View Full Version : Suspension & Brakes
- blue lowering springs
- Ssbc Residual Brake Pressure Valve
- Replacing rear shocks..? Air shocks
- Vibration????
- New Springs
- LCA relocation brackets for Moser 9 inch
- Adjusting Panhard Bar
- Suspension
- Cross Drilled and Slotted Rotors Sale $175
- Ok, a little more help please
- Will KYBs work with my (lowering) springs? Current bilstein with slp/eibach?
- Front spring not low enough, please help..
- Clunking From Rear
- Strange Drag Brakes....Prices
- Road Racing Set Up
- How do you remove the caliper from its mounting bracket?
- which upgrade?
- New Products!
- Do BMR LCAs and PHR flex?
- Has Anyone Converted to a Short Front Spindle?
- Can air in brake lines cause this???
- Are Shorter Brake Boosters Out There?
- DMS springs? If not that then Goldline?
- Quick Sway Bar Question
- How to remove lower spring perch from a deCarbon shock??
- loud squeak from front driver's side suspension... help!!
- taking off backing plates
- looking to upgrade the LT1 brakes... need advice
- BSI brakes/Edge rotors, slotted only or drilled too?
- Best Shocks?/springs?
- Dumb Sway Bar Question - HELP
- Centering M9 help
- Rear Issues
- making it hook
- Popping noise When I hit Brakes hard/Turn wheels fully
- SandBlasting my Suspension?
- Koni 4/4's
- 2 Questions (Parking Brake Light and Squeel)
- adustable coil overs
- DS Loop / DS clearance issue (pics)
- high mph braking=tail out
- Lakewood Bolt-in 3-pt. SFCs...Opinions? vs. UMI?
- abs wheel sensor harness wires
- right motive bleeder adapter for brakes?
- Front End Squeeks!Like A Cheap Mattress
- LCA question
- Hotchkis Sway Bars...
- Driving the TRZ with a spooled S60...
- Lookn at whole suspension kits
- FYI: 9/10-9/21 Strano Performance will be closed
- Yay or Nay on these shocks
- Autozone Pads lol
- BSI Brakes for my zo6?
- So I decided to do the tie rod ends tonight.
- anyone running KYB AGX shocks?
- Installed Pro Kit today...HELP
- LT1 tublular k-member into LS1?
- New to this, need suspension up-grade advice
- Konis on... sorta
- Need help replacing lower ball joints
- What is a good blank C5 rotor and what color for my C5 Calipers?
- what to buy??
- squeaking from under car - Tq arm?
- 3-point SFC's or standard SFC's
- BSI is AWESOME
- Best control arms to get??
- Koni warranty...
- QA1 front springs
- Electric Emergency Brake??
- C5 brakes and TT2s...
- steering wheel play
- shocks and springs
- strut tower nuts
- UMI Torque Arm Install Qs
- Some pictures of my caliper powdercoating work
- New setup=can't hook
- Anyone have data on brake swap performance?
- Put on some KYB AGX's this weekend
- koni install issues
- Steering is loose on 96 LT1
- rear doesn't look lowered
- please help, drivability problem
- Rotors warped?
- ABS relocate
- Wilwood Dynalite front kit
- Torque Arm Question
- Car pulling to the left
- Coilover Question
- bigger brake question
- Hawk HPS
- No Tracking At The Track Please Help!!!!!!!!
- OEM Upper panhard closely axle w/PIX
- panhard rod relocation kits...
- can somebody help me find rear sway bar bushings??
- Need help with Ground Control install
- Thunder racing Line Lock...
- Front brakes on rear
- G2 springs + Koni SA 4/3 = rear bottoms out
- Any sponsor want to sell me a 1"-1.25" front drop springs?
- Spohn Torque Arm ?
- Rear Suspension stiffness?
- c5 caliper only swap?
- Centric rotors = awesome!
- replacing high pressure hose on ps pump
- Those of you with front AFCO shocks inside please!
- stupid question...rattle clips.
- 2000 fbody brakes help
- QA1 and Strano question
- Another satisfied UMI customer
- adjusting panhard???
- New springs, 18's, questions
- Brake Kit Questions
- 67 camaro Ls1 brake problems
- Part numbers for Engery Susp End Link kits?
- SPOHN front a arms are bending!!!!
- Whats the cost of a rollbar?
- What Settings for Street KYB AGX Shocks
- Stopping on a Dime
- vibrating noise coming from suspension
- LCA making noise.....
- Why was MikeRotorsOnline banned?
- Brembo or Baer 6S/6R
- rubber mounts on top of front shocks
- Which strut mounts to buy?
