View Full Version : Parts Classifieds
- Quick Fuel SS-830 Carb and Spectre Plenum
- 806 LS1 Heads
- For sale: 18" Fikse Aro wheels & tires
- SOLD PTM 102 TB 102 MAF and housing SOLD
- (2) 275/40r17 Cooper Zeon RSA3
- FS: FAST 65# shorty injectors
- 243 heads
- 2010 4.8 nnbs parts
- LS9 cam with cover and harness
- WTB Wideband o2!
- H/C LS1 engine 89K
- FS: DRE Rev Kit
- "Sold" Ls3 gmpp cnc heads w/manley .650" spring kit
- Torque Thrust IIs 17x9.5 & 18x10.5 - need a little work
- Circle D Twin Disc 3000 stall converter
- LS 243 and 241 Heads for sale.
- Brand new snapon tool box 3k
- '99 LS1 Knock Sensors & Harness
- PRC 2.5 LS6 Heads
- Brand new A&A Twin Pump fuel pumps(Holley 12-1800) w/ wiring
- nitrous outlet 90mm plate kit
- C5R intake, solid roller cam, valve springs, front coils.
- comp cam 921 springs
- LQ4 pistons
- Lots of LS stuff for sale, Swap parts, old school oil pan MORE
- Fikse FM5's 17/18
- 25th aniv. t/a door panels, umi vc spacers, ls1 covers & more
- Full Nitrous Kit
- FJO wideband and Apexi AVCR electronic boost controller
- Polished Typhoon intake+Pro products Fuel rails/ Nitrous&some misc.
- ls foxbody swap headers
- custom grind cam
- f body magnaflow muffler
- coil packs/ truck intake /harness/injectors
- Holley dual quad carb intake ls1 5.3 6.0 2x4 intake $250
- Few items for sale
- 241 heads
- 42# injectors for sale
- #60 ls3 injectors
- ***SOLD***Stock LS1 injectors
- procharger 1300 hp a2a intercooler hard anodized black
- Jesel LS3 Rockers and Lifters
- **SOLD** 421ci LS rotating assembly $2000. or trade
- ls6 bare block
- SOLD!! New LS3 Intake Manifold #12602477
- LS6 Hollow Stem Intake and Sodium Filled Exhaust Valves Genuine LS6 Z06 CTS-V
- Trick Flow® GenX® 255 Cylinder Heads for GM LS3 TFS-3261T002-C01
- 98-02 FENDERS 4Sale
- Ididit steering column
- Eboost Street 40psi SOLD
- LS7 lifters
- Precision X275 88mm turbo
- prc 675 dual springs with titanium retainers
- $200 ly6 intake complete
- WTB Trans Am bumper/fender/hood...
- Need 2 inch arh or kook headers
- wtb midwest chassis or Wolfe tq arm
- B&B C5 Mufflers
- Small bore ls3 heads.
- Sbc solid roller
- Pictures!! CHEAP FTI Converter!!!!!!
- Nx Nitrous bottle solenoids etc
- Forced Inductions Garrett 94mm Turbo
- ls6 rods and pistons
- Ls6 Intake
- Stock engine parts
- LS1 Coil Packs, Brackets and Harness
- 102mm tb
- WTB 93-95 LT1 crank hub
- GMPP LSX LS7 heads SOLD!!!!
- Sold....
- CORVETTE NAV,XM,DVD Touch Screen Display .
- 1998 Trans Am left door (black)
- 1998 Trans Am right fender (black)
- 1998 Trans Am decklid, spoiler, glass
- 1998 Trans Am Rear Fascia
- stock spark plug wires
- center caps, fog light, 4L60E mount
- 1.7 yella terra ultralight rocker must go asap....
- Jegs Axles
- C5 LG super pro's. Cheap!
