View Full Version : Parts Classifieds
- c5 Powerbond 25% pulley
- Patriot "Xtreme" .660 lift Gold spring kit
- Dual Mode Corvette Exhaust
- Doors off of a red 1998 camaro
- DBW throttle body and pedal assembly
- Edlelbrock 90mm throttle body
- Black 2000 Trans Am steering column.
- comp cams "921" package from TSP (springs and retainers) TSP chromolly 7.4 pushrods
- FS. NW102 NEW STYLE!! in York, PA. $525+ship
- ls1 clamshell motor mounts
- TSP 7.400 hardened pushrods
- Buy this brand new nitro dave's bottle heater today cheap!
- 4L60 and 3200 Conv
- 96lb Injectors (aka 1000cc's) AEM Peak and hold Box 10 channel
- LS1 Parts: Heads/Lifters/Posi/Rims/Exhaust, ect
- sTOCK LT1 CONVERTER
- Centerforce Dual Friction Clutch
- 98-02 Camaro low beams HID's
- 5.3l truck manifold, ls6 injectors..
- ls2 timing set/melling high volume oil pump brand new in box
- PRC .650" lift valvesprings and titanium retainers
- Moser 9"
- C6 corvette factory delco radio/cd player GM part # 15904665
- Parting out 30k mile 2000 z28
- Tons of ls1 parts stock and aftermarket
- Sold
- svo 42lb injector green 30 miles
- GTO 1.25in drop rear LOVELLS springs with drag bags
- exhuast tips
- 241 heads
- Magnaflow exhaust, MAF, stock 01 camshaft, injectors
- 98-02 LS1 Parts 317 Heads etc
- ls6 yellows
- comp cams dual springs
- Nitrous Outlet Wet Nitrous
- MAF / front DRL turn signals / ABS module
- ls6 intake manifold W/ fuel rails
- marcella ls7 intake
- LS2 pistons
- Weld draglights and ZR1
- FS: 93-02 Camaro Clear Corners
- cc pacesetter lt's, 02 extensions. NIB
- N/W or PTM 90mm throttle body
- FS - truck intake tube/bellows
- 799 heads
- SOLD - Expired G-Force Cam Lock 5pnt Harness
- FS - Exhaust manifolds and converters 2001-up
- SOLD - LS1 Center Bolt Valve Covers - Used
- 10# NOS Bottle w/Press Gauge - Used
- '01 Factory Rokers - Used
- Chrome powder coated coil brackets
- M/T slicks
- Moving sale. Buy my stuff!
- wtt my y pipe for yours f body long tubes
- WTT LS1 T56 w/48,xxx for 4l60e
- LS3 Camaro 2011,C6 and Lq9 exhaust manifold
- Stock 02 LS1 28# injectors
- FS: Tremec t56 1k Miles on new trans m12 $1300 including clutch and flywheel
- 42# SVO Green Top Injectors
- 4l60e 3500 midwest converter
- C5 Z06 18X12 Chrome rear wheels
- NOS Nitrous: Cheater Kit, Purge Kit, Remote Bottle Opener….
- Oem 99 ws6 hood
- FS: O.E.M. GM LS6 Clutch Kit w/Flywheel, *Brand New*
- 4 Stock 16inch chrome wheels with tires
- WTT: Procharger Big Red Race Valve
- ls1 parts
- F1C procharger for F Body
- parts for sale
- F/S: Brand New Forged CP Carillo Pistons and Compstar Rods
- Procharger bracket, custom inlet hat, fan kit, HI-6 ign, coils, wires FS
- 18 X 12 Z06 Chrome wheels 2 rears
- 93-97 LT1 GM Master and Slave Cylinder *NEW*
- LS1 block, trex cam, Aluminum drivshaft, 10 bolt rear
- NEW ls7 GM crate motor complete still in crate
- L92/LY6 brand new truck intake
- Ls6 intake manifold
- Lq9 stuff for sale
- Cragar Chrome Rims for F-Body, New Center Caps
- Cartek, SPEC, Comp R's, Nitrous stuff and more....
- Carbon Fiber Hydrocoated LS6 Intake and Throttle Body
- OEM SS hood FS
- FS: UMI STB, Camshaft position sensor, coil brackets
- Tons of Corvette, LS and Racing parts - Huge sale...
