View Full Version : Parts Classifieds
- 1998 pcm, grey ttop shades
- Brand New LY5 5.3l longblock from GM
- LED Front turn signals
- victor jr with aluminum sheetmetal elbow
- BMR rod ended LCAs,UMI TA relocation mount, chromoly Driveshaft
- Moser 9 inch, sphon, bmr, qa1 suspension
- coil packs
- S.S. z28 badges
- Aftermarket 5.3 Pistons New $125 NEED GONE
- 4150 4 bolt elbow
- Cams, Vette Exhaust tips, AC compressors
- NX bottle, rocker arms, intake & oil pan, taylor wires CHEAP!
- 2002 Pontiac Trans Am polished wheels
- FS: Holset HX40 Rebuilt Turbo
- mt et street 315/35/17 like new!
- LS1 Hypertech 180 Degree Theromostat
- 78mm n20 oultet plate 2 Stage!
- Innovate LC-1 wideband with guage
- Wilwood proportioning valve, lunati ls1 lifters, clevite rod bearings
- z28 tips $50 and FTRA $75 for sale + shipping
- tubo system, axles, ground effects
- Ls2 coils packs w/ bracket
- 4L80e 65k Miles with Converter
- water pump
- Race Craft Ultra lightweight fbody drop spindles and STRANGE Spindle Mount Brakes
- GI: WTT TSP duals for Y setup
- NEW NX GM EFI race kit $600 shipped!!
- FS: Factory C6 Z06 Air Intake w/Filter
- FS: Truck manifolds
- L76 Intake Manifold For Sale (Used)
- 6.0 truck coils
- ls1, lt1, camaro and firebird parts, motor covers, ta tailight, blackout covers,more
- FS: OEM NIB LS6 Master Cylinder
- FS: racing seats, TB's, alternator, polished heads, etc!
- FAST 90 intake
- Infinity Reference 410cs Component Speakers and stock Amp from my Trans Am
- Built LS1(Cammed, Forged, 243s-2500 miles)
- GMPP valve covers with custom coil relocation
- Moser M9, Strange brakes
- Nitrous accessories! Dedicated, P-gauge, Remote opener!
- ARH 1-7/8 to 2inch stepped headers FS
- Trans Am Gauge Cluster Bezel
- BS3 with Trans and DAI
- Metco F-body LCA Relocation Brackets
- NIB: GM LT1 F-body Battery Cables, Power & Ground
- Twin Intank Walbro setup FS (metal tank)
- Torque Thrust II's 17X9.5
- Gen III Wiring Harness and Parts LSX LS1 LS2
- FS lingenfelter 47lb injectors
- Vvt cam by mast motors ports
- LS3 Comp 3 bolt double roller timing set.
- F/S: 69-72 Nova Rocker mouldings -Brand New
- Diamond 4.005 bore forged pistons
- gm 10 bolt 3.73
- P&P 317's
- Fast 102mm intake with rails,injectors
- Th-400 Transmision shield
- LS1 Cooling Fans SOLD. SOLD
- All Firebird/Formula/TA (some will fit Camaro) parts must go! eBay ending Sat. 21st!
- P1sc-1, cam kit, nitrous kit
- Sold
- Parts
- Almost new QA1 front coil overs, SPEC twin, UMI torque arm,BMR k member
- 30# injectors
- Ls1 intake with 33# injectors
- 8.8/10 rear, 35/21 sways, c6 pds/rtrs, LS spindle, UMI LT1 tqarm reloc
- FS Stock parts (New parts added)
- FS: Borg Warner S252
- Fuel rail -an fittings (4), -08an black hose
- FJO progressive controller
- ls6 intake ported tb and heads
- New tc78 .96 a/r
- OEM LT1 WS6 hood
- Brand new mickey thompson drag radials.
