View Full Version : Parts Classifieds
- 2011 4.8/6l80e 2wd
- Ls1 Super Vic EFI w/rails & 90* elbow for 4 bolt tb
- Nitrous outlet bottle
- Ferrea super alloy ex and stainless in LS1 valves
- Gen 4 5.3 rotating assembly 58x
- Morel 5290 tie bar lifters New $330 shipped
- Procharger d1sc helical gears f-body reverse rotation
- OEM carbon ZR1 hood
- 98-02 LS1 Computer and Harness/4l60e
- Snow Performance Meth Pump, Nozzle holder with big nozzle, fittings and some plumbing
- lq4 engine parts n other parts
- ly6 shortblock
- Fbody Stock Gears, Axles, Windshield Wiper Arm, 20 lug covers, intake gaskets
- Circle D 4L80E Pro Series Billet Multi Disk Torque Converter
- Yella Terra Ultralites
- ISO black wheels for 2007 CTS V
- (2) GoodYear Eagle F1 GS-D3 275/40Z/R17 Tires
- Many parts FS - Flex fuel sensor, Wideband, Ignition, etc.
- MagnaFuel 4303 and MP9950B
- LS1 Knock sensors + wiring
- LS1 Corvette fuel rail covers
- LQ4 6.0L computer
- Thunder Racing LS1 Custom Cam TR230/224 111
- Complete Custom Truck Turbo Kit *s480*Turbosmart* Tubular Manifolds*
- Two Corner Steam Vent setup
- XXR 962 17X9 wheels +35mm offset
- l92 heads
- Cadillac CTS-V LSA supercharger blower lid
- Ls2- Ls1 stuff, Holley display ect
- Looking for D1SC or complete kit~~
- LS Hooker Block Hugger Headers
- f-body fuel rail
- Edelbrock Elbow
- Turbo Car Part Out w/ Trailer (Tons of Race Parts)
- Wilwood 3/4 bore master cylinder
- Eibach pro-kit $125
- 1998-2002 Fbody Carbon fiber intake/Filter $85
- WTB: Nick Williams 92mm throttle body. NW92
- Pushrods - 7956 Comp Cams Hi-Tech 7.450" long, 5/16" diameter, .080" wall
- WTB - LS6 cam and ported TB
- Tires and wheels
- FS Brand new SLP beehives 53003 with GM locks and caps
- Yellow ls6 springs and retainers
- 7.4 Hardened Pushrods, Brian tooley 660 springs, MS3 cam
- ls1 to ls2 cam/knock extnesion harness
- ls1 cam, ls2 valley cover, ls3 intake
- FS: New Tick Performance cam and Morel 5290 Link bar lifters
- Powdercoated Parts
- UMI Valve Cover Spacers, 3.70 gears, Walbro 255 Pumps
- Pending Sale
- 238/254 Tick Cam and Cometic Head Gaskets
- Auto meter ultra light gauge
- Iso stand alone fuel system for nitrous
- LS T56 Quicktime Bellhousing ,ARP bolts, ACT Twin Disc, SLP Knob + 240SX Parts!
- 90mm zo6 maf 50+ shipping
- 2014 Camaro SS Brembos (F&R)
- Storage Clean up Interior & More
- Tick, Alky, suspension, tail lights
- BTR 3/8 7.375" Pushrods
- Coils and engine covers from Z06
- Wanted F1 Procharger Standard Rotation
- LQ4 6.0L crankshaft
- FS~F body parts
- BMR Trak Pak Torque Arm
- GTO Fuel rail covers mint
- Superchip hand held tuner
- Used FTI sb3200 converter
- LS7 rocker arms w/ BTR trunion kit installed
- 317 heads for cheap boost
- 416 ls engine-
- Miscellaneous clutch master parts
- Deatschwerks 90lb LS3 injectors (108lb @ LS fuel psi)
- **SOLD**C6 Updated Master Cylinder
- 4l80e Rebuilt W/ Jakes Level 2 Kit
- SLP Line lock, Taylor Pro Race 10.4mm Spark Plug Wires, C6 shift knob for FBody
- Factory 2001 Firehawk hood.
