View Full Version : Parts Classifieds
- Camaro Seats
- JE -18cc pistons
- Ltx parts
- LS6 Longblock 10K miles, injectors, and other parts
- 2x Precision 6076e T4 Turbos
- Powerbond SFI F-Body Harmonic Damper
- Procharger D1SC Head Unit RR
- C6 Z06 parts for sale
- FS: Brand new Set of iForged wheels for you ride
- PTC converter, SD 80lb injectors, hotwire kit, walbro 255's, fuel line and fittings
- Updated: Grey Interior need it gone OBO
- Comp 921 Springs Brand New!
- Wtb fast intake
- Timing tunner box
- Patriot gold springs and retainers f/s
- 1 in. BMR lowering springs-- brand new
- FS: NX Automatic Bottle Heater
- WTB Drag Radials 275/50/15 Or 275/60/15
- Midwest Fab 9 SOLD!
- Cloyes LS2 timing chain set NEW
- 2004-2012 canyon billet grille insert
- Wanna save $1000 on a new RPM Level 7 transmission?
- OFI Aluminum Radiator, Spal Fans, MSBC boost controler
- WS6 Stainless Steel Grille Kit
- trick flow 120lb injectors
- edlebrock 90mm throttleboby and elbow
- Ls2 timing chain set
- M/t et street radials 275/40r/17
- Lid,Borla,Clutch, Stock Suspension/Engine,Cruise Control, SBC/BBC MUCH MORE!
- **TCI 3500 street fighter converter 4l60e**
- 70 Chevelle Spectra gas tank for LS conversion W/ Pump new
- FS: BNIB GTO 3.91s and Install Kit. Et streets with rims!
- 93-02 Formula light gray door panels leather
- 93-97 formula dash 50.00
- 93-02 Formula door black chicago
- camaro 1le exhaust
- Brand NEW +2004 Gen IV ARP 12-point Head Stud **BUY/TRADE 4 NEW Gen III STUDS***
- Complete Ebony Interior 2000 Camaro
- Masterpower mp t70 used with .96 housing
- patriot gold springs, retainers, locks
- Built Ford 4.6 Mod Motor
- TWM M1 Abrams Shift Knob - Stainless Finish
- F/S TSP 100mm MAF
- BNIB ACT clutch kit, part number GM9-HDG6
- 2 l92 intakes f/s and Ctsv oil pan
- Trans am stock chrome wheels zero curb rash with or without tires
- FTI custom cam 225 shipped
- Harlan Red Shift Light
- FS: 3 in 1 Black Face Exhaust Temp and Digital Boost and Temperature Gauge
- BMR Lowering Springs
- set of 8 ford motor sport 160lbs injectors
- LS1 Intake, Brackets and Bolts!
- Torque Converter 2500 STALL
- WTS: Brand New Crane Cams Valve Spring Compressor (LS3, L92, SBC)
- Hurst Short shifter and white SS ball
- Forgeline ZX3 19 x 9.5 w/ RE11s
- 241 heads, stock 01 cam
- 241 LS1 Aluminum heads -mint valve springs, stock cam+rockers and shafts
- Darton sleeved ls1 block, ls6 intake, 228r camshaft, injectors, tb,
- PRC LS6 Stage 2.5 Heads
- kooks 1 3\4 jet hot coated ft/fs
- Diamond Audio D6 700.4
- some stock 6.0 leftovers
- NEW Kooks 2" stainless headers for F-Body
- ls6 intake and two c5 TB's
- LS1 intake - bare
- trans am Driver side fender
- Goat 4 pin O2 extensions
- p1sc-1 head unit
- ARE Dry Sump Setup,
- DBW TB WP Truck pan parts from 05 5.3
- c6 z06 stock shocks
- Norris catch can setup,, nice and cheap----SOLD----
- Magnafuel 525 4302 fuel pump
- f1 stage 3 clutch
- Ls1 part out
- 230/230 Custom Grind Comp Cam
- 405 HP LS6 Cam (04 Z06)
- new ls2 timing chain
- Misc items
- Autometer A-pillar gauge pod for 3 gauges
- zr1 16x8 (4)
- Stock LS1 valvetrain, oil pump.
