View Full Version : Parts Classifieds
- Parting out 1999 camaro z28
- FS: 33lb/hr injectors from l59, 25lb/hr lq4 injectors
- LS1 Intake, TB, Rails and injectors
- Magnaflow Catback for FBody
- MACD LCA's
- PartsAdded Prices reduced Billet valve cover spacers,10-15lb nos bottle bracket,
- Diamond forged Pistons for 4.030 bore
- SLP 85 mm maf descreened
- stock and aftermarket parts for sale.
- F/s or trade built t56 transmission
- diablo predator u7198 99-02 vehicles
- Fast 90 intake manifold
- ls7 intake manifold for sale
- LS1 Armor coat
- C5 parts-tires-Baer-exhaust-shocks- make me an offer
- 2 Slp air lids 60.00 shipped each
- set of 20 closed end aftermarketlug nuts. 10$ shipped
- 4l60e
- t56 crossmember 60 shipped
- Speed inc cam for sale
- powerbond 25% underdrive harmonic balancer 100$ shipped
- 4l60 srl series billet fti converter
- 97-98 hypertech programmer
- FS: fully built 4L80e W/ Jakes T-brake
- USED forged Eagle H-beam 6.200 stroker rods, NEW ARP 134-6006 rod bolts *bolts sold*
- lt1 96 built tranny
- LS7 438ci built motor. 525-650rwhp+ potential
- Mezeire Electric Water Pump w/ pulley
- Brand new Gm ls6 block with low mile 241 heads and patriot roller rockers
- Brand new ls1 starter
- Pair of Precision 6766 Turbos
- Hand Ported 243 ls6 heads..
- LT1 stock & aftermarket parts FS (lowered price)
- (2) ccw classics 17x11.5 w kumho slicks
- ARP Bolt Kits, Brand New!!
- 2 DBW harness' and 1 DBW pcm.
- NEW 4.10 gears w/ install kit | rear sway bar
- GFG 3 piece wheels 19" 5x120 Cheap
- T56 Parts
- 305/35/18 mickey thompson et street radial II $575 Shipped CONUS
- Fender Roller from Eastwood
- ls2 intake
- 98-02 f-body part out
- Eaton LSD 12 Bolt Car 3 series 33 spline
- 99+ Porsche Brembo Calipers
- 6.0 IRON LQ4 Engine (South Florida)
- Griffin F-body Radiator
- f1c complete kit for f body
- LS Turbo Cam CHEAP!!!!
- gto t56 6 speed with bellhousing
- edelbrock pro efi intake manifold black
- Auto Meter Sport Comp Boost Gauge
- I need just two LQ9 pistons
- WS6 Speedline wheels/tires
- FS: 2012 CTS-V Front and Rear Brembo Calipers
- Comp cams 227/235 614/621 on a 113 200 miles on it
- SOLD!! LS1 ARP head stud kit
- SOLD!! 25% Powerbond/slp underdrive pulley
- LS1 ARP Stainless header studs
- Upgraded Procharger K&N filter
- Stock 02 SS rear end
- T56 six speed transmission
- Custom 408 cam made great power through a fast intake
- Ls1 coolant crossover pipes SOLD!
- Added 01 ECM 02 Silverado ECM Poly trans mount
- anyone need a ls6 cam and springs
- Midwest Chassis F-body Panhard Bar
- qa1 275lb front springs
- f/s hypertech programmer lll
- 93-02 Magnaflow cat back For Sale
- Performabuilt Level 1 4L60E Transmission
- Twin GT3076R's on the market.
- NIB: LSA 8 bolt complete Clucth setup
- wtb stock fuel injectors
- Marshall Electronic Nitrous Pressure Gauge & Camaro tail light
- 3600 Stall Converter for 4l60
- Heads! Heads! Heads! 241 are the last ones left
- C5 Corvette Cradle/Crossmember
- F-body alternator and power steering brackets
- 04-05 gto tailights fs
- 60lb Injectors Idlers Gauges Corvette Fuel Covers Wideband MAP LG Cam Valve Springs
- Labor Day Special...$250 SHIPPED FOR EVERYTHING!!!!!!!!
