View Full Version : Parts Classifieds
- Grudge motor/aluminum 402 best of everything
- FS Set of 8 floating pin rods.
- FS: Kooks 1 7/8 Headers with Catted Connection Pipes - BNIB - $1500 shipped
- LS1 Motorsports lid 50.00 shipped
- Kennybell Boost a pump
- Ls1 f body eng brackets
- Bare LS1 Intake
- Custom grind Speed Inc. cam
- HSW nitrous kit with FJO mini plus more...
- Performance & Stock Parts
- NEW 04' GTO LS1 Oil Pan
- FS-Snow Performance Boost Cooler
- FS: FIC 1000cc fuel injectors
- 30lb. Injectors
- Used HPT Pro
- Powerdyne bd-11a supercharger for sale
- Complete Nitrous Kit, Insane price..
- For sale 8.1 marine injectors.
- Ported 317 heads, yellow gmpp springs, comp cams pushrods
- fuddle 3400 stall for 4l60 lt1 and c5
- I need ls1/t56 camaro Bellhousing!!!
- Bosch Motorpsorts 1000cc and 1200cc injectors
- Two chrome zr1 rims with 275/40/17 tires together or seperate(IL)
- lq9 dbw harness, pcm, intake, tb
- Fast 92 TB like new!
- LT4 Knock Module / GM LT4 ED Timing Set
- NX gen 2 wet kit plus extras
- 99 SS drag car project
- Fast 102 intake and 102 PTM TB
- FS- LS2 style FAST 33lb injectors W/ adapter to fit LS1
- FS-Dual cone intake for C5
- FS-C5 Titanium Exhaust
- Stock LS1 Fbody Cats - is anyone still buying them up?
- Stock 95 Z28 Brake/Suspension Parts
- Mustang Cobra IRS Control Arms
- masterpower t70
- Tc78 new in box
- SLP 25% underdrive pulley for Fbody
- holley 750 dp by cj engineering flows 830cfm $200
- LS2 behive Valve Springs
- 317 heads
- Camar Parking lights/ Gear
- Damaged ls3 head
- BNIB LS7 lifters 125 shipped
- 2 GM 16" black wheels w/drag radials
- Misc. Stock Camaro/TA Parts
- perimater valve covers, stock injectors
- Stock ls1 converter 5k miles
- SOLD !!! Hooker Ceramic Long Tubes
- ls1 textured valve covers, Bumper cover braces
- Garage sale!
- WTT stock length moser 12 bolt
- 243 heads w/ upgraded springs
- Tru Trac, 12 bolt gears, Z28 SS floor mats, Bullets
- Lt1 parts
- Weld Racing RT 15x10's with slicks
- l92 5.3 leftover parts
- Nick Williams 90mm DBC
- 4 magnaflow mufflers
- New and Used Performance Parts: LS6 Intake, ASP Underdrive Pulley, UMI TA and More
- Stage 2 L92 Heads
- 3 bar map - knock - air charge temp sensor
- 17" Black ws6 wheels
- MTI lid
- Pistons for sale
- bmr th350 xmember, injectors, pcm's
- AFR/ FAST/Comp/Circle D/ Madman and more!!!
- 60lb injectors, Boost a pump
- Aftermarket Fuel System Parts – Pumps, Filters, Fuel Injection, Carb
- Parting out Modified 2001 Trans Am
- 238/242 605/610 on a 113+4
- Built 382 for sale
- **FS Original 2001 Z28 CD Player,CD Changer,Tail lights and Springs**
- 98-02 F body T56 Swap. D&D rebuilt t56 and Centerforce DFX clutch
- F-Body Prothane Eng & Trans mounts
- LT1 T56 swap harness for third gen F-body-SOLD
- 1998-2002 Firebird superhawk hood
- *PRICE REDUCED* Comp 918s wth ti retainers, comp hi-tech 7.325 pushrods
- Brand new Huron speed alternator relocation bracket
- 98 TA ABS wheels/WS6 center caps/lugs
- lq4 intake complete
- FS: Procharger "Big Red" Open Race Valve
- QA1 complete set
- BNIB dual 3" stainless exhaust cutouts, PIC UP!
