View Full Version : Parts Classifieds
- Custom Nitrous Switch Panel with Pressure Gauge
- Wiseco 4.005 x 4.0 -8cc pistons
- Jakes transmissions th400 auto lvl 4, rollerized
- 98-02 Trans Am WS6 hatch w/spoiler
- 2006 Corvette Z06 brochure foldout poster
- Racetronix 255 & Hotwire, already installed
- LS1 Fbody Power Steering delete belt, idler and spacer
- OEM LS3 injectors
- Stage 8 Locking Header Bolts Chevy LS Engines
- 4150 NX plate with solenoids
- NX nitrous acc, comp cam,
- Turbowerx Exa scavenge pump
- Rectangle port top end
- Dynojet Wideband 2
- Huron v2 turbo kit for sale
- UMI Tubular K-member (non turbo)
- Kent-Moore Time-Sert Kit - LS1, LS6, 5.3 GEN III
- 6 speed cruise control module
- Tr6060
- DiabloSport inTune i2 i2030 GM programmer with 7 GM licenses.
- 85mm lid and MAF combo
- Strange manual brake conversio, sjm abs delete with line lock for 98-02 fbody
- Iron 6.0 Professionally built Long Block For Sale $3500 OBO
- Sold!
- ES Autometer Oil temp gauge
- ES Autometer Fuel pressure gauge
- Misc 93 LT1 Parts
- Nitrous outlet ls1 plate
- 6.0 long block
- Efi source ls1 style 3 bar map
- f body K&N intake, Ls1/6 Map sensor
- Nitrous Express Maximizer 4 Controller
- PAC-1209x Valve Springs
- Comp Cam
- Walbro GS342
- NEW LS3 Fuel rail
- Aeromotive FPR 13129
- LT1 - Holley 58mm throttle body, new in box
- C5z Kooks High flow catted midipe and FAST 36lb inj
- COMP Cam For Sale - SOLD
- LkE ls3 417 stroker low miles
- Complete LSA Blower F-Body Kit
- F-body Camaro Crossmember
- K&N cold air kit 1998-2002 F-body
- Siemens Deka 60lbs. Fuel Injectors
- H&R Sport Lowering Springs Pontiac G8 (2008-2009-2010) 50750
- Turnkey lq4/ls3 carb to pan with msd box
- ARP head bolts 04+
- FAST Big Mouth 102mm throttle body,
- Potz ls1 throttle body
- American racing torq thrust m black with machined lip
- LT1 Electric water pump motor
- Zl1, Ss parts, headers, intake Npp exhaust mtw
- lq4 6.0 block
- tig welding torches & cables
- QA1 coilovers
- Weld rts s71 drag pack F/T
- New 66mm wastegate
- FS: LS6 intake, ported TB and fuel rail... $425 shipped
- Huron Speed V3 Hot-Side T4 Turbo Kit with Turbo & Cam
- 2016 GM Performance LS376 525HP Crate Motor
- C6 Z51 brake parts and a sub box
- Pcm,LS6 fuel rails, brake booster, truck intakes,books
- Hurst t56 shifter umi stick
- 0411 ecm (vats & emissions deleted) $100
- GMPP CNC LS3 heads
- S480 ETR-HO Turbo
- 60mm JGS Wastegate
- ID 1300 injectors
- NEW Race Star 92 Black drag wheel 15x10 4.5 inch backspace
- BTR Platinum Spring Kit, 7.400 CC PR 3/8"
- OEM Stock LS1/LS6 Timing Chain
- Stock F-Body T56
- Ls3 0821 heads
- 2wd 4L80e
- Greg Banish tuning dvd’s
- C6 Corvette LS2 LS3 Oil Pan GM #12624617
- Stock 2004 CTS V Silver Aluminium Hood
- McLeod RST clutch #6912-07 twin disc clutch assembly and McLeod flywheel 600 miles
- Smooth painted Ls1 fuel rail covers
- Midwest Lower A Arms and Viking front Coilovers fbody
- LS3/TR6060 dropout
- Complete LS6 Intake
- Big Stuff3 (SOLD)
- FS: Jesel Solid Roller lifters NEW
- Ported ls3 heads, TSP cam, ls3 intake and 52lb injectors
- Custom grind 3 bolt comp cam for LS 236/244 578/595 114+2lsa
- 2006 C6 Z06 Shifter assembly with lower box
- Lingenfelter 100 MM Mass Air Flow Sensor - MAF - GM Applications
- 1999 Camaro Part Out
- 60 lb/hr Deatschwerks Delphi truck injectors
- Wanted ..A4 99-02 main WIRING HARNESS
- Square port LS3/LY6 valve covers, SOLD.
