View Full Version : New LS1 Owners - Newbie Tech
  1. Quick Help please!!
  2. what is this used for? lol
  3. Do I need New Fuel Injectors???
  4. new 98 z-28
  5. Good For Header Install?
  6. Not sure where to post this...
  7. ls2 parts on ls1?
  8. what viscosity is right for me?
  9. Timing off ??
  10. CA smog LT's and catted y-pipe combo
  11. Hello Everyone!!!
  12. Stage terminology???
  13. Diff Overhaul?
  14. How much HP???
  15. Very important Ls6 questions
  16. Cutout Info Needed
  17. LT's/catted y
  18. Bright Purple Camaro's???
  19. Wow, my lid's seal was... not doing its job
  20. Spec Clutches?
  21. Exhaust shakes when pop the clutch?
  22. 1998 6.0L truck heads for 01LS1 good or ?
  23. ls6 intake install
  24. Question
  25. Header install SUCKED! Kinda long sorry
  26. just bought a new t/a firehawk
  27. breaking up
  28. is this true?
  29. new to the board basic beginner question
  30. about to buy an 02 z
  31. how much would i put down w/ these mods?
  32. best method to shorten shifter
  33. Most desirable LS1(fbody) to turbo?
  34. Do's and donts taking off A/C
  35. Best way to get 400rwhp NA
  36. Headers For A 00 Ws6 Trans Am
  37. where is the radio fuse located.
  38. Might be gettin this Z tomorrow...
  39. Starter question
  40. traction control
  41. Launching help.
  42. stock Gears
  43. new trans am firehawk owner
  44. Major Tune-Up on my 2002 Z28
  45. Auto Launching
  46. Pulley ??????
  47. Gum in stock driver side car floor mat! help
  48. Who makes it???
  49. Quick question about fuses and such
  50. oil change light wont go off
  51. Difference between Pacesetter and Hooker LT's?
  52. steering knuckle cover?
  53. LT1 injectors on an LS1?
  54. Help! 7 coil packs - 1 missing - Bad?
  55. camaro ss headers
  56. how to install aftermarket racing seats?
  57. I'm dangerous now, but no smarter
  58. LS1 Engine and Transmission Removal?
  59. launching for a newbie
  60. Shorty Accessory belt LS1 - No power Steering
  61. 'chevron techron concentrate plus fuel system cleaner exclusive synthetic formula'
  62. cam swap.
  63. Rear diff fluid?
  64. Is this true
  65. How a Stall works
  66. slp loud-mouth or magnaflow ??
  67. header and Y pipe question
  68. What kinda horsepower and 1/4 times can i expect
  69. Help Asap
  70. LS2=Junk?????
  71. Are F-bodys Problematic or do I just have the start of a lemon..?
  72. clutch and hydraulic system rebuild!
  73. Skip Shift
  74. exhaust question
  75. A4 Vs M6
  76. i can't find the !EGR with pics...
  77. Ls1tech decals were to find?
  78. BBK shorty headers
  79. Service Engine Soon Light
  80. whats the difference from LQ4 and LQ9 ???
  81. WTF??? My horn is making a different sound now
  82. The oil question..
  83. Need some help with shifters
  84. buying parts
  85. Value of LS1, 4L60E and PCM?
  86. LQ4 Pricing
  87. Magnaflow Or Hooker
  88. 99 Z28 Trip odometer reseting/battery not charging
  89. Oil Change?
  90. How strong is the OEM clutch?
  91. alarm problem please help!!
  92. 02 Z28 wont shift into gear
  93. newbie cam question?
  94. random question about power
  95. what exaust should i get ??
  96. stupid question
  97. bought an ss
  98. Cable around Alternator?
  99. Best time with stock suspension
  100. Greetings and question
  101. HP rating on my car?
  102. Help with Signal
  103. 01 ws6
  104. LSD on a z28?
  105. Production numbers
  106. Where can I get a replacement fog light bulb?
  107. 3rd gear again
  108. Is this 2002 ws6 worth it?
  109. Looking at buying a 98 TA
  110. Taking Out Dash
  111. Need advice on my LS1
  112. I caved. LS1 #2.
  113. New valvetrain noise question
  114. really dumb question.
  115. Getting there
  116. Is It True
  117. do ws6 trans ams have fiberglass hoods?
  118. Which Radar Detector do you use?
  119. Proud new 99 Formula LS1 Owner
  120. plugs & wires
  121. Finally got my LS1
  122. whats this
  123. 1998 Silverado
  124. Smoke headlight covers!?!?
  125. Best plugs and wires.
  126. car jerking! HELP!
