- 327 ci budget build
- Timing/Dieseling problems on my sbc
- Brakes??
- 99 bbc efi can i convert to carb
- Old School Muscle Guys...Help Me Out
- 400 bbc?
- Looking for an odd-ball, old chevy motor...
- BBC 496 3,000 LBS bird
- What head/cam for 460ci BBC to reach 600 bhp?
- 89 350 blazer dies in gear?
- anti-theft bypass??
- 190cc or 225cc heads for 355
- Mechanical or hydraulic cam/lifters?
- 496 bbc
- 408 ?
- 1997 427 Camaro
- TPI to Carb and TH400
- manual to auto
- 4 speed clutch
- Pushrod length question
- BBC E-85 Carb
- Gas tank/ Fuel cell
- 350 SBC 400 HP Build Help
- Which carb should I go with ?
- 78 camaro 400hp
- What BBC rotating assy?
- NIGHTMARE :s
- 496 BBC Electronic Fuel Injection
- N/A 383 or 396 in '96 Z28
- 65 396 build ideas??
- custom cam anyone?
- engine wont idle, or stay running
- fuel system problems. HELP!!!!!
- what jet size are you using?
- Water temp acting funny.
- 305 ticking sound!
- 3rd Gen start-up vid as promised
- engine fuse???
- FS thread closed.
- Mating SBC to 4l60E
- another 383 build help thread
- what is the biggest cam you can put in a stock 454?
- We have a bet with some ford guys.. help us win this bet
- cheapest aluminum bbc heads?
- you think this will wake it up?
- 283 build
- anyone identify this plastic BBC EFI intake manifold?
- Parts Suggestions for my Build. Help!
- why does the car just slow down....????
- bbc camaro overheating
- 1st gen small block and t56?
- What plugs for an SBC with TFS heads with the Edelbrock Eforce Supercharger?
- Machining costs
- 2+ Years In the Making...
- Hesitating
- Upgrading my carb
- slight hesitation issues
- 383 long rod. Worth it?
- Forged piston question
- 3.4L firebird starter Help
- How hot should the engine be?
- my engine still backfires !
- What internals?
- Carburetion vs. Fuel injection
- Quick question on BBC conversion
- ~Need new Cam~(383 stroker)
- Broke rocker stud again!!
- Post pictures BBC alternator set-ups
- Finally was able to get a vid of my new set up.
- just a spare budget build 350
- i read the sticky but still unsure
- Okay I am no genius....but.....
- 454 TBI Vortec conversion
- sbc383 stroker questions
- 1998 Camaro 1st gen engine swap
- MSD hel
- having problems with 96 vortec 5.7
- SBC 383 Rings
- About to get a free mid 80s 305 Any good to play with ?
- Small block help
- valve clearance
- fuel pressure problems
- help me set timing
- 454 TBI rebuild
- t-5 transmission help please...
- MSD ignition timing on SBC
- BBC Conversion questions
- Camel Hump Heads Q's....
- got fuel and spark wont start
- lack of top end power, any ideas????
- 1997 vortec 350 power?
- Converting from old generator to alt.
- video of the nova runnin
- Engine install from the top?
- found a torque converter on ebay...someone tell me what im missing
- 1976 nova
- Carburetor Rebuild, still having problems...
- 95 Z dyno
- should i mill my heads???
- Crack in lifter valley???
- should i go with a hydralic or mechnical lift cam?
- Got all my parts ordered...
- y-pipe for long tubes.
- 396 BBC or 400 SBC?
- backfiring through carb
- 383 Stroker Kits
- fuel pump or relay
- Cam selection advise needed
- Valva Sprigs shims question ???
- New Build Thread
- turbo cam thoughts !?
- Need help
- Valve lash problem/rocker bottoming out
- 383 turbo build quistions/ suggestions
- 572/720R cam in blown 496?
- fuel return
- anyone know torque specs for 97 5.0 vortec?
- The new 89 RS
- SBC-Anyone ever leave the mech. fuel pump rod in after going to electrical pump?
- Valve overlap problem.
- 64cc vortec heads
- timeing chain cover
- Which one will be Faster
- Chevy 307ci build up questions
- What do you think?
- frustration!!!
- any one intersted in a doug nash 5 speed?
- Does anyone need some Earls -16 fittings?
- What kind of power will this 383 make?
- Info On A 377 Needed
- 7 year project help!!!
- Engine build: Best way to learn?
