View Full Version : Parts Classifieds
- Red AC Delco plug wires
- LS6 Z06 cam and springs BRAND NEW ZERO miles
- 4l60E Swap for sale or trade
- MTI Stage 2 R Heads
- what would u sell used 02's for?
- ARKANSAS CHEAP PARTOUT! 408 L92/l76 Nittos Exhaust
- FS: Cams, valve springs, pushrods
- UMI Tubular Lower Control Arms. Like New
- MSD Ignition: 6AL, Multi Function Controller, HVC Coil
- FS; 2003 z06 red body side molding
- Fs: Grey z06 covercraft noah custom car cover
- volant 98 02 trans am intake for sale
- Comp Cams #7106 Keyway Adjustable Billet Timing Set
- white rear panel, tail lights, SLP bellow, 85mm MAF
- 98 clutch/fly/pp/bolts
- TIRES 255/50 DR, 315/35 DR, 275/45/20 GOOD YEAR and ZR1 wheels
- 42lbs injectors for sale/trade.
- F/S Masterpower t70 .96ar, with fittings
- FAST 78, Ported TB, Nitrous MAF ends, and more
- 99 LS1 engine
- Nitrous parts for sale
- Sold
- wtt vrx4
- gmpp intake manifold with nx kit and more
- Excelent shape M6 console 97-02
- Brand New Gm MLS Head Gaskets
- LS Engine Swap Parts
- 243 heads complete
- Lifter Trays LS2/LS3/LS7/L92/LS9
- parts z06 brakes,Heads, DS, ORY, coils,front covers, rockers, pedals and more...
- Polished valve covers, Camshaft Springs Pushrods
- SD 72lb Injectors
- RAM billet steel flywheel
- Brand new Aeromotive 17125- AV1000pump- Aeromotive Universal Bolt-On Fuel System
- FAST 92/92 setup
- Complete nitrous kit GM or F-body
- LS1 Valve train parts and gaskets F/S
- FS: Roller TH400, Drag 8.8, TH400 Driveshaft
- Garrett T6 74mm turbo
- LS6 Intake Manifold
- 2 ls6 intake manifolds
- 6l80e with T-case for sale
- FS: MS4, 7.400 HPRs, Dry NOS kit other parts
- L92 heads
- 98-02 Trans Am GM Sail Panel
- LS3 L92 rocker arms and stands
- LT1 Lingenfelter CAI and polished elbow
- PTM 92mm tb and Edelbrock Elbow.
- Black powdercoated stock 2002 Trans Am WS6 speedline wheels *SOLD*
- Chrome ZR1 wheels and tires
- TSP ported oil pump, stock driveshaft
- 1996 Camaro Partout
- LS7 Lifters $100.00 Shipped
- Corvette C6 Procharger Setup P1SC-1 w/ injectors & BAP
- Nitrous for sale w/all extra's(Nitrous outlet, nx, dynotune)
- FS: McLeod Adjustable Clutch Master Cylinder (NEW DESIGN!) NIB
- FS: LSx camshaft 22x°/23x°-.585 lift-114 LSA
- For sale or Trade: My Red PHB for your Black one.
- Diablosport tuner u7198
- Electronics Stuff and EFI LIVE Scanner for sale or trade
- LS Parts - Cheap
- L92 823 Heads & Loaded Intake Gen IV NEW
- Loaded TrailBlazer SS Intake 09-10 Gen III TBSS
- 4150 Halo Nitrous Plate
- Procharger D1SC Headunit FS
- Leather Hurst Shifter Knob
- WTB a epp front mount intercooler kit
- CTS-V Brake Upgrade for Sale!! - SOLD !!!!!!
- laser interceptor / Jammer the best period !
- Vigilante 4L80E 10.5" multi-disc converter 2800-3200
- parting out '99 WS6 procharged
- Automatic and 6-spd pedals
- Autometer Sport Comp 5" Tach
- LS1 crankshaft - stock
- 97-03 ARP 12pt Head **STUDS** - $150 shipped
- LS1 heads - 806 casting - stock
- LS1 Camshaft - 236/242 .580/.590 with 112 LSA
- LS1 engine block
- LS6 cam, valve springs and push rods
- Black powdercoated C6-C6 caliper brackets
- 3rd gen LS swap turbo hot parts
- 317s with COMP 918s- Low miles! COMP hardened pushrods
- Autometer GAUGES (speedo/tach/oil press)
- B&M Steering wheel Transbrake button
- Complete Aftermarket Fuel System Partout (ANhose/ends/pumps/filters/regulator/tank)
- WTT C6 Z06 wheels for C4 ZR1's
- WTT Leathor Seats
- LS1 coil packs $95 shipped
- Precision PT88 Turbo, Turbosmart Eboost 2, and TurboXS Boost Controllers
- Mcload Bellhousing, SLP Billet Flywheel, + a few sets of Hardened Pushrods
- Last of T/A Part Out
- Sold!
