View Full Version : Parts Classifieds
- TBSS intake complete
- Ls6 intake with fuel rails
- 224/232 Cam Motion Cam brand new
- New TSP Torquer V2 +Comp & Performance Parts
- Ls1 complete engine and 4l60e swap
- SOLD HP Tuners MPVI Pro SOLD
- 4th gen Camaro leather door panels
- CNC L92 Heads Complete
- LT1 F-body A/C compressor, poly motor mounts
- 4" I/O Bullet muffler
- BBC 565 rotating assembly
- Fuel stuff. Walbro Racetronix gt500
- ALKY Controller + Gauges + Pillar
- Koni yellow sports SOLD!!!!!!!!!!!
- Ls fbody longtubes
- 4th Gen 98-02 Rear Backing Plates + Calipers
- Sold
- Yank SS3600 and 4L60e *SOLD*
- Gauges for sale fuel / nitrous / wideband
- Nitrous Outlet - Jets, blow down tube, brackets
- Turbo kit, injectors, torque arm, tail lights
- Diamond 4.030" -15cc Pistons for 4" Stroke
- DM Main Girdle
- Behind Bars Racing Fuel System Pro Touring - Magnafuel Pump
- Complete ProCharger kit
- ls3 manifold 102mm tb
- 799 heads 95k miles dual valve springs
- FS: LS9 Heads complete
- Gen 4 Aluminum 5.3
- Ly6 truck intake with fuel rails and 92mm throttle body
- Complete Ls1 and Roller
- Kwik Perf. high mount alternator/PS bracket Corvette Pulley spacing
- Z28 Supthump Box and SA-12
- 98-02 magnuson mp112 supercharger
- Fast 102 lsxr intake ls6
- FS: BNIB Precision PT8847 turbo
- New Holley Ultra XP 950 cfm carb
- LS3 / LS7 fuel injectors 42lb (8)
- LS7 Intake & Fuel Rail
- Chevrolet Performance 19201806 LSX-LS7 "As-Cast" Cylinder Head
- C5 Z06 Ti axle back
- Ls2 throttle body 210 shipped or trade for ls1 cam
- Siemens deka ev1 injectors - 60 lb
- Ford red top inj (8)
- New LS3 Rocker Arms with Comp Trunions Installed
- Ls1 fuel rails and injectors
- Precision Wastegate, Tial bov, Siemens 60lb injectors
- UMI T56 torque arm relocation crossmember
- ONE DAY SALE PRICING!!! LS3, D585, LS1 Coils & 0411 ECM
- SOLD 1 3/4 Pacesetters headers and ORY
- BTR platinum .660 dual valve springs
- Aeroforce Inteceptor CN series, like new
- Wtb/trade/sell driver side A pillar
- Wilwood 260-10375 Master Cylinder Aluminum Black 1.00 in. Bore Universal Kit
- Canton Racing Products 22-631 Remote Oil Filter Mount Chevy LS1 (Pan Mount)
- MWC Manual brake conversion *SOLD*
- Aeromotive fuel rails
- Borla Stinger Quad Exhaust C5/ Trade for stock w/cut outs or Corsa Extreme
- Patriot Valve Springs and HD Timing Chain
- Spicer driveshaft
- WTT 2 Madhammer Chambered Exhausts (GMMG Style) for 2 LM1's.
- 90mm TB & Adapter/85mm SLP MAF
- big red procharger bov and flange kit like new
- Speedway Motors F-Body High mount alternator and power steering bracket
- New weld rts 15x10 6.5 backspace wheels!!!!!!!!!!!1
- ls1 billet steel mechanical cam
- 219/231 Cam (Blower cam)
- Wilwood pedal/clutch swing forward mount pedals/ 3 wilwood master cylinder
- LSX CTSV twin turbo oil pan and Gbody swap mounts
- LS Valve Covers
- DOD Delete Valley Cover and OPSU fitting
- 5th gen camaro F1A procharger kit with 12 rib upgrades. Off a 2010 Camaro
- 98-02 camaro factory air lid, ls1 intake manifold gaskets and EGR
- HUGE garage cleanout, lots of GTO parts PLUS MORE!
