View Full Version : Fueling & Injection
- recomend an injector size please
- My injectors too small??
- how much hp will 42lb injectors be good for??
- fuel rails hitting intake
- What is a stand alone fuel system?
- Contacting Racetronix? Need dual pump harness
- High Flow injectors
- Newbie Questions Sorry
- anyone used the new NGK wideband?
- Which racetronix kit do i need
- Whining fuel pump
- Any 03-04 C5's using APS fuel system?
- Fuel injector help
- Anyone wanting to do a dual walbro 98 setup..
- How do you setup an air/fuel ratio guage?
- My car is flooding HELP!!!!!
- FAST Fuel Rail install?
- hardwiring magnafuel pump
- loud injectors?
- Walbro 255 external pump
- fuel probs
- Anyone sella similar setup to this?
- 35lb enough?
- Gas problem? Not sure?
- quick fuel line question
- fuel injection ?s
- 2 Walbro 340 intank fuel pump install
- when to upgrade pump
- Fuel Rail fitting - how do I remove??
- Gas tank guru's please help.
- simple... wher to get a set of bosch 420 pumps?
- need help with seleting fuel line and pump
- Tanks inc setup
- fuel system diagram
- question/opinion external regulator and return line
- noob oil pressure question
- Standalone Help
- Fuel pump
- Speed Inc stg 2 fuel system???
- external fuel pump for daily driving?
- all that is needed for fuel rail and braided hose install?
- 96lb/hr injectors can idle like stock!
- do Injectors go bad ?
- GTO fuel tank
- Dual in-tank pumps?
- max power on single in tank f/i ?
- Duty cycle really high...
- Will Cobra 42# injectors work for an LS6 setup as well as green tops?
- nastyperformace fuel tank, fuel sending unit
- injector duty cycle dropping
- can't fuel her up
- Stock injectors on 38# tune?
- Putt Putt Mobile...What Gives???
- RUS 640850 doesn't fit my rail?
- Pos. Vacuum Leak...where?
- fuel system setup recommendations
- 36lb injector question?
- Ethenol E-10
- Post pics of your nasty fuel setup
- fuel pump on convertable?
- Anyone using the Professional Products fuel rails?
- In middle of intake swap & need help! Can I swap 26.6lbs to 28.8lbs with no tune??
- Injector/Fuel rail cleaning frequency request
- Me no stumble now!
- Cleaning and flowmatching? who does it?
- Fuel pump is acting up
- Fuel Line Q
- '96 Firebird V6 Fuel Pump
- Injector size does a small change need a tune?
- Regulator location vs. fuel temperature WOW!
- Tool for measuring fuel pressure?
- bad fuel fuel pump?
- ls1 injectors
- What size injectors are these?
- Injector experts, question about SVO 30lb/hr injectors
- Fuel line...
- Damn fuel pump relay!
- Fuel gauge problem.
- MAF air leak causing "too lean code"?
- Leaky MAF hose = too lean code?
- Power gains on 42# injectors?
- Fuel pump for 500-700hp
- Can Bank 2 issues cause Bank 1 code?
- Quick Question please!
- Extra Pickup on Pump/Bucket?
- Fuel gauge issues after racetronix install
- got my fiel rails and install kit, have no idea how to install! HELP
- Return style fuel system questions
- braided line interior turned to black sludge..what gives?
- FPR Plumbing Questions
- just installed new pump, thru the trap door
- Mounting FPR before rails
- Megasquirt and Carb??
- L36/LS1 fuel pump question
- Harrisspeedworks Stand Alone
- plug size for return
- 60# motron question
- So which is it??
- Fuel Pressure ?
- fuel line picture?
- Anyone had issues with the Eliminator pump?
- Stumbles - too lean code - what fuel pressure?
- Fuel or electrical problem Cranks but does not run
- ? for those who HAVE the nasty performance fuel setup
- Belt drive fuel pumps?
- 2002 z, fuel pump on its last leg, and
- Enough fuel?
- 42# injectors w/ stock pump?
- Loud fuel pump, need replaced?
- What prevents our cars from blowing up with an in-tank pump? Bare wires and all?
- fuel pressure to high
- Injector swap question
- Different Brands of Gas and Manufacturing process?
- 94 Fuel pump relay?????????
- H/C motors need fuel injectors?
- what should i set my base FP at?
- Fuel Flow Ratings for Venom Injectors
- Do I need bigger injectors?
- Intank pump fuel cell
- Twin Intake pump guys check in
- Need help with Fuel PSI dropping under boost.
- Need some feed back on this product!!!