- SFI LS F-Body Harmonic Balancer
- Complete 2000 Ws6 Transm am partout Ls1/T56
- LQ9 Truck Coil Packs and Valve Covers
- F body harmonic balancer, valves
- F/S FAST 85lbs Fuel Injectors for LS3/LS7
- wiseco pistons,241s
- 5.3 parts (GARAGE CLEANUP)
- Stock 317 heads
- all sold!
- chrome zr1s with tires
- 1963 impala 409 tri power
- 409 tri-power
- stock 4th gen exhaust stuff
- ***KOOKS 1 7/8" LONGTUBES X PIPE/MIDS, G5X3 CAM, PATRIOT GOLD VALVESPRINGS, etc
- Satin Black Berger Panel WITH Stainless Steel Inserts
- 99+ tank and sending unit assembly
- Ls1 aem ems standalone system plug and play
- Misc charcoal and tan interior (seats, door panels)
- LS1 cam gear and retainer plate
- Used 233/239 Texas-Speed cam
- Used ls1 oil pick-up tube
- 5th Gen specific Nitrous Outlet nitrous system
- Holley HP 12-150 fuel pump (carb guys)
- Ls1 intake manifold
- Meziere Electric water pump
- Turbo, ported TB, taillights, ignition switch, TA poly bushing, more
- TSP off road y pipe and rumbler catback
- FS: LS2,4L65E, Accessories
- 67-69 camaro/firebird ls1 swap oil pan FS.
- "Gauging interest" P-Ayr ls1 "mock block" with heads
- Powerbond 25% under drive pulley with belts. Fbody/gto
- TRADE: Pre-04 LQ9 FULLY DRESSED for LSX block
- Ls1 swap oil pan "new" forsale
- Parts for sale holly tb zex gm gears
- 10 Bolt/DBC LS6 TB/DBW Truck Throttle Body/Muncie 4 spd
- Corvette filter/regulator kit---conversion
- AMS 1000 Boost Controller
- new magnaflow tips for magnaflow catback
- SLP Cold/ Ram Air intake duct
- fabbed valve covers
- new summit/trickflow roller rockers
- 4l80 Swap Jakes Performance manual controller
- band new 222/222 .581/.581 114lsa 225$
- a6 tci billet flexplate for ls9 or LSA for 8bolt cranks
- [PRICE REDUCTION] BNIB! Top-End: AI Ported Heads, Cam, Ported FAST 102 Intake
- WTS CNC 853 heads
- LT1 CSR electric waterpump, Kenwood dd
- Lsx, Turbo, Tial, Moroso, etc. Parts for Sale
- LS7 Z06 complete motor
- Pair of 799 heads
- lt1 performance parts and two sets of aftermarket injectors
- FS: TSP LS3 231/236 cam
- Bosch 42lb Injectors
- Ls6 fuel rails
- FS 2002 WS6 TA LS1 Motor- W/ Cam - 400+HP at tires
- ls3 top end
- 1.7 scorpion roller rockers
- GMPP LS3 CNC Heads With Manley Ti Spring Kit New
- SOLD 2001 ss camaro monsoon head unit SOLD
- Ls2 402 complete motor
- 6l80 4WD adapter
- 07+ truck DBW pedal
- Mmagnaflow cat-back exhaust
- fast 102 ls3 heads
- 3 Bar Map sensor plug n play
- 5.3 engine
- New ls1 swap/turbo goodies!
- Fti 3600 stall converter built for my 5.3 turbo car
- Autometer ultra lite 5" 200mph mechanical speedometer.
- Misc stuff for trade or sale
- 98-02 f body Hooker headers
- FS/FT: LS7 Heads and Intake combo
- 5.3 parts
- msd atomic EFI 2950 with extra ls1 adapter harness
- LS 2 Intake
- e38 ecm
- dual pillar gauge pod
- MISC LS1,3,6 Parts GM truck 20's 14 Bolt
- 99 transam 383 part out
- Stock LS3 rotating assembly
- L92/LS3 conversions
- Comp billet 78 PRI released wheel in race series ball bearing
- Sold
- FS: Brand New UMI LT1 Road-Race KMember!
