View Full Version : Parts Classifieds
- LS1 MSD Ignition - New
- Diamond Racing Pistons 11510
- MSD 8733 2-step for LS engines
- LT1 head light bezels
- Multiple sets of 98-02 Calipers
- Parting out 99 Fourmula Firebird
- Differential parts "98 camaro"
- Sold
- C5 thin spokes and tires
- Remove Please
- SLP headers and y pipe, gutted cats
- LS1 ARP rod bolts BNIB PN: 134-6006
- 80# injectors, Ported heads, 5.7 LS1 block..
- like new ram air intake off 01 ws6 and others
- Ls6 Springs
- M6 parts for sale!
- FS: Nitrous Outlet Bottle heater / stand
- ls2 ls7 t56 slave cylinder, 3" electric cut out
- Ported LS3 intake with fuel rails
- New BMR Subframe connectors, panhard bar, torque arm, 1 control arm and springs in MD
- Yella Terra Rockers ls1/ls2/ls6
- LS1 Front and Rear covers
- WTB: LT1 to LS1 engine conversion harness
- Magnaflow race series mufflers
- ISO/wanted: 78mm nitrous plate and nos mini progressive controller
- (2) pair valve covers and stock tb
- K&N FIPK 2, 99 harness/ecu a4, cats /maf-lid
- FS: 2002 Camaro Z28 parts. Pacesetter headers, SLP lid, truck MAF, etc
- looking for turbo kit for 98-02 fbody
- A&A C5 V3si
- bbk 52mm throttle body
- wtb mast all pro. wcch set of heads
- mega death cam
- M21 rebuilt w/ hurst shifter, clutch kit +++
- 99 Z LS1 Coils $115 shipped
- Twin Turbo Kit - Top Mounted T4's
- 1990 foxbody part out
- Brand New!!! LS7 Clutch Kit
- LY6 PARTS!! Wiring Harness, cam, oil pan, power steering, etc.
- Sold Edelbrock pro-flo intake with fuel rails and injectors $500
- LS1 cam and crank sensors, LT1 tps, camaro shifter handle
- F-body oil pan and pickup
- 60# and 80# injectors for sale
- 1200rwhp capable turbo kit
- LS2 Shortblock and Corbeau A4 Seats with Rails
- LS2 oil pan, windage tray, pickup tube
- F Body T6 turbo kit Keeps AC and Sway bar.
- F/S: set of gm 4:10 gears
- TR224 Cam & Comp 918 valve springs
- F/S: Detroit tru trac locker
- Air fuel ratio and vacuum gauge
- MSD programmable shift lite
- 99 Transam camaro plastic gas tank
- 853 heads $75
- 16" M/T et streets 26x10.50 and 78 fast
- wtt/wts:5.3 truck parts,ls3 heads, lg G6X3 cam, holley 830cfm carb
- Trans am & Camaro signs 35$ shipped
- New Callies Ultra H beams
- SOLD! Eibach 15mm Hubcentric Spacers
- Original 2000 wheels & tires
- 6le cme tips
- dual intercoolers and piping
- Ford 9 inch Center Section SOLD
- WCCH Edelbrock 245CC Heads
- ****P.I. Vigilante Converter****
- Trade OEM SS hood for VFN 3 inch SS bolt on hood
- Complete AC for fbody
- Complete Brand New Car System!
- Brand new never used f1a
- Fs: Bogart Bolted R/t
- wtb 265 amd bigger heads
- Brand new T6 BW turbo
- Weld Draglite 15/10 15/4.75
- LT1 Engine Part Out -1997
- WTS Racing Seat's/Nitrous Bottle
- Silicone 90 degree boot
- Complete dual cat Y pipe off 97 SS
- Procharger Cog Pulley
- bfg tires 275-40r17
- 2001 C-5 Harness,manifolds and misc parts.
- STS Turbo kit exhaust Tips!!!
- magnum 80mm 1.15 AR NEW
- 2010 camaro rearend axles and ds
- 243 heads, stall, oil pump, timing set, valve spring tool
- New holley dominator pump regulator and procharger 2000 hp intercooler for sale
- Precision pt1000 air to water intercooler SOLD!!
