View Full Version : Parts Classifieds
- fbody fuel cell factory tank foxbody swap headers and exhaust
- rossler hybrid manual box for 4l60e
- "ss" hood
- FS: SLP/PB UDP 150+ shipping
- Eibach 15mm hub-centric spacers, PC'd front sway bar mounts
- FS: (2) 17" Vette Speedlines and tires
- C5 McCleod adjustable master
- garage sale
- LS1Edit, 0411 ECM, tuning cable
- 6.0 pistons 4.030 bore and more!!!
- Iron 6.0 Turbo Motor
- F.A.S.T. 65 lb. Fuel Injectors, For L76, L92, LS7
- FS- Cam and Nitrous Plate
- LS6 cam, Supercharger, and other misc parts
- LS1 complete motor i need to let go
- Racetronix 98 Fuel pump
- EPS Cam - 900 miles
- LS1 Yellaterra Rockers & 1/2 inch alum. Spacers
- L92 heads
- FS:C5 vette Front license plate RAM AIR mod.
- 2005-2006 GTO Turbo Hotside
- ls6 intake #2561184 good shape $400
- GM Performance ls7 intake w/rails and aarons elbow
- Stock ls9 Injectors
- Stock ls3/ls7 Injectors
- WTB: LS2 Valley Cover and LS1/2/6 complete intake
- T56 with LS2 flywheel and LS7 clutch
- standalone harness for ls1
- FS: Water-Air Ice Reservoir
- Kirkey Pro-street seat - 18inch
- Granatelli MAF - LS1/LS6 corvette Z06 #350119
- Gen4 5.3 flat top pistons and rods
- E67 pcm
- 90 mm tpis throttle body 3 bolt
- D1sc procharger c5 corvette rear diff and suspension
- C6 Vette Z51 Sway Bars
- Twin turbo part out-turbos,wideband,boost controller
- WTB 9 Inch Center Section
- 5.3 intake harness injectors
- Richmond 4.56 Gears
- sold!!!!!
- Efi Live Autocal
- SOLD- L92 Intake Manifold w/Rails, inj, TB
- WTT C6 NW102 for C5 NW 102
- SOLD 67-69 Camaro Modified Clutch Master Cylinder
- NEW* McLeod Clutch Master Cylinder 98-02' 139301
- Stock Ls1 cam... 2000 Camaro 5.7L; 04' 6.0L cam
- 98-02 camaro front grill $20 plus shipping ....SOLD
- WTB tuned pcm for my 5.3 swap
- Harness and ECM
- 3" Godspeed Electric Cutout/Wireless remote
- 42#/hr fuel injectors (8) $235 shipped
- Innovate LM-1
- LS part out, lots of new parts for sale
- BTE Top Sportsman Powerglide
- ERL superdeck1 6 bolt with 1/2 head studs
- please delete
- Pacesetter Longtubes
- C6 T56 For Sale
- Stand alone harness and pcm
- Converter 2800 stall 4l60E YANK low mile
- Grey Front Seat belts
- SLP Tbss Headers
- Circle D 2E 4000
- Part out of swap parts
- nitrous express 78mm plate
- FS: LS1 fidanza flywheel
- Dual/Dual cat back for trade $1
- lt1 pcv tube throttle body to valve cover
- pro 5.0 shifter t56
- 2000 Camaro ebony complete center console
- 2009 truck dbw throttle body, truck manifolds
- kooks 2inch longtubes
- 78/75 turbo, wasteagte, bov, couplers, t-bolts etc
- 90mm nitrous outlet plate
- Ls1 w/ fresh 4l60e many new parts
- Precision 66mm wastegate
- Nitrous Outlet 90mm plate with hard lines
- FS/FT:Custom BLACKED OUT CCW Drag Pack trade for 18" Classics!
- FS: 31k mile stock LS7 short block
- FS: LS7 Stock Intake Manifold, TB, and Fuel Rails
- 4l60e 45k miles fs!
