View Full Version : Parts Classifieds
- Misc. LS1 parts. other
- Lt1 643 Heads, Intake plug and play! need gone ASAP
- 6.0L iron block !!! Magnacharged!!!
- Valvetrain Parts
- Brand New LS1 Water pump and valley cover
- Diamond Pistons 4.10 bore
- Vortech Super Charger V9 98-02 LS1 Fbody + Extras!!
- GM 36lb injector 12594512
- Ls2 413 Stroker Shortblock-SOLD!
- FS: Precision PT2000 Intercooler
- Kooks Long tubes and Kooks Y pipe SOLD
- AFR 205's SOLD
- abandoned 6.0/L92 build
- FS:LS1 stuff and F body aftermarket parts
- ls1 coils
- Sumitomo Tires 5k miles!
- just throwin this out there 5.3 intake manifold f/s
- NEW Rossler TH350 RMVB, ATI 8" Treemaster Stall
- Sold - Volant cold air intake camaro/trans am ls1 98-02
- Throwout and Pilot bearings
- Lokar oil dipstick LS6 coolant crossover
- SBC Milodon steel splayed main caps
- 2002 z28 exhaust manifolds to tips compelete
- NX kit with standalone fuel system msd timing twister and more
- 1997 LT1 t-56
- Ls6 intake manifold
- REV Valves, 317 heads, Aftermarket Fuel Rails, Stock 5.3
- Cometic .40 mls Headgaskets thinkness 4.030 bore *BRAND NEW*
- 317 heads, LQ9 cam
- Zex Wet Nitrous kit with BRAND NEW window switch. $325 SHIPPED!!!
- LS1 EGR intake & AIR
- SOLD* FLP Longtube headers with cats/Off-road pipes and y-pipe
- FS: 93-02 Firebird Monsoon CD Player
- LS2 Shortblock - needs rebuild
- Ractive Exhaust Tips (Wide Oval) SOLD!
- 07 Vett LS2
- LS1/LS6/LQ9/LM7 parts for sale, head gaskets, ARP pulley bolt, rod bearings.
- procharger stock and aftermarket parts
- Magnuson LS6 Valley Cover
- Custom Procharger kit for LS powered 2nd Gen Camaro
- Spohn Extreme Duty Drive Shaft
- FAST 65# Injectors
- center bolt valve covers w/ bolts
- 04 GTO black leather seats
- LS6 Intake and fuel rail
- C6 exhaust manifolds
- Sparco torino 2 race seats
- 243s with springs, retainers, seats, locks, also rocker arms for sale! Free shipping!
- One WS.6 Rim
- Mufflex/Y-Pipe/4inch Exhaust
- Wanted Trickflow 225cc heads
- Circle D HP 4L60E LS Torque Converter
- One-off 17" black Billet Specialties street lite wheels
- S475 Brand New!!!
- WTT or SALE 18" Z06 wheels for HPTuners
- Katech LSx Billet Oil Cooler Adapter
- FS:96mm Typhoon intake
- 6.0L shortblock and 6.2L heads for sale
- ls1 mustang swap headers/custom vortech kit
- strange u1667 chromoly transmission slip yoke
- 317 Heads w/Patriot Duals - Cleaned, Milled, Valve Job
- 2x 97-01 WS6 Wheels $80
- Sweet center console M6
- steering column and key (from a 1998 Z28)
- "Z28" emboidered floor mats, black with red stitching
- prc .675 valve springs
- 2002 - 2007 LQ4 Drive by wire setup and reflashed computer
- Stock LS rockers
- Ported LS6 intake
- F.S. - HP Tuners MPVI Pro - SOLD!!!!
- ls2/3 parts for sale!!!
- New G.M L-92 pistons
- 60# siemens/mototron injectors
- blown ls1 shortblock,mti 5.3 heads/cam
- IROC/LS1 header back exhaust, grant wheel, fancy SBC valve covers
- Superchips Cortex 2950 Tuner
- UPDATE centerline split spoke street/strip wheels
- LS2 Intake Manifold and fuel rail
- Aluminum 5.3 block for sale
- Stock Springs
- WS6 stock shocks and springs
- FS: Mostly-complete ’98 LS1 with PCM
- SBC Trick Flow heads
- LT1/LS1 Parts - Forged Rods,ECM,Injectors, and more!