- LS2 bare block with main caps
- 3.5" Borla XR-1 Race Muffler. #40946
- like new percision pt88 turbo
- 95 Camaro V6/LS1 parts
- Comp Cam Custom Grind Texas Speed LSX
- L-33 FI Silverado intake (reduced)
- F/S deka 60lb injectors
- FS: All Pro LS7 Heads
- Complete ram air setup
- Turbo hotside kit fbody
- LQ9(LS2) rods & pistons
- LS6 Intake Manifold
- Brand new LS3 complete intake
- 2010 Camaro SS brembo brakes
- ls7 long block $4000obo
- LS1 oil pickup tube
- Zex Nitrous System
- Wanted LS1/6 short block
- ls7 ported intake 92 mm t/b
- looking for good boost controller,ams,eboost2
- LS1 Shortblock, Pro 5.0 Shifter, Driveshaft....
- WTB 80e dust cover, dipstick, used stall
- FREE !!!! Front suspension off 01 T/A
- for sale: brand new madman tq arm, gmpp ls7 carb intake , wolf door panels 2 fuel
- WTB: Stock rocker arms and pushrods
- Reduced price!! Afr 210 heads brand new - $1950
- Holley hi ram l92/ls3
- Ctsv 56# injectors
- WTT: LS1 fuel rails
- L92 Truck Intake complete
- Koni SA 4/3, BMR Springs, Berger Panel, Z06 Wheels/Tires(Price reduced)
- WTT corsa cat back
- WTT my 17" Chrome TTM's
- 1998 Z/28 Roller
- LS1 F-Body (Plastic) Racetronix Fuel Pump Only
- Brand new fully built 427ci LSX built for boost
- coils, fpr, clutch/flywheel, trans cross member
- trans am honey comb light
- F1A head unit recently rebuilt
- 16 Manley 7.350" Chrome Moly pushrods
- Interior Part out
- slp air lid/25mm h&r wheel adapters
- EPS Comp Cams 226/230 cam for sale 98-02 ls1/ls6
- 2000 WS6 17in Wheels w/ Tires
- LS7 Clutch kit and LS7 intake manifold 17k mile 2008 Z06
- Tint Meter Tool
- Custom F.A.S.T. 102/102. SOLD!!!!
- Wheels/Tires Greg Weld Stars/Jegs Stars
- ARP LS2/3/7 head studs. $200 shipped
- LS2 coil packs, brackets, and MSD wires...$150 shipped
- Accell Gen VII DFI for LS1 New In Box
- WTB t56 shifter/knob
- Msd ls two step
- UCC 8" Powerglide Converter
- LT1 Engine Parts
- Texas Speed Catted y-pipe from '00 SS
- WTb Ls6 Intake
- Precision 6765 Billet turbos
- Stock k-member, fuel rails, fans and SDPC engine cradle
- Weldon Fuel pump controller
- Weldon 2025A fuel pump
- Intake elbow (4500)
- Bw s475
- KATECH ls9 clutch for Z06/ ls6/ls1 cars
- Eibach Pro-Kit Front Springs for F-body
- Meziere Street water pump part # WP319S
- [BRAND NEW] UMI SFCs for '93-02 F-body
- TPSM Sensor for 2006 CTS-V
- K&N FIPK with SLP smooth billow
- (2) quarts of GM manual transmission fluid
- 10-lb NOS Nitrous Bottle, Jacket, Bottle Heater, and Mounting Bracket
- ragin racing lethal cam + ls7 injectors
- ls1 intake,fuel rails,tb and injectors
- New in box Motive 3.73 gears 7.5 10 bolt series 2 thick
- Granatelli maf for sale $150
- f body oil pan
- Tunnel mount nitrous bottle bracket
- Wanted: Ls6 243 heads
- LS2 Coils, LS2 Water Pump
- UMI solid motor mounts.
- 6speed swap
- MSD 8.5MM SUPER CONDUCTOR Spark plug Wires
- nick williams 90mm tb
- FS: Nitrous Outlet 102 plate kit and C5 standalone fuel system + tons of extras
- SLP Blackwing lid.
