View Full Version : Parts Classifieds
- Lloyds mats TRANS AM EBONY***NEW***NEW PRICE!!!
- Jegs 2.25" X-pipe kit
- FS: HP Tuners Pro, DB/LC-1, & Master EFI Tuner Book
- Skinnies & 15x10 with Tires forsale
- c5 Y2K STYLE CORVETTE WHEELS SUPER CLEAN LIKE NEW!!
- BOGARTS! Boagart Bolted RT's!
- angel eyes cover and black corners
- patriot heads, fast intake, NW throttle body
- FS: K&N air filter, Hurst shifter
- N20 stuff cheap!!
- QTP stainless headers, 10 spokes, spec 3+ clutch with flywheel
- 2 Catalytic converters from 02 Fbody
- 98 Convertible trunk lid **Silver** NY
- hooker swap headers
- Katech clutch spacer, comp pushrods, LS7 injectors, SPEC, 2010 Camaro shifter etc...
- Cleaning out the garage - steering wheel, water pump
- Ls2 short block calis crank,comstar rods man. Piston
- Brand new L92 intake valves, springs, retainers, locks, and seals
- NJ/PA - NOS Gm Cowl Hood - Still in box #03949708
- FS: nj/pa - ls2 fuel rail covers, shaved & painted red.
- Ls1 intake manifold and ported TB
- FS/TRADE - Dual Tank Nitrous setup W/ Mount $500
- FS: 97-04 DWB pedal/ TAC module
- Strano lowering springs /w KYB AGX Adj Struts
- Linginfelter GT7 cam
- CTS-V Brembo 4 piston calipers
- 2001 LS1 T56 Transmission
- Trickflow Heads (complete)
- TTops, shades, keys and weather stripping. All sold together
- Complete all new LS7 long block
- Magnaflow Catback -SOLD-
- Intake
- LOW mileage 18" tires. Nitto 555 Fronts, MT ET Street Drags in Rear
- 1.8 roller rockers
- K&N FIPK Intake
- Red UMI trq arm
- F/S c6z replica wheels or trade
- Wtt th400 for 4l80e, built 60e or built t56
- L92 cylinder heads
- Siemans deka 60lb injectors new
- ls2 H/C/I
- Hinson LS1 RX7 FC motor mounts with clam shells, T4 Turbo Blanket
- 04-06 GTO 3.90 gears
- Strange SA Front Struts, Hypercoil 300lb Springs, Bearing Kit, Wrenches - Like New
- Littelefield 8-71 Competition blower. Fresh rebuild
- 2006 GTO Stock Parts for Sale
- Fast 102 intake CHEAP must sell asap
- TCI Streetfighter Torque Converter
- Patriot Stage 3 Heads FS
- 4l60e and stall
- Nasty Performance BILLET Valve Covers and Coil Brackets
- Aluminum Driveshaft '99 M6 Camaro
- Ls2/ls3 MSD coils for sale
- SOLD 17 x 9.5 ZR1's, Silver, VG shape
- WTT: 17x11 Chrome ZR1s for 17x9.5 or...
- LS1 T56 Transmission
- some stock stuf
- Excellent Condition GM Chrome ZR1s w/ Goodyear Eagle F1s
- FS: LS3 Corvette Long block 6400 miles Intake to Oil Pan
- flywheel bolts
- Set of 4 2000-2002 Factory GM Trans Am Speedline 5 Spoke Wheels/Tires
- Borla XR-1 Oval Muffler 3 1/2"
- Sold
- Hallman Boost Controller
- Stock door speakers and amp from a '98 Camaro SS
- 17x9.5 Chrome ZR1 wheels MINT Condition
- ZEX Wet Nitrous System*SOLD*
- Nick Williams 96mm Cable Driven Throttle Body
- Siemens deka 60lb injectors
- Ls2 Connecting rods (low mile)
- LS6 manifold/ Fuel rail
- FS: Weld Prostar 15x3.5 15x10 *Sold*
- edlebrock progressive controller
- 799 heads for sale
- MT ET Drags for sale or trade
- 4150 quick fuel q- series 950
- 2001 WS-6 aluminum Driveshaft
- 2007 Truck Harness and Accessories
- Truck engine parts, TKO500/600 input shaft
- LT1 drivetrain partout
- "SOLD" STS Turbo Kit 98-02 Camaro and Trans Am's CHEAP!!!!