- 02 Camaro Z-28-SS-35th Anniversary Limited Edition Wheels GM
- very clean set of 706 heads
- Xenon Body Kit with Wing
- Iron Block LS3 Build (Mostly Complete)... Updated Price
- Seats, 5 point harnesses, Motive 3.73 gears
- FS: SLP Power-Flo axle backs for Pontiac G8
- Procharger Parts
- 1996 LT1 timing covers
- Texas Speed High Flow Catted Y-Pipe
- Comp cam
- Autometer gauges
- Abbott Cable X Speedo Conversion Box
- siemens deka 60lb injectors
- 98-02 chrome firehawks
- FS- LS1 Intake Manifold
- ccws 505 with tires
- used complete alky injection kit
- Black LS3 FAST 102 Intake
- Ls1 intake, lid, hood, mostly stock stuff.
- ls truck fuel rails with an fittings
- 31 spline truetrac 9"
- Strange 12 bolt
- precision 88/84 cea billet wheel
- Comp pushrods and oem parts
- For Sale Dallas - 2004 Z06 Speedline wheels - Silver Painted
- NIB BTR Stage III blower cam, LS7 Lifters, BTR push rods
- 241 heads, rocker arms, lq4 parts
- Various speed parts! Trickflow, FAST, accufab
- New GM TTY head bolts, GM valve seals and NNBS Parts
- Lsx stuff
- Jgs 50mm wastegate
- For sale: 18" Apex arc-8 wheels/tires
- Cleaning out garage 6.0 truck manifolds
- PRC 250cnc heads and ls3 holley hi ram
- Ls2 cam for sale, custom turbo cam, Ported 241 heads
- Ls1/t56 egr
- Built Ford 8.8
- Built LQ4 for sale. 6.1L Head/Cam
- LS1 intake w/TB/injectors/rail, LS1 coolant crossover
- 2002 LS6 Z06 corvette harness and 0411 dbc pcm with full bolt on tune
- LS parts - garage clean out!
- Improved racing oil block for accusump or turbo feed
- Slp "flow-pack" cold air intake
- Bmr xtreme shocktower brace!
- Modified clutch master for conversion
- Fast 102mm throttle body, Nick Williams 102mm throttle body
- Yank py3400 ( fresh)
- Stock LS1/2/LQ Rocker Arms
- Mast Conversion Oil Pan fittings
- Fast 92 intake
- CP Pistons LS7, Max Compression set of 10!
- FS: Nick Williams 102mm LSX DBW Throttle Body BNIB
- 15x 9.275 Weld rts wheel
- ls1 t56, 00-02 slp y pipe, lt1 60# injectors
- Ls3 intake and lq4
- 94-97 t56 with lt1 bell housing
- FS: 6.0L Block with forged pistons.
- Stock ls3 camshaft...!!!SOLD!!!
- ARP Bolts LS1/6 04+ engines 134-3610
- 5th gen Camaro Bmr rear drop springs
- TCI Streetfighter converter 242931
- Sold...Spectre cold air intake for 06 gto
- FS: 12 disc CD changer
- FS: 98-02 Camaro fog lights
- FS: LED turn signal bulbs
- NIB ID 2000 injectors FS!!
- TCI Super Street Fighter 4L60E Converter
- 5.3l LM7 complete w/wiring/accessories/0411 ECM
- Umi K Member
- more ls3 blocks, gen4 5.3, tbss intake
- Madman 4l80e Dipstick Tube
- Brian Tooley Racing TURBO STAGE II CAM
- B&M Pro Ratchet Shifter
- 17x6.5 17x11 Bonspeed Atom Bomb
- 98-02 F-body backing plates
- Procharger J bracket LS1 Fbody
- LS1 Factory water pump
- MAF sensor and billet housing
- Nitrous Outlet 102 hardline plate kit
- LPW diff cover 10 bolt
- Ftp 98mm lid and austin ssra
- Sold...2000 fbody exhaust manifolds
- powerbond 25% ud pulley ls1
- 2003 ls6 cam
- 232/240 cam
- Sold..Bare ls1 fbody intake
- Fc Rx7 ls1 motor mounts
- Ls1 rocker arms, bolts, stands!!!SOLD!!!
