View Full Version : Parts Classifieds
- Shop Clean out - LS1, LQ, LM, LS6 and L92 parts!
- Brand new RPM level 4 4l80e with madman dipstick and new vigilante converter
- F/S: Garage Clean out - 93-97 Lt1 cars
- 1999 camaro back seats
- Comp 26915-16 Springs and Retainers NEW .600 Lift
- 98-02 F Body Hedman headers, brand new
- 98-02 transam partout
- 01 camaro ss parts for sale!!!!!!!!
- Ported LS1 TB
- LSX INtake Manifold, Fuel rails, injectors, ext.
- yank 4000 stall
- ARE LS1 short block (bent rod), 317 heads, Reverse split cam, Cloyes adj Timing set +
- Almost Full Turbo kit With 6.0 Heads FOR GTO
- Winter Tires 225/55-16 Dunlop Graspic DS-3 Set of 4 barely used
- Brand New MS4 Camshaft! **sold***
- LS6 Intake with Ford Redtop 30 pound Injectors & F-Body oil pan
- FS - 2007 L92/LS3 Engine and ECU
- FS C6 and C6 Z06 items
- FS: 8 Coil Packs GM Part #12573190 - fits 2005-2009 LS engines
- torque converter and flexplate
- SLP 51013 Cam
- 2007 -2011 GM truck/Tahoe/Silverado intercooled Procharger kit P1SC
- Stock 10 Bolt
- AEM injector driver,96lb acceleronics injectors,racetronics harness
- 4.56 Ring and Pinion Richmond Gear, out of Moser 12 bolt
- Nitrous express Dual shark nozzle conversion
- Polished Magnaflow muffler
- New Katech Timing Chain Dampner LS6
- LS9 and Camaro Engine Covers
- Black ZR1s 17x9.5 & 17x11 Low Miles Excellent Condition
- ***Evo8 Part out*** GT35r ect.
- Three 2000 factory camaro harnesses
- Bunch of parts for sale! C6Z06 rims, Halltech CAI, LC1, etc
- HVAC interior section
- stock ls1 motor mounts
- Stock 2000 LS1 Parts
- Kenne Bell BAP, Nitrous Accessories, Procharger Pulley
- ati super damper (damper only no hub) BRAND NEW #917015
- 4L60E tailshaft extension housing for 1996-1997 F-Body. Brand new & never installed.
- Custom Ground cam
- used PRC dual valvespring kit - please read carefully
- 26" Firestone skinnies and 275/50/15 Hoosier drag radials.
- HPtuners MPVI pro
- Polluter cam for sale
- WANTED- Stock GTO T56 Manual Shifter Assembly
- NIB Master power t-76 turbo
- shift knob and short stick
- Camaro bumpers / abs modulator
- 28x4.5 Moroso DS2 tires
- FS: FAST 92 intake with Direct Port Nitrous
- Texas Speed 1 7/8 headers and ORY
- 98-02 SS Camaro Parts (Dash,airbags,column,interior, etc.)
- FS: C5 Corvette dual cone CAI / stock LS1 MAF sensor / stock C5 air box & air bridge
- Parting out 1999 firebird engine and trans gone
- polished ws6 wheels & Nitto drag radials
- Parting out HSW LSX Sudden Impact Dry Plate Nitrous Kit
- LS6 Block Total Seal Rings ARP Main Studs Head Studs
- FS: Mecham Trans Am hood
- Crane Gold Race 1.6 3/8 stud NSA rockers LT1 sbc
- NX Nitrous Kit
- ls1 short block fresh hone
- Kooks 1 3/4 LT's C5 Z06
- diamond ls7 pistons, lq4 rotating assembly, 4.8l longblock, 5.3 speed pro pistons
- random 98-02 parts
- 85 mm delphi maf and 7.400 .080 pushrods
- c5 corvette parts mgw, cats,stock shifter,
- GTO Griffin Radiator, LS2/LS6 valve springs
- 370 LQ9 forged pistons, shortblock, new
- 2002 Corvette LS1 241 factory heads and cam
- GTO Spare Rims Tires "Skinnies For Drag Setup"
- 228/232 Ls comp cam
- GM 12 bolt gears/spools
- (Cable) Trade NW 102 TB for FAST 102 TB?
- Textralia OZ 700 Z grip Clutch and flywheel pressure plate.
