View Full Version : Suspension & Brakes
- Baer Brake Gt Kit issue HELP
- Bilstein HD rear and KYB AGX front?
- BSI Rotors
- MA roads + Eibach Sportline = pain...
- Torque arms.
- Wet Brakes NFG
- Steering Problem??? !!!
- Rod end question
- Grinding rear calipers to fit 15s
- C5 Brake Question
- Any way to lower just the front?
- SLP Line lock ???
- Baer EradiSpeeds + Hawk CERAMIC Pads = ?
- Remove steering rack - how to cut bolt?
- How to use QA1 adjustable shocks?
- Some basic questions about removing the torque arm?
- Panhard bars and lowering???
- WTF is with GM part numbers?? Confusion about brake numbers...
- Anyone have an extra Rear Caliper Mounting Bracket?
- UMI LCA and PH bar adj. question
- Car won't hook
- finally got my stranos installed
- stock swaybar and moser 9" issues
- Any have detailed instructions for installation of QA1's?
- LS1 brake REupgrade
- losing weight
- pinion angle help
- torque arm ?
- need so help on my alignment...
- Other parts needed for install?
- Which sponsor offers free shipping on suspension parts
- Have TCS but no button
- Instant center question
- really torn on brake upgrade....
- Back to stock springs?
- FUBAR right now
- UMI torque arm relocation kit
- Strano lowering springs and drag racing?
- Need help ASAP!
- Installed BMR Torque Arm
- spindles
- Where to get DMS springs
- UMI to BMR to Spohn which is better
- front struts are hitting in engine bay
- relocation brackets
- best suspension mod!
- installed strano / koni today mixed results pics before and after
- Dbl adjustable qa1 vs single adj?
- SS brake lines
- I want a qa1 setup..what should I get
- Play in steering wheel after alignment was done
- URGEN question for anyone with a set of front KONI DAs off the car!!
- just installed my prokit
- Front Suspension Damage???
- Quieter brake pads?
- light bump or knock when slow driving?
- Brake light failure
- Alignment OK?
- Is a 1LE lower
- help decide which rear springs
- lca advise
- do i NEED to change my shock mounts out when i change my springs and shocks?
- Any had a problem with upper mount bushing...
- Rotors from WS6store
- Tax Refund Sale from BMR Fabrication on 4th Gen Suspension Parts
- ABS Question
- Need new brakes....
- Tax Refund Sale from BMR Fabrication on 3rd Gen Parts
- Brakes Dragging. Big Problem. Need help.
- Strano Springs and KONI shocks 4/3, UMI TRQ ARM, ADJ. PANHARD.
- You ever hear this noise...?
- LS1 Brake Conversion Questions
- qa1 adjustment knob settings
- which will help better with traction....
- Lowered My car..
- what to adjust koni 4/3 to for cruising???
- LS1-LT1 backing plate question
- Where to get ATE Super Blue???
- Paging people with UMI New double adjustable panhard bar.
- bilstein hd's still on back order?
- Subframe Connector ??
- bmr panhard adjustable bar 4 sale
- Lowering springs, with only 1/2 inch to 3/4 drop.
- 2006 Z06 brake upgrade?
- stock C5 rotor offset?
- steering collum
- typical suspension only gain
- Cutting the rear springs?
- Rear Lowering springs
- How to adjust Koni Fronts?
- Please Help Koni Shocks
- newb question maybe
- Plastic piece on bottom of spring?
- Brake squeel when turning right.
- BMR Box VS Tube..
- I have searched and cannot find.... TSP TD's and DL
- In progress of spring install, have a question
- Install Questions? qa1 Shocks and Springs
- strano springs and kyb?
- So I'm thinking of getting a Wolfe 4 point roll bar..Q's
- BMR Springs Before And After Pics.
- 100,000 miles on my bilsteins
- Strut mounts breaking
- ABS question
- metal noise
- WTB torque arm
- need help with spring choice!!!
- need speed sensor
- Paging UMI Performance ......
- Installation help
- strengthening a Convertable
- Subframe install question
- Does anyone have short T/A and TD's??
- Front end floats at higher speeds
- questions about caliper carrier bracket material and brake forces
- which lca's to get????
- Torque Arm Question
- whats involved getting C5 brakes 2 fit strange 12bolt 4 fbody
- 2001 1500 truck brake dragging
- Questions about lowering my car
- wheel hope and lowering question
- Eibach Sportline w/ KYB AGX
- Pulling front wheels
- is this a common problem with our calipers?
- couple of questions
- Edelbrock Panhard
- Energy Suspension Endliks & Swaybar bushings
- Drag Shock question for older muscle car??
