View Full Version : Parts Classifieds
- ***SOLD** Ported FAST LSXR 102 cathedral intake
- HSW 150 Nitrous Kit + Dyntotune heater&purge+ Trick controller
- l99 valley cover with solenoids
- ls1 front timing cover
- Nitrous kit with extras
- Ati 8.6 LSA pulley , bosch pump , 90mm to 102mm 45 degree coupler
- oberg oil filtration setup
- Th400 converter
- 317's, LS3 Valley cover, timing cover
- supercharged/blown cam for sale
- Holley O2 oxygen sensor NEW!
- ls6 cams for sale # 5308
- 2000 Camaro part out 6cylinder
- Lots of parts stock and aftermarket!
- Speedhut Vacuum/Boost & Fuel Pressure Gauges **SOLD**
- Kurt Urban crank trigger mount
- Looking for 100221 slp 25% under drive pulley
- Burkhartt spindles, solid cam, injectors, race parts
- Billet Specialties R/T 15x10 6.5
- LS7 heads, rockers, Ls3 oil pan complete
- Huron Speed Fbody turbo kit 98-02
- 2016 L-86 engine
- Strano Springs & Bilstein Shocks
- EFI live v2
- FS: Weld RTS Bead Lock 15x10 7.5 inch back space
- 1997-2002 slp new camaro ss floor mats
- NEW PRICES Magnaflow Exhaust, Shifter Knob
- 2000 z28 interior part out
- Billet s480 t4 92mm back
- Siemen Deka 80lb ev6 injectors.. BNIB
- 42lb Fuel injectors LS1/6
- 243 Heads
- LS1 Long Block
- OEM 35th Anniversary SS wheels
- Comp Cams magium push rods 7638-16, 7.400
- HSW Bottle Heater, Remote Bottle Opener, Ported TB
- 06 GTO cats
- Frozen Boost heat exchanger, type 101 huge! brand New
- Modified Corvette LS2 Alternator Bracket
- D585 coils with 1 5/8" tube mounts
- (SOLD) 2002 SS Camaro LS6 Intake Manifold
- pst stock length driveshaft 82-02 fbody
- ltx 383 rotating assembly, stock block and turbo kit
- GEN IV 5.3 Rotating Assembly
- Lt1 parts - rockers, pushrods, valve springs, etc
- Procharger F1C for SBC
- Gen4 5.3 rods and Pistons
- Knock off Aeromotive fuel regulator boost referenced
- Maradyne Challenger Series Electric Fans MC162K
- Parting out 2001 Trans Am WS6
- FS: NGK AFX NTK w/ AFR Gauge
- intake heads shaft rockers valve covers steam vent kit. Complete top end
- Pst driveshaft
- Lsa Injectors
- Ls2 vette coil covers
- WTS: Nick Williams black 102 TB DBC
- C5 t56 transmission
- C5 342 rearend
- SubThump Millhouse box with Firebird emblem for 1 square sub... $50+S/PP
- Improved racing oil cooler adapter w/180 thermostat for c5 vette w/ -10an fittings.
- FAST 92mm Intake Manifold w/ gaskets
- F/S: Comp Pushrods
- F/S: NIB Cometic,BTR, GM
- 00 ss m6 6 speed setup trade
- New Tick SNS 2 cam
- FS 102 nitrous outlet plate
- MSD coils PN82468
- BNIB BBK 102mm DBW Throttle Body Part # 1790
- PC valve covers, water pump, truck intake
- sheet metal intake elbow 4150 style
- 60# injectors, LT1 dress up, intake
- Mls head gaskets
- 99-07c Silverado/Sierra Turbo Kit
- Sold!!!
- Ebony leather seats from a 2000 SS - 80k miles
- Tall aluminum valve covers
- Sold
- je srp 4.030 forged piston ls, ls1, ls2, ls6,
- FAST # 80527-8 LS3, L99, L76, LS7 Type 65 lb/hr (409.5cc/min)
- Vararam Snake Charmer Cold Air Intake - 2006-2013 Corvette & Z06 (LS3 & LS7 Engines)
- 98-02 fiberglass Camaro SS hood
- Morel Hydraulic Roller Lifters (GM LS) [6504] NEW FOR 2017
- Stock trailblazer SS cam
- Hughes Performance Locking Trans Dipsticks HP7438LS
- *****SOLD****** Nitrous Outlet 102 for FAST intake
- Camaro Export Tail lights **SOLD**
- 241 Head - Needs springs, valves etc
- Parts laying around.