- Brand new Powerbond 25% ud pulley, Stock maf, SLP cold air
- LT1 Emergency brake cable, may work for LS1
- C5-R Valve Covers
- "Novak jack" monsoon radio
- brand new tsp 1 7\8 headers
- McLeod RXT clutch and Tick master
- Fs: 91mm turbo, bmr turbo k-member and more
- fast toys 104 lid
- textralia oz700 z grip clutch used and a spec stage 3 clutch used
- Electric fans and nitrous bottle w/brackets
- 85mm DELPHI GM MAF -- NEW
- 6-Piston Stoptech Big Brake Kit - NEW
- Wolfe race craft mini tub
- MSD Blaster coils and Comp Mag Rockers fs/ft
- 15x8 Weld Pro Stars with 27x10.5 QTP's
- GM LS1 Rocker Arms
- LS1 Coil Covers
- BRAND NEW in box lg motorsports g6x3 cam
- Gauging Interest- Almost new Racetronix + Hotwire with Bucket ready to go.
- LQ9 6.0L iron LS block, race prepped for boost, ready to build
- (No longer for sale!!!) Please delete!!!
- 78mm Nitrous outlet plate kit w/ FJO progressive controller.
- *NICE* Autometer SHIFT LITE FOR SALE
- ls2 intake for trade or sale
- 93-02 Black TA CRACK FREE door panels
- Monster LVL3 LS1/LS6 1000miles 550.00
- FS/ TRADE: FAST 78mm Intake
- For Sale-MOSER 9 Inch (BUILT), BILLET SPECIALTIES WHEELS W/ HOOSIER Radials
- 6.0 truck manifold fuel rail map sensor & tb
- magnafuel fpr
- Stock 3.23 Gears 10 bolt
- ev6 ls3 injectors and 2 new slp loudmouth mufflers
- Center Mount Exhaust and Tips
- ls1/ls6 nitrous kit
- gto spare and drive shaft
- ls3
- F/S Yank SS3600 Stall. for 4L65E or 4L60E
- 799 heads (stock)
- 60lb @ 43.5 psi motoron injectors 2 sets
- New- upgraded mosoon speaker package
- Alky Control 3Gallon trunk mount kit
- (Brand New) LS2/6.0 Wiseco Pistons & Rings
- (Brand New) Callies LS1 Crank
- (New in Box) Wiseco K1 4.250 Crankshaft
- SOLD VHP Diagnostic Tuner SOLD
- 99 NBM T/A everything partout
- LSX Tall Deck Block
- Dynotune nitrous kit for LT1 or ls1
- Lg Motorsports G6x3 cam
- 98 TA sleek hood and two 16" wheels w/ tires
- chevelle A-body turbo hotsidepiping log
- 2004 Stock Escalade Rims $400 OBO
- Garage clean out lt1 parts must go
- Eibach sportline springs and LS3/7 injectors
- milled TFS 215 heads & vindicator cam
- LS1 Valve springs and Retainers!!
- Eibach lowering springs trade for stock
- 60mm Wastegate TurboSmart
- 78mm Turbo
- Nice LSX Logo for Custom F-Body Floor mats
- Car audio - 12W7 custom ported box for well
- Hurst billet fbody shifter 75 plus shipping
- 04-07 cts-v magnaflow catback f/s with cat delete pipes 600$
- 1600 shipped 05 cts-v m12 t56 transmission f/s
- Gto part out 04
- Ls6 dbw electronic throttle ported body 100$
- 04 ls6 cam and springs
- 76mm turbo ,turbonetics racegate
- 98 Z28 Parts List.....
- Narrowed Strange 12 bolt, New Pro Series Spohn Anti-roll Bar
- 97-02 camaro tailights
- Strange Single Adjustable shock's Front and Rear set
- FS/FT CCW Classics $400 *PRICE DROP*
- T6 S475 Turbo hotside for LSX swapped fox body
- Boost ref fuel regulators
- Nitrous Plate 78mm Ls1
- Bogart D10s CHEAP!!!!!
- 04 Z06 pushrods and timing chain $25
- Turbosmart Race Port blow off valve for sale
- F1R, 3000hp A2W Intercooler, Big Red Bypass
- brand new 373 gears in box
- 42lb green tops
- New adjustable lower control arms
- AeroForce Wide Band O2 Add on - SOLD
- 2010 Camaro Vortech Polished V3si Complete kit
- Low mile stock parts for sale. Cats, manifolds, etc.
- melling,ls6,ls7
- C5 Y2K wheels & 275/40/17 tires
- moroso tall lsx valve covers
- Lq4 Lsx ignition coils
- 3" DMH Cutout
- TH400 to Strange Dana 60 Driveshaft
- Sold!
