View Full Version : Gears & Axles
- Shift Extensions? Info Please.
- one more dumb one......
- Whining noise bearings???
- Reverse Lockout Selenoid question
- What inside Detroit locker causes
- Quietest /best 4.30 12 bolt gears? What do u have?
- Need help rear end making clunking sounds.
- steel vs alum. driveshafts
- best place to buy gears from???
- Need Help with GM P/N 12572731
- Who has the best deal on moser 12 bolt??
- Tranny is out of the car, what to replace?
- Is it worth it for me to get a 12 bolt???
- weight of BMR anti roll bar.
- Billingsley 9-inch
- TA Cover w/Stud Kit
- TC hurting top end ?
- Got a Mcloed Revlok II step inside please!!
- 4.30's for 10 bo0lt
- Moser, brake fitment ???
- rearend suggestions?
- Rear End Problem
- Where to get a Strange 12-bolt?
- Upgraded Hydraulics
- Adjustable master cylinder
- just got my new moser 12 bolt! help!
- Pics of axle leak, how do I fix???/
- Please Help! Broken spring?
- T-10 Tranny Swap??
- Changing syncro's
- another gear ???
- Let's play: "Name that drivetrain noise!"
- Does anyone make a 9" that supports 3-channel ABS?
- Stuck in 4th... tranny gurus please help.
- Reverse a pain in the ass
- Short Throw Shifter breaking transmission???
- 3.73's to 4.56's...et gains?
- will slicks loose time on the street vs track?
- gear whining
- Rearend experts: squirm under accel/decel
- What is needed for a Strange 12 bolt install?
- OK how to assure theres no air in the slave??
- Should I or shouldn't I? (poly tranny mount)
- Thump...drivetrain noise?
- Anyone have tips to get a Moser Pinion seal not to
- Need place to rebuild transmission
- which is better for street/strip, A4 or M6??
- Intalling TC and Headers next week.....
- Trans help
- how much e.t. reduction will 4.10's do?
- 6 speed conversion
- Transmission problems please help!
- agressive alginment questions
- Will this work?
- are strange 4.11's quiet??
- what size gear does our rearend's take?
- Driveshaft length
- Has anyone ever weighed a moser 9inch VS.....
- Girdle/02 T/A???
- Post your pics please...
- Has anyone ever...?????
- can a 12 bolt be made quiet?
- differences between rear ends in............?
- Need to hear from folks with the Spec Stage II
- 1LE driveshaft vs. LS1 aluminum shaft
- Moser is REALLY pissing me off!
- before/after dyno with 12bolt + 3.90
- Transmission Movement?
- Anyone else having TCS problems?
- busted pass. side carrier bearing...wtf?
- Swaybar mounts with a 12 bolt?
- what has changed in a 9" since introduction?
- Which way to put in Large Diff Pin/Block?!?!
- WHAT IS WRONG!? TRANNY MOUNT OR U-JOINT!?
- WHAT'S A DRILL MOD?
- How to Remove Wheel Bearing?!?!
- Removing C-Clip from Axle
- Drill Mod - HELP!!!
- Torsen shot, recommendations on replacement diffs?
- How to tell if tranny is slipping
- Paging CAL about 9" !!!
- I just ordered my Ram VDS 900 series, any thoughts
- So when do I need drag radials?
- Genuine GM gears
- How to make stock master adjustable
- Mcleod street twin install questions
- Transmission woes
- I need Moser 9508B axle bearings,ASAP!
- Suggestions on rebuilding my 4L65E?
- need some suspension help
- bleeding slave cylinder.
- Spec Stage 3 in. Should I replace stock master???
- Posi problem?????
- zf gearbox out of a 95 vette.....???????????
- worth a little chuckle
- Need to know the length of rear end cover bolt so
- Thread and pitch of Moser 12 bolt rear end cover
- Build stock rear end almost as strong as 12 bolt?
- Fastest and cheapest place to get hydraulics from?
- WTF??? somebody help me out please???
- Transmission Pan
- 9" on a dropped F-Body??
- did dealer use correct fluid in rear?
- Trying to understand a gear conversion. . .
- Is there an after market flex plate ?
- My car doesn't like to go into reverse.
- Driveshaft hitting exhaust pipe?
- Play in rear wheel hubs??? (problem)
- Noise help!
- noise from 4.10 motive gears in a 10 bolt, help??
- Moser rear pressurizes??? How to cure/whats wrong?
- Pulling transmission, have some questions
- G2 10 -Bolt Girdle
- breaking in new gears
- how to dyno? tcc locked or not
- Which 12 bolt to get?
- Moser Engineering/ Plane Crash
- Drill mod without Master cylinder removal?
- TA Girdle fill hole
- Anybody use that Granetellie trans shift improver?
- Transmission Experts Please Help!
- ABS INOP after rear swap
- Does anyone have the Hurst Billet Plus shifter?
- Anyone here have or used a 8.8 rear end?
