View Full Version : Parts Classifieds
- Parting out 4.8 & 5.3 trucks and 04 GTO
- FAST/Bosch 36/42lb EV1 injectors
- lt1 heads, intake, and a few other parts
- F/S C5 brake calipers and LT1 adapter brackets
- AC Delco O2 sensors AFS75 / 32mm poly bushings
- SLP Underdrive Balancer/Crank Pulley Camaro 10-12 Silverado 99-12 Sold...
- BRAND NEW Comp 918 springs
- 210/218 Comp Cam
- LS1 Alternator w/ Bracket
- LS1 PS Pump Complete
- Parts Lot '10 camaro SS
- 18x9 factory 5th Gen wheels and tires
- Ls7 Parts GALORE!!!
- L76 Intake/rails/seals
- F/S: 98-02 Camaro parts
- FS: Innovate LM-2 wideband kit
- F/S: ARE dry sump components (tank, vent, filter, extras)
- MSD digital window switch
- oil pan, t56-harness
- jakes black box (manual 4l80e controller)
- Ls stock motor and some other motor parts and stuf
- 1.8 Ratio Roller Rockers
- GTO Stock exhaust, strut tower bar
- Gi: 4l80e nitrous stall. Jakes low brake. Billit Parts
- FS: Holset HX52
- Brand New ACDelco 213-4657 Mass Air Flow
- FS:93-97 trans am WS6 ram air hood.North ,AL SOLD
- 8.1 marine injectors 42#
- LE LT1 Ported Intake
- EFI Live V2
- 3 Channel Backing Plates
- CBR Alt. Relocation Bracket
- 1998 LS1 Auto Wiring Harness
- LS1 80mm BBK TB Cable Driven
- $650! pics added!readytobuilddisassembled lq4 for sale!
- Bunch of extra LS parts, coils, balancers, MAP, MAF
- Stage 2 750cfm Quadrajet
- Catalytic Converters Random Technology High Flow - 2.75" Diameter In/Out
- 1998 engine/trans pull out/parting out
- New Lt1 engine mounts
- ASA GT5 wheels and LT1 parts!!!
- LT1 Air Foil
- Mildly Built 4L80E
- misc. 93-02 firebird trans am camaro parts
- AFR 205 heads
- LS1 stock starter
- PCMForLess 4L80E conversion harness SOLD
- ARP Wheel Studs and Wheel Spacers
- Cliche' garage cleanout thread: heads, intake, f-body parts, wheels, random stuff.
- 6.2L Truck Intake Manifold
- Billet Aluminum Steering Wheel
- Patriot Gold Dual Valve Springs just springs and retainers
- Sold!
- Jetstream Blue FAST LSXR 102, NW 102 TB, 80# injectors, rails - complete pkg for Z06!
- LT1 and LS parts need gone! Make offers! Updated 8/19/2012
- 2000 LS1 Throttle Body
- trans-dapt 1" set back mount plates
- C5 torque tube and LS 3 camaro oil pan
- New comp cam
- "Sold" A/C Compressor
- Stock LQ4 for sale
- Magnesium wheels and c6 wheels fs
- nitous outlet direct port kit
- ls1 f-body passenger side header Brand New
- Ls1 f body oil pan complete
- Stock ls2 Cam, Yellow Springs, pushrods 29k miles
- SOLD SOLD 6LiterEater Radio bezel, A/C, Gauge Plate
- Kooks 1 7/8" Headers - fbody
- 1998-2002 Power Steering Pump & Hoses with Complete Rack and Pinion
- FS: Carbon Fiber SS spoiler
- Lower control arm Relocation Brackets
- Convo Pros 15x4 15x8 with tires
- WCCH Stage 2.5 LSA Heads (Big Boost friendly) Hollinw intake valves, Inconel Exhaust
- BBK 52mm throttle body
- Pacesetter Longtubes (ceramic coated)
- TSP true duals **SOLD**
- Brand new Edlebrock 90mm LS throttlebody must go or it is being used
- Ltx shootout is around the corner/advanced induction
- LS1 injectors, Master Clutch Cylinder
- nitrous parts
- ls6 intake with ported tb
- Hp tuners vcm suite
- Katech Tensioner / Raptor Light
- Brand new scat 4.100 crank 4340
- stock front shocks and springs
- Hypertech Power Programer III Lowered Price
- Patriot Stage 2 243's CNC Ported And Milled Heads
- Like New Walbro 255
- Stock Exhaust
- 93-02 Grey Rear Seat Delete Kit!!!!!
