View Full Version : Suspension & Brakes
- Suspension questions
- 1999 Trans Am vs 2011 Camaro SS Convertible Suspension
- Additional welding on SFC install?
- macpherson strut removal
- K member retaining nuts stripped 98 Camaro
- Failed bleeding/busted MC?? ABS delete/Prop valve on LS1 conversion HELP
- Drag wheels and tires with ABS
- Drag Launch
- bmr TA012R. Problems
- SFC different lenghts on f-body (UMI)
- Bmr springs with Bisltening shocks help
- Okay to remove this?
- Boss 302 VS F-body at the nurburgring, which is the better track car? Updated!
- Ground Control's coil over conversion kit
- Squeaky suspension
- Viking performance A206-300k
- Suspension advice
- Squeaking when Braking from 35mph~ to 0mph
- Sway bar question (pics inside)
- LS1 front brakes with welds
- Looking to buy qa1s up front, what spring?
- Video of my suspension at the track
- Anybody using the UMI Roto Joint Ends
- 2001 fbody PS pump gets hot
- Nut size for lower ball joints
- My CTS-V Brake Upgrade Thread
- Smaller Brake Booster
- sanity check regarding measuring toe
- KYB adjustable shocks
- My BMR Set Up.
- Rear LCA Options
- PS fluid reservoir pressure / fluid seeping out
- Does anyone run HydraTech/ hydraulic brake booster?
- Shock question
- shock/strut/spring combo
- Issue installing UMI torque arm
- What's the recommended transmission mount?? Any advice appreciated
- Rear lower shock bolt size QA1 & 9"
- Fay2 fitment with Strange 12-bolt and aluminum cover
- Viking double adjustable settings for AutoX
- Car shaking at 80+ mph
- My BMR 4L60e crossmember doesn't fit right
- brembo brake question
- Would a tranny mounted torque arm be okay in my case?
- Ride height and k member clearance question
- Adjustable shock advice
- Need Afco part numbers
- Brakes for weld draglites on the front... HELP!
- Looks like there's a DIY IRS kit now.
- Need help picking the right spindles and brakes
- Viking vs. QA1 coilover for street
- Strano spring Koni Strt install
- Help Me Hook! (Videos Included)
- 28in tall tire..what lowering spring
- setting camber at home
- Foxbody ls swap for circuit / autox
- Metallic Squeal Ideas? 00 Z28
- Viking front coilover drag settings?
- Popping noise from front
- Help a beginner's wheel hop issues
- Help with rear springs on 6 speed camaro
- Mystery SFC's
- Rear diff rotation at takeoff
- BMR Suspension New Product - Billet Pivot Upgrade for Watts Link - WL007
- UMI 5-Day Sale- 10% Off & Free Shipping 07-01 to 07-05
- thoughts on ebay 4th gen front tubular lower control arms??
- Looking for pictures/info on 4th gen camaros with mini tubs and narrows rears.
- Need your help identifying these LCAs!!!!!!!
- Help identify these rear lower control arms. UPDATE:fixed and installed
- Weight reduction question
- 70-81 Camaro/Firebird sway bar comparisons
- Rusted out brake hard line ABS and TCS - 1999 z28
- Where to buy 2001 camaro phb relocation bracket
- Founders LCAs
- Brakemotive parts received....has anyone had this issue?
- Can/should I reuse sub fram connectors
- Drag shocks
- Break Wobble and a pull to the right...
- Torque arm install help
- Cts-v brake upgrade and compatible rims?
- Stop the scrape with Stranos?
- Disk brake calipers flipped?
- Where to get best prices on BMR?
- Brake lines and fittings replacement
- Installing spring seats on bilsteins
- Rear brake squealing and rust ring.
- Odd rotor wear after rear brake maintenance
- Pan Hard bar relocation bracket? do I need them?
- Street/Track Suspension Setup?
- Power stop calipers
- Lowering springs sway bar links
- any members make t/a relocation mount??
- Lowering springs on a vert?
- trailblaze v8 swap mounts
- Bleeding brakes
- BMR Showing some 3rd Gen Love!
- Ws6 Rear Shock Model Year Changes?
- Do any Ford PBR's or other calipers use the same pads as the C5 and LS1 Fbody PBR's?
- Brake Noise!
- 1999 Z28 Rear Calipers
- What is wrong with my brakes?
- Brand new Bilstien HD/BMR set up, odd feeling over bumps
- 5th Gen SS Spindles on 4th Gen F-Body for Brembo Break Upgrade?
- Better Choice
- Do I need to bleed abs block if pedal feels fine? (Reassembled car)
- Mini tub + 9"
- Reviews on the TRZ Motorsports anti-roll bar?
- Quick performance 9" torque arm relocation
- 100 - 0 MPH Braking Distance 300+ Feet?!
- MIDWEST CHASSIS Motor Mount Help
- Potential 2006 GTO Suspension Issue
- C5 rod end taper angle
- Lowering springs
- It's finally time
- New Suspension Parts need advice!!
- Koni/BMR Springs Installed!
- Manual Brake Install with Pictures
- Having a tough time figuring out what I need...
- Help with front lower control arm measurements
- will lowering the front mess with my launches?
- HELP, I have searched. But all dead end posts.
- SLP line lock 25000 junk?