- 355 exhaust
- How far do I push the harmonic balancer onto crank on a 305 GenI?
- HEI distributor mechanical advance limits
- 383 or 350 stroker?
- Can you tell me the cause of this?
- 4.3 V-6 question
- timing help please
- 73 454 "239" casting.
- Accelerator pump nozzle ?
- 400 sbc running very hot-PLEASE HELP
- Anyone with a 540 CI or bigger swap?
- Looking for an aftermarket throttle body for a 96'-00' vortec
- Many one of a kind parts for sale at EPP
- ZZ4 Performance Issues
- starting problems
- Bogging problems
- plastic mpfi bbc intake, anyone know what this is from? injector size?
- 383 swap- trany filler tube wont fit!!
- New parts-Need opinions
- TBI Injection Gurus?
- 1989 corvette...
- What cam for 4x4
- calling all engine guru's need your help!!!!!!
- starter hitting the flexplate
- what do you think i will run in the 1/4?
- Help i need peoples knowledge on vortec blocks
- 1965 GTO Black Smoke + Knocking
- which BBC cylinder heads best for the street?
- BBC in '02 GMC Help
- Pics of my Engine Swap. 3rd Gen.
- Your thoughts on the Edelbrock E-force?
- Is cam button necessary on GenI 350 small block?
- Vortec heads with Hot cam
- Which heads for 400 sbc?
- HELP! 350 swap into V6 87 Monte.
- looking for some, ideas? SBC 4th gen swap
- SBC 350ci won't start
- couple of questions about my recent swap...
- What do ya think?
- Anyone looking for some bbc tall valve covers?
- how to get fuel to my sbc...
- Question about putting a tbi 305 into a 97 S10
- Crankshaft Strength
- Question reguarding horsepower
- Marine Chevy 350 Build ?
- I.D. This Motor
- Lt1 cam & timing set in a GM Goodwrench SBC???
- .060 over 454 4bolt main block
- please help
- O2 sensor bungs
- Olds 455 help
- 1994 camaro z502 project
- Solid motor mounts?
- ehxaust gas crossover block
- Priming the oil pump...
- white smoke
- Which carb for L48 vette
- X-pipes,H-pipes, or neither?
- tick in valvetrain?
- need help pickin cam 350sb
- anyone know of a good SBC specific site?
- 385 build 98 l31 vortec heads
- i need a carb for my setup
- What rocker arms should I get?
- the right intake for this set up
- 3rd Gen guys please come in!!
- New heads & cam, watcha think?
- What SBC parts will work with 85 l98 motor
- 82 Crossfire Injection problems
- looking for a bbc f-body's!
- Airplane Gas????
- please help me!
- Stall converter - 85 C10 truck = bad idea?
- Smoking but doesn't look like head gasket?
- average hp for a crate zzr 383 motor
- 97 v6 to sbc swap
- need some advice.
- worried about my engine
- electric choke wiring
- The Mulletbird ... lives!?!
- Procomp heads
- Wanting a streetable 425+ crank h.p. from my 305...tell me how.
- fast air fuel meter
- 305 sbc...
- speedometer ???
- V6 TO V8 Parts Needed
- Need cam help
- Okay what would you choose the Edelbrock E-force or Vortec v1 t-trim?
- 89-MAF TPI(HSR)....Tuning?
- 350 to a 383
- I have a ? for you LT1 guys...
- My 95 383 TPIS miniramed T-56 Turbo S-10
- BBC Cam Timing
- Does the Weiand 177 blower have clearance for HEI dist?
- 85 iroc cam?
- timing cover removal w/out dropping oil pan?
- 327 help
- gasket matching
- Need Advice!
- Truck cam for 85 silverado with 305
- anyone know what vehicle application for this part
- Towing capacity of 58 sbc truck?
- Tuning Help
- Throttle cable setup for SBC in 4th gen?
- Why LQ4?
- The best top end set up for SBC 350
- what size of harmonic balancer for 383?
- Has anyone run any KMJ Performance parts?
- L98 heads on this combo
- BBC Solid Roller Lifters in a SBC
- guess my rwhp!
- Who has ran a SBC with a blower @ 10-1 compression?
- ls1 camaro to SBC swap question
- SBC 305 Headers
- Tossing Six Shooter, Going Four Barrel!
- Speed Shop in Houston area?
- The hole in the crank shaft for a T5(swap)?
- 454 BBC...with electronic fuel injection
