View Full Version : Parts Classifieds
- Garage Sale. Lots of parts!
- lucas #38 injectors and other items
- 2002 Stock LS1 241 heads with PRC dual springs
- FAST*LSX LS1 Fuel Rails w/ Fittings & Crossover
- Ford 42lb SVO Green Top Injectors
- LT1 Taylor Cable 98026 ThunderVolt 50 Ignition Wire Set
- F/S stock y pipe and manifolds
- New F-Body Prothane Poly Motor Mounts
- New GM LS1 F-Body motor mounts
- LS motors and performance parts
- Ls1 f body single turbo kit
- Borla Adj catback
- 6.0 Intake/TB
- custom turbo kit good for 1500hp- $6000
- 28.8lb Injectors
- LS6 valve springs NEW!, water pumps, etc
- WTT SLP Muffler for ?
- Ported And Polished 862 heads 2" valves
- OEM Chrome Camaro rims & tires (salad shooters)
- 99 T/A air bags/ crash parts
- 17" ZR1 wheels and tires for sale in AZ
- TNT F2 Kit....Complete Plus Accesories!!!
- LS1/LS6 Engine Wiring Harness
- LS2 intake for sale. $200 shipped
- 05 GTO fuel injectors for sale Cheap/shipped
- 6.0L + 4l80, wiring harnesses, PCM
- 6.0 intake, electric tb, fuel rail, injectors, & cover
- CCW Wheels FS/FT
- Vengeance Racing Ported Fast 92mm and 95mm tb
- stock 5.3 parts ,LT1 parts, headers.intake, lots of MISC ect...
- BRAND NEW C5 Z06 Wheels
- tea ls6 heads/ ford 42lb green tops new price!!!!
- fs 03 lq4
- Ported milled 243 heads, LS7 Clutch Kit, etc.
- Crank Pinning Kit - New ! 40 Including Shipping!
- Iforged Wheels
- FS/FT: 243 heads
- 241 heads 28.8 injectors Stock ls1 cam
- 93-02 Trans Am honey comb taillights
- Salad Shooters and 5 spokes
- Stock LS1 Parts, some performance parts for sale
- LS9 Supercharger
- Granatelli Lid, K&N and SLP smooth bellows package
- ls6 intake, bbk 80mm tb, P&P 78mm tb, sanderson shorty headers
- FS/FT: Aeromotive Fuel Rails ls2
- FS: Brand New TEA Ported 862 5.3 Heads!!! <=========================================
- PTk turbo pipes ls1
- Edelbrock 7118 Performer RPM Kit
- 2004 gto ls1 shortblock
- Lakewood drag shocks, Edelbrock torque arm
- Center Caps, Thermostat, Power Steering lines, Throttle sensor, Serp Belt, & cluster
- UMI NEW tubular A-Arms (black), NEW Ron Davis aluminum radiator, NEW Scorpion rockers
- stock/aftermarket LT1 PARTS roller, sb, opti, OTVC wires etc
- stock fuel rails
- Tahoe Escalade reverse sensors CHEAP
- MagnaFuel pump,reg, Jazz cell.
- LQ4 tear down ( price update!! )
- pro stars for foxbody
- 2002 Camaro Chrome OEM wheels
- sold
- AFR 205's, Yella Terra 1.7's, Ported FAST 90/90, HSW 90MM FS!!!
- us exotics nos superhawk outlaw hood new no flaws
- LS1 Engine Block
- Tsp ms3- cheap
- PTM 92mm TB - Cable Driven - Almost NEW -SOLD
- misc F-body parts
- G.I. on some parts. sportline springs, agx shocks, heads, etc.
- FS: Big comp cam
- FS:92# Injectors @ 60 PSI Deka EV1
- garret 47-88
- F/S: Harland Sharp 1.7 Roller Rockers
- Yank TT3000 4L60e converter
- FS: 02 Z06 LS6 Camshaft,Valvesprings,pushrods
- 96mm Typhoon intake w/tb and rails complete
- Nitrous Bottles
- Complete NX Wet kit with Nitrous Outlet plate and extras!!!
