View Full Version : Parts Classifieds
- 2004 GTO 5.7 starter
- fs: trans am chrome 16" stockers w/tires
- LS cam and spring kit
- 10-13 Camaro Magnaflow full exhaust
- Aeromotive A1000 (13101) Fuel Pressure Regulator **SOLD**
- Truck exhaust and intake manifolds
- Ms3 cam aka Magic Stick 3
- meziere water electric pump wp119u
- ProCharger P1SC Head Unit Only
- Holley valve covers
- Fabricated aluminum valve covers
- OEM F Body MAF
- FS: 09-13 ZR1 Mufflers w/actuators and H pipe
- LT1 SDCE ProCharger Bracket, FLP headers and y pipe FS
- ON3 44mm wastegste
- Tahoe/Yukon STS kit
- WTB Broken LS2 or LS3
- 275/50R/15 Mickey Thompson ET Streets FOR SALE
- 33 spline tru track 3.73
- Mid west chassis manual steering rack, new!!
- Set of 8 Genuine Bosch 4-Hole Upgrade fuel injectors. Flow of 48lb/hr @ 43.5psi 500CC
- LS2 Intake Manifold
- New Holley hp ecu
- Aaron's 6061 Elbow
- Heads and Cam for 383 Lt1
- Boost Ready Gen IV 5.3 Long Block
- Small block parts for sale
- lsa nitrous outlet blower plate
- mufflers
- Midwest Chassis Fabbed 9" rear
- Billet Specialties 17x11 17x8
- computer
- Dropout LS1 and t56 from 2002 Z28
- 8.8 Rear End
- Wtt fast 90mm for nw 90 or 92
- LS1 alternator $70 shipped
- Wheels
- Tsp 233/239 .600/.600 112lsa
- (SOLD) Front Single Adjustable QA1's & Springs
- Comp Cams 918-16 Valve Springs
- Brand new Nick Williams 92mm throttle body cable drive
- Blackwing Lid
- 1996 LT1 Motor
- Aeromotive A1000 Fuel Pump + Aeromotie Filter
- SLP Speedometer calibrator
- 1996 Camaro Z28 ls1 swapped part out, BMR, QA1, nice interior
- Vette Center Caps
- FS: FAST 102, NW 102 DBW TB, LS3 fuel rails
- FS: AFR "Mamofied" heads
- Vband Truck Manifolds
- Garage clean out
- F-body water pump
- Katech Tensioner
- BMR tubular K-frame for 93-97 LT1 F-body
- Hallman Manual Boost Controller
- LS1 T56 Mcleod RST Pedal Assembly Driveshaft
- Meziere FP319 168 Tooth Billet Flexplate for GM LS1
- callies and lsa crank,je and wiseco pistons
- Ls1/t56 setup
- LS1 engine 64,000 original miles
- F/S New in the box PAC 1218 Beehive Valve Springs
- F/S Gently Used 8MM Hinson Spark Plug Wires
- F/S: Brand New Comp Cams Beehive Valve Spring Micrometer
- New in the box SLP 1.85 RR for LS1, LS2, LS6 engines
- LPE GT11 Cam
- Spohn solid motor mounts
- Stock LS1 Crankshaft
- Turbonetics y2k 88, PTE 66mm wastegate, Tial 50mm BOV
- Lq9 truck intake/fuel rails/injectors
- 1995 Camaro z28 LT1 Parts
- Strange coil overs
- GEN IV 2007 super low miles LMG 5.3L motor with 799 heads - 800$
- Totaled 05 PBM GTO,BC coil,K&N, Tick clutch
- JL Audio 10" sub with Stealthbox and Keenwood 400w Amp
- FS: LT1/4 and B-body Parts
- Comp Cams tie bar lifters
- It's the "Wow, do I ever have a LOT of spare LS parts sitting in my garage!" sale
- LS3 intake, G8 Fuel Rail and Nick Williams 92mm TB
- Full LS6 INTAKE TB RAILS INJECTORS
- FS: Texas Speed 3/8" pushrods
- FS: Firecore LS Plus Wires w/ heat sleeves (1" longer than stock)
- ev1 Siemens Deks 60lb injectors
- 4L60 Transmission
- Looking for racetronix 42# injectors
- ls1 flywheel
- LM7 block crank
- LS1 alternator bracket, tensioner, upper tensioner
- Comp 26918 new $120 shipped
- 8 stock LS coils c1251
- K40 Calibre radar and laser detector
- 799 heads 2 sets
- Improved Racing 19-Row Oil Cooler -10AN
- holley mid ram ls1/2 style, 90mm TB, rails
- Brand new ls7 hi ram hydro dipped hi-ram
- Intake set-up
- Umi rear lca double adj. roto joints.
