View Full Version : General Maintenance & Repairs
  1. Help Changed oil now clanking noise and pieice comes out exhaust *PICS*
  2. tapping noise
  3. check gauge light, and all of the other messages
  4. Replacing all my pulleys
  5. PICS - How deep is this nail in my tire?
  6. R.I.P. 10 Bolt or just U-Joints?
  7. Can't get the car to start
  8. Changed fuel filter/trans fluid
  9. Check gauges light on when drag racing.
  10. oil pressure????
  11. What Kind Of Bulbs Are Behind The Gauges On 4th Gens?
  12. car wont go into park.....
  13. Passenger Squeak
  14. #6 cylinder ignition problem
  15. code question
  16. Why won't my driver window close flush with the door?!
  17. Replaced low coolant sensor, light still on...
  18. 99 camaro, help me jimmy rig my cruise control button
  19. Help, Rear Main Seal
  20. egr valve????? hesitation, sputtering, vibrates
  21. antifreeze leak!
  22. Which Fuel Filter is the best?
  23. Need gauge cluster wiring help
  24. Cars overheating
  25. Right headlight "higher" than the left
  26. major electric problem
  27. Need An Opinion On A Car Cover
  28. MY car Vibrates after I Accelerate..
  29. My Car Vibrates After High Rpm When I Drag
  30. HELP p1870 in a 99 blazer
  31. Windsheild wipers stay up sometimes??
  32. plastic starer cover
  33. ls1 to lti tail light issue (camaro)
  34. Cylinder Head Coolant Plug..what size?
  35. Easyest way to change plugs on 93 formula LT1
  36. power windows to manual windows
  37. Window rattle problem
  38. Engine removal
  39. Trouble Starting! Need Help!!!!
  40. Oil pressure ? and General maintenance ?
  41. Problems with my 98 camaro
  42. Need Advice PS Pump Install Gone Bad
  43. A "moaning/humming" sound when I turn my wheels?
  44. oil pressure question
  45. HELP with SES light????!!
  46. car won't start security flashing please help
  47. started car for a split second with TPS/MAF/and AIC unhooked
  48. part number for 1999 Camaro headlight bracket
  49. Engine Bucking
  50. Heat coming in from the floorboards????
  51. Tach and speedo jumping around at WOT!
  52. Replacing Steering system, need advice
  53. Z28 kills after 15 mins, won't start for any hour or so
  54. Keeping the car in the garage, how to keep in safe in unsafe neighborhood?
  55. Weird Ticking Noise......
  56. radiator plug
  57. knock sensor p0332??
  58. Cleaning The Maf
  59. gauge ???
  60. Drivers side door alignment
  61. Front Turn Signal(DLR) help
  62. Power Steering...
  63. Dyno Tune-Having Issues
  64. What to check for after WOT runs?
  65. Replacing window glass
  66. Car buckles below 1500 rpm
  67. shake
  68. basic maintenance question
  69. water in engine??
  70. Ignition problems...
  71. Tick sound. coming from right side of engine
  72. Check Trip Computer
  73. Another window motor gone
  74. Broken Bolts!!?
  75. SES Light, Water Leakage, Headlight motor buzzing?
  76. Turn signal and speaker issues
  77. Power window off track
  78. Anyone else have a leaky AC Compressor?
  79. Gas needle fluctuating...help
  80. part numbers for mirror glasses for 99'camaro??
  81. Oil Sending Unit??
  82. Sun Visor mirrors can they be replaced????
  83. a/c showing very high pressure
  84. Wtf Plese Help !
  85. How much air in my setup?
  86. My rear right wheel seems to be tucked in more than the left?
  87. Daily driver help?
  88. Anyone changed to a smaller AC condenser?
  89. Accurate tire pressure gauges?
  90. Where to get high grit sandpaper? 1000+?
  91. LS1 - AC not blowing cold, need freon?
  92. Bad water pump?
  93. NO A/c need some help fast
  94. How-to: Cleaning Throttle Body?
  95. new shudder
  96. lid question
  97. seat belt stopped working
  98. I Have A Question
  99. Lost my gas cap key...
  100. I think my horn is broke... sounds really wimpy
  101. Engine Coolant
  102. My Hatch all of a sudden stopped working??
  103. shake/vibration
  104. Charging system problem
  105. power seat wiring harness, missing end need help! (PICS)
  106. Somender Singh groove.....
  107. Clunk noise, have no idea what..??
  108. low oil light
  109. abs inop and tcs light on after header install
  110. For those that are having A/C issues and have the V5/7 variable stroke compressors...
  111. WTF Happened
  112. WTH is an orifice assembly? A/C problems...
  113. ses light question
  114. How are the trans/ps/cooling/etc systems actually flushed?
  115. starter overcranking problem
  116. That metaly... rubby noise when going in to R?
  117. Loose steering column/wheel
  118. Parking/Emergency Brake Adjusment Screw
  119. Tick, Tick, Ticking noise.....
  120. i have a dashboard wireharness problem
  121. when i downshift
  122. 95 T/a 1500-2000 Rpm The Gauge Goes Down While Engine Is Cold
  123. Oil pressure changes at same rpm
  124. filter brand
  125. A/C Compressor clutch
  126. 90,000 Miles Gcs Any Good
  127. check engine light came on at high speed
  128. Rat chewed on some wires!!!
  129. Steering slack -- shaft through firewall?
  130. A/C trouble and the good ole Orifice Tube
  131. car sputtering
  132. NGK TR55's.
  133. warped belt sound coming from LS6 intake?