- 99+ Dual pump/wiring setup
- 2 tial 38mm wastegates and springs
- Holley 554-114
- WTS: 5.3L LS Flex Fuel Injectors (8)
- 4th gen F body ebony sun visors
- Brand new mamo ported LSXR 102
- NOS WOT/RPM window switch
- FS: 2001 Alcoa Z06 wheels
- 4 brand new 265/40/18 pirelli p zero trofeo r trophy tires cheap free shipping
- Brake booster/master cylinder/calipers/brackets
- Stock rear springs out of 2002 Z28
- A4 trans bracket from 2002 F-body
- Stock flexplate off of 2002 lq4
- Strange Chromeoly Trans Yoke
- Yank ss3600 for 4l60e
- For Sale F body D1 Procharger set up with extras
- NEW Holley dual quad dual plane with rails, TBs, linkage
- LS3 Fuel Rail (works with FAST manifold) and LS6 Injectors
- WTS/WTT Corvette Spyders 18x9.5
- Brand New LS6 Intake Manifold
- 4 chrome C5 thin spoke wheels and 4 Goodyear Eagle F1 tires
- 2000 f-body PCM-SOLD
- Complete LS6 Intake FS
- Black 102 Warr TB
- Ls3 heads for sale
- LS3 intake complete
- Nick williams 102mm tb black
- strange 12 bolt / auburn posi 3.73's SOLD
- sOLD TCI EZ-TCU trans controller for 4L60, 4l80 etc
- ARP 234-5608 LS Main stud kit
- F/s tci 3600
- Racequip Jacket/ Used Line Lock/ CBM Water Pump Fitting
- new BTR cam/procharger pulleys
- LS6 intake, TB, fuel rails & injectors
- 4l60e & 4l65e new oem solenoid kit 2003 to 2005
- JE 4.005 pistons nascar pull outs. LS7 and other parts
- NOS Mini2 nitrous controller
- SOLD: LSx 99-02 Truck Engine/Transmission Harness (RED/BLUE, Cable TB 4L60E)
- Ebony Leather Rear Seat Back
- LS4 exhaust manifolds
- SLP Oil Pump, Clean Aluminum 5.3 Gen4 Short Block
- Holley LS hi flow fuel rail fits stock manifold--SOLD!!!!
- 02 pcm 411
- Stock 317s with LS6 springs
- WS6 Speedlines Original Goodyears. Excellent
- PAC 660 Springs!
- Hawk Performance 9012 Pads
- Edelbrock Victor jr
- Ls2 ls6 ls7 corvette , ss silverado new coils oem gm 12573190
- Kenwood excelon dnx693s double din touch screen nav
- Water pump spacers (truck)
- SOLD High Impedance HPI Injectors - 120lb SOLD
- Rapid Motorsports Dominator 2
- 3 foot GM performance parts decals
- Granatelli 85kv coil packs and performance wires
- Rebuilt Tremec T56 zero miles
- Camaro or Corvette chrome z06 wheels $500
- Nw 102, Holley 105
- Kooks True duals camaro/firebird
- 862 Heads with .650 springs, GTO stock shifter
- GMMG, Nitrous, and more
- Lnc 2000 SOLD
- TSP 228/232 .615/.615 112 LSA Camshaft
- F/S Borg Warner S369 sxe super core
- Front Brakes for 4th Gen and pushrods for sale
- Dragonslayer crankshaft
- Cathedral FAST 102 setup
- The Tuning School. GM lvl1 learn from home package.