- LQ9 Valley Cover, Oil Pan, Front Timing Cover, DBW TB, GMC Emblems
- D1sc procharger standard rotation
- Aeromotive 340 w/Bulkhead and bucket
- 99 Z28 stock springs *** just pay for shipping
- AEM Wideband 35-8460
- LS front Crank Pin Kit
- Stock cooling fans 98-02 f-body only 50k miles
- Carburator Set Up Trade For EFI Set Up
- Ls7
- Externally threaded lug nuts for thread on style caps
- ls1 pistons/parts and cold air intakes lt1
- Wiper arms from lt1 body style camaro
- 6 speed console cover for lt1 camaro
- Ngk spark plugs
- All my fuel stuff for sale carb,pumps regs
- (NEW) Twin Walboro 255 fuel pump external setup
- SOLD...Comp cam for lsx for nos
- Fbody headers headers headers headers headers
- Misc. parts from a 97 camaro
- WTS: 98-02 TA gauge bezel with fog light switch
- 7638 comp cams push rods
- Electric Cutouts, X Pipe
- FAST 102 Throttle body & Patriot shaft rockers bnib
- KEEP CALM AND BOOST IT t-shirts
- Lsx Racing parts 4 Sale
- cobra half shafts
- Stainless works Down and Fwd Turbo Headers
- 1998 trans am parting out
- LS1 Aluminum Driveshaft with Yoke
- UMI adjustable panhard bar & lca's(RED)
- Lid/maf for sale
- New Whislter modded Headlamps Hotchkis RS kit Magnaflow
- nitto extreme drag radials
- NIB oil pump, front & rear & valve covers
- Callie's Compstar Forged Rods
- Fikse Mag Wheels-$1250
- lsx/ls2/ gto parts for sale
- TCI Flexplate PN#399754
- LT1 Trans Am Fenders FREE
- Complete lt1/tpi nitrous wet system
- Pair of Michelin Pilot Sport 335/30/20 tires 60% Tread
- BNIB Comp Cam 224/240 Camshaft
- Fs: Gt4294r
- greg banish beginer dvd
- 6.0 and 5.3
- Used Garrett GT4088 turbo. 6k miles. T4 supports 700+hp
- FS: 4l65 with stock converter and flexplate
- Precision Industries converter 4200-4400.
- ls6 short block, 317 heads, harland sharp rockers
- LS6 Intake/TB 450 shipped
- LS2 Block, Cranks, Pistons and Rods
- 373 gears with posi unit
- Ls6 fuel rails and injectors
- Hurst Shifter
- 447" Mast LS7 Headed LS2
- KYB AGX 8-way, ETP rocker stands
- Rare Nitrous Outlet 90mm nitrous plate kit with the solenoids built into the plate
- CCW 505a's 18x10 & 18x11's
- 2007/2008 L76 Longblock (Aluminum 6.0 w/ L92 heads)
- LS3 Block, Heads, Intake, Etc. Michigan Only
- Z06 Replica wheels
- 2000 Trans Am WS6 Springs and Shocks
- New LS2\LS3 waterpump, stock valve covers, heat sink coils, stock lq4 valley cover
- Racetronix 44lb injectors, B&B,317's, magnavolt, posi, bumpers, etc
- 806 heads and f body throttle body
- 88mm dbb Turbo
- ls7 Lifters
- Diamond Forged Pistons,4.000 moly & ceramic Coated, New Total Seal AP Rings included
- Lunati I-Beam Forged Rods #6125FM3
- Camaro/GTA 1LE Rear Disc Brakes
- SLP MAF, ROCKERS, LCAa, behive springs, shortblock
- Joe Van O spoiler, Sunoco hood, alumastars, etc. TONS OF PARTS!
- LS1 4L60e flexplate
- FS- EPP Blower cam - 232/240 .595''/.608
- lt1 t56 with bellhousing and stock shifter_SOLD
- LS Computer for sale
- 42lb injectors for sale
- Nitrous express wet kit
- 12way adj QA1S F-BODY
- Comp cam and billet timing chain
- C5 Z06 parts-Engine Cover's, etc. Price Drop
- 4l60e trans go installed
- Fays2 Watts Link for 4th Gen F-body
- 4l60E and swap parts from '01 Z28
- FS: Custom BorgWarner s475/Race cover
- LS1 Victor jr and nitrous
- ls3 maf and harness
- SS 10 spokes, widened, powder coated
- 2 (two) 99-02 Caspers Hotwire Fuel pump kits BRAND NEW!