- Texas Speed Torquer V3 231/234 .643/598 Camshaft
- pacesetter lt headers and custom ypipe exhaust
- F Body Drive Shaft Loop
- FREE stuff to whoever needs it
- Nasty Performance LS7 Billet Conversion Rails
- PTM 102 Throttle Body
- New Aeromotive 340 Pump and 42lb injectors
- FEELER Forged Ls1 Heads/Cam
- 17" Rims - Best Offer
- LOTS OF GOODIES!! Garage Sale!
- Umi front arms and Polyurethane Ends
- intake elbow for sale
- Factory cd deck. works great
- WS6 Speedline Wheels with Tires
- Bilstein shocks for sale!
- FS SSRA (for cars with a/c)
- Mickey Thompson ET Street Drag Radial
- Pat G custom cam 3-bolt 235/239
- SLP 2OTL Exhaust w/ cutout
- Firebird Hood, 01 cam, stock muffler/tips, and others
- Sold
- Pro 5.0 shifter w. UMI shortstick , 2 knobs
- FS used ls6 intake manifold
- 1986 1987 Honda VFR 700-750 Jet Kit, Sprocket, K&N Filter
- 2 Stage Nitrous Kit and Nittos 555r's
- New dmh low profile cut outs with
- 4.125 Bore LS1 Block w/Darton Sleeves
- N.I.B. Zex Nitrous Oxide System
- New adjustable pan hard bar with set of adjustable lower control arms
- F.A.S.T. 90mm Intake Manifold
- 1 7/8" coated headers
- Callies 4" Stroke Crank For Sale
- Flexplate ls1 engine to 4l80e converter/transmission wide pattern sfi approved
- New circle d converter GM 258mm Pro III 4L80E Torque Converter
- Ford 9" narrowed 2.25 per side with
- AFR CNC Ported 225's For Sale
- PAC 1518 Beehive Valve Springs LS/LT
- Valley cover and Steering wheel w/ airbag and controls
- 98-02 Camaro stock hood
- GM 6.2 Short Block **SOLD**
- 1998-2004 Corvette Underdrive balancer pulley
- 15x10 Billet Street Lites
- Lunati 73925K1 Dual Spring Kit with steel retainers $199
- Patriot Performance Extreme Dual Spring kit P/N 8501 $250
- Comp.cam 7.400 chromoly pushrods
- MSD Digital 7 Plus Programmable #7531 with slew/traction control $600
- FS: LS1/4L60 Dropout
- Nitrous Outlet specific kit
- Sold----
- Pro Systems 1300 cfm Dominator carburetor $800
- WTS or trade: Spohn adjustable torque arm
- LT1 MSD opti spark distributor
- Turbo kit and etc
- Moving sale! All must go!
- Garage Sale: 555Rs, Car Cover, GTO Strut Bearings, etc...
- TCI flexplate, LS3 intake, Victor Jr. L92 carb intake, Ls1 intake, misc.
- Small Block chevy 383 stroker with vortec heads complete carb to pan 2200 or trade
- Ported TB without sensors
- TR Cheatr cam
- 2 merieze water pumps black anodized
- Wts/wtt t-top conversion for hardtop headliner/a pillars
- BMR K-member
- FS-TFS 215 cnc heads, without springs
- Lt1 t56 Fs/ft
- F/s: 1997-2002 camaro tailamp assembly driver side-clean throughout
- 2002 camaro A/C controls
- RevExtreme catch can
- ls1 coil packs
- LT1 Cooling Fan Assembly
- 2 motors for sale CHEAP 1 4.8 Gen III 24x // 2 Gen IV 58x
- aftermarket firehawk hood
- Bumper mounts and brackets, washer bottle, hood latch and bracket
- FS: Firebird/Trans Am Hatch
- Drivers T-Top
- Gauge Cluster
- Transam Front Bumper
- Rocker arms, rails, bolts-stock LS1/6
- 98-02 Fbody lowering springs Sportline Front/Prokit rear
- Fs: 2004 lm7 5.3l
- 01 trans am a4 harness and computer
- Stock 16" 2K T/A wheels plus tires
- ARH 2"-2 1/8" stainless step headers and bullet mufflers $800
- Rossler Terminator 2 TH400 w/transbrake and Ultrabell $995
- WTT: My Borla Adjustable for your True Duals
- 3.898" Forged rods and pistons w/ ARP 2000 bolts
- SX performance A-1000 fuel pump
- nos big solenoids
- wtt/wts stock 317 heads n dual springs
- FS: CHE LS7 Rockers
- FS: CAM, Injectors, CAI, Cutouts & More
- FS ((( LS1 Body Control Module))) 2000
- msd 6al and coil centerline 16in wheels
- Like New ET Streets and Camaro Salad Shooters For Sale
- (SOLD) Patriot CNC Stage 2 LS1 heads with valve covers/coils, fresh rebuilt $750
- FS: Used Corsa cat back with Premium Tips!
