View Full Version : Parts Classifieds
- FAST 102mm LSXR Intake Manifold Cathedral port black
- Racing/Swap Oil Pans Water Pump 6.0 gasket Set
- LT1 T56 Lakewood QuickTime Bellhousing, GT4202 Garrett 74mm Turbo, 374 Heads
- NOS Universal Nitrous Kit (Minus Bottle)
- 2010 Camaro cats oem
- T56 Crossmember and stock shifter
- (11) 4 inch t clamps
- 09 L76 51,xxx miles with extras
- Tvs 2300
- SOLD! Beck Sheet Metal Intake and 42 Draft Design's Ultimate PCV Catch Can
- AMS 1000 boost controller New
- Toyo Proxes Tq's Drag Radials
- Wanted: FAST 90 or 92 intake manifold, rails, tb and injectors
- metco 2.5 ring only
- Ls1 parts
- B&M black diamond shifter
- 2002 MINT Camaro sunvisors
- FS: LS Front Runner Setup, Camaro Center Console
- FS: F-body un cut ls1/t56 wiring harness
- Bosch 32lb Injectors
- F/S: Set of Bilstein Shocks and struts with SLP Coil over springs
- F/S: Fast 102mm Lsxr Ls1 Ls2 Ls6
- LS6 Intake - Great shape, also LQ DBW TB
- NEW Kooks O2 Extension and 93-02 Auto Shifter cable
- Steering wheel with radio controls, air bag, sway bar, impact wrench
- [SOLD] TrickFlow 220 Fast as Cast Heads, Dual Springs & Yella Terra 1.7 rockers
- LS1 ported and powder coated MAF
- WTS: ARP Extended Wheels Studs 100-7708, New In Pack
- WTS: Camaro/Firebird 4L60E Transmission Shift Lever with 10 mm Ball
- MTI clear lid, protorque LS stall, 896pcm, LS1 shortblock, upgraded ls1/6 rocker arms
- 411 ECM VATS delete LS1 LS2 swap
- FIKSE FM 10 wheels for sale, 18x10.5 and 18x9.5
- (SOLD) Brand New N.O.S. Chrome Firehawk Wheels
- 317 heads
- Speedmaster 02-06 head studs nib
- LS1 PCV system, coolant crossover, radiator hoses, valley cover
- Gun metal C6 17's an New Tires!
- Billet Fbody engine mounts/stands
- SLP 3 1/2" round tips for sale
- Plug & Play Ecu and Harness MS3 Gold Box EFI
- LSA supercharger base
- Sun Tach and Auto Meter Pro Shift Light
- 5" Sports Comp Tach
- Weiand Lingenfelter cathedral polished intake
- low-mile OEM LS3 injectors
- LS6 intake manifold $350 shipped
- Brand new prc 225 cast heads
- Parting out s13 ls swap
- Extra Parts
- 6Spd Crossmember
- T-top shades
- 98-02 SLP High Flow Lid
- F body clear lid w/stock maf+smooth bellow
- TCI, Yella Terra, COMP CAMS, 243 heads, Fuel Rails, BMR,
- Innovate MTX-L WBO2
- HRE 540 17&18 set of 4 wheels with tires .
- AN Hose Test Kit Includes: 4AN, 6AN, 8AN, 10AN, 12AN, 16AN Fittings
- Cammotion Low Lash Solid Roller Holley Ls3 Dual Plane Manifold
- 14 Rib 1:1 Rear Drive Pulley Set + belt & bracket for TVS 1900 or 2300
- RHS Ls7 pro elite 291cc 6 bolt bare big flow heads
- BMR TH400 crossmember
- 5 Gallon Air to Water With Ruel 3700 Pump
- Viper 5900 car alarm and remote starter brand new, never opened. -SOLD SOLD SOLD
- 434 CI 700 hp LS racing engine
- Budget drag setup
- Nitrous Express kit for sale
- GTO Wilwood Big Brake Kit
- Brand New S475r. T6 1.32 a/r
- new in box mufflex 4" exhaust with spintech muffler for 98-02 fbody
- GARAGE SALE Nos plate, yella terra, XR288 CAM, 224-230. COMP Cam, Tci, NX,
- Black CCW classics drag pack for sale
- Holley 5.7 LCD display for sale
- Arp 234-4316 HEAD STUDS 12 PT
- FLEXLINE KIT,CHEVY,55-57/UNIV 16in. KIT,3/8-24 TO 90 DEG
- (SOLD) LS6 Intake Manifold (Check the pictures) #12561184
- brand new cam motion cam EPS
- ls performance parts for sale!!
