View Full Version : Parts Classifieds
- 6.0 parts
- FAST fuel rails, Racetronix 42 lb injectors *sold*
- fs; 5.3 heads
- Built T56 Transmission
- stock lid, bellow
- Bullseyepower S362 T4 .88 turbo w/race cover for sale, mint condition $670 shipped
- rear ws6 wheels with mt et streets
- 98-02 ls1 F-body y-pipe, washer fluid reservoir
- WTT: 78mm plate for 90mm plate
- WTT: Turbonetics TC76 turbo
- Need to get rid of some parts
- TC78 and Boost cam for sale,Chicago or ship!!
- FS: Standalone harness/pcm/throttle body/MAF - CHEAP
- LT1/T56 Combo
- BMR Front Shock Spacers
- Spohn Rear Sway Bar Relocation Brackets
- OEM GM Alternator
- 853 heads in really nice shape
- LS2 water pump. ADM 100mm maf housing. w/pic
- Ported FAST, TFS Heads, Valvetrain, Oiling, Interior, 93 Z28 Partout, + Lab Surplus
- Craigslist Alert LS1 Trans Am
- Stuff in the Garage
- ls6 comp cam
- Melling High pressure oil pump p/n 10295
- Holley 750 DP, flows790 cfm, perfect for street/strip LS motors etc. Last wk on here!
- GM Performance L92 carb intake (like new, 20 miles on it!) Like new /clean!
- Dynatech Fox body stang LS swap headers 79-93 (updated version) Last week on here!
- Ss hood nice 550 obo
- FS: Stock LS2 Injectors
- 96-97 LT1 Stock Exhaust
- FS. Mecham Design 4-Port Extractor / Ram Air HOOD for 1998-2002 CAMARO
- LS6/LS1 partout LS6 Cam
- LT1 Trans Am Ram Air Hood
- 1999 Trans am Part out - LS1 w/ 16,000 miles
- WTB - Strange or QA1 Adj Coilovers for 98-02 F-Body
- (4) bridgestone potenza re050a tires (255/35zr19 & 285/30zr19)
- Fox Body Performance Parts,hurst ratchet shifter, etc. NW INDIANA, Last week on here!
- Disassembled LS1, LQ4 wiring harness
- 83 lb and hour injectors LS1
- 18' beyern five chrome wheels & tires
- Weisco 4.125 bore pistons
- Weisco custom pistons 4.135 bore
- Meling High volume oil pump 295
- Patroit extreme dual gold valve springs
- Callies compstar H beam rods
- Callies Compstar 4 inch stroker crank
- 94 camaro z28 complete part out
- FS: TSP LS7R cam CHEAP!!!!
- LS1 Edit Unlimited License/Cable
- Sold
- stock aluminum DS w/ spicer u-joints
- ebc red stuff brake pads corvette gto
- Harris nitous stand alone fuel cell/pump/regulator/filter
- 102mm TB
- FS: MSD Wires, Misc
- 4 c6 z06 OEM wheels
- L92 heads new, ls3 intake fuel rail injectors, and new 90mm eldabrock tb cable
- LS7 Intake and Fuel Rail $245 (Sold)
- Ls3 Valley Cover-Non Pvc Type (SOLD)
- Lsx Truck Oil Pan P/N 12619776
- Ls3 Rotating Assembly (Stock) SOLD
- lt1 shortblock fs
- FS Chrome 10 Spoke SS Wheels
- Ebony interior parts
- Brand new Ford Red Top Injectors
- ls1 "The timing tuner" timing and nitrous controller
- FS: 8 ID2000 injectors (2200cc/min+ high impedance!!)
- Advanced Induction 200 cc heads and cam
- Ended
- 98-02 Ebony A4 Console
- SOLD-Damaged LS1 T56-$275.00, Bell Housing and Used RAM VDS Clutch/Flywheel FS
- 226/229 cam for sale
- set of 4 rear (18x10.5) c5z06 speedlines w/ R888s
- 1999-02 A4 Wiring Harness
- MWC 9" aluminum center section 3.50 gears 35 spline Moser Wavetrac
- 2003 Z06 LS6 Intake/LS6 Clutch
- 92-94 GM optispark brand new
- WTB Sweet Thunder Bullets
- 93-02 Camaro rear lettering
- Some parts off my turbo setup
- Lunati LS1 camshaft FS
- 243 Cylinder Heads
- Metco Motorsports control arms and parts!