- Wheelhop on a lowered LS1.. ?
- Need advice on what shock's and spring's????
- constant squeeking from rear of my car...
- Rear Bumpstops?
- who's f-body is LOW?
- Just got my Koni's installed?
- Need Brake Info
- Stock LCA bushings??
- Opinions needed; how do I proceed?
- hotchkis springs?
- Spring rate show down
- Issue with UMI parts hitting!
- Who has the best deal on QA1s?
- What shocks with eibach pro-kit springs?
- No Brakes Issue
- Need need imput on rotors possiably DecelaRotors
- Are 1998 firebird front brakes the same as LS1 2-piston??
- Upgrade from LS1 stock = Truly worth it?
- Upper Ball Joint replacement
- How do you adjust Koni rears
- Corvette caliper red powder coat color?
- Sportline and Koni's or stock and Koni's
- Will aftermarket sway bars make any difference?
- torque arm installed
- Measuring Pinion Angle
- brake drag when pushing car?
- Help With Suspension Install...
- Installing front lowering springs and want to do the rear hose mod... any info?
- saitisfied grand sport 6 brake pads
- has anyone used satisfied grand sport 6 brakes
- front suspension making noise
- just picked up some springs and gotta question
- Red or Black Caliper Color on my Car?
- Bench Bleed New Calipers?
- 01 TA-Caliper pistons all the same size?
- problem with torque arm
- has anyone used satisfied grandsport 6 brakes
- BMR Springs & stock shocks= bottoming out?
- Pro Kit rear and BMR front?
- Lost my TR Line lock instructions
- What should my next suspension mod be?
- BMR Torque Arm install
- New Brakes installed!
- Adj Torque Arm questions....
- Broken Shock Bolt... help?
- What come with the Koni shocks.
- How to replace shocks and springs - need some help
- Ok this is another blowhard posting his results !
- UMI Torque Arm
- Problem still not solved...
- C5 brakes on a 1st gen. Camaro
- lowering 1st gen. Camaro
- Squeaky Sound from right rear shock
- c5 brake conversion
- SMJ abs delete kit?
- what is the Hose Mod and how do you do it
- Help with front struts(i need an alternative)
- Front End Drift
- Whats the purpose of ABS
- Brake Problem; Looking For What Part to Buy
- need pics, 1.2" drop
- Raybestos???
- Which rear sway bar for drag on 9 inch?
- BMR extreme torque arm and other chassis ?'s
- Anyone done the Hose Mod with SLP Headers?
- Rear Brakes Dragging
- Shocks...
- Shock question
- Hose Mod- 3/4" or 5/8" Hose?
- IRS for 2000 LS1 camaro? is there such a kit?
- If your educated in the way of the torque arm come in!
- Vibration shelled my rear end
- choosing a TQ arm
- Tourqe arm umi or spohn
- My new stance!! Slam!!!!!
- Compressing springs -- how to?
- Back End Slams when i hit bumps
- Safest strut spring compressor?
- dropzone springs
- Stock Springs
- spongy brake pedal!!! help please
- My Wheel Hop has Got to Go!
- BMR spring users in here!
- Just Received my Koni's- Have a few questions.
- moser makes good!
- Front Sway Bar End link size?
- whats the difference?
- suspension help please...
- yup got another suspension issue
- getting new suspension
- Getting ready for the track
- Do I really need an adjustable torque arm?
- I FINALLY lowered my car on Stranos....
- Got my 3 pt SFCs, tunnel mount torque arm installed
- Will these work?
- Drilled/Slotted rotors
- will corvette front brake calipers fit on a 2000 trans am?
- Master cylinder rebuild kit
- Cold or hot formed sway bars?
- Front drag shocks
- Removing Rear Isolator Question
- Squealing brakes...
- need a better ride?
- Brakes make weird sound..
- What needs to be modified to use C5 caliper abutment with the LG bracket?
- Caliper / bracket colors....just an idea
- Suspension help
- eibach lowering springs which shock???
- Question?
- Brake Pads Dragging
- What are these called???
- What setting on the yellow koni's? What position for front strut spring purch?
- Need some help
- Lca popping/clunking
- Where to start with handling mods
- The next best shocks to konis?
- Stock Suspension
- lowering with no PHB. questions???
- brake issues...
- "ASR", "ABS INOP", "BRAKE" lights all on!!!
- Stranos and konis overkill for a DD?
- K member
- 12-bolt rearend improves handling
- Torque arm question
- Caliper Bracket Sliders cause rubbing? Help! BRAKE PROBLEM!