- 1984 Complete Covette Chassis
- wtt: my FAST 102 for your stock ls2 intake
- 275/40-17 Nitto Drag 555R *used*
- Bosch 52lb fuel injectors
- SLP Dual/Dual tips
- weld magnum III's with 28x10.5 stiff
- Camaro/Firebird Stealth Sub Box
- 35spline 12bolt axles
- **SOLD** Lunati T1 221/221 112lsa
- Nitrous Outlet 10# Bottle
- Cam, Rods, Pistons,Pushrods.........
- F2 Procharger polished NEW in box
- Nano 4500
- Powerglide 10" Bradco vert BOTH FRESH 0 runs
- Spohn LCA for Fbody
- wtb after market k member for lq9
- T56 partout feeler
- ***Eldebrock Vic Jr. LS1 Carb Intake***
- BULLET Racing 234/238 .650/.650 cam, TRICKFLOW dual valve springs and retainers
- FS. Truck coils with brackets, plug wires and harness
- Cammotion Custom turbo cam / Morel High rpm Hydraulic lifters
- weiand ls1 / ls6 intake for sale.
- bmr torq arm relo bracket A4 (new)
- Fuel Pressure Gauge
- FS: ARP Flywheel/Pressure plate bolts for LS1 and equivalent
- Garage Sale
- 98 ls1
- fs: to jacksonville members....4l60e trans
- FS 2002 LS1 engine 29k miles
- 5.3 engine with msd 6010 /edelbrock 7118 intake
- FS: C5 Corsa pn 14111 like new
- Intrax Lowering Springs
- Lots of BNIB GM parts Corvette/Trucks
- F/S HSW Interface
- 02+ ls6 cam/springs and ls2 chain
- FS- Fresh boost ready 5.3l longblock
- FS: LS6 Intake
- Autometer Phantom (orig) Boost Gauge, MINT
- LS6 intake
- Cleaning out the garage - Various Parts
- Calibrated Success DVD - $215 shipped
- f/s or f/t 2 speed glide
- ARP Head Bolts
- GM LS1 front Distributer drive cover
- 120lb injectors, aem driver box $510
- Ported ls2 throttle body w/ls1-ls2 harness
- Exedy twin disk
- all kinds of misc. STUFF YOU NEED IN HERE <---
- Bogarts for Ford/Mopar
- Themostat Housing - New
- LS3 Fuel Rail
- LS7 Lifters 180 miles *SOLD*
- NIB Fast Fuel Rail Kit
- Kooks C5 Longtubes & X-Pipe 1-7/8
- Hal/QA 1 Shocks/Springs Complete
- Hoosier R6 Tires 315/35/17
- 96mm Typhoon Intake/T.B.
- Ls1 fuel rail and 05 dbw harness/pcm
- FS: G8 Flowmaster 44 Axlebacks REDUCED!!
- Lt1 Starter Brand New
- FAST XFI Fuel Injection System
- Edelbrock Vic JR. and elbow with fuel rails
- Comp xer 230 236 cam
- Complete T56 swap!
- FS N.O.S 78 mm Plate
- 408" LS motor 100% NEW BES/Barker
- f-body-FTP 104mm Lid and TSP 100mm MAF
- BES 370" Nitrous Motor NEW
- Stock 3rd-4th gen Camaro / Firebird Suspension Parts (Placerville, CA)
- PST Aluminum Driveshaft
- FS/FT:335/35/17 & 285/40/17 kuhmos
- Bogarts for Ford, Mopar, or can be Universal
- Vigilante 4000 Stall converter 4L60e LS1
- PowrMAF 102mm
- STOCK FBODY Injectors W/ 60K MILES Updated pics
- Transmission mount (GM)
- Gauging Interest: ZR1's w/Nittos, LT1 Cam, etc
- LS6 Intake Manifold - 12573572 - SOLD!
- WTT BUILT 4l60E and converter for 400 or 350turbo
- Two (2) 15x10 (7.5 BS) draglites with 28x10.5ss MT ET Drags
- Camaro Switches
- New LS1 Camshaft
- Sold!!!