- LS1 front accessories
- Lokar Dipstick For Powerglide
- FS: set 16x10 ccw classics
- 17/17 racestar drag pack with new tires.
- Aeromotive Stealth 340 Pumps For Sale
- Practicly new 80lb Seimens Deka Injectors
- Complete LT1 and 4L60 out of 95 Impala SS
- OMP Race Seat
- FS. 06-13 C6Z06 OEM Manifolds,Cats,hpipe,bi-mode mufflers in Pa.
- brand new in box bass link sub
- Camaro GM SS spoiler light brand new (in box)
- Brand New 2002-06 Dodge RAM Hemi 5.7 Performance Cold Air Intake
- 7.4 pushrods, .650 springs
- FS: Dry sump ls3 shortblock w/valvetrain
- 4L85E with 10K miles on Rebuild
- Borg Warner Super T10
- 3600 Stall Converter TCI SSF-SOLD
- FS: Mantic 9000 7 miles like new $1200 shipped
- Meziere LS water pump
- FS: FAST EZ-EFI 2.0 1200hp System
- ***SOLD****Ls6 intake, TB, Bottom cushings, intake bolts
- 241 heads off a 40K mile 2004 GTO
- 2009 L76 engine
- driveshaft for ls1/t56 FC rx7
- LS7 LSXR, lines, fittings, rails, NW102 TB
- New Water to Air Intercooler Radiator - 26x7x2 (Type 118)
- LQ4 complete
- Factory LS6 intake with TB, NO SENSORS
- FIC1000 LS1 Injectors For Sale
- LS1 ac line wheel caps and lt1 TB cover misc lots
- Ls1 intake and throttle body with optional egr port
- Stock '99 Formula Exhaust Manifolds
- F/S: Innovative motor Sport Wideband controller & OBDII Wifi Interface
- Cometic MLS Head Gaskets
- 2005 truck intake with sensors, injectors, throttle body
- Gen IV floating rods and 5.3L pistons
- 100mm MAF with LS1 adapter
- Brand New 2011-16 Ford F250 F350 6.2l K&N Performance Cold Air Intake
- FAST red fuel rails LS1 LS1 FAST 102
- 441 lsx
- LSXR 102 intake for ls2
- RPM Level 5 C5 MN6 trans
- Wiesco Pistons, Scat Rods, Fresh 6.0 block, Super Victor
- Slp loudmouth 1 catback for sale
- FS: Pacesetter TrailBlazer SS Headers
- Precision metalcraft LS7 intake brand new!
- Fuel system components (magnafuel,fuel lab)
- Nitrous express cam NX-3
- 12 ctsv front calipers
- GM fresh 243's W/ BTR .660 springs etc
- ls9 tvs2300 lower unit now have pics
- FS Borg Warner S475 T6
- NOS mini progressive controller
- 4.8 5.3 6.0 Cathedral DBW Truck Intake
- Misc LS1 parts F/S
- 01 ls1 f body t56 engine harness
- TRADE: FAST 102 intake for FAST 92/92
- FS:Camaro 1LE TR6060 Transmission for sale with stock clutch
- TOTRON 54" Curved LED Light Bar
- CBR High mount alternator
- 2011-2012 ctsv magnaflow catback
- F-Body Water pump
- SOLD - Harlen 2-Step
- [SOLD] Magnuson Supercharger HD Tensioner Upgrade - NEW - P/N 31-12-00-082
- TIAL 46mm WG with flanges and 3 springs
- FS: 67-72 C10 Parts - Unisteer Power Rack, TBSS Headers, Drop Spindles Etc
- PSI 1511ML Valve Springs, with Retainers and seats for OEM guides
- HP Tuners VCM Suite MPVI Standard
- Sold
- Holley fuel rails - arp rod bolts
- Frozen boost heat exchanger fs
- RAM Aluminum Flywheel (19lb) Lightly Used
- a1000
- Autometer gps speedometer
- lq9 6.0 shortblock
- Ls turbo headers
- Brand new s480 turbo
- TCI Flexplate - Like New
- 4.8 ls engine
- LS Twin Turbo Set Up - Fox Body Fitment
- C5R Engine Block Guaranteed good
- Pacesetter Lt's and Full x-pipe back exhaust
- LS1 Edit cable
- FAST 102 intake, FAST fuel rails
- 2000 ta leather seats , tbss stuff, 2010 camaro parts
- Stainless Turbo Headers
- LQ4 Intake-2-Pan, Harness, ECU
- FAST 4500 throttle body (for trade)
- Borg s478 t6 billet wheel turbo.
