View Full Version : Suspension & Brakes
  1. Brake fluid o-rings for calipers?
  2. Cage Pics
  3. what size rear sway bar can i run 25mm or 22mm
  4. adj.PHB & adj.LCA HOW TO INSTALL
  5. What should I be concerned with, suspension-wise?
  6. UMI Pan reloc kit and adj. panhard are hitting
  7. Shocks
  8. Wtf??
  9. Wheelbase will not stay set, rear shifting
  10. Abs Inop
  11. anyway to bleed abs without scan tool?
  12. going to install front kyb shocks what kind of springs would be good
  13. Proportioning box bleeding?
  14. brake balance question
  15. Stranos Installed!
  16. URGENT HELP PLEASE - Koni SA install
  17. Wheel Hop
  18. Thinking about Koni shocks
  19. new rotors, help plz?
  20. new rotors, help plz
  21. slp stb instructions
  22. Next suspension upgrades
  23. Koni 4/3 and 4/4
  24. Lowering springs worth it with stock shocks?
  25. Revalve Guys
  26. QA1 Coilovers?
  27. Need lowring springs please help
  28. Koni's
  29. shocks and springs
  30. lca + relocation ???
  31. why is my gf's 98 honda ride smoother than mine??
  32. G2's w/Bilsteins?
  33. Torque Arm Weight ???
  34. Best Torque Arm/Adjustable worth the extra $$$
  35. Must Have Suspension Mods
  36. Brake warning light
  37. Lsx Suspension mods plz!
  38. Need BMR stuff
  39. 1LE konis?
  40. Power Steering Rack Rebuild Video
  41. Brake line swap, couple questions
  42. New Trans Mount Now Vibration
  43. Best suspension company for a street/strip car??
  44. Ground control coil-over kit?
  45. HAWK HPS Vs. Ceramic
  46. how to adjust lower control arms and panhead bar -
  47. Are these nuts suppose to be torqued?
  48. Need new rotors/pads
  49. sway bar bushings
  50. torque arm angle?
  51. What UPS man droped off today!!
  52. Cutting springs question???
  53. Too low now what?
  54. spanner wrench + strange shocks
  55. FYI: Limited shop hours beginning 4.30.08
  56. Are There Any Good Rear C6 Z51 Rotors?
  57. to sam strano!
  58. Rear Sway bar
  59. Torque Arm, Trany or Tunnel Mounted
  60. Pro-Kit install problem?
  61. Brake pressure/Hot wheels??????
  62. How to adjust panhard rod?
  63. Loud banging noise on bumps
  64. LT1 Pro-Kit on LS1 F-body???
  65. Rear Lower Control Arms
  66. torque arm poly mount and poly trans mount install
  67. Which torque arm is upgradeable?
  68. Looky Looky what the LS1 god dropped off today...
  69. made my final suspension decision.
  70. anyone have before and after BFH mod pix??
  71. which after market springs?
  72. Would like some suggestions on suspension.
  73. Electric Power steering
  74. Are Bilsteins back in stock anywhere?
  75. Kyb-agx ???
  76. My Eibach Pro-kit/ KYB AGX Review
  77. Torque arm install
  78. Looking into lowering my car
  79. What rear springs? Wheel hop problem!
  80. Small problem please read brake guru's
  81. Need Wheel Bearing Assembly!!!
  82. Strano swaybars review
  83. Umi Performance
  84. Lets Talk Manual Brakes
  85. More pistons on my caliper means bigger rotors?
  86. bilstein struts with h and r springs
  87. UMI Single Adj Panhard Bar Question
  88. comp eng. drag shocks - need help on settings.
  89. High Rpm launches
  90. what does everyone think?
  91. 4x4- HELP ME!
  92. Forgot to install a front spring perch...
  93. problem changing rotors
  94. What does a tunnel brace do?
  95. adjusting PHB for new rims
  96. Suspension Problem Please Help.
  97. E-Brake Problems Need HELP!!!!!!!!!!!!1
  98. E-Brake
  99. vibration at 75+
  100. Brake Opinion
  101. Passenger Side Front tire wobbles on bumps
  102. Lowered front end's
  103. stb keep it or remove it
  104. Help getting brakes for my particular setup
  105. 1/2" To 3/4" Drop Springs?
  106. how low is too low for exhaust??
  107. What is this? Took pictures, please help!
  108. BMR Fabrication to be at Speed Inc. Open House
  109. Complete suspension setup for the bird, pics
  110. Need steering rack part number!!!!
  111. Rear suspension install problems..PLEASE HELP
  112. where can i buy powdercoated calipers , i want all 4
  113. Tokico Shocks - Review
  114. stiffer springs
  115. Ls1 rotors
  116. C5 brake and wheel question
  117. whats gears for my a4(2.73)?
  118. stock suspension question?
  119. Relocation Bracket Settings
  120. Drove for 50 miles or so with broken panhard bar...did i do any damage?
  121. FREE Sway Bar Kit from BMR FABRICATION
  122. stock a arm install ?