- brand new dual valance $250
- 1 GM SS Emblem red/black
- gto shifter, slave, crossmember
- xenon bodykit
- Nasty Performance Sumped F-body race fuel tank
- 42# Injectors
- fs:TSP 7.4 (5/16th) Pushrods(sold)
- Comp Cams GT7
- LS2 flywheel, slave cyl
- FS - bleeders, C5 poly arms, Go Pro HDs, crankscraper, seat/harness, tires, etc
- FS- C5Z front wheels
- 4L60E Bellhousing
- FS OEM 98-02 Black WS6 Hood
- WTT 04 CTS-V T56 for F-body T56
- corvette c5 sport seats BLACK
- brand new 315/40/18 NT05R's
- *NEW* Fast 102,vic jr Carb,6ls module,tsunami,TSP 1 7/8 etc
- Parting out my freshly wrecked Corvette C5 targa 6-speed
- LQ4 Exhaust Manifolds
- Msd opti
- Sold..
- F/S: Godspeed 102mm TB
- Gauge Cluster from 01 Z28 - 126,000 miles
- 98 stock flexplate, will fit t400/4l6oe, 806 cylinder h camaro motor mounts w/stands,
- Polished valve covers, Coil brackets & RC helicopter For Sale
- K&N FIPK Cold Air Induction Kit
- 1998 Camaro LS1 Engine and 6 speed Transmission Complete
- 93-02 Formula LT1 parts
- AEM Fuel Pressure Gauge
- F/S: set of 16 GM LT4 roller rockers
- TCS 3800 N2O converter
- LT1 4l60E
- Meziere LS1 Street Water Pump *polished*
- LS6 Longblock For Sale
- 4 firebird 5 spoke 16" rims and tires
- Typhoon Intake Polished w/Direct Port Nitrous and T/B - $1000
- Procharger Kit 99-Up GM Truck, FMIC, Tial 50mm, P1SC, complete - $3250
- stock LT1 374 Heads Clean Ready to go....
- 2000 and 2011 GM Truck Complete Intake Manifold Assembly
- -4AN nitrous line 11'ft
- 30# svo's
- McCleod Adjustable Clutch Master, GM Clutch Slave
- F/S: LS3 Intake manifold, Cam, Weisco Pistons, Link Bar Lifters
- EGR from a 2000 Camaro SS for sale.
- AIR pump with bracket from a 2000 Camaro SS for sale.
- Corvette Bat Wing Oil Pan
- Mac Mid LS1 Fbody Headers
- Spring Clean out. LT1. SBC. 6.0 Lq4
- C6 Z06 wheels
- 862 Complete Heads
- 04 GTO Kooks Longtubes
- HP Tuners - HPTuners - Serial Interface
- 243 LS6 Heads and 03 Z06 Cam
- 408 High comp. motor
- Brand New TiAL MVR Wastegate (44mm) and "Q" 50mm Blow-Off Valve
- Pro 5.0 Shifter
- LS6 intake for sale
- Stock 5.7L LS1 crank - great condition
- LS6 and LS1 intakes for sale
- WTB th400 stall converter for ls1
- FS: Powerbond 25% UD Pulley / LS2 timing chain
- FS: MTI Z1 cam
- Aeromotive A1000fpr (13101) with Auto gauge 0-100psi fpg
- Big treadstone intercooler, universal plumbing kit
- Custom Grind Cam
- Magnaflow Cat Converters 2 3/4
- 1992+ Camaro/Vette/Impala SS "LT1" 383 stroker motor.
- Set of (8) 90 lb high imp. fuel inj.
- **SOLD** LS6 243 Heads w/comp cams 921 springs
- Set of LS1 piston rings rods W/ ARP Wavelock 2000 Rod Bolts
- C5 and Fbody stuff for sale
- Black Seats
- Edelbrock jr. intake/ Tial 44mm wastegate
- yank ss 4000 converter, 4l60e, stock 10 bolt
- Spohn t/a
- FTI 2.2 STR 3600 stall Billet, lock-up Torque converter for 4L60E
- Stock LS valves 2.00" and 1.55"
- For Sale
- SLP Dual Dual exhaust low miles almost perfect!
- 2005 5.3 Aluminum Block
- Powerglide $430 shipped
- FS: Trickflow 215 cnc heads & Fast 90mm ported
- Ny Trex Nitrous bracket
- FS: SNL VX Cam
- LQ4 HEADS; Plus valve springs installed
- Ross forged pistons, eagle H beam rods
- RAM Powergrip HD Clutch & Billet Flywheel
- 3 2002 GM SS Emblems Black/silver
- Harmonic Balancer, Comp Cams Pushrods, Trans Damper
- HSW 90mm plate
- Edelbrock Victor Jr. Manifold Ported Polished
- Slp CME and Two piece Valance kit
- Flow Matched High Flow Injectors LS3/LS2/LS1
- FS: Black Powder Coated Weld Draglites
- Ported 241 Cylinder Heads
- LS2 MAF with adapter harness
- Gen 3 Swap mounts
- LS1 intake, throttlebody, ws6 lid, t-top shades
- HJC CL-16 Snell 2010 racing helmet size medium
- (2) 2002 Speedline 17" wheels with Hoosier drag radials
- Cammed LS1 Engine, LS1 driveshaft, water pumps, AC parts, Tie rod ends, etc
- NIB Crane LS3/L92 1.8 Rockers.