- Door Weather Stripping for 4th Gen F-Body...
- T-Tops for sale
- LT1 stock heads, and ported intake
- Patriot Hardened Pushrods 7.400, only 1500mi!!
- G5X4 Cam
- truck coil packs
- Aeromotive Eliminator Fuel Pump. Almost New!
- Rossler 4L60E Trans Brake
- 93-02 Camaro Race Craft Frontend
- Dana 70 ARB locker, 35spline.
- 78-81 mALIBU 12 bOLT
- FS:.528/.535 218/224 custom blower comp cam and trpile spring valve springs
- T56 with LS7 clutch kit and everything you need to do an M6 swap
- torquer v2 cam for sale!!!! cheap and supporting mods
- LS3 style Delphi 42lb Injectors - Almost New - 200 obo
- Like-New SLP Airlid 2001-2002
- Borg Warner T-56
- Built 4l60 & Fuddle 3000 tc
- Stock steel driveshaft and more... Jacksonville, Fl
- New Brembo rear calipers- Camaro
- cleanin garage
- MSD 6010 Box and accessories
- CORSA Oval Mufflers!!!
- Newer 4l60E flexplate
- 1999 ls1 FS - SOLD
- FS: Ed Curtis FTI 214/220 .597/.600 108+2
- Silicone High-Temp tape
- diablo predator programmer
- Y pipe and Pushrods. BRAND NEW!!!
- FS: NIB Comp 220/234 581/598 115 - Perfect L92/LS3/LY6 Stealth/Boost Cam!
- Comp Cams 240/248 114+4 XE-R LS 3 Bolt Camshaft -USED - $200
- Garage clean out
- HSW Nitrous Kit
- 1993-1997 & 1998-2002 Body parts/interior. Incl. 98-02 front end parts!
- Meziere 35GPM Electric Race Water Pump
- Fs: Lt1 heads with behive 918 springs and lt1 intake
- Edelbrock Super Victor Carb manifold
- Forged 22" Lorenzo WLO11 Wheels
- TSP Pushrods ARP HEAD STUDS Underdrive pulley
- FS: TNT Nitrous Power Ring kit
- Garage Sale For LS1 LS2 LS6 Parts
- Firebird Seats - Complete Set
- Corvette 85mm ls6 typhoon intake with fuel rails.. patriot gold...many other parts!!!
- FS: 317's, Bare Brand New L92's, Trick Fuel Filter & More!
- GMPP LSX standard deck used o-ring block SOLD!!!!
- FS: Crap in garage(misc parts) w/pics
- Calibrated Success tuning DVD and books. New unopened
- Dynotune Nitrous Window Switch $30 shipped
- LT1 T-56/B&M shifter/Mcleod street twin for small block chevy/Full S-10 Swap
- 3.905 HTD piston rings
- FS: Brake brackets to use c5 rotors by LGMotorsports
- Billet 88mm Turbo Inlet Bellmouth
- 3.42 Ring And Pinion
- My Goodbye Opti sale! LTCC, opti, brackets
- (SOLD) Slp oil pump and timing chain
- Stock L92 Rocker set up
- Gray leather door panels
- FS: headers, SLP dual dual, K&N FIPK, KOOKS, ORY, SS hood
- Cragar SS's
- Procharger Velour
- SPOHN solid LS mounts-NEW
- Kooks LS1 Headers and exhaust for Foxbody Mustang
- c5 DD wheels + 10lb new nitrous bottle
- Help Fund my F1-R! Brand New Custom Nitrous Kit/Fuel Pump Kit/Gauges...CHECK IT!!!
