View Full Version : Drag Racing Tech
  1. I ran 12.8, but what SHOULD I be running?
  2. ET Sheet / tool
  3. Altenator mount w/motor plates
  4. 17" Drag Radial ?'s please help
  5. aerospace rear brake users
  6. Help me choose tires please...
  7. New shock setup? afco's Help me get close.
  8. How much more gear to get 800 rpms?
  9. Torque curves, Tires & Traction . . . Looking for advice
  10. Something happened with my tranny at the track?
  11. battery holddown question
  12. Which is better for me, 9.5" or 11"?
  13. Hotchkis rear sway bar
  14. 315/60/15 drag radials
  15. fire extinguisher
  16. Battery relocation fuse or circut breaker
  17. What to expect with 2:73 to ?? gear change?
  18. Mickey Thompson tires
  19. 4th Gen BBC Project
  20. Need tire advice.
  21. Weighed the car today!
  22. What fuel to run on a 200 shot
  23. Lightweight Racing seat
  24. 5 pt harness question
  25. Slicks vs. DR's questions
  26. Want Consistent Car
  27. New TRZ ARB Install (w/ pics)
  28. Help me with my drag setup
  29. pictures of weight reduction on cdr's cam only car
  30. LCA relocation bracket postion
  31. limited tire racers (5.20ish 1/8 times)
  32. starter will not engage after wire removal
  33. new kmember motor mounts, motor sits uneven ???
  34. fitting a M/T 28x10.5S
  35. 4.30s in an A4?
  36. wheel studs with drag lites?
  37. Quarter panel is deformed, caused by torque?
  38. bogart owners please help me
  39. track bar removal? (panhard brace)
  40. Drag bar and brackets LOOK INSIDE
  41. corvette traction?
  42. Strange dual caliper brake install?
  43. 13.472@109 mph
  44. lexon?
  45. Question about Drag Radials
  46. Do these really work to kill sound ??
  47. Vette Coilovers Setup for Drags - recommendations....
  48. Burkhart Quick Release Steering Wheel Kit
  49. 13.4? wtf?? @108.72???help!
  50. ABS Delete people come in
  51. does m/t still make a 16" slick
  52. car feels like its trying to plant when i hit bumps?
  53. 25.5 cage
  54. Any body use M and H radials
  55. 11's question
  56. 3750lbs, 450RWHP, 1.52 60ft, 500ft DA trap speed is?
  57. What tires for 15x12's ?
  58. YT Ultralites vs stock rocker weight difference
  59. Arguing with some Mustangers, help out please
  60. looking for a 02 camaro hood to clear a BBC with dom & Plate
  61. QA1 R's and springs install ?
  62. I need some help?!?!
  63. I want to address the "What's it made from?" question
  64. Piston For High Compression - Sponsors, Suggestions, Rotating Asbly.
  65. Will relocating battery to the rear improve ET?
  66. cage ???? convertible
  67. need tire suggestion.
  68. M6 trap speeds making go to 5th gear
  69. Street/strip car driving without panhard brace
  70. a/c box?
  71. Snapped a pic of the tucked 315/60/15 Drag radials
  72. best drive shaft loop with 4 inch exhaust and torque arm
  73. needing help to know the best way to launch a 6spd
  74. Mounting the 5pt harness with the stock belts
  75. Non-stock location TB guys, what cable?
  76. Ozite carpet finally installed!
  77. Optima battery and relocation.
  78. Lingenfelter Launch Control (2-step)
  79. QA1"F" to a QA1"R" ?
  80. adj Torque Arm and True Duals?
  81. Help me with Tire Size
  82. Normal or Abnormal time
  83. Th400 with 4.30s?...
  84. Check out this removable crossbar
  85. Tex Flywheel or Stock With 0z700?
  86. narrowed 9 inch help
  87. how hard is it to put a M/T 28x10.5W
  88. Burkhart site is updated
  89. Hey A4 Guys...
  90. swiss chesse seats
  91. what should i run?
  92. Roll bar protection...
  93. vibration/noise after 9 inch install
  94. Spohn Solid Motor Mount fitment
  95. Fastest Stock Clutch/Stock Rear?
  96. Madman come in.
  97. With QA1s in the rear. can you take out the bumper stops
  98. MOSER 12 BOLT. Do I need to keep the emergency brakes
  99. Deep Dish Bogart D10 15X11's Teaser Pics
  100. pics of my "racecar"
  101. Harness date question.. How long good for?
  102. Anyone make a drag swaybar that fits in stock location?
  103. Dry sump progress pics
  104. bbc in 4th gen.... HEADERS?
  105. Sponsorship lettering?
  106. throttle body downsize
  107. v-type harness allowed across back seat bar?
  108. Wolf 6 point ??
  109. a4 with ms3
  110. ABS Delete people come in
  111. Real world 1/8th mile to 1/4 mile conversion
  112. jegster 8 to 10 conversion cage kits
  113. 1/8th mile mph
  114. abs delete ?
  115. Anyone still sell a airbag delete
  116. Drag Racing Tire FAQ
  117. Swiss cheeseing rear well
  118. Mini tubs installation question??
  119. Drag Question
  120. Duals and Tunnel mount T/A anyone??
  121. whats the fastest you have been on a 17" drag radial?
  122. "What do I need for.." Safety Requirements for NHRA (Rollbar, Rollcage, harness, etc)
  123. Mickey Thompson Tires where can i find them?
  124. taller tire??