- LS Valley Pan Knock Sensor Grommets FS
- Manley .650 lift Springs
- Stock and Aftermarket Parts for sale, something for everyone
- 2002 Camaro SS 241 heads
- Scat H-Beam rods with arp2000 bolts
- Ly6 cam
- FS: Stock LS1 (2000) Engine Wirning Harness
- Brand New OEM Jaguar Trunk Emblem/Badge (XJR XJS XJ8 XJ6 VDP)
- Pilot style motorcycle/scooter helmets
- New "Leaper" Gas Cap - Jaguar XJ6,XJ8,XJ12,XK8,XJR,XKR
- walbro 255L in-tank pump with sending unit
- Pro 5.0 shifter
- MTI Stealth Cam II
- DMH 3.5'' Electric Cutout
- 98 m6 camaro COMPLETE PART OUT, Clean Bare Chassis F/S
- Ls3 intake, NX nitrous kit, ls6 springs, c6 z06 stock air intake, ls3 crank pully
- lt1 Parts for sale, TPIS HEADS, LONGTUBES, INTAKE, INJECTORS- GO FAST PARTS
- Mass Air Flow
- 4l60 trans an converter
- Fuel Rails - FAST & Professional Products
- 317 Heads off 2004 Escalade $200 shipped
- Vig 3600 and 4L60E, BMR LCA's, Adj Panhard, TSP 100MM MAF, Hubs with Studs
- ls6 Intake
- SOLD!! valve covers carbon fiber hydro dipped
- New 80lb Motron fuel injectors
- New LS9 ZR1 Engine Complete $18K
- lt1: heads, cc502,other valvetrain parts *lowered prices*
- ms3 112lsa
- 02 gm "ss" hood
- FS: TR-6060 08 Z06 Good condition!
- 241 heads
- 31 spline spool for Ford 9"
- Rebuilt Ls1 longblock w/ upgrades
- 2002 Camaro 4L60e, 8000 mi. w/extras. SOLD
- 2002 Camaro stock 16" aluminum rims w/ tires Low miles
- 2002 Camaro Passenger airbag
- harris speed works nitrous kit,tial 50mm bov,alky control kit,strut tower brace
- FS: c6 z06 OEM Intake + Filter
- FS: c6 z-06 Exhaust Manifold - Great Condition
- New LS1, LS6, LS2, LS3, LS7 and SBC Morel Lifters
- SLP UDP, LS6 Clutch, Stock Valvetrain, etc..
- LS1 Rocker Arms and schtuff - cheap
- pa racing lca's
- L33 intake
- Ram Powergrip HD Clutch, Intake, Lid, etc.
- K&n oil filters
- NEW Comp Cams "r" series hydraulic roller lifters
- 99 ta oem black non-ram air hood
- ls1 block, crank, manley rods, and CP pistons
- WANTED-90, 92 Fast Intake(PORTED)
- NEW CTS-V oil pan and gasket, LSX swap plates +/- 1
- 408 LSx
- Wanted - LS1 full roller rockers
- FS: ARP 234-5608 - ARP Main Stud Kit
- lots of ls parts for sale!!! great condition!!!
- Bosch 47lb Injectors
- wanted used 427 ls7 engine bare block only
- Ls1 Engine harness with ECU *Great Shape*
- Katech Rod bolts
- NEW Vortech supercharger, BRACKETS, fuel pump, and bypass valve.
- O2 Sensors, Stock Manifolds, Stock Y Pipe
- COMPLETE direct port nitrous kit with stand alone fuel system
- One day only sale!
- 42# SVO injectors
- AEM UEGO Wideband
- Silver Trans Am stock Hood
- 4'' cowl hood glasstek 93-97 camaro
- Lt1 edelbrock performer heads
- crane powermax tuner
- Misc LS1/LM7 Parts
- fs: NEW LS7 SLAVE CYL.
- TCI TCU 377000 Trans Controller w/ 4L60E Harness
- 2000 Camaro ebony leather seats
- Garage cleaning SALE , little bit of everything !
- FS or Trade: 42 lb. "Green Top" injectors, Comp R Lifters, Comp PR's, & More
- Torquer v3 cam, tsp pushrods, shifter stick and handle for gto. SLP MAF
- 93-02 oem camaro wing black in great shape!
