View Full Version : Generation IV Internal Engine
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 [36] 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52
  1. LS2 Intake Question
  2. L92 Valve train Question
  3. JPR on LS2
  4. Crane valve sprig tool with L92 heads (will it work?)
  5. 416Ci cam choice
  6. Sodium filled valves? l92
  7. LS1 to L92
  8. couple L92 assembly questions
  9. L92 swap to 2001 truck
  10. L92's on a Big Bore 388
  11. L92 - milling? PTV?
  12. l92 block-
  13. LS7 valve springs specs??What are they
  14. How Much Power And 1/4 Times Guess?
  15. RWHP guesstamate
  16. oil pump question
  17. what did you spend on your stroker??
  18. LS2/L92 heads ???
  19. 6.0 truck engine dyno at 534rwhp sweet
  20. Ls2 Build
  21. I have an engine noise, I'm thinking push rods
  22. Info on New 402??
  23. Cd Z06 Piston to valve clearcance?
  24. 07 5.3 with cam and head work
  25. LS7 RPM Limit
  26. Couple of LS2 questions PLZ Help
  27. L92 rocker stands. Need them bad
  28. ls2 wont start please help
  29. LQ9 & LS2 Help!
  30. Torque specs for the crank pulley
  31. Finally Parts for my W2W 427 starting to come in...
  32. Corvette fuel rail covers??
  33. What all is needed for cam install (and yes i tried to search!)
  34. Mast Motorsports Updates and L92 HO VVT Dyno Results
  35. Need info on this cam for my 427
  36. LS7 Pistons
  37. L92
  38. No Crank
  39. Is there a cam I can run on stock rockers
  40. lsx block
  41. Cam sensor problems, Help?
  42. et ls7 head availability?
  43. 454 LSX Buildup Photos Inside
  44. Motor build over winter
  45. PVC help ls2 l92 combo.
  46. Wondering about cu. in. in LSX Block
  47. what else to do for a cam swap?
  48. Fly cutting pistons for L92's?
  49. CAM guru's, i need your help....
  50. LS3 Crates
  51. Weight diffrence between iron 6 liter and ls2
  52. Thoughts on ls2 and what mods
  53. LS2 double roller timing chain
  54. Need piston advice for a 430 w/ LS7 top end.
  55. LS1 cam the same as LS2?
  56. LS3 blocks...
  57. L92--LS3 Compression Difference
  58. Questions about a 402 into an '03 Z06
  59. L92 intake question
  60. LSX shake down runs on spray.
  61. 4.1 stroke in lq9 ?
  62. Dart 225's and MS3 on LS2?
  63. gm truck mods
  64. LS3 cam specs
  65. Mods to a C6?
  66. Head gasket options for LS7 heads???
  67. Heads/cam combo LS2
  68. LS7 heads, what are your rocker choices,
  69. ls2 v ls3?
  70. LS7s suffering valve-train failures from mild after-market cams???
  71. What is the oil capacity??
  72. Bumping Compression - LS7 headed 427.
  73. LS7 double roller?
  74. STROKER MOTORS - LS1 vs. LS2 & DRY vs. WET SLEEVES
  75. info on ls engine builder
  76. SDPC 416 in and ready to go
  77. Engine and Rear end noise
  78. Show me your cam for a turbo car?
  79. LSX True Street Challenge - Oct 2007
  80. LG Motorsports compares the LS3 vs L76 intake manifold
  81. Which cam would you choose?
  82. 402 Short Block Inquiry
  83. Anyone recognize these Ls7 427 forged pistons...
  84. Hi Tech cam
  85. h/c setup, 4th or 3rd gen, which is wise?
  86. h/c setup, 3rd or 4th gen, which is wise?
  87. Does anyone know who WOTFMAN is?
  88. 427 cam
  89. Head mill limits for LS7/L92?
  90. 427 Rotating Group Depth
  91. L92 Heads on stock LS2 - what cam specs?
  92. High oil pressure on startup
  93. L92 heads ??'s
  94. LS3 Cam Only with LG Headers, G3X-4 cam, K&N Air Charger, no tune
  95. L76 intake kit
  96. Is it official? Can we rename the L92 Heads and call them LS3 Heads?
  97. Can't remove cam retaining plate
  98. manifold for ls3?
  99. Anyone runing either of these two cams with an A4??
  100. H/C Combo on LS2 is it leaving power on the table???
  101. ls1 valve covers fit ls7 heads?
  102. LSX bowtie block
  103. Any word on ET's L92 heads?
  104. 400rwhp/tq from LS6/LS2
  105. AFR 225/Beck-Wilson -vs- ETP LS7/LS7 on a 402
  106. 416CI Cam choice
  107. C5 427 Dyno Results
  108. ls3?
  109. should i put stock rockers back on???
  110. L92 block strength (FI?)
  111. What cam to support 550+rwhp on a stroker?
  112. L92 forged internal questions.
  113. Warhawk 9.8
  114. Does the Corvette run on a new fuel source?
  115. Warhawk block.
  116. gaskets and bolts
  117. Heads are in
  118. ?? on LS2 timing chain gear
  119. Beck's 408/LS7 Powered SSR
  120. LS3 hollow stem valves for the L92 crowd!!!
  121. ls408
  122. LSX already coming apart.
  123. LS7, LS2, L92, L76 fuel pressure?
  124. Any Idea about the CR here?
  125. Adjustable rockers for LS7 heads?
  126. L92 head question
  127. 600RW n/a...
  128. changing lifters
  129. I am afraid to hit the nos button
  130. Nicely wrapped gift from TSP!
  131. AM i the first?? LSX track results.
  132. 2007 2500 6.0 Vortec=l92??
