View Full Version : General Maintenance & Repairs
  1. 2000 z28 starter issue
  2. Express Down not working
  3. '99 Z28 - Headlight Switch Replacement Bulb
  4. starter issue in 2000 z28
  5. Heater not blowing hot
  6. camaro z28 99
  7. LS1 Slave cylinder
  8. 02' Squeaky Clutch pedal
  9. help 1998 corvette LS1 engine
  10. Battery recommendations?
  11. Chronic thrown serpentine belt?
  12. Help car wont start with new battery!
  13. Question
  14. Harmonic Balancer removal
  15. 2001 trans am backfiring
  16. 1998 Z28 Camaro
  17. aggravating noise from rear of the car
  18. Gas gauge stuck...anyone seen this before?
  19. 2001 camaro z28 having problem with instrument on steering colmn and
  20. Help plz random misfire
  21. Hard to Turn Key in Ignition
  22. Anyone replace their 98-02 F-body heater hoses?
  23. how to find a vacumm leak?
  24. Trunk won't unlatch when released
  25. Anyway to clean o2 sensors?
  26. Least expensive O2 sensors?
  27. Will New Battery = More power?
  28. z28 Weird Problem?
  29. Vibraton, when in idle help?????
  30. New steering rack is shorter than one I just pulled
  31. 99 Trans am No start need help!
  32. F body k member compatibility
  33. Really really loud noise - Bad Alternator?
  34. Automotive Maintenance Software/App
  35. Getting a wierd sound
  36. In car oil pan replacement??????
  37. cylinder 3 missfire
  38. 5.3L Coils wont fire
  39. Rough idle
  40. Castrol Confusion
  41. lost
  42. ls1 camaro fog light issues
  43. MS4 cam, wrong pushrod length????
  44. Coolant temp -38 degrees
  45. WD 40 damage O2 sensor?
  46. LS1 Camaro Overheating
  47. Which Sponsors Sell Plugs & Wires?
  48. Idle Air Control Valve question
  49. Seafoam question, deep creep in spark plug holes?
  50. Car will not crank/start. (vats)
  51. WS6-2001 no spark
  52. Found my issue and got her fixed!!!!
  53. fuel cut off and rpms not working
  54. clutch engagement point varying?
  55. Best lube for power windows?
  56. Strange knock coming from rear of car
  57. P0341/P0342 - cam sensor different on 1998 and 99-02?
  58. Can I use 2 O-rings instead of 1? (power steering hose)
  59. Bad altenator??
  60. (Fixed with new alternator) Flickering/Pulsating lights from pully swap?
  61. snapped hood latch cable
  62. Trans am DRL issues on FR
  63. Rattle Clunking when breaking?
  64. Oil or trans fluid in my coolant
  65. Driver side turn signal not working. Tried the basics
  66. How to remove driver seat without power to the motors
  67. Torque arm bushing install question
  68. Drivability issues
  69. Overheating/not holding coolant
  70. Drivetrain noise problem - VIDEO INSIDE
  71. Air pump code!
  72. Has anybody used the Torque Pro android app with racetrack record
  73. Engine noise (video)
  74. Embarrassingly Loud Headlights (Not the gears!)
  75. Rage against the machine?
  76. Loud vibrating noise?
  77. installed 9" rear, now speedometer/ABS not working
  78. Transmission & Rear End Question
  79. Quick question on storing my car for the winter
  80. 98 LS1 no spark/injector pulse
  81. New Alternator In - Now having Problems
  82. radiator question
  83. crank position sensor?
  84. Fuel pressure regulator question
  85. over revved my 99 ls1 now loud knocking
  86. Oil change light
  87. Sounds like 'maggie' under the hood, but isn't. Huh?
  88. Rear Defroster Problems
  89. Anyone That Has Solved Idle Surging / P0507 Please Respond
  90. 01 corvette ms4 cam installed now having a ticking noise and lower oil pressure
  91. 2002 Trans Am door is falling apart? Help
  92. Dash lights on and don't know why
  93. Parking brake/emergency brake problem
  94. Heater won't work
  95. how hard????? a/c compressor
  96. Ls3 starter
  97. Help me please.
  98. Car cranks, but won't start
  99. ls1 ta stumbles during idle and low rpm
  100. is the motor shot
  101. Would a Stripped Valve Cover Bolt Throw a P0507 Code?
  102. ls1+ rain puddle=voltage surge and lights flicker on and off?????
  103. Electrical Short??
  104. Anyway to test a ignition coil?
  105. console interior light problems
  106. Can not pump gas
  107. LOSS in fuel economy after brand new spark plugs and wires!
  108. Thermostat Delete
  109. Leak After Clutch Install
  110. Whats this sound coming from my engine? (video included)
  111. Oil pressure guage being wierd (vid inside)
  112. Low Coolant light
  113. Grabbed a jug of 5w-20 by mistake
  114. Battery Acid leaked on my bolts
  115. 99 Z28: No brake, dash or hazard lights: FIXED!!!
  116. Odd problem with start
  117. starting issue PLEASE HELP
  118. 1998 Z28 Camaro odometer guage and radio display wont light up
  119. Keep Blowing Horn Fuse
  120. Transmission Crossmember won't line up
  121. LSA oil consumption
  122. Overheating 370/D1
  123. Window/ door issues.
  124. '05 CTS-V LS6:Replace just the A/C compressor clutch without buying a new compressor?