- Precision 7675 Turbo .96 a/r BRAND NEW
- Stock Throttle Bodies
- LS2 rods style
- GI Huron Speed Complete non AC T4 Kit (low miles)
- LS2 E40 cam extension harness
- Brand new STS Scavenge Oil Pump
- 2010 truck MAF
- LS1 Stock Crank Pulley / Damper / Balancer + Refinished
- GI: T56 Setup w/Extras For 4L60e Setup
- 800 WHP lt1boost turbo kit.brand new COMPLETE bolt on and go!
- Th-350 Built w/ 3800 stall for LS1
- Brand New Hurst Shift Knob
- FS: 2004 6.0/4l80E/NP261HD 2500
- LT1 fuel rail covers
- 243 heads
- Weld rts rear wheels black
- Snow performance Alky injection kit
- 2005 Corvette Part Out
- GTO/FBody 19" Avant Garde M310s Machined Face STAGGERED with Goodyear F1 Asymmetric
- Brand new Car Cover and Floormats Cheap!!
- 427 Rotating Assembly balanced NEW!
- Polished Extreme Velocity blow through carb hat
- 17x11 Silver ZR1 wheels *SOLD*
- Richmond 3.90 Gears for 12 Bolt (3 Series Carrier)
- Moser 12 bolt , Misc LT1 parts
- True duals for lowered cars, x-pipe, magnaflow bullets
- Siemens 80lb EV1 Injectors. Like new!!!
- AFX Wideband, C6 Tips, Shift Knob
- RPM activated window switch
- FS: Built t56, lots of swap parts
- Stock suspension, C6 Wheels, Monsoon Radio, Mid Pipe
- Stock Hurst Shifter
- fuddle 2800 stall converter
- 17/18 C5DD wheels/tires
- FS: GTO Interior,Wheels,Front Bumper,Mirrors,Radio,Stock Exhaust,Stock Springs
- 42# injectors and fuel rails
- Honeycomb tail lights
- Allstar Line Lock kit
- WTS 99-02 3.8 K&N Cold/Ram Air intake setup
- Ported 243 heads
- Ls2 intake with ls1 injectors
- C5 Transaxle, Suspension, shocks, rack and pin, 4l80E
- Fresh 496 BBC with Built Th400 - 665hp / 670 Tq
- WTT 17 inch Torque Thrust (TT2) Wheels with ET Streets for Drag Wheels...
- (SOLD) LS3 Heads w/ .650 Dual Springs
- M6 Xmember, M6 Pedals, Stock Hurst shifter, PRNDL switch
- LS1 Auto Engine Harness, m6 pcm
- FS/FT th400 Manual Valve Body with Coan 4300 Converter (trade for T56 or 4L80)
- 04-06 gto otr intake
- Corvette ZF 6 speed for LS conversion
- stock cats
- AFR 225's with quick lift rockers and valve covers
- FS ((Stoptech big brake kit f-body 93-02))
- WTT: American Racing Headers Y-pipe w/ Gutted Cats for same Y-pipe w/ Working Cats
- LS1 LS6 Corvette Camaro GTO GM Crank Pulley Pin drill kit
- Nitrous Outlet 102mm Nitrous Plate
- Texas Speed CAI for gen 5 camaro like new
- 5.3 & 6l80 58xxx miles complete
- Magnaflow Axle Back
- IOM Roto-Fab CAI with Carbon and Polished Tubes
- Eibach Pro Front Springs
- FS: Stock LS1 Injectors
- FS: Burkhart abs delete/Burkhart manual brake
- 6L60e automatic transmission for sale
- Complete L92 for sale
- Mickey Thompson ET Drag Slicks,33.0x10.5-15W
- Nick Williams 102 dbw throttlebody
- wtb 7.4 pushrods
- NIB Compstar 6.125 rods and Wiseco 5.3 pistons, rings and bearings
- Magnafuel Pro Tuner 750 pump (2000HP)
- Ls6 Intake and ported TB, 317 heads, NIB lifters, ARP main studs
- NIB BW S480 Billet Turbo
- ls2 intake manifold/ monster stage 3
- Anyone want to go from stock Procharger Hat to Truck Hat for Half-Price?
- 05 LQ4 Truck Harness
- Ported Ls6 243 Heads for sale & New .675 double Springs
- Boost Referenced FPR and AN Fuel Filter
- 93-96 trans am 6 speed console fs