- 99 Camaro z28 Stock Silver Hood
- Silverado ss rolling frame all wheel drive
- Stock Thermostat
- Almost new injector dynamics ID850's
- Centerline 15x10
- Hp tuners pro
- Ls1 Block, Rods and Pistons, Cam, Crankshaft, front rear and valley covers,
- 799 heads 228cc ported titanium valves pac 1519 springs
- NEW Forgeline RS 17x9.5 Wheel
- LS1 Supercharged Fender Emblems
- 95-97 vented new MSD opti's and others
- LS6 valley cover
- nick williams 102mm throttle body
- TPIS 90 MM throttle body
- D1SC procharger with front mount set up for sale
- Borg Warner s480 billet and Borg Warner s500 88
- comp cam from texas speed
- Cable throttle body
- C5 manual swap
- 706 heads
- BIG POWER custom Diamond pistons 4.125"(9 of them)
- Nitrous kit W/ 92mm plate
- Serpentine accessory drive setup similar to March
- 97 Trans Am Fender and LT1 Intake
- Garage clean out
- C6 Z06 Wheels, C6 Fitment 19X10 79MM Offset, 5X120
- Black meziere street water pump
- Slp oil pump w girdle
- Slp lid and smooth bellow
- 1 3/4 Dynatech Stainless Headers and Intermediate Pipe with gutted cats
- Misc LS1 Parts
- Autometer Phantom 2 Water Temp
- Dedenbear Relay Center MRC-1
- Accufab 6500 Throttle Body
- Carbon nitrous bottles, billet valve
- Camaro Export tail lights ..**SOLD**
- 75 lb injectors and truck intake/rails- decapped 25317628 (truck injectors)
- 2000 Pontiac Firebird 5.7L V8 Air Intake
- MSD boost a pump 80lb bosch injectors
- Trick Flow 235CC Heads, BRAND NEW
- WS6 stock 32mm swaybar 1LE
- LS1 / LS6 Rockers, Trays, and Pedestals
- Driveshaft Loop UMI
- CSR TH400 composite trans shield
- SLP Larger Diameter S.S. Y-Pipe
- d585 coil packs
- ls2 pistons rods
- Brand new UMI Chromoly Adj. Upper Front A-arms, 3 Sets, Discounted!
- Trans Am,Camshaft, springs, converter for sale
- Energy suspension
- Garage sale
- 86 & 87
- Brian Tooley Racing flexplate adapter kit
- Mwc rear diff with axles
- Sold
- WTS: Stainless Works NPP Cat-Back Exhaust - 2016+
- Holley LS Throttle Body 112-585
- Ev1 to Ev6 injector adaptors
- Ls1 to ls2 tb harness & ls3 map sensor
- Mallory Hyfire 6A Ignition Box and Coil
- Kb bap msd 102 nitrous kit head studs injectors
- 85mm maf's
- Racestar shank style lug nuts
- OEM Brand new fbody claim shell motor mount
- Want LS1 Oil pan, windage tray, pick up, and dipstick
- Viper Spec T56
- Hoosier drag radials and Camaro wheels
- Super Sucker Ram Air - SSRA
- Twin Turbo Tony Mamo built 416 and lsx parts
- Brand New PAC-1218 Valve Springs (set of 16)
- Comp 1618-16 Ultra Pro Mag rockers, & more
- Precision Turbo PT88 **Sold**
- LS3 FAST 102mm intake & TB, Kooks, ATI, MSD, built 4l60e, katech, etc
- Garage sale: intakes, fuel bits, cams, + misc other
- Bw s484 billit wheel v3 with race cover t6
- 317 lq4 ls1 parts
- Rebuilt 02 4l60e w/ stock converter for sale illinois
- 15x10 Weld Vitesse Wheels 5x4.75
- SCT X3 ...model 3400 tuner for sale
- A&A ysi c6 z06
- Siemens 60lb ls1 injectors
- C&S 850 Blow Through Extreme Hat for sale or trade
- LS3 Heads
- Z06 ls7 water oil cooler and timing cover
- Misc LSX parts
- Ultimate converter N/A 9"
- FAST 4150 Throttle Body
- Bogart bolted rt rims and drag radials
- Brand new n box ls ecm
- Complete procharger for 2015-2017 corvette
- 06" GTO Black REAR seats-12k miles $300
- Custom COMP CAM VVT
- FS: Fresh LSX Iron block w/ Extras. Big Boost or Nitrous Ready!
