M 3 speed forward gate plate for prostick shifter
- New In Box PST 3.5" Driveshaft!!
- Custom 107 mm halltech cold air intake for f-body w/ mass air
- ls1 t56 bell housing
- LSX Drag Race Motor, new never run (pics added)
- LS1 ROCKER ARMS Jesel KSS-317070 - Jesel Sportsman Series SS Shaft Mount Rockers
- k&n 57 series FIPK Ram Air Cold Air Intake 57-3022-2 ls1 camaro firebird 98-02
- motive 9" 4.30 gear new & eibach front drag springs
- ls1 meziere water pump electric blue drag ls1-ls8 $375
- Pt88 turbo SOLD!!
- Metco Driveshaft Safety Loop 1993-2002 Camaro/Firebird RED
- 2002 WS6 White part out
- Nitrous Outlet (STYLE) F-Body Nitrous NOS Switch Panel
- ls1 throttle body stock
- WTB Bottle heater for a good deal!!
- silverado ss harness re wire/ braided loom
- Cobalt Boost Gauge NIB
- Weld RTS 15x8" Polished Wheels and Hoosier 28x10 Slicks
- 2008 G8 GT Steering Wheel
- Texas speed .675 daul spring kit
- stock ls1 mass air camaro grills
- New FAST fuel rails with lines
- Sold sold sold
- LS1 BBk 80MM throttle body
- Pro street bandit shifter
- Sold!!!
- FAST 102 for LS3
- LS Swap harness w/4l60e & A/C
- WTB: LS9 water pump inlet
- Stock Front Susp. parts
- complete Camaro 1995 lt1 with harness and MSD optispark
- FS/FT- LS3 Money Maker kit with extras
- Ls1 fbody headers
- Ported LSA heads complete, 376 LS3/LSA/LS9 rotating assembly
- CX Racing Twin Turbo Intercooler - Brand New For Sale
- Starter MSD APS PN 5096 new for ls1
- Comp Turbo CT3 60mm Billet Turbos For Sale
- 4.10 gear for 10 bolt 3 series carrier
- Coan TH350 XLT Ultra light aluminum Nice Piece Fresh!!
- BBC CFE Big Chief Heads, Tunnel ram Dual Dominators FRESH!!!
- Older PRC 5.3L stage 2.5
- (2) c5 Z06 Front OEM wheels with hoosiers
- Fully Rebuilt, Machined, and Milled L92 Heads Ready to run
- Set of 2.055 1.60 valves
- TurboSmart EBoost2 controller
- Texas speed 1.0 243 heads for sale
- Corsa Catback for F-Body f/s in Charlottesville, VA
- CCW Classics 18x9.5/18x12 w/tires **S O L D**
- C5 Corvette 3" XS Power Exhaust
- 2001 Trans Am part out, 108k. T56, Hoosiers, Kirkey seat
- (8) LS truck coils
- BRAND NEW: Strange Manual brake master / Line Lock / Proportioning Valve / SS Lines
- Shop clean out. Wolfracecraft adj spring perchs,qa1 springs,drag ,5.3,ls1 parts
- Monster stage 3
- belt guides grey and ebony
- Sold....
- t56 swap!
- 2000 camaro clean title part out
- 5.3 balancer.
- Stock 2002 fbody camshaft
- Spohn Lower Control Arms
- LT1 T-56 transmission
- LS 7 Exhaust manifolds And Cats in South Florida
- cammed ls1 fs/ft
- FS ACCEL 30lbs fuel injectors
- 2002 Z28 Convertible & B4C Part-Outs
- 2009 l76
- Radium Multi-Pump Fuel Surge Tank
- LS1 Trans Am Part Out
- ls1 cam, springs, pushrods
- ls6 yellow valve springs
- 550hp Mast Motorsports 6.8L stroker 416 LS3
- 1998 ls1 camaro z28 part out
- B&M 14,400 BTU Transmission Cooler
- Fresh 4l65e
- Shop clean out LS1,LS2,LS3
- UMI weld in relocation brackets
- richmond 7.5 4.10 gear
- 4l80e complete swap kit for big power
- T56 whole set up for sale
- drag camaro part out.
- LT1 RHS 235 heads, DRE Shaft rockers. NEW
- LS1 parts, heads, truck intake, stereo stuff etc.
- LS1 Fbody Oil Pan
- BRAND NEW Michelin Sport Cup 335s
- Flt street performance trans with all new gears!!!!!!
- QuickTime Bell Housing LS1 T56 BRAND NEW
- Fresh rebuild 4l60e trans.. slips.
- New Magnaflow cat back for C6 #15887 CHEAP!!!