- BILLET SPECIALTIES WHEELS w/MICKEY THOMPSONS
- Shop Clean Up - Precision,LS3,Holley,MS4,Comp,PST,Mickey Thompson, & More
- FS: DMS springs and relocation brackets
- FS: Lightly ported/deburred FAST 78/80mm BBK
- Fast 90 mm Polished fuel rails complete
- New GT4708 Garrett Turbo
- Forged ls6 and more!
- Precision .81 exhaust housing - Came on my PT7675
- Weldon A2040 Fuel Pressure Regulator
- Walbro 255 Fuel Pumps.
- Lt1/LS1 Magnaflow Catback
- ls1 engine, intake to pan, still in car running, RI
- 2 stock ls cranks; ARP main studs
- Stock fuel injector set, 1999 Camaro SS
- Ported/milled 243 heads
- LS1 coil covers
- WTT/WTS: Complete set of stock 317 heads
- Custom polished valve covers, K&N, MSD wires, catch can with hoses and fittings
- msd digital 7 ta programmable 75301
- Stock WS6 wheels and tires
- LS1 Stock Water Pump (Complete)
- 305/45/18 Nitto 555R's
- Gauge Cluster
- Comp cams torquer v2 112
- Escort Redline radar detector
- 80mm Throttle Body ::SOLD::
- Brand new Borla Adjustable catback FS!!
- 42lbs injectors LS1/LS6
- 6L80e w/Converter and TCM Harness
- a bit of everything ls7 ls6 ls2 gears
- LS 224/224 cam and LS6 intake
- LIKE NEW Siemens Deka Mototron 60lb Injectors
- WTT/WTS rebuilt 4l60e, trades???
- ls1 brake calipers
- Almost new 18" rpm wheels & f1 tires
- 666 cam 6.0,370,408
- New In Box! Ported Fast 102mm, TB, Fuel Rail
- SOLD OTC-6667 OTC Harmonic Balancer Puller
- Brand New FAST 102 LS7 Intake and 102mm TB w/Gasket Kit!
- WTT: Madman manual rack for stock +cash
- for sale Gmmg Cat back w/oval tips
- Patriot Performance Dual .650" Valve Springs with New Valve Seals Sold...
- FS FAST92 intake W/injectors-fuel rail
- 1995 trans am part out! T tops!
- LTX parts 4 sale
- stock low mileage 241 heads off a 02 ws6
- Custom cam, springs, retainers, etc
- LS1 Stock Intake
- 4 Brand New Michelin Tires
- Griffin 1-55241-XS Stand Up
- ls1 rockers maf motor mount clams coil packs alt bracket harness/pcm +more
- Stock LQ4 Rods, Pistons, and crank
- SOLD 2001 Camaro Front Leather Seats
- 224/230 xer cam 114lsa
- ported Fast 92 intake/Nick Williams 92 TB SOLD!
- 241 heads with ls6 yellow springs
- AC compressor, both lines and dryer
- Fast 90mm intake an ls6 intake
- steering wheel with radio controls
- ARP rod bolts
- LQ9 truck manifolds
- 1999 - 2002 Fbody Engine Harness LS1 T56
- Comp Cam $180 shipped, Lq9 Rods $120 shipped
- NX digital maximizer controller
- FS: Champion (beadlock) Drag Wheels, full set.