- Comp XR275HR XFI RPM High Lift Cam 222/224 Gaskets and Timing Chain
- NOZzle Direct Port Kit. 100-300HP
- V6 swap
- WTB cc503 cam
- PCM, wideband, Harness
- ls1 EDELBROCK VICTOR JR. INTAKE
- L76 Intake Manifold, LS2 Fuel Rails, L92 rockers and bracets, LS6 Valley cover
- stock stuff
- 05-06 GTO Cold Air Intake
- Used LS1,2,3,6,7 parts, stock & performence
- GM Dist Conversion Front cover/MSD dist complete
- WTT yank 4000ss for tighter yank ss (4L80)
- (2) Brand new S366 turbos, T4 flanged
- lsx parts
- FS: ebony cloth firebird seats
- LTx/LSx! Gears/LTx Intake Mani/Driveshaft & More..
- Wtb: Ls2 gto oil pans!
- brand new in box racetronix f98 pump
- 98ss show car part out
- PRC Stage 2.5 5.3 Heads.
- MT1 s1 CAM 244/244 .612/.612 lift
- Bare LS3 heads
- Alum Driveshaft
- BRAND NEW CME with 90s and Valence
- FS: Weld Magnum 2.0 wheel set Aerospace Front Brakes
- Painted LS6 Intake w/ stock fuel rails, 26lb injectors, stock tb
- Brand New Billet Precision 106mm Turbo
- Hooker Super Comp LT Headers LT1 NICE!!!
- Spintech Muffler w/3" catback
- Custom sheetmetal oil pan
- F Body pedals cluster, pedal assembly, manual swap, 6spd conversion
- New Take off LS3 intake manifold
- Transmission Pan for 4L60E-factory stock $50!
- LS1 Engine Mounts complete with bushings
- Hurst Shifter Lever, Weghted shift knob, t56 shifter
- LS1 / LS2 Headers / exhaust manifold
- LS1 AC Compressor LS2 Air Condition
- vinc programmer
- Corvette LS2 Plastic Valve Covers Fuel Rail Covers
- Hypertech Power Programmer III #30025
- Autometer Phantom 2 5/8" Trans Temp & Oil Press. Vent Gauges
- 2000 Camaro SS stock 80k Mile Heads
- Free to a Good Home - 4703 Sylvania low beam Firebird headlight bulbs - Used pair
- Free - 880 Sylvania fog light bulbs - used pair
- 880 Sylvania fog light bulbs (Firebird only) - NEW pair
- Stock T-56 F-Body 6 spd Shifter
- Stock LS1 F-Body PS Cooler
- 4 Black Z06 17x9 with chrome lip and tires
- Friebird front license plate filler
- Stock LS1 F-Body PS Pump Pulley
- LT1 LOTS o PARTS SALE 93-97
- Fragola PTFE teflon hose and Stainless Fittings
- Stock 2004 GTO Shifter
- (8) Lucas 51lb Injectors - Practically New
- *SOLD*OFI T6 Turbo Kit
- sold
- sold
- Precision 66mm wastegates
- Strange spool and gear for 12 bolt
- TCI 3500 Stall
- 1998 Carmaro LS1 4L60E TRANS
- Gauging interest Trick flow heads, yella terra rockers, cam, headers
- Custom Painted Trans Am Tail Panel FS
- part need gone asap make offer
- need parts gone ASAP
- need parts gone
- parts need gone
- delete
- 5k mile 243 heads complete...
- Misc parts Camaro, Trans Am, Mustang, and more
- "NIB" Big Comp cam!!! $250!!!
- Black mirrors NIB, 85MM digital MAF,MSD Opti, 60# injectors,more
- 04-06 GTO Tail Lights
- O2 simulators for sale
- LS6 Intake/Throttle Body/Fuel Rail
- 4l70e
- WTB!! stock LQ9 piston assy asap!
- FS:Hypertech Max Energy Programmer 98-04 ls1
- Comp Pro Mag roller rocker 1.85, MSD Timing Twister, LS2 Flywheel, NOS Plate
- LT1 X pipe exhaust
- 76mm turbo and spec3
- New GMPP L92 Carb Intake
- Rapid Motorsports Dominator 2X Cam Kit (New)
- FS: VVT Delete Kit (LS2 Cover, 1X Cam Gear)
- (PRICE DROP) Nitrous outlet 78mm plate **NEW**
- vinc programmer
- G body 9 inch housing and upper arms
- 2004 Y body Valve Covers NEW
- 225rwhp 1992 Turbo Mazda Miata drivetrain
- 10lb Nitrous bottle with High flow valve
- Fresh rebuilt 4L60E and 2500 Stall Converter
- ls1 valley cover w/ sensors, timing cover
- 97 trans am parts
- FS: ARP 234-4316 Head Studs