- Pt7675
- Edelbrock pro flo 7139 and Fuel Rails
- TRUE LS6 243 heads, 02-04 LS6 cam,
- T56 lower shift boot cut for aftermarket shifter
- New QTP 3in cutout $135
- New Comp lifters and trunnion kit
- 12 bolt gears 4.56
- New Weld rts s71 15X10.5 with M/T 3053S slicks 1100
- New BBK 102mm TB
- Fs Truck coils w tray and harness
- Strut /shock tower brace STB
- 2 sets of Holley black valve covers SOLD
- Gtech Competition Pro Performance Meter
- 93-97 LT1 car upper radiator support / mount / bracket
- Convertor TCI 4500 Th400
- Edelbrock elbow & throttle body
- New Racetronix F99 fuel pump and Hot wire kit
- Heidts adjustable power steering valve
- (SOLD) QTP Billet 2 Piece Timing Cover
- Diamond forged Flat Top LS 6.0L .030" over pistons
- MSD Atomic EFI setup. Part#2910
- AFR 205cc Mongoose Street Aluminum Cylinder Heads - 66cc Chambers
- Borg Warner S484 Billet Wheel Turbo
- 10 spokes
- Ebony leather Camaro seats and door panels
- Ls7 exhaust manifolds
- 40# gm injectors, DBW throttle body, truck fuel rails
- LS3 throttle body, gold blade
- LS1 LS6 Spec billet Flywheel (New)
- Injector Dynamics injectors BNIB
- ***SOLD****Nick Williams 102 Throttle Body - cable driven
- *SOLD* Nick Williams 92mm cable TB
- LG Motorsports Harness Bar
- Edelbrock Water Pump
- AFR Heads - SOLD
- LS OEM Rockers with BTR TRUNION kit
- MACS Fabrication Drive Shaft Loop
- T4 turbo log manifold for LS engines
- Haltech Platnum Sport 2000 with LS wiring harness and IQ3 display for sale.
- FS: Auto Meter 7774 Electric N20 Pressure Gauge
- Spohn Solid Motor Mounts 98-02 F-Body USED
- TSW Interlagos Wheels 18x9 set of four
- Nice clean set of Valve Cove and UMI 1/2" Spacers.
- Ls6 cam/springs and blackwing lid
- Delete meeeee
- katech ls1 rod bolts new
- Slick Rick ported dart pro 1 heads
- MSD boost a pump, bosch 80lb injectors, snow meth stage 2 kit
- QTP 3.5" Cutout.. Brand New!
- LS rocker arms - SOLD
- M&H Racemasters 26/4.5/17
- YT Rocker Arm
- Ls3 rockers holley ls1 3bar map sensor
- LS3 rocker arms
- upper lower control arms
- Prothane poly F-body LS1 motor mounts N.I.B.
- Built 4L60E For Sale
- 102 nitrous plate
- LS1 Motor for sale Running strong-SOLD SOLD SOLD
- ISO The tuning School
- 408 stroker. Long block fully assembled
- Sold
- Moser WaveTrac, 31 Spline for Ford 8.8
- LS1/M6 Engine Harness and ECM (04 GTO)$325 shipped
- L92/LS3 Heads (823's) $535 shipped
- 104 lid
- Fast 90 intake and fuel rail
- Complete Nitrous outlet kit hidden halo dry kit. 15lb bottle.
- WEGO III Single Channel Wide-Band Air/Fuel Ratio Display