  133. L92 flycut tool rental?
  134. Warhawk News
  135. L92 forged, block and boost.
  136. LSx 6 bolt Head gaskets
  137. time to start buildin....
  138. Head Gasket setup for extreme combo
  139. ? about rokers
  140. LSX block, ready to use out of the box?
  141. What size hole in the restricted push rod ?
  142. 455 LSX w/ LS-7X warhawk heads
  143. What was GM Engine Oil Supplement (EOS) PN#1052367 replaced with?
  144. LSX pics and info. must read if your doing lsx.
  145. LS2 Swap, cam sensor help
  146. WTF is wrong here?
  147. What bore can I go on 6.0 iron block?
  148. LS7 with KB / Lysholm / Autorotor or dual Rotrex
  149. Got the LSX going together!!
  150. 4inch bore head gaskets
  151. LS7 OEM Main Fasteners
  152. The Infamous Gm Engine Knock
  153. P to V clearance with this cam and l92 heads stock bottom end question
  154. LS7 Conversion Done - 66 Vette
  155. New Carbon Fiber Valve Covers @ SDPC!!
  156. ls2 psi rating
  157. LSx block & Warhawk heads pics
  158. removing DOD on l92 block?
  159. Lifetime billet high flow oil filter for LS1/LS6/LS2 !!!
  160. 69 Camaro LS7, It's alive
  161. L92 head 427 makes 700HP n/a!
  162. MS4 & Stg1 LS6 head results
  163. l92 on ls2 mill to 11 comp question
  164. New shortblock 427, 440, 454+ daily driver??
  165. Another Cam Question??
  166. Changing Cam effect AFR on already tuned car?
  167. Biggest cam on L92 head?
  168. LS6 intake on LS2 longblock????
  169. LS7 head flow data?
  170. Need some advice on my broken 408 please
  171. LS2 Heads and Cam Question
  172. High RPM Stroker
  173. Beefing up a built LS2 for big power.
  174. Patriot springs need machined seats?
  175. L92/L76 Fuel discussions
  176. L92
  177. Anyone running the cheaTR 2 yet?
  178. all pro LSX W7 HEADS
  179. Are Comp 921s a direct bolt in for LS7 Heads???
  180. L92 Crank and Bottom End In an LQ9 Block?
  181. Question bout Cam install/lifter
  182. Cam/power & 1/4 mile questions
  183. L-92's w/ forced induction what's wrong?
  184. LSX suggestions
  185. LS2 swap for LS1
  186. Heads and cam dilemna
  187. Whats the deal with the GM LS7 Stg 3 Cam - 233/276, .595, 107 lsa
  188. Are you racing an LS7 block?
  189. car is in the shop to get the 402ci w/ported l92 heads & l76 intake installed.
  190. Cam time!
  191. West Coast Heads...
  192. Opinions on using 20-50 oil in 427 stroker
  193. 59cc heads + LS2 + X3 cam
  194. need alot of help thanks
  195. New LS3 Block will be the perfect way to make 427 cubes cheap and reliably!
  196. lookingfor 400+ci shortbolck for boost
  197. Video of our LSX on the Dyno
  198. Cam / Crank sensor colors?
  199. dumb question about motor size?
  200. Katech LS7 9:1 pistons now available
  201. L92 flow data with and without manifold
  202. Katech rod bolts back in stock
  203. Cam gear compatibility
  204. Two different L92 heads, will it matter?
  205. head gaskets l92
  206. Pushrod length?
  207. Katech 427 L76/92 Pics
  208. l92
  209. Who is running this TSP cam in their 408?
  210. Looks like LS7 Shorts are getting cheaper
  211. Clearancing Piston #8 for crank sproket.
  212. What is the most efficient SB?
  213. p0336 still coming after cranksensor replacement
  214. Morel lifter lenght vs LS1 lifter
  215. LSX 454 How dose this combo sound to you?
  216. Building a 408 stroker, need advice
  217. What Should I Do????....
  218. Operating remperatures
  219. Escalade Cam!!!!!
  220. L92 heads ??? Assemble
  221. Our LSX is done
  222. 5 qts Valvoline Synthetic oil and filter for $17.99 @ Autozone
  223. pushrods for ls1 l92 combo?
  224. Which valve springs are the least problematic
  225. L92 valve to bore clearance
  226. Factory LSX454 Iron Long Block
  227. PLEASE HELP! Broke a bolt off in the end of my crank!
  228. Broken Comp 918 Batch # Thread
  229. How many quarts of oil does an ls7 hold?
  230. L92 Head w/ Iron 408 & GMPP Intake: What RPM, and how to get more?
  231. Help needed after header install.
  232. Ordered some new parts today :)
  233. anyone running the Cartek 2X cam on a A4
  234. Katech value 427 w/L92 top end makes 604hp
  235. OIl pan spacer?
  236. Fel pro 1161 correct for ls2?
  237. Single LS2 vs Double roller
  238. Finally got my C5R intake
  239. couple quick questions about an ls2 swap
  240. Forge an LS2
  241. Yaaa.. Gen IV for 2008 Colorado.........
  242. Who sells Morel lifters?
  243. Cadillac and LS7 lifters...weight
  244. Torque Specs for LSX Motors......
  245. PRC LS6 Stage 2.5 w. G5X3?
  246. Abstract question on displacement, overlap, and fuel smell...
  247. C5 427 Installation Complete
  248. MTI Hand Ported L92 Cylinder Head Flow #'s
  249. .800 to .900 lift for a 100% street car....anyone doing it with success?
  250. TSP 402 is alive