- SOLD- Harland Sharp LS1 LS6 Roller Rockers
- Fast 78mm Intake & Harris Speed Works Plate
- 17" ZR1 Replica wheels with Nitto's
- Ls2 gto parts
- New CRT Midframe 76mm Turbo
- Front ss brake line kit: goodridge hoses, ate super blue, speed bleeders
- WTB: street strip wheels
- GTO SPARES with M&H racemasters on them and spacers
- 42lb racetonix injectors
- NEW- Ls2 timing chain
- Nitrous Outlet 78mm plate kit
- Procharger P1SC Head Unit
- Ls parts for sale
- Gto ls2 radiator and fan assembly
- 00 c5 rear! and cradle and rear suspension
- B&B, injectors, Line Lock, etc FS in NJ
- Ls6 manifold complete with 80mm bbk throttle body
- FS: PSI LS1 conversion harness. With computer.
- walbro 255s x2 and PRC eht .675 springs.
- FS: LS1/LS6 Coil Packs
- heat sink coil set
- Axles for NON-TC 10-Bolt F-Body
- MR Gasket Head Gaskets 5713G 5714G
- ARP Rod Bolts 134-6006 LS1
- ARP Head Bolts 134-3609 LS1
- gto ls2 ac compressor with bracket
- Forged, Boost Ready LS1 w/LS3 Heads, Complete
- Single Turbo Kit, FMIC, T78, Meth, Tial
- LS1 Coil Packs
- P1SC-1 /w FMIC and "Big Red"
- parting out 99 trans am
- rear end conplete with brakes 323 geara
- Auto meter triple pod gauge
- OEM trans am wheels
- Wtb ls1, 243, 799, ls3 or 5.3 heads with .650 springs
- 243 LS6 Heads NIB
- Custom FRC's, Weld & ZR1 wheels, gauges, nitrous kit & parts, y pipe, stock parts
- Futral STROKER cam(243/251) & ls7 lifters
- 04 4l80e Transmission
- lsx 427ci rotating assembly callies wiseco
- Nitrous outlet n20 solenoid
- Stock shortblock lq4
- Turbonetics turbos, ls2 intake, throttle body
- Pair of gto spares
- LS2 with Zero miles... Never installed
- NIB LS6 yellow valvesprings never installed
- LS6 Clutch, Pressure Plate, Flywheel
- Brand new ls1 f body alternator
- A Few LS1 Parts
- Ls1 wiring harness (6 speed manual)
- LS7 camshaft, like new take out
- 4th Gen Camaro Hatch w/SS style spoiled
- LS6 Intake manifolds bare and completes
- P1SC procharger kit off of a 06 GTO
- kirkey seat brackets new just mounted up
- Oil Pan and Valve Covers-PRICE REDUCED!
- 15x10 stars slicks $250
- NIB Wiseco k394x3903 forged stroker pistons ls1/2/3/6/92
- SOLD Yank SS 4000 Stall for 4l60e
- stroker Futral Motorsports/cam motions Cam For Sale
- trade my ttm's for a drag setup
- stock springs, umi adjsutable torque arm
- AMS 1000 Boost controller Turbo - AEM injector driver box - Racetronix plug n play
- WTS Fast Intake/tb/injectors/etc
- Sold!!ARP 10-bolt rearend diff. cover bolts
- SOLD!! 3.70 Procharger 8-rib pulley
- SOLD!!custom grind tony mamo / AFR ls1 blower cam
- SOLD!! lonnies double pumper fuel pump kit 99-02 LS1
- FS: (4) ROH ZR1 5x5 17x8.5" Polished Wheels
- LS harmonic balancer installer
- ls1 comp cam. dyno numbers and specs!!!
- C5 z06s wheels and tires $500 price drop!
- FS: 93-02 Camaro black corner lenses/side rears/tails/blac
- Used 4l60e
- Ls3 intake manifold
- 224/240 .629" .620" 112 LSA Cam
- FRESH Stage 1 PRC 243's with .650 duals
- Hurst shifter out of 98 camaro
- 799 and 243 heads
- SLP Loudmouth cat-back exhaust system
- Low mile Thunder Racing Cheater Camshaft
- LS6 ported intake with TB
- 241 stock heads with only 18k
- Used patriot gold .650 springs and Torquer v3
- Aluminum 5.3L Part OUT! LC9 243 heads
- 2 Sets of HRE wheels / tires - NICE!