- Misc Fbody Parts. 17x7 racestars, ta bumper,
- **BRAND NEW** FAST LSXRT 102 intake with stock fuel rails and adapters
- GEN III truck motors ( 5.3 & 4.8 )
- LS1 short block ready to assemble
- 799 heads. clean! complete! off of 2010 motor
- Garage clean out
- Strano performance F-body lowering springs
- Complete 3800 Turbo Kit with intercooler. FFF manifolds.
- Turbo, wastegates, bov
- Bosch Injectors - Blue Giants
- JE LS2/LS6 pistons and rings
- LS7 Clutch flywheel (For LS1/2/7/etc)
- 94 ford mustang T5 manual transmission
- 862 cylinder head(rebuilt)
- Arp head bolt kit ls1/ls6
- SOLD Lokar midnight series 4l80e transmission dipstick 24in
- Subaru LSx swap cradle/turbo and intercooler kit/rear end setup
- LS1/M6 ENGINE Harness
- USED Comp cam 54-469-11
- NEW Comp Cam!
- 93-02 150mph Gauge clusters
- CCW 17X12 Wheels M&H 390/40-17 Racemaster
- 98-02 LS1 Master Cylinder $10
- Third gen LSX Torquestorm Supercharger kit with intercooler
- Advanced Induction AI 232cc 243 heads
- 104mm MAF housing
- 2005 6.0 lq4 ls1 oil pan.
- Garage Clean Out!
- ZR1 Clutch $200 OBO
- 03-06 truck drive by wire setup
- Strano and konis
- Stainless Works 2" headers with 3" x pipe and cats for LS7
- Ls2 intake complete; LS6 intake bare,ls2 timing cover
- brand new 1.8 adjustable roller rockers
- Fast 92 mm tb
- F-body oil pan, Pickup, and Windage tray
- Oil Cooler
- New Holley 558-309 coil harness for HP and Dominator ECU.
- **NEW Johnson short travel lifters (st2126LSR
- QTP 4" Electric Cutout
- GTO Fuel Rail Covers LS1 LS2 LSx
- Procharger a/a intercooler sale or TRADE
- Complete A/c system
- Msd ls3 plug wires/ stock spark plugs
- AEM 30-4110 Wideband Gauge w/ UEGO Sensor NIB
- Brand new black Vortech Ysi fbody cog brackets
- Circle-D 4L80E converter for sale
- Fast 78
- Fs:411 ecm
- OEM 3.42 gears, housing, Torsen Posi, springs and struts, OEM Sail Panel
- Ls1 1 7/8 pacesetter mufflex 4"
- Lunati Voodoo Cam 60511 - SOLD
- FTI 4l60/4l65e converter
- Holley Commander 950 LT1 (sold)
- 2010+ Camaro SS Parts Front Bumper Rockers Wheels and Tires
- TSP Cam Kit 228/232
- Ls valve covers
- Probuilt 4l60e transmission rebuild kit and electronics
- Hinson 1 7/8" stainless long tubes FD RX7
- CCW 500's for GTO
- FS: New BW turbos S300SXE 6974 billet wheel
- LS1 engine harness
- American Racing Header
- 17" polished aluminum torque thrust wheels with good tires
- Pro Yank 3600 for sale $550.00 shipped!!
- Ls1 misc accessories
- AFX body front race Wilwood brakes
- NEW GM swap oil pan swap kit
- ls1 factory fuel injectors
- ls1 spark plug wires $30 shipped
- 4" procharger 8rib pulley
- Complete Holley AC Bracket for 98-02 F-Body LS Motor - Sold
- Lq9 intake manifolds with injectors
- GM Parf Parts Intake with Fogger Kit
- Fast 90mm Throttlebody
- Custom cam for sale, LS1/LS6
- LSX swap harness with 0411 ECM and acufab throttle body SOLD
- Stock ls1 injectors
- New MAMO CUSTOM 237/239 114lsa camshaft SHIPPED
- ***new***nick williams 102mm throttle body
- Mamofied fast 102 intake, fast fuel rails, fuel liner conversion kit (stock lines)
- 22" Escalade OEM wheels/tires
- 98 ss roller auto car
- Meizure electric water pump /street version. **Black**
- Stage II 4L80E & Billet Converter for Turbo 5.3
- New in box Delphi alternator 99-03 Chevy/Gmc 4.8-5.3-6.0