  125. how fast. What et is required to have a rollbar/rollcage?
  126. Fuel cell Mounting
  127. Harness expiration?
  128. Lots of new mods coming, what should I expect....?
  129. 25.2 complete *pics inside*
  130. camera mount
  131. Stiff Sidewall slick for a T-brake car???
  132. th400 or nitrous?
  133. sway bar
  134. dry sump or accusump?
  135. SLP LM1's at E-Town NJ
  136. removing rubber moulding sealing back of hood
  137. TA bumper support prototype from Burkhart
  138. PAF 8.50 Sportsman cage done pics.
  139. Double adjustable LCA installation question? Do I need grease, what length to adjust?
  140. Shank style lug nuts question
  141. welding roll cage
  142. safety note on stock wheel studs and drag radials
  143. My car is a dog. Help!!
  144. just a few chassis questions
  145. Front K-member construction/strength
  146. 93 Z28 25.5 Project pictures
  147. strapping down battery/required to race
  148. ladder bars??
  149. Enough tire? - and other questions.
  150. Rear shock question
  151. cutting out rear seat belt mount
  152. Adjustable TQ arm questions.
  153. What RPM should I be shifting at???
  154. Questions about Strange/Aerospace brakes
  155. stock crank pulley or asp pulley for drag car
  156. What to set rear QA1's at
  157. Need help with QA1 front shock settings?
  158. Help with my weight Reduction
  159. looking for pics of flaming river cut off switch
  160. arp balancer bolt keeps coming loose
  161. rear swaybar reccomendations
  162. Damn Weather!!!
  163. Stupid weight reduction ?
  164. Powerglide converter
  165. W2W 25.5 cage pics
  166. launching on DR's
  167. Will these lugs and studs pass tech?
  168. ? about reaction-staging light-tree
  169. Any interest in Power Master batteries?
  170. transmission blanket or shield?
  171. People with ozite carpte come in!
  172. RCI transmission blanket
  173. are rim screws necessary
  174. Corvette Vs Trans am
  175. Anyone know anything about these Adj. LCA's?
  176. stock swaybar and 9 inch?
  177. great deal on helmets for track day...
  178. Tire Sizing
  179. Will this set up work on a 2000 SS camaro
  180. Billet Specialties wheels ready to ship
  181. Which QA1 for the rear?
  182. Which rear tire wears fastest - left or right side?
  183. 28 x 11.50 ET Streets - Pictures!
  184. Track Jack?
  185. American racing Trakstar's
  186. Good deal? VERY CLOSE TO BRAND NEW Weld Racing Prostars with Hoosiers 10 street miles
  187. where to get intake bellows?
  188. In the 11's, but what would LT's and LS6 intake do?
  189. Upgrading Yank SS3600 to a PT4000
  190. Need more cooling.....
  191. anybody have this kit?
  192. my MIDWEST CHASSIS CAGE
  193. Shocks , fronts or rears first ??
  194. Who has the M/T Drag Radials In-Stock????
  195. Burnout??????????????
  196. Crotch strap bracket comparison Wolfe and Madman/Thunder
  197. stock brakes dragging
  198. What tire pressure for a 29.5x10.5x15 ET Drag?
  199. Paging Burkhart...
  200. Qa1 help
  201. Strange 12 bolt narrowed 3 inchs
  202. Who runs 28 x 11.50" ET Streets?
  203. Roll bar help/tips please!
  204. whats the better idea
  205. 4 Wheel Line lock?
  206. Help me out, car won't 60'!!!!!!!!!!!!
  207. Pushing Water ????'s
  208. do i need frame ties if I put a cage in?
  209. Little help
  210. who Has fastest stock susp. Torque arm car
  211. comp engineering shocks
  212. Something new for the Manual Brakes Crowd
  213. What suspension to use??
  214. Best flywheel
  215. What kind of hood??
  216. Fire and safety install
  217. just another list of weight ive removed...
  218. One tenth reduction in 60ft equals.....?
  219. Who's interested in a front bumper support?
  220. LS1 Wheelie pics????????
  221. What Sponsors sell Strange Eng 12 Bolts
  222. after market radiator?
  223. C5 9" rear?
  224. How to basline/optimize adjustable suspension?
  225. Going with 28X10.5X15 ET Drags
  226. any guess's on my ET test urself..
  227. NHRA accepted location of N2O Purge outlet?
  228. Burkhart Chassis Anti Tax Sale
  229. Can I hit a 12.9? even with my bad 60'?
  230. vfn hoods
  231. Dave Connely update
  232. Project Pinkenstein
  233. What kind of driveshafts are you 10 sec or lower guys using?
  234. Another ET guess let see who knows their stuff
  235. Interesting read....
  236. 1300 RWHP Camaro
  237. wheelie video's
  238. K-members??
  239. Drag Chute Help Needed!
  240. Congrats Dave Bowman!!!
  241. 60 foot trouble
  242. First time at the track in 6yrs - a few launch and suspension Qs
  243. Should I plug or patch ET Street?
  244. Finally my tires came in MT 325/50/15
  245. Kirkey Seats - Econo Drag or ProStreet Drag??
  246. Questions on k-frames / madman rack
  247. Draglite and ET Street questions *Help!
  248. Guages in air conditioning dash vents
  249. A few new parts from Burkhart
  250. Ignition box?