- Anyone put the 6 piston brembo gt kit from a 2010 camaro on a 4th gen?
- ABS INOP, no communication
- Fox body 60fts inconsistant since new motor??
- how fast to Koni SAs wear out?
- Strange brake issue regarding bleeding.
- Will these shocks work? FE4
- 79 Camaro in serious need of some upgrades
- I f'ed up. Ran MC dry
- New Koni yellow...stuck?
- Adjusting parking brake?
- Installing new shocks and springs
- Cleaning calipers
- polyurethane rear upper shock bushing
- Excessive Rear End Travel
- KYB shocks?
- daily driver shocks
- Front Shock Hardware
- Brake Hardware
- Light popping noise when turning the wheel from left to right when stationary
- DIY: How to Remove and Lubricate Disc Brake Sliding Pins (VIDEO)
- Umi+ afco?
- LS1 rear caliper/rotor options?
- Hotchkis STB For 98-02 on a 97?
- Solutions for tighter steering
- UMI/Strano coil-over kit is about ready to roll. Read more here.
- UMI/Afco coil-over kits
- Brake problem
- BMR KM003 install Question
- Should I buy springs also? 188k miles
- Who in San Jose Can Weld-on SFC's?
- Lowering my 60' times.....
- New shocks, springs & sway bars: '99 Z28 totally transformed!
- Narrowed rearend and no Ebrake now
- Redoing 2002 Z28 suspension-need opinions
- Front lower Rubber spring gasket needed on Koni Yellows?
- Watts Link install-driving impressions
- To low, Did I do something wrong?
- what brand tie rods to get ?
- Can't get 18mm bolt off of caliper on 2000 z28
- help with suspension setup
- Lifespan of Bilstein HDs
- Parking brake parts
- Edelbrock Coilovers--Spanner wrench?
- Founders strut brace wont fit
- ABS inop code 35, where to look?
- Strut and spring questions
- Wbody Rotors Compatible with Fbodys?
- 98 trans am spring questions
- C5 Z06 brakes and Fikse FM5's
- Upgrading 99 T/A brakes to C5
- Lower Ball Joint too large???
- Ctsv brake upgrade fail
- ABS repaired
- Afco SA coilover setup recommendations
- Pic request koni sa's with stock springs on lower perch and heater hose mod
- Stainless braided brake lines & TCS
- New Proportioning Valve Leaking Through Sensor
- 10 years later... I finally lowered it.
- Anyone running an electric power steering box?
- Pulled The Trigger Today, Suspension Now Done.
- Suspension or brakes?
- Braided lines on all 4 or just the front for CTS-V Upgrade
- Lowering spring alignment
- This bolt why will it not come off?
- BMR, Koni STR.T, Moog, and Poly - Car didn't lower much. Why?
- * UMI* Wanting FULL UMI Adjustsble Suspension, Also Black UMI Billet Brackets?!
- Brake kit that includes calipers, rotors and pad?
- I'm looking for suggestions for the dragstrip.
- Thank you Ls1tech!
- 2000 WS6 sway bar bushings
- How did 4 piston Brembos make your car feel?
- Our ugly factory calipers.......question
- where to get caliper rebuild kit?
- I need a steering box rebuilder
- Upgrade/update ABS on '94 TransAm?
- Quick rear shock question
- Super low ground clearence with UMI 2203 Torque Arm.
- Upgraded suspension car doesn't feel solid
- Front Lower Control Arm bolts
- Very hard hitting right rear
- Whaaat ???
- Lowering spring troubles
- Who makes a complete Big Brake Kit....All 4 corners....?
- Strano Adjustable Sway Bar Install - What's the Issue Here?
- Bc coil overs problems, help!
- Project Z28 Killer.
- need help with brake upgrade!!
- So it looks like I need better brakes
- Koni sport won't adjust
- Short TA question (not a long vs short thread)
- Lower A-arms effecting center point?
- STB clearance with Fast 92/Nitrous Outlet
- Cts-v brakes on a corvette c5?
- Anti roll bolt in tabs
- 94 Z28 suspension problem.
- Trying to hook and go. Any suggestions?
- Strange Squeaking Noise - After sitting in traffic.
- Are my brake hoses installed right?
- What shocks/struts should i buy?
- BMR TA012 instant center position and quick review
- Lowering Question
- Fix for Antilock Brake and Brake warning lamps both lit
- Rear rotor flange thickness
- Getting all this rust off
- 4th gen 9" installation help needed
- Strano sways
- Anyone ever upgrade their rear calipers?
- Another steering wander issue
- Whats springs!?!?!
- Hydro boost knowledge
- Need part #'s or sizes
- advice with needing lca brackets
- What brakes to go with
- Backing plate swap lt1 to ls1
- Lower A-arms
- Swapping front shocks... Bolt for retainer nut is spinning
- strano/koni/isolator question
- Putting steering knuckle on
- Couple questions about my stock front lower control arms
- Tq arm: full length vs tunnel brace mounted
- Popping noise/feel from the front end
- C10 Lovers
- Will UMI Solid Mounts work on MWC K member
- Replacing Rotors and brakes.. Any recomendations on what's best for 2002 SS?
- Best brake pads with bite?
- UMI torque arm issue
- Koni/strano install
- 2000 Camaro Brakes Help!