- 3.73 gears for moser 12 bolt cheap!
- Clutch Hydraulic Lines, Short Shifter, Master Cylinder
- PST Alum. Driveshaft TH350 700HP rated NEW PRICE!!
- M&H Racemaster Drag radials 325/50/15
- jegs adjustable torque arm
- 99 Chrome Trans Am Rims 16s
- JBL BPX2200.1 Car Subwoofer Amp
- ROLLMASTER Adjustable Timing Chain Set, Single Row w/ Torrington Bearing
- **RARE** C5 Magnesium light weight wheels!
- LSx, LTx sale at Charlotte Auto Fair April 8-10
- Bare Ported Patriot Performance 243 LS6 heads
- 228/232 custom grind cam
- LS6 Intake/Ported TB
- 2000 camaro parts
- 2002+ Z06 cam
- Firebird Window Cowl Trim
- T56 Transmission Crossmember
- Stock and Modified Spindles FS
- WTS/WTT Vintage Fuel Rail Covers
- crane ls1 valvespring tool
- F.S. aluminum driveshaft
- fs: 4 channel axles
- Comp Cams FI Cam
- Crane Dual Valve springs, SVO 42#, Fuel Rails
- ABS junction block/bracket
- BMR bolt in lower control arm brackets
- 99 z28 pewter partout feeler
- FOR SALE: GMMG exhaust tips
- Harris Speedworks wet nitrous kit
- Ross Racing Forged Pistons NIB
- Black powder coated valve covers
- HP Tuners licensed for 98,99,02 cars FS
- Red Camaro tail panel with oem badges-Indiana
- LS6 Intake, Fuel Rail & TB
- Monsoon CD Player from 99 TA
- Brand new set total seal rings "moly" $50
- MSD Super Conductor red sparkplug wires $45
- New OEM GM HD Timing set for LS motors
- ls6 intake from 01z28
- FTI 4K converter for 4l60e
- Brand New Fuel Pumps and Hotwire kit
- Forged 347ci LS6 longblock built for boost. Only 2k miles
- spohn tubular motor mounts
- F/S new in box comp cams custom cam for NA application
- B&M RIPPER shifter 93-02 T56 6-speed camaro firebird trans am formula
- 8 lucas 42lb high impedance fuel injectors camaro firebird corvette
- LS2 vette oil pan and pickup tube ***SOLD***
- 317 Bare heads, New.
- Deltec opti cap
- BMR adjustable torque arm
- LT1 Fluidamper
- Procharger P1SC Kit
- GI: Ls6 Lightweight Valve set
- custom cam
- Complete 4L60e swap for t56 conversion
- ls1 parts, slp lid, headers, ls1 brakes kmember
- Stock LS1 MAF
- AFR 225 LSx Heads, NEW
- FS: Danny Miller 9" 4th gen housing & axles
- Pace Setter Long Tubes, Catch Can, A/C parts, ABS Block, 4l60e to 4l80e adapter
- EPS camshafts (2)
- FS: 2010 camaro ss intake manifold and injectors
- Grotty headers aka qtp ls1 fbody came off jantzers 10 sec ss
- Uncut LQ4 4L80E harness
- Billet Specialties Polished aluminum bowtie BBC valve covers
- FS: Fbody Parachute Launcher tubular Frame/mount
- FS Rebuilt LQ4
- LS3 crate motor NEW ****SOLD****
- Headlight motors, brackets and lights.
- Gearbox.org master rebuild kit.
- Patrick G/EPS 251/258 .654/.647 111+3 LSA almost new!!!
- Chrome ZR1s 17x9/17x11
- ~*~almost new big comp cam~*~
- Fast 90/fre 90
- GI: C5 Z06 seats
- Built, 0-Mile LS1
- L-92 pistons and rings
- 4th gen f-body Weld Draglites
- GTO Pedder Struts & Lovell Springs
- FS : L92 intake manifold/fuel rail/Injectors
- Pat G custom Cam, LQ9 Block, LS1 Block, Head Studs
- NX bottle heater kit
- F/S LG LS7 Z06 1 3/4 super pro headers
- F/S LS7 1.8 rocker arms
- 240/250 comp cam $100
- fs: ws6 wheels/tires
- Stock Lower Control Arms & Panhard Bar
- 2001 Manifolds, Y Pipe, AIR System
- Brand New LSXr 102mm Intake, LS3/L76/L92/L99
- Stock Torque Converter and 2.73 Gear
- Feeler-Trade D1sc head unit,sdce tensioner setup,ATI dampner plus cash for longblock!