- lt1 383 short block
- LQ9 short block
- Camaro RS-Z28-SS OEM BodyKit
- PCM serv #12576106/ hdw# 12570558
- Custom grind cam (very similar to G5X4), Knock Sensor, a/c condensor
- GM LS3 rockers set with Comp Cams trunion kit installed
- UMI Pan Hard Bar off of 2001 Trans Am
- LS2 96mm throttle body by Professional Performance
- Virginia Speed custom LS3 cam
- nano 3000 universal kit fs / ft.
- Parting out 98 Camaro Z28.
- 4l80e Trans and Vigilante Converter
- Manley dual valve springs, seats and ti locks
- *SOLD*Ebony door panel Trans Am/Firebird No Crack
- GI- LS6 intake
- FS:Saikou Michi dual CatchCan
- ARP Head Bolts 04-
- Ebony A4 Console Top - New in GM Box
- Texas speed 408 and supercharger
- tail lights
- LS1 Engine - Long Block, Low Mileage
- 98-02 brand new kooks y pipe with custom cut outs
- ls1 conversion parts
- Complete A/C
- Valves, springs, retainers, locks.
- 441 ls7
- Pcm/ecm holder/bracket
- Power antenna
- F-Body Subwoofer Box
- Jesel Shaft System for All Pro LSW 12 degree head
- holeshot holestar wheels mickey sportsman fronts nitto rears
- SLP HD Oil pump(>2k miles). 130$shipped.
- rocker stands,gto springs, drag brags, o2sensors
- magnaflow muffler
- Shaved and powder coated calipers and brackets for exchange program
- Vengeance Racing 440 Cubic Inch FORGED LS7 Longblock
- Bare LS2 block
- borla non adjustable WITH tsp ofy pipe need gone asap
- Monster Level 3 Clutch Package
- Lots of different parts
- Air to water IC
- 6.0 truck manifolds
- LS Swap headers for foxbody
- O2 Sensors
- ws6 roller has to go--95 firebird made a CETA clone!
- LT1 Garage sale
- 2007 Monte Carlo DBW pedal
- C5 B&B Route 66 Exhaust
- 98-99 SunVisors
- FS 6.0 Trk Coil packs
- lq4 oil pan with pickup and windage tray
- lq4, 12### miles.
- Kooks 1 3/4" 98-02 F-Body Stainless Race Headers ($575 Shipped)
- Ls1 Intake, Coolant tubes, EGR/AIR Setup
- Yella Terra Rockers 1.7
- 317 heads with rockers and stands
- F/S: Edelbrock Performer RPM Carbed LS1 Manifold
- ls 6.0 engine with goodies
- SLP Manual Fan Control Switch
- Hurst Shifter T56
- Spohn Solid Motor Mounts, Black, F-Body
- lt1 prothane polyurethane motor mounts
- Nitrous Outlet NANO Full System 15lb N20, 3000psi NANO. PRICE DROP!!!!!!!
- SLP Tuned LT's Stainless/Ceramic Coated w/ORY
- lq4 parts
- lt1 parts
- 19" OEM G8 GT rims
- Milled 243s
- FS:Complete truck intake, Front accessories, water pump
- Ngs xl can with vin
- Centerforce Dual Friction Clutch T56 -$100 shipped
- Turbo stuff and other leftover parts (Price Drops!)
- NGK TR55 V-Power Spark Plugs (52 total)
- LS7 Red Fuel Rail Covers
- Fikse FM5's with tires
- Silver oem ZR1 17x9
- Ebony trans am door panels mint
- Wings West Ground Effects Kit
- FIKSE FM5 17x9.5 17x11
- F/s brand new ls6 long block SOLD
- Kenwood DNX6960
- stock camaro parts for sale, harness, pcm, etc
- Stock PCM for 2000 WS6 M6 car.
- LQ4/9, LS2, etc... Cometic head gaskets
- 7.5 Auburn posi unit with new bearings
- BRAND NEW TruFiber 98-02 SS Hood *Functional* Open to Trades
- FS: ETP/EDC head and cam package
- Camaro and Lt1 parts (alu. heads, block, suspension, auto transmission parts)
- New 99-04 Vette motor mounts & C6 LS2 Exhaust Manifold
- Torquer 7, 1.8 Rockers, HSW Fbody Cell...