- stock lq4 oil pump
- turbo and slp ram air
- F-Body LS1 Calipers/Rotors/Lines
- Vararam vr-sc1r
- Brand New: Devil's Own water/meth injection kit complete plus extras!!! *PRICE DROP!
- Race Star wheels
- FS/FT/GI: LS3 shortblock
- fs: lsxmustang foxbody shifter plate
- M/t 28x10.5-15s slicks for sale
- Ls6 383
- Lq9---
- ARP Ultra-Torque LS rod bolts
- Lsx 376 valve covers
- Mint stock WS6 rims with brand new tires!!!
- Oem ss spoiler
- Stock 99 Camaro LS1 Camshaft
- FS: 5.3L parts, truck intake with TB, egr exhaust manifolds
- LT1 Z28 T56, bellhousing, cluth fork, B&M shifter for sale
- FS: Torco Accelerator Unleaded Race Fuel Concentrate
- Nitrous- Wet nozzle-bottle brackets
- 243 heads
- SOLD Comp Cams upgraded trunion stock ls1 rockers
- Xer287hr-12 comp cam for sale!!
- Ls1 block 241 and 803 heads
- A2W Intercooler tank and pump
- Texas Speed MS4 Cam 7k Miles 239/242 .649"/.609"
- gto ls1 drag wheels lingenfelter part out asap
- Lsx ls3 carb gm intake like new
- March LS1 UD Pulley $110 Shipped!!!
- (2 new) magnaflow race mufflers 3"
- 6012 msd kit complete to convert ls to carb
- 1998 corvette throttle body
- CCW Classics FS Black w/ Polished Lip
- LSX hats & other gear
- LS1-T56 Harness / 2007 5.3 Harness / 5.3 Injectors
- Head studs for '97-04 gen LS1
- Cam, Timing chain, torque convertor, rad, fans, lifters pushrods
- L92 Direct Port VicJr Nitrous Partout, Intake, Cam, Standalone fuel system, ect...
- 90mm ls2 intake manifold
- one last try:Brand new TSP 1 7\8
- F/S 38mm Tial WG
- F/S precision turbo
- LS1 stock injectors and fuel rail
- 4th gen f-body parts
- ASP UD Pulley and Alternator Pulley
- WANTED Sachs nfw1050 flywheel
- Prc 2.5 LS6 heads
- LS6 Intake
- LT1 93-97 Camaro short tube headers
- slp underdrive pulley
- 160lb low impedance injectors with flow match and pulse width data sheets
- 96lb high impedance injectors with flow match and pulse width data sheets
- COMP CAMS NEW 921's/aluminum driveshaft LS1 front brake assembly
- Fast 90 Intake Ported/ TB w/ rails, & DP nitrous setup
- LS1 Edit Package Unlocked for all 1997-2004 Cars
- 98-02 Lower Dash, Cluster, rear sway bar, and more; 1999 Z28 parts
- C6 and Z06 Caspers Electronics Hi-Lo Fan Controller
- 317 heads
- Nitrous parts!/adjustable lower control arm brackets/ driveshaft safety loop.
- Harness/waste gate fs
- New set of Holley/Delphi 50 pph injectors $175
- FS: New Yank Pro Yank 3600- 6L80E
- Complete NOS Cheater Dual Shot Nitrous Kit
- 96lbs injectors (high imp), 2.5" Mandrel bends, truck manifolds and flanges
- t-56 for sale with clutch and hydraulics
- wtt mint condition ws6 speedline wheels for tt2
- FS: 91mm 1500hp Turbo
- FS: f body procharger parts, sub thump box & 12's (added D1)
- lowering springs
- Going Back To Stock :Performance Parts
- LS7 Lifters and 317 Heads
- Parting ls1 build from heads to oil pan. new & used.
- Manley H beam Rods Brand New
- SLP Beilstien shocks w/springs
- 98 TA parts
- Incon twin turbo kit for 98-02 f-body
- Complete 4L80E Swap for F-Body!!
