View Full Version : Parts Classifieds
- GM factory knock sensors
- Sold
- Comp (T&D) 1500 1.7/1.7 Ratio Aluminum Shaft Rocker Arms
- QTP Wireless cutout, AC bracket, starter, PCM, etc
- Fs: Aem infinity ecu with BoomSlang Fabrications harness
- SOLD - ls3 intake w/ fuel rails & injectors
- LQ4 block, rotating assembly, etc.
- 98-02 brand new slp line lock
- C5 dedicated fuel cell
- Kooks quad tips
- Complete LS6 Intake/Rails/Injectors/TB
- Like New Tremec T56 Magnum(6060) TUET-11012, less than 1000 miles
- Nitrous outlet parts
- LS3 Intake,LS3 rockers,LS3 fuel rail,LS6 cam
- BTR .660 springs Ti retainers
- Trick flow 255cc -Needed!!
- 97-04 C5 Corvette Tigershark bumper / nose
- S o l d
- BTR .660" Platinum Springs Titanium retainers
- SBC valve covers w/spring oilers and left side breather tubes
- WTS 99-02 f body Camaro engine harness, for auto trans
- Through-the-radiator oil/tranny cooler mounting kit
- For Sale: 55lb injectors
- Free Battery Cutoff Switch
- Flex Plate off of new crate LS3
- Weld RTS front runners
- Jokers ported LS7 throttle body (gold plate)
- Huge 98-02 fbody turbo partout ! Lots of nice stuff
- PRECISION TURBO GT4788 88mm .96ar
- 91 Firebird seats.
- LSA internals, pistons, rods, cam, snout and balancer, valves and more for sale
- 3" Bullet style resonators Stainless Steel
- Ported Super Victor LS3 intake-new
- 93-02 F-Body Drag Pack (Racestars)
- Ls1 Camshaft position sensor
- Ls1 Mass Airflow Sensor SOLD!!!!
- ls6 intake,nitrous and circle d converter
- Comp Cams Hi-Tech Pushrods 7.800 Chromoly Hi-Tech Pushrods
- C6 accessories
- Comp solid lifter cam 225/230 .562 114 lsa
- Fuelab pump and regulator
- Stainless works turbo headers
- FS: magnavolt boost a pump
- Bosch 160lb/hr injectors
- SOLD! Air conditioning kit A/C compressor, bracket, tensioner, belt, bolts
- Mishimoto Intercooler
- Looking to trade T56
- Oem firehawk hood fresh paint
- Big list of parts!
- Complete 5.3 4l60e Harness, PCM, Throttle Body, and Coil Packs.
- Used LS7 Heads
- Turbo Smart boost controller
- ARH 2" primary with ORX for 5th gen camaro $1100
- Heads/rockers/shifter/studs/spacers
- LT-1 vacuum lines and fittings
- SOLD....LJMS/Wiseco 5.3 Turbo pistons, Callies Compstar Rods, ARP main stud kit
- Tick Adj Master and Speed Bleeder 98-02 F body
- FS: Metco 2.85 Upper Pulley for LSA
- 3.45 Rear differential out of 2014 Camaro SS
- A/c bracket ict billet
- FS: Ls9 Head gaskets and stock 317 6.0 heads
- Moser 9" inch WaveTrack and Nodular iron case FS/or trade for Spool Aluminum center
- FS: LS7 Longblock or shortblock
- MSD Coil brackets and LS1 coils
- LS6 Intake Manifold TB Fuel Rails
- On3Performance LSx F-body Single T4 Kit (Except turbo/intercooler)
- PowerBond 25% UDP + JP Performance Timing Set
- TBSS Intake (90mm inlet), LS3 coils
- Stock LS1 rockers, oil pump, PS cooler.
- PSI Max life springs .625" lift, PB 25% UD pulley with belt, MAFS
- new ls2 waterpump-used 97/04 vette throttle body
- Dakota Digital BIM-01-2 OBDII Interface
- Used Vararam VR-SDR for 2005-2006 GTO
- 4L80E 2wd
- ARP rod bolts, 130 amp Delphi alternator.
- LS3 standalone GMPP harness and ecu
- ARP thread Chasers
- Corvette 2014 Gen V LT1 Complete Used Engine, Needs Rebuilt
- Lingenfelter TRG-002 58x-24x
- TCI SFI rated flexplate brand new
- Assorted parts.