- FS: UMI F-body Rear LCA Relocation Brackets
- Yank SC3000 Converter 4l60-e F-Body
- Tilton 4 disc LS 5.5" clutch
- FS Yella Terra 1.8 Rocker arms
- stock rack and pinion
- braided powersteering lines(modular turbo)sold!!!!
- powersteering pump with cnc bracket
- speed inc alternator kit
- griffin radiator(-20 bungs)lines, fans, ls2 pump with -20
- Mt radial 265/40/18
- LS7 lifters
- Precision X275 88MM (new)
- 2001 LS1 Camaro Part Out
- Sold
- LS Brand new Compressor
- RobbMC alignment dowel Pins .007"
- coil relocation brackets and other stuff, some new stuff still in boxes
- 97 trans am passenger door parts
- ARP Head Bolts, Starter Motor, make me an offer
- Diamond Pistons
- NIB Holley black valve covers
- Parts List to bring to LS Fest Sept. 8th Bowling Green, KY
- Revmax 3600 stall converter like new
- FS: Barely used ported FAST 102 LS2
- 98-02 camaro cloth seats. MINT
- 60lb Siemens Dekas
- P-1sc kit for 07 & up Full size gm truck
- Wheels and tires fs/ft
- Random Parts for sale
- Hurst 1/4 stick shifter 700R4/4l60
- Lokar th400 dipstick tube
- coan 8" converter th400
- LS1 Dart pro 1 heads, Diamond 11503 Pistons and eagle rods.
- Patc 200R4 and early 27 spline 700R4 2800 stall almost new less then 200 miles
- 2000 Camaro SS Stock LS1/T56 PCM
- ms3
- 90k 317 heads FS
- FS - Tech Edge - 2COB Wideband - Serial Output
- FS: A few parts from an '04 GTO (driveshaft, shifter, manifolds, etc.)
- Ls7 exhaust manifolds
- SLP Blackwing Lid
- Fiberglass Side-Panel Enclosure with 12" Critical Mass Subwoofer~
- lt1 yank 3600ss torque converter
- Camaro ss stock suspension
- F.S.: '93-02 F-body in car laptop mount.
- Camaro billet grill
- Brand new Lunati .660 dual spring KIT
- LS1/4L60E harness
- Brand new Powerbond 25% ud pulley with belt and bolt
- MS4 cam,ls1 intake,comp cam solid roller,lots for sale
- Wtb or wtt for MGW shifter
- Single Halo Headlights camaro 98-02
- Jet DST tuner for sale
- turbo kit
- left over parts, coils, ls6, compressor PRICE DROP
- F/S: Lingenfelter CNC ported LT1 heads
- Powerbound 25%under drive f/s
- Stock ss 10 spoke wheels
- FS: 80k mile LS1 long block with cam $1400
- On3 76mm Turbo 60lb injectors TSP Pushrods adapters
- Victor jr intake
- t56/LS1 engine harness 165/80 metric radials (like new skinnys) & NOS & misc.
- LS6 intake f/s SOLD
- PRC, 4l80e controller, truck coils, meth... etc
- Yank ST 3500 stall
- Sold
- 2002 m6 harness
- TCI Street Fighter 3400 Stall LS1 4L60e 98+
- Oem raptor hood (trans am/ firebird)
- WTT: MS4 cam for MS3 or similar
- New Aeromotive 12304 100 micron filter
- Edelbrock/Aluminum valley cover plate kit for GM LS1/LS6
- Stock Grey Floormats, Steel driveshaft, Goodyear tire
- FS: LS3 heads off of 2010 Camaro
- LS FRONT DRIVE KIT by WEGNER
- FS: 200$ gift certificate to East Coast Superchargeing
- Kenwood KDC-152 Deck
- Full Nitrous Outlet LT1 Plate kit + Mallory 685 and spare tire mount FS
- Ls3 intake ass. New ls3 rockers and stands
- Yank SS3200 (4L60e), Patrick G Comp Cam, Motive 3.73 gears
- LS parts in Raleigh NC Spec 3 clutch
- aeromotive bypass regulator and block off plate
- C5 motor mounts
- LS1 waterpump
- 241 LS1 Heads
- Suspension Stuff BMR - ALL SOLD
- Stock tan leather seats for trade