  134. o2 sensor problem
  135. cant open hatch with key?
  136. LT-1 - Small Block Chevy Differences
  137. Can't find misfire, details inside
  138. smoke coming from some where
  139. Power Steering Fluid is ORANGE???
  140. oil consumption
  141. adjustable throttle cable?
  142. need new steering column, price?
  143. Fuel Filter
  144. Oil Leak out exhaust tips?
  145. Brakes: Is it supposed to be hard to reattach the caliper?
  146. Airbag question
  147. Changed Fluids, Gained HP?
  148. ls7 water pump?
  149. run regular oil for 100-200 miles?
  150. Help please!My window
  151. what car cover do you use??
  152. Weird knock in the motor...
  153. ?'s about posi traction
  154. Car will not start......Help!
  155. Instrument panel lights fuse keeps blowing?
  156. Brake Light Problem
  157. ac and power steering kills motor
  158. Random Misfire at low RPM
  159. LS6 Intake manfold?
  160. `98 seats into 2001 TA - Now no lumbar!
  161. Oil change question (No, not "how do I do this?") :)
  162. 2001 Trans Am Headlights Question
  163. Multiple engine misfire???
  164. So, I'm buying a 2001 Z28 and he told me this..
  165. Fram oil filters
  166. stuttering/bucking ????
  167. Changing Battery Cables
  168. Which SES scanner to get?
  169. Steering issues
  170. Plugs still good?
  171. Door wont open need help!!!
  172. T Tops Leaking...Where To Buy New Seals?
  173. Hood Bird/Paint Question.
  174. cooling light question
  175. Question bout Air conditioning harness..
  176. Easy way to check the A/C?
  177. squeeking tensioner?
  178. anyone know 3.4 v6s
  179. No oil pressure when I started the car.
  180. sqeaking coming from the back!
  181. anyone know 3.4 v6s
  182. loss of power?
  183. Fuel overfill?
  184. 98' TA, Dead Battery (new Optima)
  185. hesitating, stalling, sputterring,
  186. how to stop the y-pipe from hitting the floor
  187. Starter install, which to buy/ difficulty???
  188. Turn signals not working
  189. Seafoam and spark plugs???
  190. Removing side mirrors
  191. Has anyone ever replaced there door glass. can I get some tips and help with some ?'s
  192. I had wet carpet on the passenger side???
  193. Hi-beam switch is broken, sort of
  194. help please
  195. ses code
  196. traction control stuck
  197. car won't start and everything is going wrong
  198. Relays.... Did GM cut some corners?
  199. Oil leak help!!!!!!!!!!!!
  200. SES light: Evac syetm leak (small). Is this bad?
  201. Changing Fuild
  202. Faulty Fuel Gauge
  203. replace cat or get rid of it?
  204. 50 amp ingnition fuse blowing
  205. Oil FilterMAG
  206. Starter/Relay/Electrical Issues Car is sitting in a parking lot HELP!!!
  207. TA throwing a p0102 code
  208. Need a Water pump
  209. RPM range?
  210. air conditioning question
  211. no oil pressure!?!?
  212. Windshield Wiper issue *highly embarassing while driving*
  213. Bad horn or relay???
  214. rough idle, hesitation when accelerating
  215. Throwing MAF code after header install
  216. alt. help needed
  217. how to get to lifters?
  218. Fuel injector cleaner
  219. p1637, Think I found my gremlin?
  220. SES light, bad exhaust emissions, can O2 sims fix?
  221. Headlight motor
  222. Airbag replacement help
  223. nasty oil leak wtf? lol
  224. Turn signal keeps burnging out
  225. Ten Kinds of messed Up!!!
  226. car making a weird sound
  227. Weird light
  228. driver side window fixed :)
  229. Stupid Question?
  230. daytime running light bulb replacement
  231. water in horn ...
  232. turn signal not working not bulb ?
  233. Replacement wiper motor issue?
  234. MAF reading high?
  235. spark plugs
  236. Ls1 = Corvete Engine???
  237. Car won't start...
  238. Help! car is stranded at autozone
  239. fram, K&n, blackwing air filter
  240. gauge problems
  241. HPC coated stainless headers, how tough?
  242. starting issues
  243. **** WERIDDD sound from my ls1!!!
  244. HELP - I think I got water in gas
  245. Front Plate Screws? WS6
  246. Let see if anybody knows how to do this
  247. Which rack and pinion for WS6? Anyone have a WS6 VIN i can borrow?
  248. Catch can or LS6 Conversion?
  249. Check Gauge light flashes at high rpm..
  250. Putting chrome Lug Nuts On?