- Brand New GM LS3 head gaskets
- 17x9.5 TT2’s VN615 brand new
- 2002 z28 10 bolt for sale
- Sub Box 3 12's
- Fast EZ-EFI 2.0 Engine Control Kit - New in Box - SOLD
- BTR .660 Springs with Titanium Retainers and Locks
- Circle D 3C 3600 nitrous conv
- FIKSE FM5 - 17x9.5, 17x11
- Ls3 injectors and Valve cover spacers
- Fast 102, PRC heads, TSP headers, Custom Y, + other parts
- 2002 Camaro 35th Anniversary SS Hood
- 295/35r18 Bridgestone Potenza RE760
- GenIII truck harness out of 06 Escalade.
- EFI Source MS3 Gold box with universal harness
- LS2 Pro Flow with rails
- Alky control methanol system
- FS Firebird Aluminum Three Rivers Driveshaft, TB, truck oil pan, t56 flywheel
- Ls1 Factory Rockers
- Racetronix In Tank 340lph Fuel Pump and Hotwire Kit
- Circle D Torque Converter, Big HP Driveshaft & Gauge Pod FS
- (2) Turbine Housings - T4 .68 A/R P-Trim
- Complete LS1 from a C5
- UMI subframe connectors 93-02 F-body - Red - bolt in - SOLD!!
- Midwest Chassis Driveshaft Safety Loop - Fbody - Black
- LS6 Z06 intake manifold, LS1 DBW TB, C5 and Truck exhaust mani, water pumps
- Katech blue LS7 oil pump
- All kinds of f body parts!switch panel,cluster,door panels,body
- WTT M6 Console Top for A4
- 2010 Camaro SS partout
- random stuff. lsx g8 gto f-body.
- Fast 90mm t/b
- LS7 engine harness 40k mi clean
- A&A Corvette secondary drive system
- FIC 850cc injectors
- New lunati 4" crankshaft
- ZL1 pump
- F/S LS3 Rockers with Comp Cam Trunions
- Garage clean out. Trans am seats. rear seatbelts. Hood
- 93 NV3500 5speed for trade!!! WTT for T5, T10 or Saginaw 4 speed
- Nick Williams 92mm throttle body
- Ls6 fuel rails,truck pan,etc
- Trunnion modded rockers
- 22" Billet Wheels(New Lower Price)
- SOLD LS3 Valve Covers GM CT525 Crate Motor
- Line lock
- New king billet ccw ls crankshaft
- Trans Am LED Dash Cluster
- FS: 5th Gen Camaro SS parts
- LS1 SPEC Clutch and pressure plate.
- FAST 36pph injectors
- NEW ls1 forged shortblock
- Speedhut 3 3/8 Tachometer
- 2001 4l60e Transmission w/ wiring harness
- 4 Speed Saginaw Transmission - SFI Bellhousing - Good Condition
- PRICE DROP NEED GONE ASAP: Corvette Electric Throttle Body
- Fi Tech 70050 standalone
- Stock LSA Injectors
- Performance and stock parts for sale
- Weldstar RT 15" x 10" - 4.75" Bolt Pattern - 4.5" Back Space
- Ls1 throttle body and flywheel
- AFS C4 17x11 ZR1 made in USA OE front
- Ls comp cam
- Mustang LS swap headers
- 03 LQ4 OEM Parts
- 22" Billet Wheels
- LS1 42lb (53lb @ 58PSI) Green Giant Injectors
- Weisco LS3 pistons
- 98-02 TA tail lights
- LS1 Fbody garage sale: alt, starter, knock harness, MAFs,
- F-body Acc brackets water pump P/S lines belt pulley etc
- NEW GM swap oil pan swap kit
- L33 and LM7 Parts
- Brand New BTR Stage 4 Cam
- gauge cluster, white gauge, HVAC, headlamp switch overlays
- LS3/LS7 MAF Housing Spectre 9705
- LS rear cover w/hardware and gaskets, SOLD.
- Siemens Deka 80lb EV6 injectors
- B&M Stealth Ratchet Shifter Carbon Fiber Pistol Grip
- 93-02 camaro passenger airbag
- LS1 intake manifold, SD 60s
- stock LS3 DBW throttle body
- STOCK LS3 injectors
- LS3/LS7 lifters
- COMP Cams Ultra Pro Magnum Rocker Arms 1678-16-- sold
- stock LS3 intake w/ map sensor
- LS3 821 casting heads with comp springs kit installed
- LS1 Parts
- A.I.R. check valve