- FS/FT: 17x9.5 Chrome ZR1w/ 275/40 NT05R
- Turbo 400 trans
- Black 17" FM5's
- FS: T-top shades 97 98 99 gray
- Rims corvette 18 inch thin spokes
- 4L80E 2wd for sale
- FS LS1 25% UD balancer & belt
- For Sale: Stock LS2 Cam
- 2001 LS1 T56 Drivetrain
- FS: 22" wheels/tires for Trailblazer
- gto aps twin turbo kit
- procharger bracket
- GTO SLP Longtubes
- SLP LS1 ram air kit
- Nitrous Parts
- Aeromotive Eliminator Fuel Pump with fittings
- KOOKS stainless headers 1 7/8 -3"
- Victor JR w Fogger set up
- NEW Wegner front drive set up w msd distributor
- F1R Procharger system/cog drive
- New aeromotive fuel pressure regulator
- Set of Bogart D10 15" wheels with tires -- sale or trade
- Audio Equipment: Amp, Stealthbox, Flip out DVD and more
- 85mm descreened maf, ported 90mm fb tb
- LOWERED PRICE - GM 85mm 25168491 MAF Sensors, Truck Coils, Brackets & Harnesses :)
- siemens 60lb injectors
- New PAC 1518 springs. .650 lift
- New LT1 Crankshaft & New 4340 Scat Rods
- need to sell 2004 gto parts
- ls1 engine and tranny
- NIB hotchkis springs and panhard
- Camaro headlight mounting brackets
- Ported LS6 intake and TB **SOLD**
- FS: Yank PT4400 LS1/4L60E converter
- 18" c6 replicas w/tires SOLD!!
- BMR turbo K member, Meziere race pump, 317 heads
- C5r lsx na grudge or all motor class worthy small block motor
- DBW LS3 throttle body F/S
- Centerforce Dual Friction Clutch, LS3 Intake Manifold
- intake manifold from 99 gmc 2500
- 02+ LS6 5308 cam
- nitrous,TB,Fuel rails,valve covers
- hardened pushrods .080 7.750 new in box
- LT1 parts, Igntion parts, 60# injectors
- fast 92mm intake and fast 92mm throttlebody
- F1A Procharger w/pulleys (Crank and blower) Aster bracket and HD Belt
- wall 7.400 .080 harden push rods
- Mallory HyFire Box
- Wtt balanced 6.0 rotating assembly scat h beam,mahle
- ATI Damper Hub 916033
- ***OEM Firehawk hood*** with grilles, latches, hinges
- LS9 Valve Covers
- ls1 camaro throttle body
- f/s ls1 intake
- F/S like new walbro 255 intank fuel pump
- 4l60e core
- Truck manifolds, 6LE side splitters and rear splash guard planes
- FS: 35th Anniversary LE mats and more!!!!
- MT ET drag stiff wall 28x10.50 x15
- Turbo cam, springs, and HS roller rockers
- FAST injectors LS1 intake GTO oil pan 4.8 lsx motor
- NGK TR55GP plugs
- 6.0 Truck pans
- 98-02 camaro and firebird air filter
- Thunder Stroker V.3 camshaft
- Crane Cams valve spring tool
- FAST 90/NW90 W/42lb injectors&rail
- Track wheels, Cargo cover 4th gen and 3rd.
- T&D 20042 shaft mount 1.7 rockers, lightened
- brand new autometer digital tach shift light level 2
- Fresh HPS ported LS7 heads, SS valves, springs, as new ready to install
- LS1 Crank
- Slp lid and summitt ls1 roller rockers
- Factory WS6 Air Lid *MINT* W/ Lower Airbox and Tray
- LS1 MAF ends
- zo6 style wheels fs
- 4 18 x 12 CCW Classics for Corvette with DOT race Hoosiers
- 59cc Patriot stage 2 243's
- LS1 brakes Powdercoated orange/ hammertone black
- FS: Stage 4 Monster Clutch w/ 18 lb Billet flywheel
- Brand New in box Poly Motor Mounts
- SLP "smooth bellow"
- Coils and brackets
- Lq9 block pick up only
- M6 to A4 Swap Parts
- C5 z06 wheels for your.....
- Fs: 408 ls
- New AEM Wideband Air/Fuel UEGO Gauge Kit $175
- JE forged pistons