  125. Strange buzzing while car is off
  126. Installing another 10 bolt... Difficult?
  127. headlight acting up after motor rebild.
  128. Power windows not working
  129. Excessive water drip in floor board with AC on...
  130. Power steering pump squeak
  131. Car Back firing?
  132. Surging Idle
  133. Help finding annoying vibrations.
  134. 4.8l truck throttle issue
  135. Aftermarket Auto Parts Installer Directory
  136. removing air deflector
  137. 98 Camaro - odd occurence when starting
  138. Voltage from alternater won't stay steady (video)
  139. lost spark plug in engine bay!!
  140. Clunking while driving (steering wheel and seat)
  141. Car will shut off while driving and can be difficult to fire
  142. A/C clutch replacement help needed
  143. Pwer steering cooler hoses leaking?
  144. coolant flush
  145. vibration under acceleration
  146. split oil pan
  147. anyone know length of brake booster hose......?
  148. electrical tape to re-wrap wiring harness............
  149. Wind noise
  150. anybody try one of these Dorman "easy drain" oil pan plugs.......
  151. Overheating!! Please help!!
  152. P0332 Knock Sensor Low Circuit Input- Checked Everything
  153. Won't Turnover!! AGAIN!! (VATS Bypassed) EDIT: VIDEO!
  154. 2002 camaro rear end substitute
  155. how much coolant does ls1 take?
  156. pulley replacement video
  157. passenger headlight lowbeam
  158. Nice size oil leak?
  159. High beams wont come on.
  160. Strange WOT problem
  161. What does this sound like to you?
  162. Why is my car running hot?
  163. Lots of trouble codes need some help!!
  164. parking brake light
  165. Toy in ac/heater blower (location of blower)
  166. un-obtainium, WTD: schematic for GM computer: p/n 15063578
  167. Have a n00b question sorry =)
  168. ~ Front end and hood latch support bar broken - need advise ASAP ~
  169. Unresolved rattling- a lot going on
  170. Window stuck down from broken switch
  171. No A/C after a couple of days.
  172. Holy heck Batman! Big Oil Leak!
  173. Front left turn signal is toast?
  174. Overheating
  175. I know this has been beaten to death...
  176. 2002 Camaro fuse size standard or mini ??
  177. Tune Up
  178. Car Was Broken Into Need Help fixing window & locks
  179. Motor Clucking (video)
  180. Bucking stalling out at stop signs...
  181. Exhaust Leak
  182. Help Code P1415
  183. Intermittent Air Conditioner issue
  184. how to diagnose valve guides/seals
  185. PCV valve relocation link needed or advice!
  186. Wiper blade Installation
  187. Interior squeek over bumps? Ideas??
  188. A/C CRUISE FUSE underhood is cut. Where does it go?
  189. Steering wheel moves up and down
  190. Driver's Seatbelt Issue
  191. LS2 block repair?
  192. Help ID Broken Tube
  193. Dumb question - Engine Idle
  194. my car wont accelerate right..
  195. Misfire help!!
  196. royal purple rear end fluid
  197. Misfire diagnosis help needed.
  198. Recommended Maintenance
  199. Tranny or rear end shot? Clunking.
  200. Vapor Lock Issue City Driving
  201. re-ring or wait?
  202. dropping column for ignition switch
  203. EXTREME LOUD very very hi pitch scream from somewhere in engine, HELP.
  204. grinding/rubbing noise from rear
  205. hose that goes from driver side head to top of radiator
  206. Changed intake gasket now p0102 code
  207. 2002 ws6 pcv help
  208. Passenger window will not go up. NOT the motor or the switch.
  209. Misfiring really bad
  210. What size belt do I need??
  211. Turn signal issue...need help/advice fellas
  212. Weird power window problem 2001 Z
  213. A/C problems
  214. Slight whistle at 2500 rpm
  215. Any tips fo mainting car !!
  216. HELP! Symptoms of a bad TPS but no check engine light
  217. whining noise
  218. Justice Brothers Emissions Cleaner
  219. Need help with high idle on my LS6
  220. A/C experts..........
  221. Starting Problem
  222. Flickering lights, big three fix?
  223. Stock Rear End
  224. A/C Clutch Bearing Replacement?
  225. Check engine
  226. Locating the multifunction relay
  227. Vaccume hose
  228. weird noises
  229. 2000 Camaro not running properly. Please help
  230. backfires and shuts down under acceleration
  231. Pulls to the left #$%#$%
  232. Cranks but doesn't always fire, not enough voltage?
  233. Rear main seal remove cover or not?
  234. intake leak or fuel pump issue? help!
  235. Window motor part numbers inside
  236. EGR/Air Delete problems. Help ID this.
  237. amperage gage ?
  238. wipers do intermittent wrong
  239. P0118, replaced sensor, reset pcm, still no working temp gauge
  240. Where can I buy molding for the rear hatch glass?
  241. Chirp noise at low rpm
  242. 02 Z28 Starting Issues
  243. Question about Cats
  244. Leaking fluid near oil pan, please help
  245. Trans Am loose steering at the column
  246. belt/idler/tensioner squeal?
  247. P0412, P0418 Help?
  248. faint white smoke
  249. Can you repair a cruise control cable?
  250. Croaking / Popcorn / Rattle Noise...