- LY6 block, Callies Crank/FS
- FS: 19x10.5 19x10 iForged Senekas, newly rebuilt PRICE LOWERED
- Stock parts garage clean out
- All sold
- **Complete Top End For Sale! FAST Intake 243 Heads Much More!**
- SLP SS Grill
- wtb ls2 intake
- Camaro/G8/CTS-V/GTO driveshaft conversion plate
- procharger Big Red Blow Off Valve with Flange
- ARP 2000 Rod Bold
- BMR Turbo K member
- Speed inc TU2 turbo cam
- 1999 Trans Am Fog Lights
- LS cams for sale low price
- Powerbond 25% Underdrive Pulley Kit for 98-02 LS1 F-Body/GTO
- GMPP LSX Heads PN#19201807
- Bottle Opener, NX Progressive Controler, Adj Nitrous Pressure Switch
- LS6 Intake Manifold
- wtb: 6.0 or 6.2 block
- Brand New Tick Performance Speed Bleeder
- NEW nitrous/Nano bottle brackets with mounting plate
- 241s and pro 5.0
- 18 inch C5 Z06 Chrome wheels
- Moser 12 bolt
- Low mileage PRC duals with titanium retainers
- ls6 Coolant Crossover tube SOLD
- Ingersol Rand 2141 3/4 composite impact
- ls1 , 5.3 parts,valve covers,valley cover
- FAST 102 TB , ported TB , SLP,Spohn stands , pro thane ,other parts b/o
- WTB: LS1 Pressure plate
- complete part out 98 Z28 NEW PICTURES
- precision x275 85mm large frame turbo *SOLD*
- LS6 Intake FS
- Big red procharger race b.o.v
- FS: OEM CAMARO 21" Rims Split 5 Spoke Style EA280 Polished/Black
- PRC 0.650" dual valve spring kit
- Ls6 intake, Camaro cowl hood NBM
- Etp ls7 small bore heads. SOLD
- Camaro seats for sale, nj
- m&h 275-50-17 drag radials like new 98%
- Leftover items from 2002 Trans Am part out
- BRAND NEW. Ls3 gm valves will separate
- LS1 Front Crank Seal (GM PN 12561244)
- Diablo Predator Trinity T-1000
- T56
- 06 gto parts
- 799 heads checked,cleaned,milled
- Ported LS Victor JR EFI Intake
- 20" helo tease rims w/ pirelli tires
- SLP LM2's 150$ OBO
- OEM WS6 Hood
- FS LS1 Turbo CAM
- Ms3 cam for sale
- Brand new LS6 yellow Valve springs
- FS: 18" Falken Azenis 615s (315/30 and 275/35)
- Tick Master Cylinder, SS lines, Remote Bleeder, and 2 Slave Cylinders
- garage sale.... ls6 ported tb fans ect
- GTO GMM RipShift
- Spec Super Twin P-trim
- Quicktime Bellhousing T-56 to LS
- T-56 lt1
- c5 dual tip borla stinger cat back
- Fs gt4788 t6 .96
- Nitro Daves Direct Port L76 and L92 heads
- Various LS engine parts for sale, garage clean up
- CTS-V various parts, need to clean out my garage
- Ls1 TH400 Nitrous converter
- C6z reps, ls6 springs 4.10s billet tb
- PST, BMR, UMI, Procharger, Pro 5.0
- 2004 lq4 78k in ny
- NEW Clevite Cam Bearings
- Neil chance torque converter and dennys driveshaft
- FS: OEM 93 Firehawk Parts
- Ls1 throttle body
- WTT: CCW Classics
- 2004-2007 New OEM motor mount
- Pushrods
- OEM Z06 10x18 front 12x19 rear wheels for TRADE or sell
- custom thunder racing motor/n20 cam
- Full CNC ported 243 heads
- PRC 227 Heads
- turboxs performance boost controller
- 5.3 MAF, fuel rail, and injectors
- FS: 243 LS6 Heads Lightweight Valves