- How to build and modify LS book
- FS: LS3 Injectors and Fuel Rails
- ARP headstud kit, new in box, PN 234-4317
- Diablosport intune i1000
- 325/50/15 M/T ET Street Radials
- Fast 92mm intake manifold ls2 tb
- Misc exhaust etc
- Trans Am halo fog lights
- Stock ls intake valves (8)
- 98-02 Camaro braided brake line
- drag radials
- LS1 Turbo hot side all stainless
- 6.0 (lq4) For sale
- LT headers -LS1 F body
- Ls2 injectors
- 98-02 fbody intrax lowering springs
- Clearing out extra parts
- Sold
- Forged LS1 Longblock 1200 miles Excellent Condition
- **SOLD**Koni Double Adjustable Shocks(full set)**SOLD**
- Fast 92/102mm intake rope gasket, poly torque arm bushing, ls1 fuel rail with clips
- Snow, G6X3 cam, Gauges, BAP, G8 stuff
- 243 heads complete
- FS: LS9 Fuel Rails
- GM 3 bar map sensor
- Engine management and tuning book
- ls1,6.0,5.3 Top end kit
- A&A V2 Supercharger
- For Sale: 6.0L L76 Rods/Pistons - Gen IV
- NEW 799 castings READ CLOSELY
- 42lb injectors
- Blue Point (Snap on) YA6490 GM/Chrysler balancer puller
- (Qty 2) AEM E85 fuel pumps, 219/235 .607/621 Cam
- TCI th400 Flexplate, New Nitrous Solid Roller Cam, New LS2 Style Timing Set
- Zex 82026 Wet nitrous system Ls1
- turbo and hotside/coldside
- AN fittings, Hose, FPR
- Speed Inc TU3 Turbo cam
- Lingenfelter 58x to 24x conversion module
- Square port l92 intake
- 2010 Camaro SS oil pan/oil cooler/pick up tube
- 2010+ Camaro SS AC stuff
- LS7 ported heads and intake, pistons, rods
- 2' Primary 3 1/2 collector TSP Headers
- Gates Fleetrunner K100557HD 10 Rib Blower Belt
- Koni Adjustable Struts & Rear Shocks
- SLP LM1 98-02 F-body
- New!!!! Msd 6010
- Ls3 balancer with 8 rib ATI pulley setup
- Comp cam camshaft
- 4500 throttle body 2100cfm
- Carbon Fiber driveshaft
- 1998 LS1 Engine + Harness + PCM
- Engine mounts/ 9inch locker and gears
- '98-'02 F-Body rear brakes
- Schneiders Racing 296-02R LS Series Solid Roller
- NIB Comp Ultra Gold 1.72 Roller Rockers
- Ls1 intake for sale
- Parting out 2000 Camaro Z28 with 23k original miles
- Procharger P1SC1 & D1SC Headunits For Sale
- Looking to trade green/blue pcm blue/red pcm
- SOLD Complete turbo kit off my 08 Escalade SOLD
- Built 4l80E and Spec-Rite triple disc converter.
- Brand new Strange SA rear shocks $250
- 60lb siemen deka ev1 107961
- F-Body Turbo Kit
- OEM WS6 Air Box - LT1 1993-1997
- ECM harness and intake 2004 6.0 $270 shipped
- SOLD - Doug Thorley LS4 Headers
- JBL XD400/4 AMP and mount board
- Energy Suspension Motor Mount inserts
- SOLD - Brand New EPS Cam - 226/230 .604/.604" 112LSA +4
- SOLD - Fresh LME Ported 243 Heads
- UMI Road Race K-member, LSX New- Black
- SOLD - BNIB LS2 Engine Harness, E38 ECU
- WTT Wheels
- Son of tranzilla hybrid T-56
- PSI Valve Spring Kit
- Comp Cams 7.400 pushrods, centerbolt valve covers, coil pack brackets
- SOLD GMPP 243 LS6 CNC Heads with Lightweight LS6 Sodium Filled Valves
- Dynotune Nitrous Plate came off fast 92 intake fits ls2 as well
- MSD Wiredless 2950
- 4channel backing plates
- SOLD - Fikse FM10: 17x9
- 90mm MSD Atomic LS Throttle Body
- Edelbrock Performer RPM LS1 Dual Plane Intake Manifold SOLD
- SOLD Proform Race Series 650 CFM Carburetor P/N 67199 SOLD
- Griiffin LS Radiator Brand New Still in box 8-00009-LS
- Hp Tuners Pro 6 gm credits
- F body oem radiator....great condition
- T56 Oem shifter stick from factory Hurst
- LS1 OEM Intake Manifold/Throttle Body, GTO Oil Pan, Coolers
- Ls2 Corvette harmonic balancer
- Holley efi HP ecu
- Complete lsx engine 2k miles
- Daytona Sensors Smart Ignition Box 24/58X
- FS: Fast injector spacers
- LS1 Intake SOLD
- Ls
- Several OEM, Extremly low mile, parts for sale.