- Upgrade stock brakes with 15" draglites
- Check out my busted A-arm
- EBC Brakes... Bullshit product
- Adjusting my Konis.... adjust while suspension unloaded or no?
- BMR Turbo K help
- Just installed UMI LCAs, wheels no longer centered.. why?
- roll cage/ bar questions
- strano koni's revalved or anything?
- rear suspension question
- Taking the top part off the Koni shocks.
- stange or qa1
- Need sugestions on bleeding brakes
- passenger lean fix with air bags?
- Z06 Rotors..
- ZO6 Brakes on 1992 Z28
- Intrax
- Super Tech Marine Grease?
- Strano springs or BMR? *Suspension question*
- Stock 02 Z06. What toe do I set it at?
- Brake Upgrade Suggestions Please
- Squeeky new brakes
- Havent posted here in a while.. springs
- Passenger side ALOT lower than driver
- burkhart Chassis anti tax sale
- whos running drag brakes?
- C5 Brake Upgrade with ROH ZS Wheels
- need brakes bad... stock or upgrade?
- Suspension questions!
- Lowering Question???
- Thanks BMR.
- whats the best powersteering fluid??
- Upgrade to Crossmember TQ Arm??
- question about rear suspension setup
- mechanic took off rear sway bar?
- Strano Springs & KYB AGX Ride Quality
- C5 front brakes with LG brackets = noticeable upgrade!
- Anyone know about these adj. LCA's?
- PRO KIT VS. SPORTLINE (drag)
- will a (C5/C6) Z51 caliper with a 13" rotor wk W/17" wheels
- tunnel mounted VS. full length T/A
- New Brakes
- Strano Springs--IN STOCK (for now)
- Thank You Sam Strano!
- OEM replacement bushing kit?
- c5 caliper slider bolts, the same as fbody?
- right rear suspension problem. ideas???
- 01 formula front sway bar size
- front wheel bearings... 4th gen
- 650 for suspension..Help!!
- stock parts alignment ? and shock suggestions
- what other parts are needed after lowering a car?
- Air suspension?
- For those who run QA1s, what settings work best for you?
- No traction
- Are C5 Calipers Different to C5 Z06 calipers?
- Shocks/Springs Install
- Konis/Strano Springs/subframes + Nitto 555R II
- Shocks Question
- Where to put line lock button?
- reinstalling the stock torque arm..
- bad power steering pump
- No Brakes
- Stock rear endlink size?
- Coil Over Help?
- UMI adjustable torque arm installed
- Weld-in SFC
- Torque Arm question
- Did I luck out with my Koni install?
- Front brakes, issues, need advice..
- c5 rear brakes?
- FREE Suspension Part from BMR Fabrication
- qa1
- Drop it like its hot!
- Suspension Mods - Where to Start?
- Strano Front sway bar install
- clicking sound? what is it
- my BRAND new Koni BROKE during istall... WTF?! pics included
- Just got my UMI LCAs
- Will SA's suffice for car w/ moser 9"?
- Where to Buy Koni's
- Strano front sway problems
- c5 calipers with stock camaro rotors?
- Frozen caliper slide pins - where to get parts.
- 2-3 shift clunk
- Is This What a "Warped" Rotor Looks Like?
- I Guess I Need New Rotors...
- Panhard Bar
- Car sits 3/4 inch higher with dana 60 rear
- Trouble with changing
- Boxed weld in subframes or Tube Bolt ins?
- A Must for All Lowered Cars
- grinding booboo
- aerospace rear brakes weld wheels
- Koni installation woes.
- Raised rear end suspension question??
- Panhard bar
- EIBACH springs
- Manual rack with 275 tire size?
- Question on Lower Control Arm Relocation Brackets
- S&w Torque Arm Good Or Bad?
- Adj. pan hard bar q's.
- spohn adj phr
- Upgrading Steering in 93-97 LT1 T/A Questions
- Koni shocks, LS1 springs on LT1
- Pics of the prokit*
- stock shock replacement question
- cheap front drag shocks?
- Strano Springs.... not in stock yet, but getting closer
- No one has Bilsteins, on back order, what is a good shock to use
- Hotchkis front springs install
- Alston Torque Arm? any luck?
- Rear Spring Isolatore Removed
- Weld in SFC question
- Strano springs and stock shocks?
- Convertible K-members
- Hotchkis and 315's?? compatible ?
- What kind of suspension only gains have you guys seen?
- Does any one know what torque arm I have.
- Do i have to jack up the entire car.....
- Good setup?
- Dana 60 & Lowering Springs
- Spohn Tubular K-Member Questions
