View Full Version : Parts Classifieds
- FS: LS procharger 8 rib upgrade pulleys
- b&m megashifter NEW
- Magnaflow Oval 3inch Tip part#35171 (new)
- FS 243 Complete 243 Casting Heads
- FS: Hooker Longtube headers - SOLD
- WTS 90mm Plate NEW Kit
- performabuilt stall
- SLP Ram Air Duct
- WTT: DBW Intake/TB
- 30th Anniversary TA floor mats New in GM box
- SOLD: LS2 Fuel rail complete with injectors
- 5.3 complete intake, 6.0 manifolds, truck motor mounts CHEAP!!
- FS: LS6 intake - $320 shipped
- 98 Gauge Cluster from Trans Am
- Torquer V2 and BMR TQ arm SOLD!!!!
- LG G5x2 232/240 cam, 311 CFM 243 heads, Shorty headers
- CD changer
- LS1 T56 Bellhousing
- Nitrous outlet 78mm plate
- 3200 stall protorque converter 10.5" lock-up
- LS6 intake & p/p stock tb
- Dr x tb conversion module ....
- ATI super damper 98-02 f-body p/n 917242 (new in box)
- P.I. Vigilante 3600 Stall
- GTO ARP Wheel Studs and B&M Shifter
- trex cam 4 sale!!!!
- Fast Toys Ram Air, Ported MAF ends, SLP LID
- prostars, dr's, nitrous parts, etc..
- Harlan Shift Light-Red
- Procharger 3.7 pulley. Big Stuff 3 BS3 O2 Sensor. Procharger Oil .
- LS1 parts for sale CHEAP- CCW 3/8 Wheel spacers, MSD bap, 799 heads, service manuals
- Like New LS6 Intake, Fuel Rail, Brackets, Bolts & Gaskets (600 miles)
- New Walbro 225 pump
- NOS Nitrous Bottle 10LBS
- compleat heads from 99 trans am.
- G5X3 112 cam
- 1998 fuel pump/sending unit-complete pull out
- Ls1 Short Block, Comp cam, asp underdrive pully,Caddy lifters, batwing oil pan,miscs
- Stock flywheel off of 2001 SS Camaro
- Stock Head Lights for 1998-2002 Camaro
- Stock 2001 Camaro SS grill
- COMPLETE stock exhaust off of 2001 SS Camaro
- For sale- Lt1 Msd Distributor 1992-1994 with msd coil
- 98 ls1 pcm - 806 heads - ADR wheels - ls6 oil pump
- stock engine parts
- m12 t56 6spd
- Everything is sold i will start a new thread for other stuff
- Fs Lovells Gas Legend rear shocks for 04-06 GTO's
- UMI Boxed Style Weld-in Subframe Connectors SFC
- Sam Strano lowering springs
- Yank SS 3600 for 4L60E
- Greg Weld Racelite Fronts
- diablosport predator 5100 for sale u7198
- Camaro export tail lights
- *** LS6 Block For Sale ***
- SLP 1.8 Rocker arms
- New in box, aftermarket Halo fog light rings FS...
- 2000 Camaro Part out....
- 4S: wheel adapters 3" 5x5 to 5x4.75
- LT1/sbc rockers,studs nuts
- Spal Fan
- Lots of Misc Parts F.S
- a/c heat controls
- Absolute Speed stg 2 cyl heads
- 4L60E trans
- 03 Envoy 5.3L
- C6 Z06 Comp Grey Replicas For C5 18x9.5 & 19x11
- Lakewood rear control arm setup with adj. relocation brackets
- For Sale or Trade LSX Tall Deck Block
- 2002 f body camshaft
- Pioneer AVIC-D3 Double-DIN $350 SHIPPED I NEED A4 MONEY
- 17" Black Corvette Wheels Trade for Pro-stars
- LY6. 6.0L Shortblock for sale
- rear berger stlye panel
- Stainless ORY pipe and SLP LM1 catback
- used k+n cold air intake and gm 1le elbow
- LS2 Shortblock
- 243 heads
- Coan converter...TH350, 400, or glide
- Innovate Dual Channel LM-2 Wideband w/ Window Mount and Pro Sport A/F Gauges
- M6 console & M6 pedal assembly Mint condition
- LS7 clutch (with LS2 flywheel) for 98-02 FBody
- FS: TPiS ZZ409 Camshaft
- Stand Alone/ Bottles/ Remote Opener/ NOS wet kit/ LS2 intake/ Much More & PICS!!!!!