- red carbon fiber shift boot
- ebony 4th gen console lid
- 4th gen center console
- 98-02 camaro "whisper mod" headlights
- "SOLD" LSX Procharger Cog Brackets And Front Accessories Drive
- BBK Power-Plus 52MM TB
- SLP Lid
- UMI Boxed front lower a-arms for 93-02 F-Body. Brand new!
- racetronix hot wire kit for fbody
- Used Milwaukee 5455 657C Polisher
- LS goodies
- Dynatech 1 7/8 Foxbody swap headers
- Awesome clutch.
- 4L60E, Doors, 10 Bolt, Interior
- List of parts
- Custom Tick Cam and push rods
- Tanks Inc PA-4 pump, Vette FPR, -6an
- New ctsv rear differential p/n 15793756
- Like New 20 Chrome Silverado SS wheels with tires
- New Pacesetter Long Tubes | Motion Industries Turbo Catch Can
- LS3 0821, 243, 799 heads
- T56 Tremec for sale
- Edelbrock LS1 Ignition Control Module
- 98 camaro parts! Complete Part Out!!!
- 2004 Silverado intake w/injectors, dbw tb and fuel rail.
- ARP head Bolts/McLeod Master/ 317's
- Lsx truck manifolds with o2 sensors
- TSP CNC LS3/L92 68CC 15k miles Stainless intake Valves
- built 4l65e
- ARP Head Bolts and LS2 Timing chain
- NEW GM 98-02 F-Body OEM Oil Pan and TSP ported Oil pump
- Fjo SOLD
- Weld Racing Magnum drag pack for a F Body!!
- NEW Lunati billet rods 6.125
- NEW Yank SS3600 for 4L60 and SLP STB
- NEW LS7 lifters, lifter trays, TSP 7.4 pushrods
- LS3 Procomp 3017 64cc Cylinder Heads For Sale
- '97+ 4L80 90* -6an fittings(nice ones)
- texas speed ls7 pushrods
- rockers,starter,valve cover n coolant parts
- 3 quart Accusump system
- truck oil pans
- LS1 Brakes, Exhaust, T/A Seats
- G body ls1 2.5" mandrel bend tig welded exhaust
- WTB: 99 F-Body rear shocks compatible w/lowering springs
- Wanted: LS3 Rocker arms
- 1999 C5 Air intake assembly with new K&N filter perfect
- Borla adjustable catback
- Flexalite dual fans
- Big cam for sale 243/249 610/612 110 lsa
- 04-06 GTO Stainless Works headers *SOLD*
- 93-02 f body aftermarket driveshaft
- C5 magnesium rims and tires
- G8 GXP 6.2 exhaust OEM manifolds and Cats.
- Emblem Pros Fuse Box Covers - valley cover. LS1 Oil Pump. P/S cooler
- WTB Meziere WP319
- Eboost2
- 78mm granatelli maf
- F/S: f body oil pan setup, versafueler, 2005 5.3 90k miles, 98 ecu, torque thrust 2's
- FTP 104 lid
- Turnone power steering pulley
- FAST 102, 102 throttle body and LS2 fuel rails
- LS6 Intake
- Nitrous Outlet plate 90mm
- Meziere EWP, less than 50 miles
- parting out 2002 z28
- 7.350 pushrods
- adjustable panhard bar-used
- th400 crossmember
- lt1 Custom valve covers
- Pacesetter lt headers w/armor coat
- 42lb Green top injectors and stock 5.3 injectors
- bmr k-member for 95 lt1
- umi torque arm w/safety loop-and bolt on brace
- Parts for sale racetroix, gmpp, arp
- fast 60lb injectors $210
- Msd digital window switch $110
- LS1 Pistons&Rods w/ARP bolts and Rings
- 2004 ls6 CAM and yellow springs
- ls3 hollow intake valves
- MWC Trans Am Front Bumper Support
- LSx engine parts,crank,rear end,suspension
- WS6 OEM Speedline Wheels low miles Great condition
- American racing catted y pipe 98-02
- T56, ktech clutch. Shifter, master
- 243 heads complete for sale!!!!