- f/s harris speedworks (the interface)
- Magnaflow SS 2.5" mufflers part #11376
- SOLD SOLD Alkycontrol progressive system.
- few A4 swap parts
- Weld Prostars 15x10 7.5 backspace. Coated
- FS: LS1 exhaust manifolds
- 1998 Firebird Roller Red Trans Am Wing
- FS: 6.2L L92 crank. Perfect for a budget build
- APS Stage 2 Extreme Twin Turbo Kit
- FBody Windage Tray and Oil Pickup + Fasteners
- Complete set Intake Manifold & Oil pan bolts
- Magnacharger MP112 kit
- 17'' chrome corvette rims (camaro/tans am)
- BNIB Torqer V2 Cam !!!!
- ls 4 bolt 92mm tb with extras
- Racetronix Flowmatched 42lb Injectors and Red Anodized Fuel Rails
- WTB:LS3/7 clutch kit,slave
- FS 2001 c5 (8) ls1 ignitions coils with bracket and harness
- UMI shock tower brace
- WTB:96-97 Lt1 engine harness
- AVS 93-97 Camaro Headlight Blackout Covers
- Firehawk style hood. primer
- Mustang mastercraft 245 45 17 tires 90% tread
- Wheels Galore! Saleen, CTS-V, ZR1, Trans Am, Draglites...
- 2002 Camaro Parting out
- SOLD American Racing Longboard wheels 17x10 SOLD
- injectors 28lb. and 42lb.
- FS- LQ4/LQ9 Injectors + Injector connectors
- C5 z06 chrome rims
- 2-Borla XR-1 4" mufflers
- Ported L76 intake with rails
- FAST ls3 65lbs injectors
- brand new in box lg motorsports g6x3 cam
- FS: PRICE DROP!!! ported ls1 throttle body, 24x12x3 intercooler, cutouts
- CORSA muffler 93-02 F body
- PRC 5.3L heads For Sale!
- GTO spares, M&H Frontrunners, spacers
- edl victor e intake new and fuel rails
- FS: used ls1 texas speed comp cam 228/232 $400
- New Unused LS7 Clutch Kit - SOLD
- Tan and black Camaro door panels
- FS:GT37-Brand New
- Ltx blowout---Electric water pump, xfi280 camforged crank,
- Air bags
- Edelbrock Vic Jr. EFI fuel rails
- LS6 Intake/ Throttle Body
- FS: Nitrous stuff
- 42 LB Green Top Injectors
- 15x3.75 and 15x10 7.5 Race Stars NEW!!! CHEAP!
- 90mm PORTED FBW THROTTLE BODY (GTO)
- Midwest Chassie fab 9" 700 miles
- F/s- water pump and damper
- Michelin Pilot Power 2CT Rear Tire
- 80# High Imp injectors
- Holley Dominator $450 (only used 2 weekends)
- exhaust, transmission, fast 102, nick williams,
- A whole LOT of good parts F/S: one-off custom exhaust, Wheels, T/B, push rods, cam...
- Lt1 Engine
- Fast 90mm Ported and Painted intake manifold.
- Ls1 Complete wiring ect.
- New driveshaft loop from MidWestChassis
- Manley Pro Series 4.125 piston (LS7)
- Fikse fm5 new tires 275 front 335 in rear.
- centerline convo pro wheels caps lugs slicks
- Callies 4" stroke crank turned 20/20
- Ls1 block, headers, tires, many new parts
- LS Hi Ram upper and lower only
- EFI live V1.2
- 3rd gen LS K-member
- Midwest chassis fab9 >500miles MWC lca-phb
- Lakewood driveshaft loop
- Magnaflow dual tips
- Delphi 65lb, Std 83lb low z injectors
- Pushrod sets: 7.200,7.350,7.400
- LS1 Camaro Taillights and SLP Airbox Lid
- F body MAF
- BBK 80mm throttle body
- Stroker cam V3 247/251 .624/.632
- LT1 moroso oil pan and pump FS
- SLP Lid and K&N Filter
- PIE GM9 AUX Input
- "eBay" projector headlights, hids w/balasts, brackets, smoked tailights
- G.I.- LS2 243 Heads (SOLD)
