View Full Version : Gears & Axles
- Which gears for TCI Super Street Fighter?
- 99 HOE tranny problems
- TC AND GEARS?
- Need an Opinion Please
- all 10 bolts suck
- Tranny noise between shifts
- Help with gear setup?
- speedo troubles!
- Drill Mod ????????
- Anyone have a stock TQ arm mount.......
- BEST REAR??? Opinions PLEASE, good and bad.
- Gas pedal problem HELP!!!!!
- TC install Problems!!
- How to make stock master cylinder - Adjustable?
- General Question
- If you go between 1st & 3rd...
- TC 's and speedo readings
- Strange 12 bolt help!
- 4:10 gear noise
- Gear Recommendation: 421rwhp/400tq N/A 540hp/590tq N2o
- Anyone using the 8.5 inch 10 bolt rear?????
- LM Performance is selling the Qwik Stick
- what driveshaft are you guys running
- Broke my 12-Bolt!!!!!
- Rear End
- 3.90 gears
- Anyone know where I can find the line from the master to the slave.???
- Just ordered PT4000 - have a question...
- 1/2" studs with stock 16s
- My Pro-Stars won't fit up front w/ my new AutoZone brakes, why?
- Swapping the Gears in a 3.42 C5 carrier
- Broken wheel stud im a dumbass!
- 3.5" vs. 3" driveshaft...
- How good/bad is the stock rear end?
- Genuine GM 3.73's
- Does descreened MAF cause TC chatter?
- poping out of 5th
- How to us Spohn torque arm with moser 12 bolt
- Shake, Rattle, and Roll
- ST4000 vs TP4000
- Need unbiased info on using 3.90/4.10 in C5 CORVETTE..is it safe?
- Another TP4400 question...
- Cheapest place to get a modified stock adj m/c?
- need help
- Anyone here with TP4400 and 3.23s?
- Shifters??? what kind?
- What rearend do I have
- Paging *stick only* (MIKE)
- Master Cylinder Question? Question
- Which master/slave cylinders? 2000 car
- Wheel Rim Screws
- Noises in the drivetrain, take you best shot!
- Another gear ?
- TC or Gears?
- How can I make a lockup switch?
- STR differances????
- Which Rear end do i have?
- Thanks RT CAMARO SS
- Strange 12 bolt owners w/i
- Q about quick change rearend
- Red Line?
- Stock Length Studs ok with 15x3.5 Pro Stars and 5/16 Spacer??
- b&m shift plus question
- Gears without programing?
- 12 bolt or 9 inch
- My stock rear end has 3.73
- Bleeding the slave?
- Dont know what to do, very urgent!!!
- Anyone have torque strap info? Pics?
- What gear/trap RPM's wth 4.10's
- Drill Out Mod
- Web site for info and prices on VIG TC ??
- Lowest cost alternative to stock 10 bolt
- new car, need help
- Who's pinion seal leaks and just lives w/ it
- ?'s concerning gears and rearend
- NEED HELP- rear sway bar hitting 12bolt girdle
- Auto redlines....
- Gear? What do I do????
- Vig 3200 STR???
- Vig 3200 STR???
- Opinions/Recommendations for a Drive Shaft Safety Loop....
- Transmission and Gear Fluids?
- Diagnose my rear problem???? please?
- Is it worth going to 3.73s if you already have 3.42s
- Driveshaft Safety Loop
- 3:42????
- Project 200-4r autotrans transplant into F-body
- Those Who Need to Change Pinion Seal Or Changed it And Is Still Leaking---->
- T/C question, (i ask alot of them)
- Locking Convereter on the Gun?????
- Rear sway bar resting on Strange 12 Bolt
- How do I get the c-clips off the axles!!
- Time for a new tranny!
- 6 speed problem
- U-Joint! What size?
- Pt. 3 of Getting Nowhere.(Long)
- Removing Check ball?
- backup lights and neutral safty switch wires?
- do all 12 bolts make a "slight" clunking sound when turn VERY sharply
- SLP AUBURN POSI UNIT
- PLEASE HELP
- Need Trans Pan Deepened
- Cryogenics. . . what do you guys think?
- do I need a 12 bolt or will the 10 be fine?
- does it matter which brand of gears to buy?
- GM Techs or experienced LS1 mechanics in here.....
- What is the best gears for a auto?
- Those who ground rear calipers to fit 15's HEEEELP
- Just got a Hughes 3500 for practically free, need some advice.
- 2:73 to 3:42 worth it or not?
- What is the weapon of choice when it comes to a Moser 12 bolt?
- shift kit question
- TCI Racing Tranny Fluid
- 9" or 12 bolt and why....
- One more question about adjusting my LCA's and Torque arm. I need a little help
- Let’s talk about aftermarket TC lifespan...(kind of a poll)
- What is involved in changing pinion seal?
- Strange clunking sound when turning
- moser axles
- Gearing Question??
- need some input on what oil to use with rear gear?
- New gears, what else do i need?
- Information needed on Jay Fishers Stealth Arm
- Rear Weights??
