View Full Version : Parts Classifieds
- Race Proven Motorsports B3 LS7 Cam
- 5.3 rockers arms
- Comp Cams 220/224 .581/.581 114+1 Gen III LS1 Cam
- 42lb ls3 injectors, Nitrois outlet switch panel
- FAST injectors and MSD coils Melling oil pump
- ATI AI003A-005 1050 HP Intercooler
- VFN Sunoco cowl hood. Lift off
- Volant Dual Snorkle Cold Air Intake for Trans Am
- Vision star 2 wheels 15x8 0 offset
- Sold
- ACCEL Fuel Injectors 150830, 30 #/hr fuel injectors, set of 8
- Bosch whites 36/42lb injector
- Auto Meter Pro-Comp 2 Ultra-Lite 5" tach w/shift light
- Ls1 rotating assembly, heatsink coils rtc
- **SOLD ** 1993 Corvette 5.7L LT1 Engine w/ Billet Alum - 39K
- Misc build left overs
- SOLD!! Coils
- 2001 LQ4 Parts
- 243 heads, TBSS intake
- SOLD 243 Heads Used
- Delphi LS6 mass air meter
- New Nitrous Outlet 102mm plate.
- 2010 6.0 LS Rods and pistons
- LS1 & LS3 intakes -Sold
- Gauging Interest - AFR 225 Heads
- 95 3Ch ABS Controller
- Looking for ls engine. Motor can be longblock or shortblock. 5.7 or 6.0
- Btr/ljms stage 1 turbo cam, ls7 lifters, pushrods, trays
- SOLD: CTS-V V1 differential bushing
- 04-06 GTO Seatbelts
- Recaro FIA Adjustable Seat Mount
- 5 sets Rocker Arms and Pedestals off of 243 heads.
- UMI Open Boxed Items- Conv. SFC's, 3-Point SFC, K-member
- (SOLD) Complete, Built 4.8, 7875 billet turbo, 4l80e, converter, and additional parts
- MSD Atomic Airforce (new, cathedral)
- Wiseco standard piston pins (wrist pins)
- NEW PRICES 93-02 Firebird tail light harness, headlight motor, sidemarkers, carpet..
- LT1 Performance & Stock Parts, 383, 24X, etc.
- Aftermarket Climate Control Knobs
- LSX Gen IV ARP Main & Head studs
- Radiator fans, coolant overflow, washer reservoir
- Dorman intake
- MT ET Pros
- Sold
- 04-07 cts v creative steel brackets and axles
- XS Power Intercooler and BOV
- 2011 Camaro TR6060 modified
- Brand New 799 Heads - Bare
- Spohn solid ls1 motor mounts fbody
- Fikse Profil 5s wheels *SOLD* & Nitto NT05 tires still available
- Nnbs/tbss intake manifold
- 243 heads
- ms3 cam $225 shipped
- NEW Tick 7.400 Pushrods
- ARH Fox Body Mustang LS Swap, 2" Race
- Cts-v t-56
- Complete Autometer Elite Series Gauge Package
- Siemen deka 80s
- Morel 5290 linkbar lifters
- HPtuners VCM Standard
- Bare ls3 intake, Slp tips
- LS6 intake manifolds
- Corvette accessories, mgw,ls6 intake,ls7 block
- 02 LS6 Intake, Stock ported and polished 78mm TB and stock MAF
- Racetronix F99 fuel pump (600hp performance pump)
- Shaved LS1 Valve covers
- Kook Mufflers
- Procharger bypass valve
- Tick Performance street heat stage 2 LS3 cam 229/244 112+4
- Custom Cam Motion cam 226/230 114+3
- Strange S60 rearend
- Ls7 Oil Pan, windage, gasket 12an fittings
- FS/FT 60# Siemens/ Mototron Injectors (8)
- (SOLD) LS3 intake/rails/injectors/throttle body and 823 heads
- HRE 547 wheels and tires
- Hooker Super Competition LS1 Engine Swap Headers for 1967–69 F–Bodies
- V Max CNC Ported 78mm Throttle Body
- 2 ls6 intakes
- *4* NEW Huron Speed V3 Turbo Kits available (2) T6, (1) Twin, (1) A/C
- J2A harness for Holley efi
- Looking to buy tick master cylinder for f-body t56. Must be complete
- Tony Mamo custom specd cam
- F-Body Fuel Pump Assembly Harness
- VT Spring Isolator by NastyC4, New OEM I/E Valves, Hurst Knob, Kooks Exhaust Gasket
- NEW Prices: Parts, parts, parts.....