- Some 69 firebird parts some orig some chrome aftermarket acc
- LT1 Camaro Steering Rack and Bilstein shocks
- Volant CAI
- Garrett GT45 80mm T4 DBB turbo
- ported 317 heads with PRC springs
- FS: Rear Drag Setup - (2) Z06 17x9.5 +54 Offset Wheels w/ MT ET Street 26x11.50-17LT
- ALDL cable for OBD1 with 16pin (OBD2) connector
- 93-02 Brand new UMI 32mm front sway bar w/ ENS Poly bushings and endlinks
- TEA Stage 2 CNC LS3 heads
- 94-95 Hypertech Programmer Great Condition Cheap!
- SOLD!!!!EATON posi/Stock posi/ axels for 10 bolt
- WTB, 2.90 Magnacharger Pulley
- Complete Super Vic Intake setup for turbocharged application
- Ls7 lifters 500 miles on them
- 5.3 lsx swap kit
- Ls2 oem short block 55k miles
- 160lb injectors
- 90mm Throttle Body & 90mm Nitrous Outlet plate
- Here's something you don't see every day! 18,000LB Rotary lift w/ Rolling Jacks in FL
- Brand New HKE 447 stroker for sale
- FS MSD Spark Plug wires
- FS: stock ls1 injectors
- Forged balanced rotating assembly LT1
- CC306 cam F/s
- FS: Complete TSP 347ci LS1
- 2010 SS LS3 Intake f/s
- FAST 65lb. LS3,LS7,L76,L99,L92 injectors
- Atrend (Pro) SQ15 Sealed Subwoofer enclosure
- Nitto NT555R 305/45/18 2 BRAND NEW
- Grey Camaro Leather seats
- LS3 main caps
- Edelbrock 90mm throttle body
- KATECH manual belt tensioner black
- 2003 Z06 cam, springs, and pushrods.
- Virginia Speed ported LS3 intake manifold
- Comp cams solid roller cam
- solid motor mounts and light weight race battery camaro ebony dash ta filler panel
- Boost controller, Spal, catch can, suspension
- FS: stock lower air box
- TCS Box, Cruise Control Module, M6/th400 spacer
- ETP 265 LS7 heads 6 bolt
- NEW Cts V LS6 oil pan / windage tray / pickup tube
- ls1 conversion harness with pcm still for sale!
- Convertible top covers for a camaro
- solid mounts, turbo hot side w/ maifolds *price lowered*
- 1998-2002 camaro ss /zo6 wheels/tires
- 7.2 summit hardend pushrods new
- ls7 clutch&flywheel,tb,maf & pushrods
- Garage Clean Up
- Headlight buckets w/covers
- (2) 2.5" QTP Electric CutOuts
- Camaro ebony leather seats
- WTB: FAST 102 for LS3
- LS7 Lifters. 3k miles, 65$shipped
- Wanted procharger
- Racecraft, Weld Wheels, 12bolt
- 96 mm Professional Products Intake w/ rails *NEW
- Crome ten spokes 01 manifolds
- FIC 95# high impedence injectors
- 98 ecu and engine harness
- Stock LS1 Parts and more
- GTO Front Seats Adapted for F Body (Black)
- Ls3 Heads, dual springs, Lingenfelter Port
- NEW OEM AC DELCO O2 Sensors (Oxygen Sensors)
- LSX emblems
- Stock LS1 Throttle Body
- M&H 16 inch 26x11.5 Cheater Slicks!
- DELPHI 85mm MAF Comp crank socket
- ARP head bolts NIB 134-3609
- Zex remote nitrous bottle opener
- Turbosmart Eboost2 with new solenoid-375$ shipped
- Wiseco -11cc 4.005" dished FI pistons for stock crank/6.125 rods used 350$
- FS: [NW Indiana] 16" T/A wheels/tires, catback, shocks/springs etc
- 6.0 ls and 4l60e tranny and converter
- FS N2o, LS3,Procharger
- LS3/LS2 parts /new prices SOLD!
- FLT stage 6 4L60