- ls1 camaro oil pan
- CTS-V Springs
- Wtb hx55, or another mild size turbo, fuel system parts(pumps injectors) 4.8 build
- *** ABACO Mass Flo Meter ***
- *** CASPER Hot Wire Upgrade Kit ***
- BRAND NEW GIBSON SS CAT-BACK EXHAUST for LS1 Trans AM
- ..CASPER Fan Controller ..
- Brian Tooley Racing trunnion kit BTR TK001-NIB
- *** Corvette Projector Headlights ***
- *** Electric Fans ***
- PST mild steel DS T56 to 9" or th350
- kooks 1 7/8 , borla , ls6 springs retainers
- N2MB wot box's with 2 step and shift light output.
- Complete engine and trans harness for 4l80 and computer
- WTB LS2 timing cover and 1x cam gear
- pcm, 70k gauge cluster, and 6 speed wire harness
- Parting out 98 SS roller
- FTI Billet 3600 converter For Sale. Only 1000 miles
- 98 Ls1 Heads and 98 Valve Covers LOW Miles
- Strange Drag brakes 4th gen 93-02, QA1 R shocks w/ 275 springs single adj.
- 2 Chrome 17x9.5 ZR1 rims w/tires $80, Front LT1 Prokit Springs $70, Fender, Bumper
- boost a pump external inline fuel pump turbo setup NOS brand,lines,relay,etc.
- 98 c5 chrome wagon wheels $250
- Texas Speed 7.425 pushrods
- DP21239 EBC Green Stuff pads New
- QA1 Front Springs
- Stock Springs
- Complete F-Body A/C System
- Hurst Shift Knob and Short Stick
- Umi upper and lower control arms
- Umi k member 500 shipped
- Wolfe Racecraft 6 Point Roll Bar
- Qa1 coil overs 400 shipped
- Yella Terra LS7 Ultralite Shaft Mount Non-Adjustable Roller Rocker 1.8 Ratio #6670
- NX express kit with bottle
- Complete built t56 setup.
- Complete NX Nitrous kit
- 2002 SS 35th anniversary hood for sale
- LS6 Yellow Springs
- BNIB... meziere wp319 with all accessories.
- Methenol kit F/S or trade for after market torque arm
- LT1 camaro/firebird SS Headers/Catback(NEW)
- UMI control arms
- 5.3 with 4L60E 2wd NW ohio 150K
- EFI Connection LT1 24x Setup NIB
- FS: Built 4l60e
- 2006 LS2 6.0 complete takeout motor, 37K miles
- 6.115" .927 2.100 A-1 Aluminum Rods
- Long block 408/TFS 6bolt 245
- LS6 Race engine 520 whp 5.7
- Callies Dragonslayer crank, 4 inch stroke
- Magnaflow 15899 Stainless Exhaust NEW First Gen Camaro
- FS: Camaro SS SLP PARTS.....ALL SOLD.
- Large Nitrous Outlet solenoid
- SOLD ATI Damper and Hub
- Katech ls1 rod bolts
- Brian tooley push rods
- F-Body rear brakes (2 sets)
- LS3 intake
- 243 heads. Complete w/ PRC dual springs, etc
- Camaro Stealth Sub Box and JL Audio W3 10"
- PTC 3700 Stall Converter Brand New 4l60e
- Yank SS4000 Stall 4l60e
- LQ4 and 5.3 parts for sell!!!
- comp double roller billet timing set
- 1993-2002 camaro z28 ss front oem floor mats dark grey
- I have a 99 trans am driveshaft
- BMR black th400 crossmember f/s
- Nitto 555R 315/35/17 Tires F/S
- Stock 42lb LS3 injector set f/s
- Texas Speed Chromoly Pushrods - 7.375" length
- 104mm Lid
- Competition Engineering 50/50 Rear Drag Shocks F/S
- stock lq9 parts
- Garage sale, fbody parts, 4.8 short block,
- Assorted C5 and Fbody stuff for sale, all prices obo
- Arp 234-4317
- tvs1900 complete set up
- 98-02 Camaro headlights
- LS Internals/ LS3 Intake Manifold
- 93-97 camaro parts
- Kenwood DNX5120 Nav DVD Ipod Touchscreen