- Brand new GM LS3 intake w/ BBK rails $330 shipped
- Shearer Fab Cathedral Port 'surge' intake manifold....SOLD
- Z06 LS6 Mass Airflow for LT1 & LT4 engines
- 99 ws6 partout
- Cammed LS1 Longblock
- 98-02 Fbody LS motor mount bushings with clamshell
- 17x7 weld rts (NIB)
- Silver blade ls2 dbw t body mint 275 shipped gft
- LS1 / LS6 Fuel rail
- Dorman LS6 intake and TB
- Fast Rails - Valve Cover Filter
- Adjustable borla for trade
- Brand new FAST LSXR 92mm intake setup
- Vs racing billet wheel t4 turbo
- FAST Intakes (78mm and 92mm), Cold Air intakes (SLP Blackwing, Vararam B2) etc
- Wolf 6 point roll bar- bolt in -m.s. Chicago only
- C6 Calipers / Brackets / Conversion Kit for 93-02 F-Body
- ** NOS WOT/RPM Window Switch **
- soldd
- BNIB LQ9 Flat top pistons with rings
- Brand new Corsa Performance axle back p/n 14139BLK. 97-04 Corvette LS1/LS6.
- 3.5" Corsa Clone Tips
- SOLD: NW102 Black $550 shipped! DBW
- Stock Fbody Exhaust Manifolds
- Light grey Trans Am/Fire bird interior door panels
- BMR 4L60E Torque Arm Relocation Crossmember
- 94 Formula Complete Part out... 7.0L, Spohn, BMR
- Tick Performance Adjustable Clutch Master Cylinder Kit 98-02 fbody
- Lots O' Parts- stock, McLeod, Spohn, TSP
- Fbody racetronix pump and hot wire kit
- Fast 102mm Throttle body
- 17x11 CCW Classics with 315/35R17 Hoosier A7s
- Ls1 Intake manifold
- Boost Leash boost controller
- FLT Level 4 4L60E SOLD
- firebird manual console
- 6.0 LQ4 With Bolt Ons
- Mickey thompson pro Drag radials
- Simpson SFI 3.2A/5 two layer race suit
- FIC 1100cc injectors
- Wideband, injectors, engine bay dress up, intake
- **Super Clean 243's Fresh**
- Procharger D1SC setup for LT1 (upgraded)
- N.O.S brand 78mm nitrous plate
- misc ls parts
- Racestar, Fuelab, and other parts
- oe 3rd gen ws6 front sway bar 36mm
- o2 sensor extensions front
- '13+ ram laramie chrome led tail lights with conversion harness for '09-'12 rams
- HP tuners MPVI STD. With 8 GM Credits
- Precision injectors 95lb
- O2 sensor simulators
- Black CCW dragpack with Mickey Drag Radials
- Corvette alt/ps bracket
- FIC Bosch 52 LB (550cc) Injectors
- Ls7 complete intake less to mint low mile 400
- Silver blade DBW t body, mint low miles 300 shpd
- 315 Pro Drag radials
- Bmr lcas, knock sensor harness, oem ls1 rocker setup
- Face Plated T56 4 speed
- Built 2000 LS1
- catch can, LSX valve cover vent!
- Textralia Oz700 X Grip Clutch - 5k Miles
- 2004 GTO Part Out
- LSx Hi Flo MAF Sensor.....