- Fikse FM 10, Corvette
- magnum 76 turbo
- need a good blower or turbo cam
- ls1 98 f-body throttle body tb
- LE GM LT4 Manifold, Ram Air Hood, MSD Opti, Mcleod FW, Holley 58MM
- Truck Tensioner and Valley Cover
- FS: GMC Sierra grille 08+
- c6 z06 diff
- 18in Chrome Zr1 Corvette Wheels Trade for Weld
- C5 Corvette Air Intake Cover
- Comp 918, LS6 intake, headers,pushrods,injectors Plus lots more!!!
- LS7 Lifters. SOLD
- Lindy IHPC FS
- LT1 performance parts
- 99-00 Pcm, harness, 5.3 coils, built lt1 a4
- 6.0 intake, water pump, exhaust manifolds, truck lowering kit, misc...
- parts for sale
- wtb: FAST 102
- 9" blower or large nitrous converter turbo spline
- Tac module,tac harness,pedal,pcm
- 98 02 camaro rksport front supplier
- Tial 50mm BOV
- Fikse fm10 17"
- Holley Commander EFI Setup
- Watts Link 93-02 F-Body
- T56 Case
- Global West Adj. Tie Rod sleeves
- LS6 intake for sale
- 17x9.5 Chrome zr1 wheels MINT Condition
- Nitrous Kit and Accessories
- Inland Empire Aluminum Driveshaft
- hypercoil springs
- 2 Nitto NT555 Tires P275/40Z/R17 New
- Porter Cable 7424XP variable speed polisher a bunch of pads and polishes/waxes
- LS3 Injectors and rail & MSD Plug wires
- SS 10 spokes, And stock parts garage sale, seats, suspension, intake, emissions parts
- L92s and intake
- Eibach Pro Kit
- WTT: 2 guage pod w/A-Pillar & 2 guages
- FS: Brand New ERL 427 Dry Sleeve Block 4.125
- FOR SALE: T56, Clutch, LT's, Ram air hood, & more
- 2x PA6 (Tapered 5 spoke) factory rims
- Ls3/ls7 injectors new
- LSX-LS7 6 bolt heads
- MSD crank trigger with 24x BS3 wheel
- 2003 Corvette - GM Sealed NOS C5 50th Anniversary Instructional CD
- Lid and powder coated stock MAF
- set of drilled slotted rotors
- Many C6 Z06 and Zr1 parts for sale
- Lsx motors and parts
- PCS TCM-2000 Automatic Transmission Controller SOLD
- NIB ls2/3 professional products fuel rails
- Ford Red Top SVO 38lb Injectors (Set of 8)
- borla adjustable catback
- S380 turbo new price
- Heads & Cam installation kit
- B&M 4L60E/4L65E deep pan
- LQ4 block/LS2 pistons/rods
- Autotap/Efi Live V5
- LS1 f-body aftermarket/stock parts, 317 heads, gto oil pan
- Trading Brand new ms4 cam for ms3 or similar
- Comp 1.5 Promags, FPSS w/ 8AN Fitting, SLP LineLock 'noid
- fs:ls1 bottom end.....
- Air Deflector for 83-90 Firebird/Trans Am, 3pc kit
- ebony front seat belts 30 shipped
- Kaltech Shop cleanup for sale
- Bosch Injectors, BBK TB, MSD, 96-97 Timing
- Lq9 6.0 rebuilt 1750.00
- Weld wheels and Mickey Thompson ET streets+ skinnies
- wtb ls7 rockers
- c6 corvette wheels
- FS: 236/240 Comp cam LOW MILES
- WTB: F Body Front Accessories
- Patriot Dual Gold .650 springs CHEAP !