- LS3 intake COMPLETE with rail and injectors NEW TAKE OFF
- BBK 85mm Throttle Body
- 18x9.5 C6 Z06 Chrome Wheels and Tires SOLD!!
- 408 block and engine parts
- chromoly driveshaft for fbody with 9" ford rear
- 383 stroker, LS6 block, ARP head studs, CAM
- Founders Performance Performance Lower Control Arm Relocation Brackets
- Professional Products 85mm satin throttle body
- Sportline springs
- Chiseled Performance Trans cooler brand new
- C5 Z06 catback, 85mm maf, ls1 maf
- 96 Camaro Z28 shell & engine parts
- Ls6 Parts/GTO oil pan FAST tb/headers etc
- FS: GTO Shift Knob
- Garage Clean Out; Price Drop- Monsoon, DRL Housing, AIR, Valley
- Procharger Intercoolers and Tubing
- Complete LQ9 engine, LQ9 short and 5.3
- Rare Stealth Intake
- wtt chrome c5 z06 wheels for prostars + cash
- Lowered Price: One-off Custom Air Intake (see pics)
- suncoast ws6 hood for sale.
- SLP Dual Dual Brand New
- custom stroker eps cam,procharger j bracket,275#springs, autometer gauges
- WTT Two Gauge Pillar Pod For One!
- Few LS parts for sale
- Harland Sharp adjustable LS7 rockers
- Wilson 4500 elbow
- Hotchkis panhard bar. Sold
- gm ls crankshafts part# 12597569 price drop
- Complete flt th350 swap
- 2 Rear Bogart Classic Star for sale.
- Racetronix/aem injector driver
- truck pan trade
- BNIB 7.400" pushrods
- Black Widow Direct Port Nitrous & Comp 921 Valve Springs
- Lots of parts
- ls6 intake complete injectors, fuel rails and throttle body
- Hypertech Max Energy Programmer
- McLeod Bellhousing
- WTT Ten Spokes for ZR1's
- Grid Style 3rd Gen Taillight R
- wtb ms3 cam or package
- wtb: starter
- ls7 clutch kit
- Fs: Garret gtx42r
- Umi tunnel mount adj tq arm tn
- Misc. ls1 stock parts
- FIC 36# Fuel Injectors
- Stock LS1 Lid w/ Baffle
- Fs-ls1 tb
- F/S ASP 25% balancer C5 corvette
- Lc-1 wideband kit (red) used
- Polished Truck Accesory brackets
- Magnaflow Cat Back Exhaust for 2009 CTS V6
- Harland Sharp rockers
- RPM level 6 4l60e
- LS7 flywheel/clutch and z06 slave cylinder 275$ shipped
- 1998-2002 Trans Am Hood (will fit Firebird/Formula models)
- (((Energy Suspension Polyurethane)))
- 4 channel abs module
- 05 ls2/4l65e swap 66K miles price drop
- 85mm PP throttle body
- new key fob 98-02 fbody 45shipped
- innovate LM-1 Wideband kit (used)
- Nitrous Accessories
- Lou's Short Stick F/S
- 3" stainless high flow converters / mid pipe for sale
- Fully ported 317 heads
- 6.0 forged 70 ported l92 heads complete also have t56 6 speed
- LUK clutch for LT1 (brand new)
- LS2 Stock Intake Manifolds & Cam.
- FT/FS: Nick Williams 102mm Throttle body and TSP 100mm MAF
- FS: pistons, rods, intercooler, etc
- 18" c6 replicas w/tires fs/ft NEW PICS PRICE DROP
- Evo iii big 16g turbo "brand new"
- ls1 motor 66,xxx miles
- PRICE DROP NEED GONE! 98 ta cluster with white face gauges 55k approx
- LsX Race parts !!
- Trade my ls1 for your LQ4
- 275-40-17 nitto 555 tires like new
- LS1 parts
- 3600 lock up stall for 4L60E
- Stock cam, converter, fuel pump, pushrods, and oil pump
