View Full Version : General Maintenance & Repairs
  1. BG Products
  2. MSD wire Q
  3. Will an alternator "whine" when its on the way out?
  4. TA Headlight motor noise
  5. Brake light problem on the TA..Help..Please..
  6. Please help its driving me nuts!!
  7. shift kit/rear slack
  8. Rubbing/Clunking Noise !?!?
  9. Horn wiring
  10. 98 T/A burning out headlights once/month
  11. fuel pressure problems
  12. Driver side window motor not working.
  13. Problem...Short video
  14. Coolant bolt problem?
  15. How do i bypass my p/s cooler?
  16. Idle RPM fluxuating
  17. Loose Steering Column
  18. High torque starter
  19. Any Ideas???? Speedo problem
  20. Valvoline says Mobil 1 does not meet specs
  21. So I'm changing the PS pump for the 3rd time and this is what I got
  22. most expensive day ever?-HELP
  23. Why my turn signals stay lit up on dash??
  24. auto lights
  25. steering wheel air bag
  26. LOUD sound when brakeing
  27. knocking sound when in park. What could it be?
  28. shutter???
  29. sludge
  30. a/c not cold
  31. Cruise control works intermittently and can't maintain speed
  32. sounds like power steering
  33. AC making loud noises?
  34. Brake System ?
  35. Jerky power window
  36. Clunk when shifting (m6)
  37. Fuel line quick disconnect - dumb question
  38. Door Clunk/rattle (did a search)
  39. Seat belt repair?
  40. headlights on/ gauge lights off wtf ????
  41. Cylinder 7 misfire even AFTER plugs and wires
  42. coolant temp gauge/oil psi gauge
  43. Dual Zone A/C
  44. Bad Wheel/Axle Bearing?
  45. I think my window motor is dead, but not sure. Testing question
  46. I need to locate a bolt plz help
  47. Where can I buy an air conditioner bracket? I need a whole new one.
  48. Mobil 1 changed their formula?
  49. Hatch struts
  50. Throttle Body gasket?
  51. Noise from brakes (not even when applying brakes)
  52. a/c not blowin air through vents??
  53. Changing tie rod ends
  54. power lumbar and sides
  55. Just Bought an LS1, Couple Question's about Maintenance
  56. Cadillac window problem
  57. headlight motor
  58. missfiring when it rains
  59. need new steering rack
  60. weird "RATTLE" in back of car
  61. where is door sensor?
  62. anyone know how to do this???
  63. My 95 Cavalier daily driver has a weird issue need Help!!
  64. Where to start?
  65. Throwing code po118 have a few questions
  66. Excessive Front tires wear... Help!!!
  67. wth? clutch squeking when I push it in
  68. Throttle body question
  69. Oil pressure drop
  70. Trip resets to 0.0m after car sits for a couple days...
  71. Exactly what kind of RP oil and oil filter do LS1's use?
  72. V6 Camaro SHOCKING me!!!
  73. exhaust hangers
  74. quick question about alignment and tierods
  75. EGR Problem
  76. water pump leaking??
  77. Help with rubbing noise when turning.
  78. Broken Mirror
  79. Prothane Motor Mounts
  80. Low oil light
  81. High idle after clutch disengagement.
  82. header bolt help
  83. Whirring noise or whistle from engine
  84. Anyone have their high beams stuck on ?
  85. Steering Column Issues
  86. clean greasy alternator?
  87. Coolant leak after removing belt!!
  88. Grinding from front when turning left.
  89. Info on building a T-Top lock cylinder?
  90. Is q horse power full synthetic 5w-30 a good oil
  91. Overheating! Help!
  92. My daily driver truck with 12000miles runs idles like crap. Have a dealer question
  93. HELP question about A/C filler valve leak
  94. LT1 running terribly rich and missing
  95. Dirty O2 Sensor
  96. Seat belt locking all the time
  97. so the wire for the horn is broke on my car
  98. Where to weld in rear o2s?
  99. Seafoam time.
  100. '99 TA won't start
  101. car misses in rain?
  102. Water pump install
  103. a/c compressor
  104. wash engine bay and motor !!
  105. Clutch pedal tightness reduced after a clank sound?
  106. Service Engine Soon light
  107. good tech documents/links location!
  108. Oxygen sensor messing up
  109. power steering pump in 2000 LS1 camaro
  110. Very odd problem
  111. Fuel Gauge stopped working
  112. Alternator wiring problem
  113. How do you remove the pulley above the a/c tensioner?
  114. intake install
  115. Power steering cooler
  116. Please someone help
  117. URGENT: how to take out the heater core on a 67 camaro 327
  118. Alternator pulley?
  119. Engine misfire Code P0308 Help please!
  120. Trouble with bucking/stalling.. AGAIN, please help
  121. *Read* Clean Your MAF Sensor for Smoother Idle
  122. Wind Noise on driverside door seal near mirror
  123. Auto Trix Window Kit
  124. i just love the smell of coolant
  125. Oil Pan Gasket Writeup
  126. Starter Makes Noise When Running!!!
  127. Window Auto Roll-Down Not Working! Help!
  128. An Odd thing
  129. belt squeal...but what is causing it???