- SLP Fan siwtch
- Sold
- fbody stock susp. parts
- Pat G Custom Cam for 6.0L L92 heads
- Bunch of random ls1 parts
- SOLD****Ported TB/LCA Relos/FTP 98mm Lid
- F/S NX single nozzle wet kit
- american racing rebel wheels/tires
- 12 bolt 4.33 pro gears 4 series
- Morel Hyd. Roller Lifters W/ link bars
- ls1 cam headers tb
- Ebony Interior Swap for Camaro
- LS1 Brake swap
- ls1 parts
- 1999 Corvette ls1 engine
- 04-06 gto d1 procharger kit complete (must see)
- 2002 Camaro SS rims 17" (2)5 1/2", (2)9" DragPak w/ tires
- FS Steering Wheel
- Eibach sport lines w/struts
- LT1 Mac mids for sale/LS1 steering linkage
- 04-06 Steering wheel controls GTO (Wheel Included)
- Y-pipe for MAC mid length ls1 headers
- 2010+ Camaro Gas Door - Satin Finish
- FS! 243 heads yellow springs powdercoated valve covers
- lt1 brodix -10 heads and solid roller lifters
- F/S Truck exhaust manifolds, Truck intake manifold CHEAP NEED THESE GONE
- C5 Corsa Exhaust *Like New*
- AFR 225 Heads $1200
- Two 35TH LE Camaro 17" rims w/tires (wheels, anniversary, Z4C)
- brand new GM cats for a cts-v
- cts-v 12 pin ballast
- brand new V emblem for 04-07 cts-v
- LS7 clutch
- 5th gen camaro magnaflow axleback
- hoosier slicks half used $45 each
- FS: Comp Pro Mag 1.8:1 rocker arms, brand new
- Comp 1.82 RR's and comp 218 cam.***cam sold***
- 9' driveshaft/SLP line lock +STOCK Parts/ o2 Simulators
- harland sharp adjustble 1.7 rockers Cheap
- 2001 ws6 rims for sale
- 93-02 Camaro SS Spoiler NEW Aftermarket
- Windstar Fans and Radiator
- Meziere polished electric water pump, Race version
- 1998 Trans Am WS6 Parts
- 87mm TB DBW F/S
- A lot of everything stock and aftermarket, torque arm, coils, fuel rails and MORE!!!
- Katech oil cooler adapter
- Accufab 4150 billet throttle body-SOLD
- WTT: 2 factory GTO spares
- Katech $50 Gift Card -$45
- LSx Nitrous Kit
- 95-97 LTX hypertech programmer
- LM7 parts
- Sparco Roadster seat, Kirkey seats
- 317s and 862s, ls1 hot cam
- WTB: Need LS Main Studs PRE-03
- ls6 Intake, P&P Throttle Body, Fuel Rails, Injectors, AC Compressor
- 243 Heads Forsale!!! Sold!!!
- stock 10 spook paited
- a few nice ls parts for sale
- ls6 intake
- AEM Impedence Converter Box, Racetronix Harness, and 120# injectors
- 02 Camaro SS car cover and tonneau cover for convertible.
- Used Comp Cam - Cheap
- Used:2006 GTO LS2 AC compressor
- FS: GN1 Performance converter
- Colorado Custom Billet Steering wheel and adapter
- Brand new GM 3 bolt LS9 cam
- 8.8 ford moser 31 spline axles NIB CHEAP!
- LM7 5.4 truck intake tb etc...
- 918 Spring kit
- SOLD!!! NIB Polished water pump for LS1
- Camaro front bumper 98-02 $80
- Mac Mids with emission fittings welded shut. $200 shipped
- Bridgestone RE-11s for sale
- F/S: 335/30/18 Drag Radials
- 243 heads with prc .650 springs
- Yank SS3600 LS1 Converter
- FS: QA1 REAR 12 way single adjustable shocks *SOLD*
- FS: BMR Anti-roll Bar*SOLD*
- FS: BMR Adjustable LCA Poly/Poly
- Guaging interest 160mph TFS 235X heads
- NEW SLP LT's Ceramic coated HEADERS PRICE DROP!!
- LS3 Blue Springs , Retainers , Seals/Seats
- pair of 19" Fikse Profil 5 wheel centers - new
- New Stock LS1 parts CAM and Valve parts
- high torque mini starter for sm or big block chevy
- set of 8 LS6 injectors
- Fbody fuel pump, ly6 pistons/rods, timing set, flexplate, camshaft
- hurst h knob, koni yellows(front)
- *LIKE NEW* 17x7 / 15x10 Billet Specialties Street Lites & MT ET Street Radials
- New LS3 Springs
- F/S LS 1.75" Header Flanges, LS Motor Mount Plates, Non Egr Truck Manifolds
- Stock L92 6.2L Rotating assembly
- gunmetal c5 vette rims and 16" mt slicks