- gto titlton clucth line and more
- t56 uncut ls1 harness
- 10 bolt with Motive 3.90s. $300 pick up only
- Fast Fuel Rails - $100
- C6 corvette comp grey split spoke rims and tires nj
- Stock parts/ performance parts
- Aftermarket Air Lid Stock 806 Heads
- LS3 intake with fuel rails and injectors
- 15x8 Race Star wheels
- Tick Master
- Cam sensor and Oil pressure sender
- Assorted 6AN fuel line fittings and hose / SOLD
- ARP LS1 Main crankshaft bearing cap fastners
- 243 heads low miles
- FS: OEM ZR1 SS wheels 17x9 with LIKE NEW Nitto 555 G2 tires
- PTC LS1 to TH350 converter. SOLD
- Ls1 long block with ls3 heads
- MBA Mallory MBA Billet Aluminum HVAC/Headlight Knobs
- Innovate LC1, XD-16 AFR gauge, and FJO nitrous controller
- fbody oil pan, oil pump, pickup tube and rockers
- DSS 3.903" Pistons
- Speartech ls1 harness and 411 computer
- 96-97 lt1 timing cover 2.25 BB
- LS2 parts
- NEW GTO or Corvette Race Star Recluse front drag wheel
- Nitrous Parts
- Scat forged H beam rods
- Z06 wheels speedline chromed excellent condition
- Misc 4th Gen Parts
- Lt1 parts!
- Water pump, alternator, starter, power bond balancer, th350 stall, valve body
- Holley 5.7 Touch Screen
- 17 x 9.5 Weld Racing RT-S S71 Drag wheel 4th gen New
- Random lq4 and 98-02 camaro parts
- Corvette Slave GTO T56 Offset Lever w/ bronze cup
- TVS1900 Supercharger Kit
- ATI LS balancer with Vette and F body hubs
- LSA Truck Conversion Parts
- AEM 30-4900 Wideband Failsafe Gauge
- Ls1/6 Vengeance Racing Vindicator
- Strange 35 spline axles, ford 8.8, c clip Elims
- Aftermarket WS-6 Functional ram air hood!
- Garage clean out gto and firebird stuff
- C6 zo6 grandsport carbon fiber side skirts and mud flaps
- 95 lt-1
- restricted push rods/ lifters
- Tick Performance Level 3 “Viperized” T56 ****SOLD****
- F.A.S.T fuel rail kit for LS new
- LT1 to LSX swap harness
- Nick Williams 102 DBC
- Fuel injection clinic injectors
- Moser spool and yukon 4.10 ring and pinnion for Dana 60
- ATI 1GN302-SCI 05-06 HO Tuner Kit D-1SC - Helical IN STOCK
- 98-02 Camaro convertible top boot in bag
- 98-02 camaro 6k hid's for sale- white light
- Warr 92 tb
- Catalytic Converters - 2001 Z28
- F-body Master and slave cylinder and flywheel
- Gto spares *trades* or best offer *PRICE DROP*
- NX Lt1/Ls1 MAF nitrous kit
- 4th Gen Firebird passenger window and mounts
- Pacesetter Long Tube Headers 2004-2007 Cadillac CTS-V
- Harland Sharp Adjustable LS7 Rockers
- 4th gen suspension
- 2000 Camaro Black Interior Parts
- pro 5.0 shifter
- Misc. 04-06 GTO Parts (prices dropped)
- Dual Racetronix fuel pump system setup.
- Lnc-003
- (4) 17" Trans Am WS6 wheels/ BFG tires
- 380lph fuel pump. SOLD
- A&A Vortech 8 rib Supercharger Bracket - Black
- 2 MT ET Street 275/40/17 and 2 98-02 WS6 rims
- T tops
- Pcm. 0411
- Spohn adjustable torque arm
- Edelbrock Super Victor 2821 intake ported for LS3 heads
- 3" Flowtech Cutout
- 98-02 Camaro headlights. SOLD
- LSx 6 bolt 454 shortblock
- 94mm 1st gen Camaro turbo kit
- LS7 Throttle body used
- All pro bare castings
- Procharger G8 8-Rib Crank Pulley & Stock Driveshaft
- F body parts
- Manual brake conversion kit
- Treadstone TRV25 Intercooler - Rated @ 1000hp
- Spohn Adjustible Lower control arms lca
- aeromotive a1000
- New Price: 2010-13 Camaro v8 Magnuson/Whipple S/C CAI
- 02 ls1 cam/springs arp studs
- LS7 Clutch and Flywheel
- 2 brand new comp cams for sale $300 shipped ea
- BadLandz e-cutout 3.5
- Zexel Torsen Differential
- FS: SLP SS grille, ARH headers and Y, high flow lid, poly mounts
- LS1/LS6 rocker arms with straub bronze bushings trunnion upgrade installed
- Lingerfelter 58x to 24x conversion
- Tsp rockers with trunion upgrade for ls1/ls6
- New Melling 10296 Pump