- TSP LS7R 248/256 .652"/.652" Cam
- after market conversion harness 24x with 6 speed
- Lnc-2000
- LS6 Intake Manifold Part #12573572
- Trick Flow GenX® 220 heads setup by TEA
- C5Z06 wheels for sale
- LS1 / LS6 Intake, 85mm Throttle Body
- LS6 Intake
- LT1 Performance parts
- ls7 lifters, ls6 oil pump, ls2 chain
- FS: LS3 vette front drive accessories complete 6800 mi
- Wtb: Z06 ls6 cam
- 60lbs Siemen Deka Injectors for sale.
- FS: Stock LS3 engine parts ONLY 6800 mi
- LS1 rear main cover
- FS: LS1 cam sprocket crank sprocket
- Ly6 parts and 6.2 pistons
- Texas Speed headers
- Tsp 370ci short block BRAND NEW
- Sold
- Magnaflow muffler - 40 plus shipping
- 1150 dominator
- Racing seat - single - vinyl eBay seat
- Ls1 fbody intermediate steering shaft
- Manton 11/32" pushrods 7.30" length
- LS1 ported MAF, 36lb red top injectors
- Intake and Accessories
- magna flow 15684 muffler set up 85mm maf
- Used LS7 Block ( SOLD )
- f body shifter assembly and cable
- ebony steering wheel f body cheapppp
- C6 z06 Brakes w/ F-body brackets ( PICS )
- FS 36lb 5.3 fuel injectors
- 4L60e cable speedometer adapter kit
- Ported Throttle body
- 4.8 5.3 6.0 coils set D581- 12558693
- 317s with BC dual springs $350 shipped to lower 48
- Cam motion cam, Ls6 pistons&rods
- Vic Jr intake with 90mm TB, rails, injectors, elbow and FPR
- LQ4 Flat top Pistons with Rods and Arp rod bolts
- Z06 Cam
- Firehawk Ebony floor mats: factory embroidered - SOLD
- Flowmaster Cat-back exhaust, brand new. Dual cat LT1 Camaro/Firebird/Trans Am
- 2005 LS2 Block, crank, rods Riverside, CA
- 97-04 LS1 LS6 Coils Brackets & Harnesses 12558948 Denso D580
- Brian Tooley LS3 Stage III cam
- Brand new gt45 69mm turbo and Bmr th400 relocation trans mount
- LS1 rocker arms with comp trunion upgrade SOLD
- Valley cover
- 317 heads
- LT1 pacesetter long tubes
- Morel 5206 link bar lifters SOLD
- PSI 1511 springs
- FIC 38# flow matched injectors SOLD
- C5 z06 cam $175 shipped
- F/S: DSS Driveshaft Shop 3.5
- FAST 90mm throttle body
- ARP Wheel Studs and Front Wheel Bearing Hubs
- 4th Gen Single Turbo Exhaust Single 3.5" To Dual 2.5" In Front Of Engine To Bumper
- 4th Gen Front Mount Intercooler and Piping Complete Setup
- 0821 l92/LS3 heads with brand new BTR Springs and Head Studs
- Garage blowout! *New Lower Prices*
- LS6 Intake Manifold Part# 12573572
- Gen III 5.3 6.0 LQ4 LQ9 LM7 D581 12558693 Square Coils
- TRE 42LB Green INJECTORS