- LS3 intake
- Morel 5315 Lifters NIB
- 2 C6 Z06 Forgestar F14 rear wheels 18x12 **Sold**
- New (take out) Gen IV rods
- Burkhart Chassis steering shaft
- Comp Cams Ultra Gold and Summit rockers Price drop
- New COMP XFI XE-R 238/240 605/609 112lsa
- Two (2) Truck Intakes for sale, one with TB
- Ported sdpc243s/Cam motion cam SOLD
- Berger Panel. Chrome "CAMARO" lettering & lsx badge
- Cloth seat covers Camaro
- cc503 new never used
- Trailblazer SS Hood Scott's Version 2 Carbon Fiber "Show Finish"
- 3 Channel Backing Plates
- Bnib .010 over je ls2 rings
- LS7 clutch kit for sale
- BRAND NEW - Kooks 3in Catalytic Converters - FOR SALE!!
- boost/pulsh leash, th400 cross member, wiring harnesses
- ****Parting out 1000+rwhp C6 Grandsport Driveline****
- 68-72 a body suspension
- Ls6 valves
- 78mm wet plate system and polished bottle
- EFI Vic Jr, Spectre 4150 hat, wheels/tires
- Sanderson Headers LS134
- CTS-V/ZL1 Clutch
- MMS/AFR 235's, 416 Stroker, and more
- 39 lbs fuel injectors. Rebuilt cleaned and flow bench
- Aquamist hpf4-pwm meth kit
- 4th gen custom turbo setup
- Custom LS braided / AN Steam line crossover
- Dirty Dingo accessories mount
- Ls1 intake manifold
- Lq4 rods and pistons
- SS long tubes for Fbody
- unlimited carbon seats. (4lbs each)
- Polished Reverse Rotation P1SC-1 Procharger
- Johnson short travel lifters
- LS1 Intake Manifold (non-egr)
- 1500hp/1000tq UCC convertor for th400
- Turbo Cam, 226/226 605/605 117
- Harland Sharp SLS17A rockers
- APR Main Stud kit 234-5608
- accufab 4150, vic jr, 80 lb injectors, nx 4150 plate
- Ecs 1500 c6 kit for sale
- Powerbond 25% underdrive pulley for 04-06 GTO/98-02 f-body
- 98/02 camaro exhaust
- FAST intake manifold LS1 LS6
- 5.3 Intake + Stand-Alone Harness
- Bosch 044 + pre-filter
- New 102mm Nick Williams tb
- New FAST 102 Cathedral port intake
- 2008 GXP 5.3 Grand Prix Part Out
- F/S: V-9 G Vortech Supercharger Kit
- Spring kit, injectors and roller rockers
- ls3 coil packs
- CNC'D 241 heads
- OEM C6 Wheels
- 317 heads
- ls1/t56 rx7 partout
- 50lb New GM Injectors, 12613412, Set of 8, Genuine Delco
- Ported 2011 CTS-V LSA Throttle Body (DBW) fits other 6.2/6.0
- T56 for sale
- 224/230 114+2 Cam
- FS: Rear shocks. Rancho single adjustable 9-way for Cal Trac setup
- FS: Extreme Velocity PRO TB/carb hat
- LS1 engine and more
- Ls1 intake complete.310 truck coils
- Jesel Shaft Mount Rockers & Morel 4708 Drop In Racing Lifters!
- Gen 1 383 stroker and misc parts for sale
- T56,driveshaft, clutch and more
- slp maf
- Sold- Polished/Stainless dress up items – 98-02 Fbody
- Misc Fbody items
- 415 Stroker Pistons
- Brian Tooley Racing 7.40 .080 hardened push rods
- Saikou Michi S1-LS1 DC3 Dual Oil Catch Can
- FOR SALE: 241's and Metco LCA's.