- Phoenix decals
- FS: 1995 Trans Am Partout
- LS6 Intake
- Homemade LT1 alternator relocation kit, price lowered
- couple of ls car parts
- ported ls1 tb
- Want to trade my tsunami cam for your cam!
- Custom 238/242 Camshaft
- *Monster Clutch 2.5 Kit **Brand New**
- VIG 3600 Stall Converter (TH400)
- LS1 short block
- TRUCK KBracing turbo kit PT88m, 4" DP, TIAL COMPLETE *NEW*
- LT1 TA tails
- Stock Cats from '01 Z28
- Pro 5.0 Shifter
- 5.3,ls1 extra parts. 75 dollar sale.
- Parts for sale!!!
- Ebony TT shades
- fast 36# injectors brand new
- Camaro Fog Lights 98-02
- 30lb injectors
- Borla Exhaust...reduced price $450
- SLP Lid
- LS1 Engine Parts
- lt1 kmember
- Jessel 1.7 sportman,adj shaft mount rockers and c/b vc.all 3 for 525.00 shipped(pics)
- 7.45, 7.25 pushrods FS
- Breathers and coolant reservori FS
- Fans, Throttle body, Fuel rail, Power steering pump, airbox
- Timing cover, rear cover, steering wheel, 4 ch amp, laptop
- NIB ARP Head Bolts (all same length) LS1/LS6 134-3610
- 1993 A4 harness and low miles o2's and iac for sale
- FS: Built T-56 Swap w/ Twin Disk
- pacesetter ceramic long tubes and off road y
- Misc SBC parts, new&used, vlve cvrs, dizzy, tools, etc.
- Stock Ls2 crank rods pistons
- Stainless longtubes SOLD PLEASE DELETE
- PS3, K&N CAI, MSD wires, y pipe
- Nitrous stuff... complete kit or partout!
- 1998-1999 Flowtech Long Tube Headers
- 241 heads
- ls1 rear springs
- FS: Borg Warner ST80 1.25 a/r!
- moser 12 bolt motive gears for sale
- Ported 5.3's, rockers, 28.5# injectors
- 90mm throttle body
- ARP head bolts, 04+ LS1/LS6
- Single MSD Plug Wires
- LS1 Radiator
- 18" Wheels for sale *Cheap* PRICE DROP! 370.00 Shipped!
- Mallory 685
- FS: Lingenfelter Highrise C5 Vette Hood
- FS: NOS progressive controller #15835B
- 383 sbc f/s f/t
- 4 billet specialty rims and mt tires brand new mounted never used
- 4l60e transgo shift kit & transgo spacer plate
- 1999-2002 Racetronix Fuel Pump
- 2 double adjustable rear afco shocks nib
- LT1 heads and RR
- yank 3000 stall
- LT1 Ported Intake
- Richmond pro 4.33 9inch gears
- 317 6.0 heads
- LT1 PARTOUT, JE pistons, AFR heads, EWP, turbo cam,rockers etc
- Parachute Mount for F-Body
- 16" CCW Classic drag pack!
- ls1 shortblock/longblock
- De-mod sale fourth gen and lsx
- stock ls1 tb
- LS Garage Sale
- Speed Inc UD pulley
- 01 Silverado ECM
- LS7 427 Short Block
- stock ls parts
- Lakewood Lower Control Arms
- Moser 12-bolt fs........
- Fs:starter, and a few other parts cheap
- LS2 Fuel Rail Modified *SOLD*
- LS1 Fuel Rail from 2004 Corvette *Trade for starter?*
- FS: Zexel Torsen diff 10 bolt
- ASP underdrive pulley
- OEM white SS hood
- ls1 engine lift plate
- 98-02 Used Firebird Formula Bumper For Sale
- Aluminum Driveshaft
- LS1 806 Heads
- FS: Intake / Carb / MSD 6LS
- Stock RED 98 z28 part out
- AFR 190cc LT1 heads (sold)
- Fs: Mickey thompson et drag wheels
- Mint Condition LS1 Scanmaster
- msd 6010
- FS/FT Brand New Snap-On and Blue Point tools--Air Impact, Air Wrench, Impact Sockets
- Textrailia Exo-Skel
- Sold!