- Sold
- Slp maf (2004 gto ls1)
- Hallman boost controller (manual)
- Edelbrock 2 piece timing cover
- Ams 500 brand new
- Trade my 95lb injectors for 80lb injectors
- Spohn Chassis Torque Arm - Seattle - $300
- *sold*GTO Kooks headers BRAND NEW *sold*
- 4.8 Truck Engine (rebuilt)
- New Turbosmart E-Boost2 w/shift lights SOLD
- Fast 92 Intake, Rails, PMT 92 TB & extras SOLD
- 823 Cylinder Heads. Complete. *REDUCED*
- 99 trans am ls1 6 speed partout
- 14' 6.0L / 6.2L Rec Port intake Manifold w/ injectors & rails
- Sold New tt2 classics and nitto 555 and 555r's price drop
- Callies Compstar Crankshaft 4.0 stroke 6.0l
- 97-02 6 speed upper console insert
- Madman 2 piece motor plate
- BTR .660" Platinum Valve Spring kit
- Summit 25% UD Pulley/02 ws6 lower airbox
- 58mm tb
- LS6 Intake
- Fore F2i fuel regulator ( BRAND NEW!!)
- SOLD: 93-97 LT1 F-Body Vortech v1 COMPLETE kit
- Rear lower control arms
- 6.0 starter new, electric oil pump
- Built T56 swap FT
- 1998 - 2002 Camaro SS Wheels w/tires, 40k miles
- 416 Nitrous LS3 - PRICE DROP
- Diamond Racing 11519R 4.030" Pistons
- Fuel parts, valve springs and Katech Tensioner
- HPtuners Pro w/Hewitt Packard I3 Laptop
- Refreshed Forged Iron Block 6.0 Long Block
- 4.8 iron block twin turbo engine (complete)
- Diablosport-Predator-u7198
- Comp Ultra Magnum LS3 Rockers
- ATI damper
- CCW SP505A 18"-19"wheels and Dunlop tires
- CCW black chrome SP500 with Michelin tires
- Huron Speed V2 AC Kit Down Pip
- Ls1 cam degree kit (comp cams)
- 04-06 GTO parts
- Question about purchasing an item?
- Nick williams 102 throttle body
- LS2 Intake with Stock Injectors and Rails
- Arp 234-5608 ls main stud kit
- FS: GM LSX454 Camshaft
- New LS1 & LT1 T56 Release Bearing to AN3 Line Fitting
- 2006 GTO T56 Bellhousing & Starter
- BMR tubular Fbody LCAs free shipping
- All type ls sht blks al and iron rebuilt from 1500
- Eagle h beam rods 6.125" 2.000" journal
- Comp, OEM, and mystery pushrods 7.4"
- Jesel Sportsman stainless roller rockers
- ARP 134-3609 head bolts for early LS1
- x4 5 Spoke stock 16" chrome wheels & tires
- LS2 longblock
- SOLD *midwest racing single disc lockup converter, fresh!*
- Volant cold air intake for trade
- 07 5.3 Complete wiring harness and ECU
- Torque Rush X-Link
- High Performance Injectors High Impedance, 60lb - 250lb w/Lifetime Warranty!
- Price drop! P1sc-1 Procharger fbody kit $2500!!!SOLD!!!
- LS swap mustang full exhaust
- Billet S485
- T56 Hydraulics and Exhaust Parts-SHIPPING INCLUDED
- Sold sold sold
- Edelbrock 3848 elbow
- 6l80 for sale Best offer
- MSD APS 5096 LSx Starter
- 0411 PCMs. $60 shipped!