- Fbody turbo Hot Side T4
- **Sold** Slp exhaust
- Ls3 Brass Blade Throttle body
- RACECAR parts / part out / new
- Holley EFI harness for 4l60/80e trans
- Fbody GARAGE SALE
- LS2 Pistons and Rods
- LT1 T56 Bellhousing
- fenders and t tops
- Lq9 rebuild long block.
- Compstar Rods 6.125
- Trailblazer/envoy rims
- Sold
- LS Dry sump pans
- Selling: De-screened MAF
- Selling: Whisper Lid
- 17x9.5 Race stars with Mickey Thompson Drag Radials
- Slp 85mm maf,ford 42# injectors,spintech crossflow muffler and flowmaster merge
- 231/235, 635/610,112+2 **brand new**
- Chevy Ls2 engine & 4l70e trans
- Price drop! DBW throttle pedal, Air Intake
- reman l92 heads
- SOLD! C5 ZO6 front brakes
- 2002 Trans Am WS6 LS1/6 speed part out. Car is clean owner with 28k
- Quicktime, ARP, Tick, ACT, SLP + 240SX Parts!
- PSI LSX SWAP harness HAR-1012
- Vortech V3 T-trim with bracket (SOLD)
- 05 LM7 5.3 Chevy with under 35k miles
- Edelbrock torque arm
- Monster Stage 5 Clutch
- Gen IV 5.3L LY5 Iron Short Block for sale
- Ebony Center console Lid, ebony Cup holder
- Ebony seat belts. FULL set
- tail light harness, tank straps, auto pedals, upper strut mounts
- 6le Seats For Sale/Trade
- fic 127 injectors
- ls7 fast black 102 with direct port
- AEM Injector Driver with Racetronix Wiring Harness, 160 Pound/Hour Fuel Injectors
- lnc 2000 timing 2step box
- Treadstone TRTT9 Twin Turbo Intercooler
- Ls7 lifters, 98-02 RS spoiler
- FS EFI LIVE v2 gm
- Battery hold downs, 3 channel axle sensor, starter shields, exhaust mounts/hangers
- powersteering cooler, evap solenoid, exh. hanger, dust shields for trans, etc
- FS AEM E85 fuel pump kit
- trans crossmembers, pedal assembly, exhaust hangers, ac/heater parts, ,
- BMR Springs w/ KYB front struts/Comp Eng rear struts (SOLD)
- 5 sets of stock c6 mufflers
- 2008 corvette split spoke rims
- LS6 Cam
- WTB Fbody oil pan
- Freshly rebuilt McLeod rxt w/ billet flywheel- CT
- 2005 CTSV Stock Axles
- Chrome moly driveshaft for f body 4l80E
- Ls1 NX nitrous gemini maf kit
- ARH 1 7/8 Headers with catted y pipe. D port for ls3/ls7 heads
- 862 heads 100$ Picked up 135$ TYD
- MWC Drag Bar. Like new. Barely any use on the street only.
- C5 corvette headlights
- UMI Drag bar. Like new. Never driven on.
- NIB Energy Suspension Motor Mounts
- Pair of M&H Racemaster drag radials 325/50/15
- Snow Performance Snow methanol kit, used very little
- Wiseco 4.010" Pistons
- NEW Nitrous Outlet 78mm Nitrous Plate, ZEX Programmable TPS Switch, NOS 90MM Plate
- Callie's Crankshaft
- HSW Nitrous Interface, Trick Performance 2 Stage Window Switch
- Wtb hp tuners pro with or without credits
- WTB HP tuners
- Fresh ls3 longblock 6.2 $2,300
- 370 forged short block or long block W/CNC l92 heads
- Crane FireBall HI-6 Igntion w/ COIL
- Wilson 4150 super Vic and zr1 injectors