- USED LS1 SLP LONG TUBE HEADERS w EGR
- edelbrock intake manifold
- LS1 Rear Cover Gasket NEW FELPRO
- NX nitrous FPSS with -4an manifold
- Used Nitrous Works Ls1 Wet Kit
- Fs- QA1s, 241w/Crane dual valve springs, Fuel Rails, QTP headers
- Garret gt4202
- BeCool Radiator - #60028
- Corvette OEM C6 Wheels Nittos Radio Bezel Bose CD player
- Tsunami cam
- FS: ARP head bolts for 03 and under blocks
- AFR 225 LSX #1630 Brand New in Box
- lt1 stainless headers, heads, tranny, shortblock, and more
- 2002 z06 fuel rails
- 2002 z06 lifters 15k miles
- Texas Speed hardened chromemoly 7.400 push rods
- Brand new Wiseco 402 stroker pistons part number K464FS
- Transmission mounted Lokar Th350/700R4/4L60E Shifter
- turbo, wastegate...wtt
- LT1 Y-pipe
- nitous parts and true duals
- Pushrods - New OEM LS1/LS2?LS6
- LS1 pcm
- Garage cleanout ls1 stuff
- F/S Stock Black Fuel Rail Covers
- F1C Procharger for F body
- SLP LM1,trade for tsp duals or magnaflow
- Comp Valve Springs
- 799 and complete vic jr intake for sale
- HSW 90mm plate/prof. products rail kit
- Mcleod Bellhousing
- MTI cam and TSP pushrods
- Driveshaft Safety Loop
- 317 heads sale/trade
- Garage Clearing Sale!!! LS1 Engine Parts/Stalls/Wheels
- FS. Scorpion 1.6/1.65 Rockers...(Sold)
- 17x9/17x11 ZR1's, Solid MM, Spings etc...
- A4 and M6 F-body PCM
- TH350 Built rmvb, coan clutchs,brake SOLD SOLD
- WTB FAST 102 LSXr intake for Cathedral port
- Stock LS6 ETC throttle body f/s
- 3' magnaflow High-flow cat, TA door switches, handle covers
- Polished aluminum driveshaft
- Firebird Front filler plate (Black)
- MSD Timing Twister, Ported TB.
- Hurst Short Shifter
- 97-04 chevy ls1 cylinder heads corvette camaro firebird
- New ls1 ls6 c5 corvette oil pan 97 - 04
- vette fuel rail covers
- Stock Radiator & Electric Fans, Elec. Fans, NX Fuel Solenoid, Stock MAF
- Berger panel,Black Chrome C6's,BNIB Gibson Truck Exh, Need a Turbosmart E-Boost2
- 2002 speedlines 17" rims and tires for sale
- 98-99 a4 upper console
- Spohn Standard duty crossmember mounted torque arm F/S
- FS: Stock monsoon head units (3)
- LT1 custom Bullet Racing Cam spec'd by Lloyd Elliott
- Corsa Clones
- Stock 08 chevy 20" wheels AND Staggered fitment BFG KDW's
- c5 rims and tires 4sale
- CNC PORTED LS1 HEADS $475 price drop $400 Drop again $300
- FS LQ-4 Rods & Pistons
- Thunder Racing T-Rak cam
- Dallas, tx camaro export tail lights
- FS: LS1 F-body rear alternator bracket
- 42lbs Delphi injectors 220 shipped, Sport Comp II NOS Gauge
- hooker muffler, 3in slashed tip, WS6 springs, adj PHR
- Bogart D10's with tires
- LS2 exhaust Manifolds
- New Nitrous Outlet Progressive Controller, BR7EF plugs
- continuing my part-out (new stuff added periodically)
- FOR SALE: REDUCED NIB BMR T/A Relocation Kit TCC007 $200 SHIPPED
- KOOKS 3x3" Catted X for C5 Long Tubes
- Sold
- FS:4l65E
- Price Drop: Spohn Solid Motor Mounts (SOLD),TTops