- m-6 transmission problems
- Where to Buy 12mm Screw-in Studs
- TA rearend cover?
- Centerforce issues
- Where to get a differential cover stud kit?
- Adjustable master: What makes it adjustable?
- Really need advice on my new PRO 5.0
- Will a 99 10 bolt z28 rearend work in my 2002 ss?
- really need some help guys
- * Wheel Bearing? *
- screeching noise from rear???
- Which master Cylinder, Ram, McCleod, Stock
- Transmission wants to start off in 2nd gear......
- I think I broke the rear tonight and need help...
- ls1 lt1 tranny the same?
- Do I need a tranny cooler with a TCI 3000?
- 12 bolt oil.....what is everyone using?
- Centerforce slippage?
- Strange Rear - New - complete - FS
- weird noises
- MOSER 12BOLT
- Need help determining if I have a tranny problem
- Theoretically speaking, does one need a 12 bolt if
- NEED HELP!!!
- Adjustable Master Cylinder and Slave Questions
- which master cylinder
- Need tranny help ASAP!
- Predator AND Nos ??????????
- Diff cover..does it really help a stock 10 bolt???
- 3200 stall w/ 2.2 STR w/3.73 gears, opinions pleas
- Pinion angle questions
- Is this m/c broken? Help!
- Good parts from a Viper tranny?
- HELP! Terrible whining noise when turning.
- Th-400 Converson
- New rebuilt trans w/ SS3600 How to make it last?
- HOW DO YOU KNOW IF YOU HAVE A TORSEN DIFF?
- Is it time for a driveshaft upgrade??
- Firestone Firehawk's
- Help! Tranny died after one 2 days!
- need help with 01' WS6
- Poll: TCI or TCS and What stall?
- gear swap
- hard shift to 4th and tranny died
- New steel Bellhousing in CHP
- Ok, I'm looking at a TCI 3200 TC, now what str?
- Help with 12 bolt question
- Moser studs caused problems with my ABS
- Part # help
- 95 6 cyl 2 piece drive shaft
- Fourth gear gets stuck!
- Transmission and rearend rebuild
- Line Lock help
- i need a pic
- Anyone Running 4.30 gears
- Rev Limiter is jacked? bad VSS after gear swap?
- Drilling Hole in Hydraulic Line to Powershift??
- M/T ET Streets on a stock rearend?
- help/can't launch
- ES transmisson mount torque arm bushing
- Least aggressive stock axle ratio from GM?
- 9 Inch Gears
- No Overdrive????
- RWHP
- TCI 2800???
- Can anyone make a shifter gate like this.......
- Other rear ends for our cars
- Idiots guide to shiftkits, please read inside...
- Strange 12 bolt GP
- anyone modded their stock slave master cylinder?
- B&M megashifter question
- Is it winding a little high?
- Auto messing up->if you know something, tell me
- 370-400 rwhp vs. Stock 10 bolt
- stock master made adjustable pics
- Rear Swap
- Gears in a 10 bolt
- Stock Gear Oil for Automatics
- Shifter Question
- SCS Cheetah Shifter
- 15" Slicks what size & B/S?
- I have a Quater Stick, and can't figure out how...
- Redline tranny fluid goog for M-6 Trannys?
- reverse lights and nuetral safety switch??
- Lakewood DS Loop fit with MACs and 3.5" Driveshaft
- 3:42 to 3:73
- Whats the biggest tire I can fit on a 99WS6?
- 60' with a Spool
- ATTENTION! All registered members inside please.
- Put in traclink, need to know pinion angle
- TA Diff Covers
- How do I remove axles on Moser 12-bolt?
- PLEASE READ: Length of driveshaft, 400T w/ Moser?
- NEED ADVICE QUICK!!! Must replace rear end
- 3rd Gear gone, need help/suggestions
- 3.73's are in - first impressions...
- TCI 3500 2.5 STR come inside
- M-6 Trouble........3rd Gear Gone Bad?
- NEWBIE Questions
- posi trac fluid
- Getting my spec st3 ceramic in today!
- U joint 4 1350 yoke
- 6 spd gear ratios?
- what gain can I expect?
- DSL question......
- possible to OVER gear a car????
- Vibration at 75+mph
- Which TC
- HELP I NEED A PADDLE PIN
- gears? gears? gears?
- Proper Break in For a Rebuilt Tranny?
- What speed should I be running at top of 4th with>
- where to find steel shift forks?
- EXPLAIN T/C LOCKUP
- Tire Hop Problem.. Whati s the best solution?
- Help!!
- Best Gear for Highway Rolls with TP4500????
- 4.10`s in my stock rear end
- TC swap ???
- Shift points with TCI 4400??
- Trans problems, no 2nd gear
- Need help - Burnout problem with 10-bolt!
- Ride height change after Strange 12-bolt?
- Getting new rear gear which brand?
- What is the limit of a stock driveshaft?
- What size hose to replace coil spring spacer?