- Stupid F***ing garage floor monster.
- what is stock fuel pressure at wide open throttle on an LT1?
- what octane
- 100 LL Avgas aviation fuel
- Best inline pump for fuel cell?
- need help assembling dual fuel pumps
- which walbro fuel pumo do i get? high or low pressure?
- Fuel System finishing touches
- Fuel pump/ pressure ? Inside
- Not Holding a CHARGE! HELP!
- 100 octane on stock motor
- 97 vett
- Guys with flow matched injectors
- tank leaks when full..
- what injectors are better..?bosch-tsp-lucas..#42??
- Fuel Question
- Messed up my fuel tank need Help asap!!!!!!!
- swapping injectors
- Upgrade???
- HELP ASAP! 98 T/A Racetronix wiring harness
- I need help to install my Racetronix Fuel system..
- Will my racetronix setup be enough for 525 rwhp?
- Elimanator
- installed racetronix fuel pump...running rich now
- gas gauge/tank problems
- fuel pressure 20osi
- Question on Fuel Pressure fluction
- Braided hose to AN fit question
- Tetraethyl Lead -- Progressive Injection
- 04 gmc truck fuel filter?
- Nasty fuel system
- stupid braided hose question...
- p600B?
- Installing boost-a-pump
- chrysler 4.9 injectors...
- F.A.S.T. 36# injectors..anyone running them?
- Race fuel in a stock ls1?
- Injector size recomendation
- Y cant we install another OEM fuel bucket to get a dual pump system?
- remove and clean fuel inj.
- FI 800+ RWHP... what fuel setup?
- A/F&O2 inline pigtail
- racetronix PnP kit recieved!!
- Flow Rate ?'s
- Help Car keeps blowing pump fuses
- Racetronix Vs Greentops
- Need 2000 Camaro Fuel Pump Info.
- Fuel System Upgrade Help
- A new twist to the what size injector question.
- some 42 # injector help needed please
- Best fuel filter
- Injector sizing help!!! Nasty and other experts please!!!
- 98 steel tank question
- Got a problem a big problem
- Single injector not firing....
- what size fuel pump is sufficeint enough?
- fuel system cleaners?
- Can the LPH on a inline fuel pump be higher than the intank lph?
- Boost referenced fuel system installed, and functional
- Installing a Fuel Pressure Gauge?
- car wont start :-/
- should fuel system hold pressure overnight?
- gas gauge compatability
- need racetronix with 408???
- stock fuel inector
- which injector for me mototron #60 or siemens #60?
- fuel pump strainer?
- injector size
- Can the stock fuel lines.......
- Weird fuel Problem need help.
- whats this wire?
- fuel cooler?
- Walbro Dual Intank Link ???
- Sponsors-Need hot wire Kit
- Help me understand flow matched?
- Running bad
- 30lb vs 42lb
- Bosch 42# Injectors
- gas gauge broken
- Newer tank question - filling and venting
- Walbro 255 thermal protection?
- Question concerning fuel pump power(long)
- need help with racetronix harness
- are the stock injectors big enough for this setup?
- Aeromotive rails, racetronix injectors and problems
- 383 ci
- Injector o ring size ?
- Which lines on the fuel pump module
- anyone running "cool cans"?
- injector question
- How loud are your Motorons?
- Impedance? High Low? Explain
- low fuel pressure
- Who makes a dual intank pump setup?
- Upgrades on a 427 for 150 shot
- Fuel Pump is talking to me ?
- Need brainstorming help...
- Those with Racetronix fuel pump
- fuel injectors...
- Will this work?
- Typical injectpr/pump combo for head/cam/100shot?
- ls7 fuel pump
- Fueling system for a 427
- A1000 Aeromotive fuel pump.. whos running them?
- runnin rich?
- Walbro 255 vs Racetronix set up
- 42#?
- help with injector size
- 02' Z06 fuel system limits?
- #26 injectors to # 28
- injector/pump question
- When does factory regulator need to be replaced with an aftermarket one
- Removing the factory fuel pressure regulator?
- Fuel pump choices for a 1998 FBody...?
- 224 cam, ls6 heads, need bigger injectors?
- Brown Top, Red Top? Which injectors work?
- 30 lb fuel injectors
- General fuel pressure question
- REturn fuel system...diections or how-to thread?
- Return fuel system questions
- Controlling 96lb Injectors
- fitting ?
- injector o-rings
- Not Starting most of the time
- Fuel Filter
- Low impedance LS1/LS7 fuel injector...
- anyone run a boost-a-pump all the time? Does it hurt the intank pump?