- FS: performance parts
- WTT SVO 42# for other 42# injectors
- LS1 Wiring Harness
- 01 ta manifolds cats and y
- Percy's/Breslin Split Lock Stainless Header Bolts**Pics Added**
- TCI Super Streetfighter Stall Converter 3500RPM Low Low miles
- Parting 2000 Camaro SS Part 2 Headers, Suspension, body and interior parts
- FS: 243'S with everything!
- 93-02 red camaro tail panel for sale
- 93-97 drivers side camaro fender for sale.
- sellin my 98 ls1 heads with valve covers
- Heads,manifolds, cam
- 4.8 truck cam
- RACE PARTS!!! Rossler,BMR, Nitrous Outlet, M&H, SVO, etc!!!!
- RPC Aluminum Raised Valve covers
- Red MSD wires and Stock 6.0 wires
- A4 4l60E w/ shiftkit and stall
- x1 DDM Tuning 5000k 880 HID
- Edelbrock 1406 600 CFM spread bore carb
- Shift Handle - Pistol Grip by Hurst NIB
- ACS C5 Side Skirts
- Camaro bumper, pass. door, spoiler, windshield banner
- ls 346/wiring harness/cnc 317 ect
- Camaro 3.4, LT1 Parts
- SS wing 02 black
- Vic jr efi intake elbow nos plate & fuel rail
- Lt1 engine
- SOLD!!! 6LE CME valance w/ OEM CME tip and polished 90* bends
- LT1 Interior Parts
- Mti X1 cam new
- 4L80E Conversion Crossmember & TA Mount
- Stock LS1 lifters
- dyno tune digital nitrous pressure guage
- LQ4/408 Forged Short Block
- LS6(03 Z06) cam
- ported ls6 oil pump
- wts/wtt 18" eagle polished rims
- LT1 Cam NIB
- PRC stg2.5, 5.3 heads
- AFR Hydra Rev Kit 6155 NIB
- 17x11 Polished ZR1 rims, red Corvette Bumper, HVAC plate - Chicago pickup only
- 7.2 Thunder Push Rods + Guide Plates - SOLD
- Updated prices!!!!! TEA Heads, Cams, LS6 Intake, Pushrods, And more!!!!!
- 243 heads/ls1 block
- FS: Moser 9" with Strange 3rd member BS Street Lites!
- 243/ 799 heads
- Black 98-02 OEM Camaro Hood / Spoiler
- agx rear adjustable shocks.....new!
- 2 dual corsa clone tips
- complete center section with Locker
- magnaflow cat back for F-body
- 2 - 3" fake cats NEW LOWER PRICE
- magnaflow 3" bullet muffler
- stock MAF with ported ends
- Spohn Pro series Torque arm
- F body 10 bolt rear end 29k stock miles
- Spohn Drag Anti Roll bar
- Moser 12 bolt
- SLP underdrive pulley.
- LS1 True Dual X Exhaust,LCA's, Exhaust Manifolds, EGR, AIR,
- Polished ls1 valve covers
- LS1 parts , rods , ported heads
- Ls7 clutch flowmaster y pipe merge
- Parting out 1998 Trans Am
- 01 trans am Rear ebony seats complete w/seat belts
- BG Speed Demon 750
- SLP Oil Pump (blueprinted)
- LS1 intake manifold w/TB
- SPOHN LCA's
- SLP Sub Frame Connectors
- ARP Cam bolts SBC/BBC new in wrapper
- LS3 intake manifold, $275 SHIPPED!
- west wing lip trans am
- monster clutch , timing chain, and more
- F/s:Oem 323 gears, LS1 Intake, Ls1 Throttle Body
- Black Weld Prostars
- Mahle 2618 Gas ported Boost pistons ,-12cc
- *parts added* innovate lc-1 wideband, lenses, ws6 airbox!!!
- FS/FT: Racestar Industries w/ ET drags
- FS: ls1 Rocker arms + rail & Bolts
- MOTIVE 12 bolt 4.11 gears 3 series carrier
- Newly cleaned and decked LT1 HEADS!!
- Bilstein, Lakewood, SLP, Lowering springs, Sway bars
- 02 T/a monsoon cd player
- LS ASA Cam!
- FS:ls1 Valve covers
- brand new off road y pipe (ORY)for shorty or stock headers
- Complete 78mm plate set up. 6.0 manifold turbo set up hot side Greg weld wheels ls1
- 346-cnc 317-new pistons and rods