- 228-232 Cam, Two sets pushrods 7.5/7.4
- SLP DUAL DUAL catback for sale in NJ
- ls1 h/c/i
- NEW Ceramic Coated 1955-1957 LS1 Chevy HOOKER HEADERS(LONG TUBES)!!CHEAP
- QTP Race-Style Headers 1-3/4 w/HVMC
- FS: Draglite 15x10 7.5" BS
- 241 heads w/duals & titanium retainers; new intake valves
- A/c compresor, bracket & tensioner
- GMPP L92 intake FS/FT
- 2005 LQ9 truck cam
- 750 quick fuel double pumper carb
- (price drop)d1sc procharger with the hybrid bracket for a ls conversion
- RS body kit for sale? Camaro
- 4l60E w/brand new yank ss3600
- Precision Turbo 96lb Injectors
- Full set of gray leather seats
- 1998-2002 Camaro SS K&N Intake Kit
- Trans Am true dual exhaust from headers back
- 1998 Camaro Firebird LS1 SLP Long Tube Headers
- BNIB JE Pistons
- ls1,lt1,5.3,6.0,ls2 harness rewire serive for hot rod motor swaps
- Edelbrock Victor Series Drag Race Headers(98-02 Camaro/Firebird LS1)
- Borla Adj Catback (Quad Tips)
- nitrous express system
- Spohn ajustable torque arm, LCA, Panhard Bar, 35th SS Mats, LS7 Rockers
- Brand new FAST 102/102 with Nitrous Outlet and 243 ls2 heads
- WTB CCW SP500 or 505a with or without tires
- strange eng. rear brakes 93-02 F Body
- Hotchkis LCAs w/ new bushings
- Balancer Pulley pin kit and install tool
- Big Flowmaster single Chamber
- Nitrous and Fuel Pressure Gages with Pillar Mount
- Parting out 2002 z28: Major suspensions, brakes, fuel
- M6 6speed pedal set with switches ----sold----
- parting out 98 Z28
- Aftermarket Ws6 Hood Black
- 10 bolt w/4.10 & LCA's FS
- McGaughys 2/3 lowering kit for 00-06 Tahoe/Yukon
- Graphite T-Top Shades
- Weld it header kit with LSx flanges
- ls6 head/cam/parts off 02 z06
- Hurst Billet Plus shifter for T5/T45
- 2 cams
- 09+ Ls3/7 TB
- NEW SLP Loudmouth Resonator For Sale
- Garage Clean Out - Billet Flywheel, SFI Bellhousing, Ported LS6 Oil Pump, + More
- Precision U-Joint for 1350 to stock driveshaft (Ford 9, 12 bolt)
- Ported 241 806 853 cylinder heads
- SLP Loudmouth 1 Catback
- 93-97 Pacesetter coated long tube headers LT1
- Kooks 1 7/8" stepped to 2" headers
- BNIB monster stage 3 clutch
- Built TH400
- Ls1,c5 corvette,camaro parts for sale
- 6.0L LQ9 Shortblock- SOLD!
- T-Tops From a 99 T/A FS $120 shipped
- McLeod adjustable Master Cylinder - LT1
- Lt1 52mm Powder Coated TB - Black
- Magnacharger m112 for ctsv/hotrod
- FS: PatG Cam, AFR 225's, NW 90mm TB, Head Gaskets & Bolts, Engine Covers, stock wheel
- WTT dd c6 z06's for drag pack/drag wheels
- 93-02 camaro power doors
- Complete 99 T56, B&M shifter, Spec stage 2.5 clutch
- Wtb edlebrock Vic Jr Efi
- Turbo wastegates
- Pair Firebird headlight motors 93-97
- 2 sets of 243 spring.
- Few 98-02 parts For Sale, ls6 cam, coil brackets
- FS: MGW, T56 and McLeod Master
- WTT- Centerline Drag Wheels an tires for c6 zr1 or z06 style
- 2 taillight panels for camaros $45 each, 6sp pedals, Rear grey seats.
- Alpine deck and HUmount! Perfect shape