- LS7 Heads, complete & GMPP LS7 LSX Carb intake
- 4.8 boost ready LS iron block
- Stock LS7 intake manifold
- Ls headers studs
- TRE flow matched 42# injectors
- SLP Intake w/ K&N Filter
- Ported LS3 Heads
- FS: Deka 80 pound Injectors! Long body EV1
- Ls6 intake with throttle body
- F/S:1400HP Rear CV Shaft w Larger 30 Spline Pair
- Tick Performance Level 2 turbo cam
- F/S:GTO OEM LH RH Interior Front Inner Door Panels Pair
- Corvette fluidampr crank pulley
- F/S:Pedders GSR Street II Strut Shock spring kit w BMR Drag bags
- Sparco seats
- FAST intake, Bosch 36lb injectors, throttle body and fuel rails
- C6 Exhaust Manifolds, 241s, rockers and stands, stock ls1 parts, ls7 lifters
- TRZ LCA relocation brackets 3rd & 4th Gen new
- BMR AC delete plate new 4th gen
- Msd 6012
- OEM Fifth Gen Camaro Engine Covers
- Vented optispark $25 shipped
- Pushrods, HOOKER LS mounts, Gears, ARP
- Strange rear Coilovers with 150 lb springs
- WTS/WTT: turbo parts, rolling chassis, etc...
- Trick Performance Turbo Manifold
- Kooks 1 7/8x3" headers and Y-pipe
- F.A.S.T 92mm intake/ Nick Williams 92 mm TB
- LE LT1 intake, LE LT4 intake, LE billet cam, Holley 58mm TB
- Two Turbonetics 6668's
- 2000 Trans Am engine harness
- U.S. Exotics Super Hawk Hood**New**
- 1999 Camaro SS Hatch
- F/s: 2004-2006 Tail Light Set PAIR
- BMR suspension parts, 9", ATI damper, Hooker LTs (Garage cleanout sale thread)
- FS:Twin GSX67 Turbos
- New SW long tubes for S10
- 2 vsracing 88/83 turbo for sale
- LS6 OEM Injectors EV1
- Borg Warner T6 S475 w/ Race Cover 96mm 1.32
- Garrett GT55-94 Billet ETR Turbo from Forced Inductions
- FS: LS2 short block w/ covers
- eBoost Street
- On3 98-02 Front Mount Non-A/C Turbo Kit BRAND NEW never used with upgraded parts
- Ls1 Coils with relocation brackets
- Spal 10" puller fan 30102057
- FAST 102 LS3 Meziere pump TB
- Dakota Digital Universal Gear Shift Position Sending Unit GSS-2000 Used
- 128k High Frequency GM Pulse Generator Dakota Digital Used
- Fast Throttle body
- C5 Z06 replica 17x9.5/18x10.5
- Carbon Fiber license plate frame
- 243 Heads
- AEM Tru boost, boost controller
- OEM 2002 WS6 speed line wheels
- LS9 Camshaft New in Box
- New Scat H-Beam Rods
- FS: Pacesetter LT headers 72C2265 - $250
- 3" catless downpipe. LS4
- Camaro/Trans Am Misc Items
- Work billet s482
- FAST 78mm intake manifold, Bosch 36lb injectors, stock fuel rail and tb
- Gmmg catback
- Stock LS1 Intake for sale.
- Precision 46mm Wastegate BNIB
- LS3 Cylinder Heads
- FS: LS2 heads
- Stock Z28 Air Box
- 243 heads off LS2
- New Dart LS1 heads
- brand New Mahle LS3 Pistons For Sale
- BMR TH400 Transmission Mount
- KPE (Airaid) 2009+ CTS-V Intake (Dry Filter)
- FS: BS3 24 tooth 004 003 With GM Trans harness
- F/S: Ram clutch with flywheel
- Turbosmart e-Boost2
- LY6/6l90e
- Garage clean out. LSA stuff and more
- 243 ls6 heads from 02-04 Z06 with OEM hollow/sodium valves
- tick stage 3 turbo cam brand new
- 102 mm kenne belle ts9001 series supercharger kit corvette ls1/ls6
- 85mm Throttle Body
- 2001 Camaro Z28 part out
- WTS: NEW ARP Pro Series Cylinder Head Stud Kits 234-4316
- 2, new nitto nt555 285/40/18 tires
- 100 PSI Fuel Pressure Sender
- Ported LS1 F-body Throttle Body
- **Corvette C6 Z06 Style Replica Wheels**
- 2004 5.3 rods and pistons
- Entire nitrous setup, NANO, Stand Alone, hardlined 102mm plate
- Huron Speed V1 A/C retaining turbo kit
- Nitrous Outlet Purge
- F/S: Fays2 Watts Link
- (Sold) B&M Magnum Pro Stick shifter
- Mahle 12.2 427ci Pistons