  123. Want to paint my calipers??
  124. Clunking noise after UMI TM adj TA install
  125. Please help decide-BMR or Eibach!!!
  126. Guys with QA-1's
  127. question on k-member
  128. Can anyplace align my car???
  129. 22 or 25mm sway bay
  130. Strano Before and After
  131. lowering question
  132. Whats missing from these pictures????
  133. Non-Stop Brake "Chirping" Saga Update
  134. LCA Polyurethane bushings
  135. Are These Koni SA's?
  136. will these fit under the wheel wells 305/45-18
  137. Installed control arm relocation brackets and now wheel hop
  138. Pinion Angle
  139. umi torque arm bar question...please expert advice!!!
  140. Pulling brakes
  141. strut tower bar
  142. Pinion angle for lowered vehicle
  143. Budget shock for DMS's?
  144. Just installed UMI Adj Panhard Bar
  145. Need rear sway bar brackets to use with 9" rear end
  146. Slp Bilsteins or KYB AGX
  147. new rotors?
  148. what is stock ride height on LT1?
  149. Strange drag racing brakes? Who uses them..
  150. Stuck slider pins
  151. Tires Wont Fit!! Need Some Suspension Advice PLEASE!!
  152. Need new rotors ASAP
  153. grinding whining
  154. Lower control arm and subframe connector install help
  155. Hotchkis/Koni 4/4s *Pics Inside*
  156. Squealing brakes
  157. sumthing knocking underneath
  158. '01 Z28- KYB AGX Adjustable Shocks with LT1 Eibach Springs...
  159. $500 Budget Suspension Upgrade
  160. i need your help please?
  161. Ground Control Coil Over Conversion??
  162. Spring change ideas...
  163. Rear End Wobbles on freeway
  164. A slightly different Pinion Angle question..
  165. Front and Rear brake upgrades for my CCWs
  166. eibach springs
  167. slp bilsteins/eibach drop?
  168. Panhard Bar. rod ends vs. poly ends
  169. ABS Delet
  170. ABS issue
  171. New brakes are on *pics inside*
  172. Who did what?
  173. replaced a brake line...need to bleed my brakes..
  174. Vibration
  175. BMR Xtreme LCA's, anybody use them?
  176. Koni's installed today
  177. car sits uneven
  178. wheel spin friction
  179. UMI suspension and others is the synthetic grease worth it?
  180. BMR adjustable TQ arm in.
  181. Edelbrock rear springs on Back order.
  182. Help: Thinking of getting an LGm torque arm...
  183. How to get a good hookup on the street?
  184. lowering question
  185. braided steel for entire brake system????
  186. spring ????
  187. Okay help me out please
  188. Adjustable Coil-Over??
  189. Brake Chatter
  190. Granatelli Springs
  191. Pinion Angle on a Lowered Car???
  192. non-adjustable torque arm question
  193. Sam Straino- Help me, please
  194. Koni adjuster won't move
  195. LS1 rear E-brake dust boots
  196. Ordered a lot of stuff but i think i need more?
  197. I changed the rear struts on my buick....
  198. any problems with heater hose mod?
  199. adj. panhard need with only 9.5/275's in back?
  200. subframe install
  201. bmr springs and koni question
  202. baer decelarotor and ebc redstuff...
  203. where to get Konis
  204. UPS Screwed me now i need help
  205. hotchkis or prokit?
  206. Trying to return calls....
  207. Pic's of Baer and TT 2's?
  208. Quick DSL Question.
  209. need stainless brake lines
  210. Any good aftermarket strut mounts??
  211. What length and thread size
  212. Boxed VS Tubular SFCs?
  213. rear c5 brake conversion?
  214. Need help ???
  215. Bad Wheel Hop
  216. adjst lca's
  217. Brake Slide Lube
  218. Guys Running Strano Springs and Pacesetter LT's Inside
  219. Goldline vs Eibach Prokit
  220. strano/koni's combo
  221. panhard relocation kit, if anyone is getting rid of theirs let me know
  222. Hawk HPS vs. HP+
  223. keep 1le suspension?
  224. alignment and rear end centering
  225. PIC! C5 front rotors inside 17" ZR-1s
  226. Koni Question
  227. BIG pics of my new hotchkis lowering springs
  228. help, rotor won't come off
  229. C6 Z06 In 18"s how much can i lower???
  230. help with changing rear pads!
  231. Where do i buy stock rear springs?
  232. Koni availability update
  233. Diy For T/q Arm ---help-----
  234. Anyone been disappointed with Tokico or KYB AGX?
  235. bushing question
  236. Need brake pads..
  237. New Products! Torque arm Relocation Kit & Crossmeber for the TH350
  238. sportline to strano ...
  239. hal front drag springs
  240. help....
  241. Morso Drag Shocks Need Help
  242. DO I STILL NEED A Torque Arm Relocation IF IM GETTING A ADJ.T/Q ARM
  243. Good replacement torque arm???????
  244. SJM linelock wiring diagram
  245. adjusting konis on the car
  246. Had the pleasure of road test with strano
  247. confused about brakes
  248. what springs to go with????
  249. Steering erratic on bumps/potholes
  250. Best way to remove welded subframes?