- Stock WS6 Hurst Shifter and Shift Knob For Sale
- F1 procharger setup for 10-up camaro
- fast 102 ported with direct port setup nitrous outlet. along with throttle body 102
- GIANT list of parts. Mostly stock ltx and lsx
- LS2 Truck water pump '07
- Ati SuperDampers, hughs, spohn, mint ebony leather seats, and more. NEED TO SELL!
- Mac mid-length headers & y-pipe
- 2000 Z28 partout
- 4.10 gears and rebuild kit
- ford 8.8 with trac lok
- ZEX nitrous kit, nitrous parts, AN fuel rail adapters
- WTB Lingenfelter LNC-003 ASAP!
- Nitrous Outlet 78mm plate kit with extras..
- Moser 9"...two of them for sale
- 370 LQ9...2200 miles.....needs TLC...
- 2001 LS1 Engine
- Tial F38 38mm Wastegate
- FS: Couplers, Manta Stripe, AC Condensor, Clutch, Shifter, Stock Suspension TX PICS
- Deka 80lb injectors
- Texas Speed MS3 camshaft
- 1997 GM F Platform Repair Manuals
- NEW COMETIC LSX Head Gaskets 4.185
- bmr lower front control arms
- ARP head studs
- Turbo Manifold Flanges: 2010 Camaro, Truck Style
- (feeler) 700R4 for 93' f-body'd
- 98+ Camaro Driver Seat Foam and grey cloth cover
- torque thrust
- Madman Trans Dipstick 93-02 Camaro/Firebird
- complete rockers set, intake gaskets, MSD plug wires, etc
- LS3 intake and FAST 90mm TB
- Headers magnaflow OTVC ZEX BMR Founders Kee audio Borla Z06 lots of parts for sale
- SLP Dual Dual Tips
- Red Shock Tower Brace
- 98-2002 Camaro Tan Cloth Door panels
- Digital Trans temp gauge/wideband /fuel pressure
- C5 Z06 Chrome wheels f-body, LT1 head bolts,
- Alpine MRP-M500 Amp & Alpine SWE-10S4 Type e 10" Subwoofer
- Cam rockers pushrods
- crank spacer and arp bolts SOLD !
- 5.3 parts cheap!
- Front end bra
- Eaton Posi Fbody 10 Bolt
- NOS 16058 nitrous bottle opener CHEAP
- Slp fan switch
- FS/FT: ECS Novi 1500 supercharger kit
- LS7 cam/retainers/springs/Comp Cams...
- t56 transmission
- Rare sell New (Custom) BBC headers 4 Fbodys
- FS vig stall, stock intake and pp tb, 224 cam, stock stall
- Shaner S2 ported throttle body
- 5.3 Engine Harness *SOLD*
- SOLD!!! Comp 918 springs w/ titanium retainers
- Flow Tech Cam (streetSweeper-ss16) 275$ firm
- 98-02 camaro tinted tail lights and led parking lights
- LS1 Eibach pro kit rear springs
- FS: Analog Dyno Dynamics 2wd
- ls coil packs
- GM C4 C5 C6 Chrome Corvette wheels
- 1998 Gray/Charcoal Trans Am WS6 Driver Air Bag
- 98-02 camaro oem ss spoiler dark blue
- 98-02 camaro oem z28 hood black mint!
- c5 corvette motor mounts
- 243 Heads for sale
- Fast 102, cathedral port
- LS7 Parts
- LQ4 Truck Oil Pan kit
- FS: Huron SPeed Turbo Kit for a Fox Body
- Used Stock intake and exhaust valves,LS1 full set
- 98-02 aftermarket SS hood JAX, FL
- " SOLD " F.A.S.T Stand Alone XFI XIM
- Mustang headers
- WTT: Kinesis K59 wheels/tires
- Bullet Turbo Cam Package, LS7 Intake & Throttle Body & A1000 Fuel Pump + Controller
- need fast 102 intake for ls7 fuel rails amd 3.5 or 4" exhaust magnaflow mufflers/tips
- 2002 Z28 calipers and brackets
- SLP SS chrome centercaps for the OEM 10 spokes
- Nitrous cam!
- 04 truck intake
- ARP Balancer Bolt Kit
- Edelbrock 3849 intake elbow
- edelbrock progressive nitrous controller