  130. What is this suspension part called?
  131. Car Clicks Loudly But Won't Turn Over
  132. I failed emmisions today
  133. Rattling sound
  134. Looking for good LS# Info for swap into classic stang
  135. Water coming from passenger's kick panel
  136. Belt and Pully General Questions
  137. tensioner pully question, PLEASE HELP!!!
  138. Radiator Shroud Rosebud Clips?
  139. Side Marker Lights Shorting Out
  140. axle movement
  141. Probs with drivers side window
  142. Car stalling, need suggestions please
  143. short somewhere?
  144. 01 camaro (no spark)??
  145. Clunk going over bumps
  146. No synthetic recomendation for the F-body?
  147. torque fluctuating
  148. ok, help
  149. question about a/c line
  150. intermittent low coolant light?
  151. Cranks sputters but no start
  152. Coolant and Electronics/Wire Question
  153. Car buying question
  154. rear clank.
  155. Alignment before or after front shocks?
  156. TTop Drain channels bad?
  157. This is getting ridiculous
  158. Sound On Deceleration HELP WANTED
  159. Jack Stand Lift Points
  160. U joint replacement help???
  161. Stock fuel pressure?
  162. knock sensor
  163. Spark plug change on a V6
  164. Advice on Oil, Spark Plugs, Etc..
  165. Power Window Issue, pls check inside
  166. Can I take my AC belt off?
  167. Anther "My engine is ticking" Thead
  168. When i turn my heat on my radios has static!!
  169. Electrical problem..Can anyone help!
  170. car wont start after new fuel pump
  171. Plug Wire Install Question
  172. Damn Clips on The door seal
  173. help how to repair/replace door lock actuator(pic)
  174. Need Help with Brake Fluid Leak
  175. Window Guide
  176. 2000 Trans Am Convertible Auto Tranny LS1 Clicks when goin slow
  177. Oil Consumption
  178. backfiring and sputtering after installing alot of stuff
  179. Gas gauge stopped? NOT THE SENDER
  180. low oil pressure
  181. Belt being thrown off
  182. gas smell
  183. headlight motor has a mind of its own
  184. CD player error code?
  185. Car runs rough in rain.
  186. shifter sticking(automatic, need HELP
  187. Idle question!!!
  188. alarm goes off 5 secs after locking
  189. Catylic converter
  190. Im lost!
  191. Question on rust, cracked plastic, Headlight motor grinding
  192. bleeding coolant system
  193. heater/blower problem, help!
  194. Can a P0440 be caused by a gas leak?
  195. catalytic converter keeps going bad...
  196. Is My Transmission Going Out?
  197. Stripped Spark Plug Hole??!?!
  198. creeking/popping
  199. Power Steering
  200. bad vibration after t56 swap! help
  201. Clanking noise around my rear of car???
  202. car not starting....need help
  203. car shakes at 70mph
  204. 93 Firebird wont start
  205. car wants to stall when stopping
  206. Car doesn't want to start
  207. swapping steering columns......need a quick ? answered.
  208. Freakin' headlights!!!
  209. Power window/lock controls keep popping out...
  210. Water leaking from above the water pump
  211. Subject comes up enough mabey stick write up worthy..
  212. Power Stearing Fluid Problems
  213. What could happen if i run open headers?
  214. Blue smoke out exhaust after cam swap
  215. High RPM power loss? missfire? video included...
  216. Spark Plugs Problems
  217. blinkers
  218. Checking Oil
  219. What is the whole for?
  220. testing coil packs
  221. Help! Starter Grinding on 02 Z28
  222. High RPM power loss
  223. oil leak rear main seal or oil pan
  224. TR55 vs. TR5s gaps?
  225. need autotrix window diagram
  226. Correct Gap?
  227. swapping pcm
  228. Help with flushing radiator system on 01 trans am
  229. Oil drain plug location?
  230. Throttle body or exhaust? HELP!
  231. Car struggles on first gear!
  232. repair kit for the alternator of 2000 LS1 camaro?
  233. Flushing and Bleeding Power Steering System
  234. Water in trunk?
  235. Door Glass Is Loose In Door - 94
  236. Whining Noise After Installing Lid
  237. Car still pulls to the left
  238. Engine Sensor Fuse Keeps Blowing
  239. my abs light and break light are constantly on
  240. Fan won't turn off on my 3rd gen. Help?
  241. strut ripping rubber boot
  242. steering column clunks
  243. Easiest way to get U Joints OUT!!!
  244. Interior rattle, vibrations, squeaks
  245. Removed AIR - Weird sound
  246. no left turn signal
  247. loud clunking noise
  248. Help! yellow gunk by radiator.
  249. Driver window motor replacement?
  250. my truck runs rough