  127. will Pacesetter ORY work with Hooker LTs
  128. Change oil light
  129. Engine miss or flutter at 2000RPM HELP!!!
  130. I Have a ?
  131. DMH cutout switch question
  132. Gremlins in my electrical system
  133. Shop near me selling flowmasters for $99
  134. need help with cam build
  135. Ls1howto.com ?
  136. seat problems
  137. which lid?
  138. 450hp in a LT1???
  139. 2002 Trans Am Slingshot Edition?
  140. Jumpy RPM's
  141. Lower Back Hump
  142. exhaust purchase question
  143. Seat Trouble !!
  144. Gauge Cluster
  145. HID install problem PLEASE HELP
  146. ORY an o2 sims that suck
  147. ory and o2 sims that suck
  148. good ls1/f-body tech articles
  149. wiring diagram for starter?
  150. Brake lights out
  151. Brake lights out
  152. Angry help me get rid of abs and air bag lights! PleASE!!(*^*
  153. How many O2 sims?
  154. what do you guys consider free mods?
  155. oil pressure question
  156. So im almost ready for an LT1
  157. 5.3L or 4.8L, how can I tell?
  158. LOL my car idles at 3k rpm
  159. Newbie here and to the LSx engines
  160. To patch or not to patch?
  161. someone please explain what compression really is
  162. What should a 98 Z29 run on a 1/8 mile?
  163. What does your fbody idle at?
  164. Low RPM Engine Ping
  165. Intermittent starting problems
  166. ultra noob question on car start up.
  167. Wideband & Stock PCM
  168. Engine Temp
  169. Help- Surges in power
  170. Help!!!!!
  171. Stock Lid?
  172. Rear O2 Sensors
  173. Magic Stick4
  174. Mods for a Firehawk
  175. Header install parts list
  176. Newbie Cam questions
  177. Cut Out
  178. pulling motor out of 02 Z06
  179. What should the first bolt ons be?
  180. Polishing engine area
  181. am i looking for trouble here?
  182. TC questions
  183. Cutout or Headers back exhaust?.
  184. Read this LOL
  185. transperformance.net
  186. Where can I find the red bulb covers from the steering wheel buttons on a TA?
  187. What is the cheapest catback I can buy and from where?
  188. Detonation and Pre-ignition?
  189. Feels like a misfire..kinda sluggish, not a cylinder prob
  190. look
  191. "Need help" Wanting to buy and mod LS-1
  192. Trans Am rear logo....
  193. 98 Trans am or 00 Trans am
  194. Best Head-Cam package?
  195. best way to use seafoam
  196. tire pressure for my bfg drags when running
  197. Easiest way to get to 450hp... with 1998 Z28????
  198. Avg. insurance on a ls1 f-body
  199. anybody know where i can buy the TRANS AM sticker that goes in the rear of the car?
  200. What mods for 25k
  201. Are Clear Corners Illegal ??
  202. running rich
  203. hesitaton and bad idle
  204. i dont know y its so slow
  205. Interior Lights and Install
  206. Buying an ls1 with 100,000 plus miles
  207. Advice needed - reproducing SES codes
  208. 98 throttle body for gm ls6 intake??
  209. Cam Only????
  210. NEED HELP ASAP!!! LS1 - Fires and ignites but doesn't run!
  211. 12 fair?
  212. does anybody know what exhaust is on this t/a?
  213. Jet?
  214. What heads do I have?
  215. what do you veterans think of this exhaust?
  216. radio
  217. What LSxs have factory magnetic drain plugs?
  218. Blaster Coil Packs??????
  219. Plugged Up Cats
  220. another, different cutout question.
  221. <----Newbie Tech Mod Marker---->
  222. exhaust system on 1998t/a commercial ad.
  223. Corvette fuel filter/regulator
  224. Check for WOT w/ Volt Meter?
  225. A/C Shut Off at WOT?
  226. Drilling Holes in Air Box
  227. What does Ory mean?
  228. How much oil to put in?
  229. ign map std for ls1
  230. intake...is it worth it ??
  231. Help!!!!!!!!!!!!!!
  232. Runs fine till WOT then bogs, why?
  233. What do i do first?!
  234. Spray on a stock rear end an tranny????
  235. Cam Help
  236. what the hell happened?
  237. LS1 Reliability Proven
  238. What to look for in a used LS1
  239. super newbie question
  240. Already ordered...
  241. Will 275/40/17 tires work on 17x11?
  242. What do you guys think about this?
  243. Need a little help
  244. Bolt Ons
  245. difference between oil pans?
  246. fuel pump
  247. Transmission or Engine?
  248. 1/4 mile et & mph for bone stock ls1 c5 Y2k
  249. Whos cars are these??
  250. 98 Style Headgasket with LS6 heads?