- 4 link it???????????
- Whats up with my 60ft?
- 30 or 33 spline?
- WARRANTY
- 3.73's what should my rev limit MPH be in 3rd?
- 3.73?
- Not happy with 1LE mount
- RAM VDS people did you use the shims?
- Tranny build-up
- help! how to make metco lca's work with moser 12 bolt?
- need to disable reverse lockout code...same resistor as !CAGS?
- Gear question
- Just got 1LE tranmission mount
- Gear ratio ?
- u joint & yolk question
- 99 and lower slave cyllinder problems?
- Fluid
- what rear springs?
- Moser pressed on bearings vs c clips
- Best 12-bolt and where to buy it at the cheapest price?
- built tranny question...Hows this option?
- Aluminum Driveshaft ??
- Hotchkis Subframe Connectors - Installed!
- Dr. Tranny Instant Shutter Fix
- Got the P0757 error again(2-3 shift noid error) and what's lowest rpm for TC lockup?
- Vibrations
- What size STR in VIG 3600
- Drag Race Setup! What to use?
- Radius of Stock Tires
- Question with a 3 channel abs car and a 9'' rear end??
- Had Pinion Seal Replaced... Now Rear is Clinking!
- Switching from Vig3200 to YTP4200 and have some questions.
- True dual x-pipe or h-pipe sytem and torque arms
- TC Install...Help
- clicking noise in back end
- Found a 9 inch
- ZO6 rims and Bumpstops
- Cheap way out of a 12-bolt...
- Rear end bottoming out
- Calling the Colonel
- any one happen to have the 4l70 coversion instructions?
- TH 400 conversion
- hey guys problems with 10 bolt
- are they genuine gm gears??
- 12 Bolt Moser Question
- Gas tank clearance with 12 bolt - WTF???
- 02 Rear in 96
- Anyonw want to trade TP 4000 for ST 3500...
- From 2.73 to 3.42, what kind of mileage losses?
- TC for A3, which ones are being used?
- What Next?
- Help adjusting the torque arm
- Tranny Fluid???
- Jason 99 TA...Phoenix Injector ?'s
- Denny's or Carbon fiber DS
- Lou's Short Stick?
- ABS
- HELP! NEED spohn new style torque arm! what's this flow tech ta?
- Anyone's DS loop hitting the weight on the driveshaft
- 9" with 2" taken off each side!
- 97 rear in an 02?
- 1LE Trans Mount People quick question
- Cheese with that gear whine?
- A quick rearend question...
- What do yall think..Will My rear end Hold??
- Does anyone have a?
- Need tranny help please
- Twin disk roll call......
- posi rebuild kit???
- Remaining Adj. Master threads...
- Who's running a YTP4200?
- Torque Management?
- Can you make a 4 channel ABS 12-bolt work with 3 channel?
- Denny's driveshaft questions
- Does the stock torque arm have a bow to it?
- SLP Bolt In Subframe connectors
- Installing A TC Rear End in a NON-TC Car
- 12 bolt options
- 12 bolt
- Odd whistle noise from the rear...
- CRACKED my Moser 12 bolt housing
- TR224 and 4.30's ?
- Who has a Thruster Pro 4000? Whatcha Think?
- Odd high pitched noise .....
- Torque management experts, is this TM?
- can i get a measurement please???
- 3 Leaky Pinion Seals in 42K..Anybody Else?
- Rear sway bar Question...Off or ON??
- OPINIONS WANTED: ABOUT TO BUY GEARS.. WHICH BRAND AND WHAT RATIO?
- How much torque does it take to take the slop out of the pinion yoke?
- How to fix a Moser 12bolt leak at the end of the axle tubes?
- Torsen, which end is up on the c-clip retainer block??
- ARRGGHH!! Are ring gear bolts Righthand thread???
- What kind of combo would you use a UY6000 on
- Won't Shift Into 3rd At WOT Help!!
- STUCK... Where do I find the special bolts to hold the axles onto the rear (8 bolts)
- Looking for Kevin Winstead
- Is this a good price for a 12 Bolt?
- HPP3 shift firmness????
- TA that will fit with true duals?
- Ram 6130 did its job!
- Speedometer
- HELP Where is trans servo?
- V6 rear springs
- what grade rear end fluid should I use for my Strange 12 bolt?
- Shifting problems 2nd and 5th
- my moser only spins one tire!!!
- 410 Gears?
- Anyone seen any write-ups for replacing the Torsen diff?
- shift kit
- Cracks in rear end housing
- Maybee low fluid was my problem.
- 2001 Trans Am posi???????
- Thinking of taking out a personal loan for a new trans.
- How do I know if I have LSD?
- Remember that Ferrari shifter I was building? Here's where I am today.
- Differential fluid...mix?
- help!!! hypertech shift settings???
- Turbo350 with OD or better??
- Not again
- auto trans stuck in 3rd
- Spohn Torque arm with front and rear DS Loops -- BIG PROBLEM
- Do 4.10's pull harder than 3.42's all the way down the quarter mile?
- break-in period for 12 bolt?