- Ls3 throttle body, and x-link
- LS Billet main caps, BTR Spring Kit, LS2 intake manifold, tial 60mm and more
- FTI 3200 stall converter, 400 horsepower rating
- Precision 8884 CEA Turbo
- TEA Trickflow 255 Heads - BRAND NEW
- 5th Gen Camaro Carbon Fiber Airaid CAI and SCT 4
- TFS AS cast heads/cam/Fast 102 intake 10sec combo
- FAST LSXR 102 cathedral port
- Edge (Siemens, Deka) 60lb/hr injectors
- ARP 134-6006 connecting rod bolts
- JP 5615T adjustable double roller timing set 3-bolt
- Melling 10296
- LS1 Coil Packs and Brackets
- 2003 6.0 Coil Packs
- 2003 Express Van Harness and ECU
- Fbody Engine Harness
- 0411pcm
- Mantic Clutch 9000 Floater Plates
- NEW FAST 102mm (Cathedral Port)
- C5 Corvette Thin Spoke Wheels 18"rear 17" Front
- FTI TH400 level 4 with F-body BMR crossmember, shifter and dipstick
- LS6 Intake W/ Throttle Body - SOLD
- Billet Aluminum Valve Covers LS7 & LS3 dry sump
- Manton Series 5 Pushrods 7.96 inches x 3/8
- Doug's Headers 3 inch electric cutouts
- MSD EFI live LS self tuning kit with LS3 injectors
- Kooks LS Swap Headers for Mustang/Holley/FIC/TCI
- Bosch 160lb injectors. ev1
- ARP rod bolts 134-6006
- Circle D Billet Pro series Converter 4L60/65/70 New!
- Truck coils
- 98-02. Maro PCM
- Yella Terra Ultralight 1.7 LS1 Rocker Arms
- Morel 5290 link bar lifters
- T3 and T4 turbo blankets
- C5 Corvette LG Big 3 Mufflers
- Pfadt c5 c6 corvette engine mounts
- Evans LS1 LS6 high flow water pump
- Lq4 complete engine pullout
- Aerospace brakes and rotors
- BTR Platinum dual spring kit
- MS3 Cam, Gen IV truck Intake, and Valley Covers
- Nitrous Outlet FAST 90/92 Plate, hardlines and solenoid brackets
- C6 Grand Sport hood liner
- Tsp MS3 cam F/s
- LS1 Rockers & Stands
- Loudvalves 4" Boost Activated Exhaust Cutout
- FS: TCI Flexplate 399753
- 15X10 Weld RT-S 5x4.75 - 5.5 BS
- Non-Castech 706 Head
- 98 to 02 camaro stock headlights
- 17x9.5 racestars
- 09 cts v lsa engine, supercharger, and 6l90 transmission
- FS: Pacesetter LT headers 72C2265
- 93-02 camaro/firebird moser 9inch rearend complete
- SBC 383 cid sht blk hi Nickle 4 bolt forged
- 2000 LS1 & Tick MC
- Nitrous Outlet 12lb carbon fiber bottle
- WTS: Console Lid Cover for '97-'02 Camaro / Trans Am, Charcoal in color
- Qa1 struts and springs
- New Kooks longtubes 06+ Z06/ZR1 $900? SOLD
- LS1 intake
- wire crimpers
- NOS A.I.R. pump kit GM#88880033
- 93-97 T56 console shifter plate
- Fast 39lb injectors Brand new
- Lunati PRO BILLET forged connecting rods LTE-9
- FUEL INJECTORS*BRAND NEW* SIEMENS/DEKA 60 LB/HR-630cc
- Complete ls3 intake with x-link
- Custom Elite Catach Can
- ZEX TPS switch and RPM activated switch
- SOLD Fast EZ-tcu trans control unit & TPS unit for Carb
- C5/C6 accessories drive w/ waterpump
- 416 LS3 short block/ Trickflow 235 Heads
- PRECISION 160lb injectors and AEM driver box
- Wisco Pistons 3.903 -11cc "Brand new"
- Lt1 gauge cluster plate
- TSP Rumbler True duals (NEW)
- 377cid blueprint , Callie's crank forged p/ rds
- Sold
- Cloyes Hex-A-Just w/o chain
- LS1 engine harness and LQ harness plus more
- 2 f-body vigalante tourqe converters - $500 (N.E Philly
- Lingenfelter 24x-58x conversion module
- Brand New NOS window switch
- Victor Jr. Intake, 90mm Throttle body, Elbow
- Tick Adjustable Master Cylinder. NIB
- Garage sale! Misc parts
- VFN Hood/Optic Armor/MWC Kmember/manual rack/Tick Battery relo kit/Turbo kit
- MMS Manton Pushrods (New)
- 17" racestar drag pack
- 3.23 rear gear-SOLD
- 6.0 6.2 al or iron sht blks
- Cam, spring kit, converter, trans cooler
- 7.0 427 ls7 almost complete engine BTR cam
- 241 complete heads $150
- LS3 Super Victor EFI 4500 with Induction Solutions X275 Direct Port
- Coil relocation brackets