- 53K mile LY6 and 4L80-E better then the LQ9 6.0L with L92 heads
- Flex Fuel Predator for GM trucks
- Pics Added! 98-00 WS6 Rims PRICE REDUCED
- Lakewood adjustable "lift" bars
- F/S: Textralia Exo-Skel, GREAT CONDITION
- Wilwood Superlite 6 piston front brake kit + lots of stock/misc. parts
- Fast Fuel Rails NIB & ATI Super Damper
- LQ9 PARTS, TRUCK MANIFOLD, Engine Covers, PCM +MORE
- SOLD---GM IAC to Ford Adapter
- 2002 Chevrolet Corvette C5 Z06 Front Brake Assembly; Cheap Cheap Cheap! Need's to go!
- 5.3 with GMPP intake and MSD 6LS ignition
- 93-02 granetelli relocation brackets (brand new, never used)
- nitrous bottle,blowdown tube,mainline
- Delphi/Lucas 42# injectors
- For sale 317 heads
- Brand New Comp Rocker Arms CHEAP!!!!
- paxton low profile blower / turbo carb hat
- LS1 Howe headers
- Spohn body mount tq arm, BMR non adjustable lca's
- ram clutch master
- HyperTech Power Programer III for 2000 LS1 Camaro/Trans am !!CHEAP!!
- Tall Performance Cone AIR Filter
- NIB PTM 95MM Throttle Body
- american racing headers
- 4th gen parts: grille, side marker, spare
- autometer ultralite II oil pressure gauge 20 shipped.
- Stock LS1 MAF
- 2002 camaro ss oem hood in mint condition
- LQ9 with 4L65 complete ready for a swap.
- GMMG Exhaust, New Motive 3.73, K&N FIPK Cold Air Kit, ZR1 SS Painted Rim, Back Seats
- 98-02 LS1 Prothane Motor & Transmission Mounts Kit
- HP Tuners MPVI Pro
- OEM Corvette C6 Wheels For Sale
- FS: Fresh FORGED 6 Ltr Iron Block 370ci
- FS: New/Used LSx mixed parts
- 2003 LM7 Parts
- K&N filter for F-bodies
- HSW 90mm Wet Nitrous Plate
- 408ci stroker kit (Callie crank, eagle rods, Weisco -20cc pistons) ***FEELER***
- Procharger 8 rib 4" Pulley
- C6 Vararam VR-SC1
- Few LT1 parts. (heads/headers ect)
- F/S: Auto Meter Fuel PSI & Digital Shift Pro Gauges
- EFILive V2 Tune and Scan Tool
- C5 Cold Air Intake F/S
- F/S---> LS2 Injectors
- FS Used Performance Parts
- Cam 239/244 .612 .612 114lsa
- ls6 intake forsale
- 96 WS6 Ram Air, Eibach, Autometer, Ect.
- 93-02 energy suspension poly trans mount
- NIB: UMI Tubular Weld-in SFC (Gloss Black)!!
- kooks off road fbody headers and underdrive pulley with belts
- Ton's of Parts For Sale NOS KIT!!!!
- dynatech, B&B bullets, wilson, comp, diamond
- Sub/Amp Monsoon H/U's
- FS: Painted Black TA Five Stars
- Parts Parts Parts
- LSx Parts - Extra parts need to go
- HKE turbo cam
- Stock y pipes for sale LT1
- big cam
- c5 wagon wheels
- ls1 GTO KooKS 3 inch Stainless highflow cats
- F.A.S.T fuel rails for LSX
- Garage Sale Including Fast 90
- fbody headers, stall and catback NIB
- T/A & Camaro M6 Upper Console (MINT) / LS6 Coolant Crossover Pipe (NEW)
- (2) 275/40/19 Michelin Sport primacys
- Valve Cover Spacers
- Yank 3600 NEEDS REBUILT, d/s loop