- New take off l92 ly6 Truck intake with injectors and rails Also have other small part
- rebuildable aluminum 6.0 engine and auto 6 spd trans comete
- SOLD NIB Meziere Remote Mount water pump and accessories
- Pre-trimmed Fuel rail covers for LS f-body
- abs speed sensor wanted
- ls1 comp cam and holley 750
- Need to sell everything sale!!
- Turbo camshaft.
- New Comp 850-16 lifters
- LS1 Engine Drop Out Automatic 44k miles
- O2 Trickers
- ls6, ls1 intakes for sale, stock throttle body, rails and injectors other misc LOOK!!
- LS3 injectors
- FS: N20 bottle, N20 Kit
- 7 blade holeset hx35
- Black Leather Shift boot
- Factory Hurst shifter
- FAST dual wide band, brand new
- 17" Chrome C6 Wheels and Tires
- Turbo hot side piping / OEM SS hood / QA1 shocks
- 2011 OEM Crome Vette wheels
- LSX Iron Block New 4.185 bore plus Callies crank+
- Built auto with converter and trans controller WTT for t56
- BW billet 83mm turbo/ 92turbine S483
- Ls1 parts lt1 parts and car parts
- lq4 pistons, SOM side skirt, ls engine covers,stock cats flow 40 series
- 10 spoke camaro pewter ss wheels
- 2002 Camaro pcm
- Non-EGR Truck Manifolds
- MT 295/45/17 drag radial brand new
- gm ls muscle car oil pan kit
- SOLD!!!GTO spares and M&H 185/55R17 Radials
- Ls2 Intake and Fuel rails and bolts
- c5z06 mod red seats
- procharger c5 inlet elbow and filter
- 1987 up sbc lt1 lt4 roller cam 226/226/114
- procharger pro-flow bpv
- Tubular K-member and A-arms, Tail light, Headlight control module
- tial 50mm bov blue anodized
- 6rib and 8rib procharger pulleys
- red c5 z06 fuel rail covers
- LS1 truck turbo hotside T4
- Futral/Cam Motion cam/double roller timing set/7.500 pushrods
- camaro passenger side ground effect
- Firehawk Chrome Wheels 1998 - 2002
- Ceramic fbody longtubes $275 shipped
- LS1 lifters, trays, knock sensor harness
- New 5.3L Crank with LS2 Rods and ARP Bolts
- Brand New Custom Cams Cam LS1 H R 242 248 110+2
- 3.70 Gears, 3.5" Alum PST D/S, Trans Cooler
- 90 mm - ls series throttle body for 4-bolt intakes
- camaro interior parts & headlights
- hp tunner pro and new innovative LC-1
- 3.23 Zexel torsen rear axle
- 2004 GTO Stock MAF
- **SOLD** Stock LS2 6.0 Cam *Very Low Mileage*
- 06-12 c6 z06 front calipers w/ pins (pics added)
- New and used parts for sale. OEM and Aftermarket. *UPDATED 10-10-13*
- ALMOST NEW Bridgestone Potenza RE760 Tires 295/35/18
- C5 zO6 Speedline Rims / Wheels!!
- Tons of go fast items LSx, n2o, carb, etc..
- BNIB painless race car 8circuit harness
- 93-02 T-top shades (Gray)
- flamed nitrous bottle
- k&n cold air intake
- FS: 42lb injectors, STB, 5.3L truck parts, Stock aluminum DS, and more
- ***LG G5X1 Cam- 228/232 112LSA 588/595***
- CORBEAU 2-Inch Retractable Harness Belts
- camaro headlights
- Miscellaneous Fbody Parts
- A&A Supercharger Kit for C5 Corvette
- New LQ4 rotating assembly
- Vs racing 88/79, bov, wg ic
- ls1 arp head studs
- Lt1 performance & Stock parts
- LS1 intake 226/229 cam ls1 heads
- SS Spoiler
- Trick flow 7.400 brand new in package
- Stock 98 LS1 Camshaft ***SOLD***
- Turbo Cam
- OEM Leather Wrapped Trans Am shift knob
- FS: UCC Converter 10 inch 4L60 Trans
- OEM ls1 spark plug wires and metal boots
- WS6 Wheels, Narrowed Fronts, Any Color you like!
- FS: F-Body Driveshaft, for TH400 to 9 Inch
- *WISECO 5.3 pistons - READY FOR BOOST! *FREE BEARINGS*
- eagle forged 4340 4.0 stroke crank billet rods
- 99 ls1-t56 drop out 96k miles $3000
- Motor Mounts, A2w intercooler and Manifolds
- LS6 Intake, fast 36lbs injecters, 3.42 gears and posi, tral lazer ss wheels
- ls1 pulloff parts
- 98 Z28 Camaro Performance Part Out
- 2002 LS1/T56 complete less than 45K miles
- G-body t56 swap parts
- Nitrous Direct Port, FJO Progressive
- 243 Heads Complete
